[MOAB-dev] r2170 - in MOAB/trunk: . tools/iMesh
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Oct 21 13:30:01 CDT 2008
Author: kraftche
Date: 2008-10-21 13:30:01 -0500 (Tue, 21 Oct 2008)
New Revision: 2170
Modified:
   MOAB/trunk/configure.in
   MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
Log:
clean up handle-casting templates
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in	2008-10-21 18:29:06 UTC (rev 2169)
+++ MOAB/trunk/configure.in	2008-10-21 18:30:01 UTC (rev 2170)
@@ -25,7 +25,8 @@
 AM_CONDITIONAL([HAVE_ZCAT],[test "x" = "x$ZCAT"])
 SNL_TEMPLATE_SPECIALIZATION
-DEFINES="$DEFINES $TEMPLATE_SPECIALIZATION"
+SNL_TEMPLATE_FUNC_SPECIALIZATION
+DEFINES="$DEFINES $TEMPLATE_SPECIALIZATION $TEMPLATE_FUNC_SPECIALIZATION"
 if test "x" != "x$FC"; then
   AC_FC_WRAPPERS
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp	2008-10-21 18:29:06 UTC (rev 2169)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp	2008-10-21 18:30:01 UTC (rev 2170)
@@ -50,19 +50,19 @@
 /******** Type-safe casting between MOAB and ITAPS types *********/
-#ifndef NO_SPEICALIZED_TEMPLATE_FUNCTIONS
+#ifndef TEMPLATE_FUNC_SPECIALIZATION
 // if no template specializtion, disable some type checking
-template <typename T> inline
-T itaps_cast( MBEntityHandle handle )
+template <typename T, typename S> inline
+T itaps_cast( S handle )
-  assert(sizeof(handle) >= sizeof(T));
+  assert(sizeof(S) >= sizeof(T));
   return reinterpret_cast<T>(handle);
 #else
 // basic template method : only works to cast to equivalent types (no-op)
-T itaps_cast( MBEntityHandle )
+T itaps_cast( S h )
 { return h; }
 // verify size and do reinterpret cast
 template <typename T> inline T itaps_cast_internal_( MBEntityHandle h )
@@ -70,27 +70,76 @@
   assert(sizeof(T) >= sizeof(MBEntityHandle));
   return reinterpret_cast<T>(h);
+// verify size and do reinterpret cast
+template <typename T> inline MBEntityHandle* itaps_cast_ptr_( T* h )
+  assert(sizeof(T) == sizeof(MBEntityHandle));
+  return reinterpret_cast<MBEntityHandle*>(h);
+template <typename T> inline const MBEntityHandle* itaps_cast_const_ptr_( const T* h )
+  return reinterpret_cast<const MBEntityHandle*>(h);
 // verify set-type handle before cast
 template <typename T> inline T itaps_set_cast_( MBEntityHandle h )
   assert(TYPE_FROM_HANDLE(h) == MBENTITYSET);
   return itaps_cast_internal_<T>(h);
-// Specializations if generic template for ITAPS types that
-// an MBEntityHandle can be legitimately cast to.
-template <> inline
-iMeshP_PartitionHandle itaps_cast<iMeshP_PartitionHandle>( MBEntityHandle h )
-  { return itaps_set_cast_<iMeshP_PartitionHandle>(h); }
-template <> inline
-iMeshP_PartHandle itaps_cast<iMeshP_PartHandle>( MBEntityHandle h )
-  { return itaps_set_cast_<iMeshP_PartHandle>(h); }
-template <> inline
-iBase_EntitySetHandle itaps_cast<iBase_EntitySetHandle>( MBEntityHandle h )
-  { return itaps_set_cast_<iBase_EntitySetHandle>(h); }
-template <> inline
-iBase_EntityHandle itaps_cast<iBase_EntityHandle>( MBEntityHandle h )
-  { return itaps_cast_internal_<iBase_EntityHandle>(h); }
+// define conversion routines between itaps handle and MBEntityHandle types
+#define DECLARE_ALLOWED_ITAPS_CONVERSION( ITAPS_HANDLE_TYPE ) \
+  template <> inline \
+  ITAPS_HANDLE_TYPE \
+  itaps_cast<ITAPS_HANDLE_TYPE,MBEntityHandle>( MBEntityHandle h ) \
+  { return itaps_cast_internal_<ITAPS_HANDLE_TYPE>(h); } \
+  MBEntityHandle \
+  itaps_cast<MBEntityHandle,ITAPS_HANDLE_TYPE>( ITAPS_HANDLE_TYPE handle ) \
+  { return reinterpret_cast<MBEntityHandle>(handle); } \
+  MBEntityHandle* \
+  itaps_cast<MBEntityHandle*,ITAPS_HANDLE_TYPE*>( ITAPS_HANDLE_TYPE* ptr ) \
+  { return itaps_cast_ptr_(ptr); } \
+  const MBEntityHandle* \
+  itaps_cast<const MBEntityHandle*,const ITAPS_HANDLE_TYPE*>( const ITAPS_HANDLE_TYPE* ptr ) \
+  { return itaps_cast_const_ptr_(ptr); }
+// but limit to MBEntityHandle for MBENTITYSET type.
+#define DECLARE_ALLOWED_ITAPS_SET_CONVERSION( ITAPS_HANDLE_TYPE ) \
+  { return itaps_set_cast_<ITAPS_HANDLE_TYPE>(h); } \
+  MBEntityHandle \
+  MBEntityHandle* \
+DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iMeshP_PartitionHandle )
+DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iMeshP_PartHandle )
+//DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iBase_EntitySetHandle )
+DECLARE_ALLOWED_ITAPS_SET_CONVERSION( iBase_EntityHandle )
 #endif
 // Need a different function name for MBTag because (currently)
@@ -101,38 +150,6 @@
   return reinterpret_cast<iBase_TagHandle>(t);
-// No template needed when casting from ITAPS types because
-// only one valid type to cast to (MBEntityHandle).
-MBEntityHandle itaps_cast( iMeshP_PartitionHandle handle )
-  { return reinterpret_cast<MBEntityHandle>(handle); }
-MBEntityHandle itaps_cast( iMeshP_PartHandle handle )
-//MBEntityHandle itaps_cast( iBase_EntitySetHandle handle )
-//  { return reinterpret_cast<MBEntityHandle>(handle); }
-MBEntityHandle itaps_cast( iBase_EntityHandle handle )
-// Cast arrays of ITAPS types to array of MBEntityHandle
-MBEntityHandle* itaps_cast( iMeshP_PartitionHandle* ptr )
-  { return reinterpret_cast<MBEntityHandle*>(ptr); }
-MBEntityHandle* itaps_cast( iMeshP_PartHandle* ptr )
-//MBEntityHandle* itaps_cast( iBase_EntitySetHandle* ptr )
-//  { return reinterpret_cast<MBEntityHandle*>(ptr); }
-MBEntityHandle* itaps_cast( iBase_EntityHandle* ptr )
-// Cast const arrays of ITAPS types to array of MBEntityHandle
-const MBEntityHandle* itaps_cast( const iMeshP_PartitionHandle* ptr )
-  { return reinterpret_cast<const MBEntityHandle*>(ptr); }
-const MBEntityHandle* itaps_cast( const iMeshP_PartHandle* ptr )
-//const MBEntityHandle* itaps_cast( const iBase_EntitySetHandle* ptr )
-//  { return reinterpret_cast<const MBEntityHandle*>(ptr); }
-const MBEntityHandle* itaps_cast( const iBase_EntityHandle* ptr )
 /********************* ITAPS arrays **************************/
 // Access this method using ALLOCATE_ARRAY macro, rather than callind directly.
@@ -169,7 +186,7 @@
 // Handle returning MBRange in ITAPS array (do ALLOCATE_ARRAY and copy).
 #define MBRANGE_TO_ITAPS_ARRAY( RANGE, NAME ) do { \
   ALLOCATE_ARRAY( NAME, (RANGE).size() ); \
-  std::copy( (RANGE).begin(), (RANGE).end(), itaps_cast(*(NAME)) ); \
+  std::copy( (RANGE).begin(), (RANGE).end(), itaps_cast<MBEntityHandle*>(*(NAME)) ); \
   } while (false)
@@ -211,7 +228,7 @@
                                  iMeshP_PartitionHandle partition_handle,
                                  int *err)
-  MBEntityHandle handle = itaps_cast(partition_handle);
+  MBEntityHandle handle = itaps_cast<MBEntityHandle>(partition_handle);
   MBParallelComm* pcomm = MBParallelComm::get_pcomm( MBI, handle );
   if (pcomm)
     delete pcomm;
@@ -224,7 +241,7 @@
                               MPI_Comm* communicator_out,
                               int* err )
   if (pcomm)
     RETURN (iBase_FAILURE);
@@ -291,7 +308,7 @@
                           int *num_local_part,
                           int *err)
-  MBEntityHandle prtn = itaps_cast(partition_handle);
+  MBEntityHandle prtn = itaps_cast<MBEntityHandle>(partition_handle);
   MBParallelComm* pcomm = MBParallelComm::get_pcomm( MBI, prtn );
   if (!pcomm)
@@ -312,7 +329,7 @@
                            int *part_handles_size,
                            int *err )
   if (!pcomm)
@@ -347,7 +364,7 @@
   FIXME; // need to handle handles to "remote parts" ?
   if (!pcomm)
@@ -366,7 +383,7 @@
   FIXME; // need to prune out entities that are remote
   if (!pcomm)
@@ -391,7 +408,7 @@
   if (!pcomm)
@@ -412,7 +429,7 @@
                         iMeshP_PartHandle *part_handle,
                         int *err )
-  MBEntityHandle h, p = itaps_cast(partition_handle);
+  MBEntityHandle h, p = itaps_cast<MBEntityHandle>(partition_handle);
   MBErrorCode rval;
   MBParallelComm* pcomm = MBParallelComm::get_pcomm( MBI, p );
   if (!pcomm)
@@ -453,8 +470,8 @@
                          int *err )
   MBErrorCode rval;
-  MBEntityHandle h = itaps_cast(part_handle),
-                 p = itaps_cast(partition_handle);
+  MBEntityHandle h = itaps_cast<MBEntityHandle>(part_handle),
+                 p = itaps_cast<MBEntityHandle>(partition_handle);
   rval = MBI->remove_entities( p, &h, 1 ); CHKERR(rval);
@@ -487,7 +504,7 @@
                                           int *part_ids_size,
                                           int *err )
-  MBEntityHandle p = itaps_cast(partition_handle);
+  MBEntityHandle p = itaps_cast<MBEntityHandle>(partition_handle);
   if (!pcomm)
@@ -507,7 +524,7 @@
   MBErrorCode rval = MBI->tag_get_data( tag,
-                                        itaps_cast(part_handles),
+                                        itaps_cast<const MBEntityHandle*>(part_handles),
                                         part_handles_size,
                                         array ); CHKERR(rval);
@@ -639,8 +656,8 @@
   MBErrorCode rval;
   MBRange r1, r2;
-  MBEntityHandle h1 = itaps_cast(set1);
-  MBEntityHandle h2 = itaps_cast(set2);
+  MBEntityHandle h1 = itaps_cast<MBEntityHandle>(set1);
+  MBEntityHandle h2 = itaps_cast<MBEntityHandle>(set2);
   if (topo != iMesh_ALL_TOPOLOGIES) {
     if ((unsigned)topo > sizeof(mb_topology_table)/sizeof(mb_topology_table[0]))
@@ -937,19 +954,19 @@
                            int* is_owner_size,
                            int *err )
   if (!pcomm)
-  const MBEntityHandle* handles = itaps_cast(entity_handles);
+  const MBEntityHandle* handles = itaps_cast<const MBEntityHandle*>(entity_handles);
   std::vector<unsigned char> pstatus(entity_handles_size);
   MBErrorCode result = MBI->tag_get_data( pcomm->pstatus_tag(),
                                           handles,
                                           entity_handles_size,
                                           &pstatus[0] ); CHKERR(result);
-  MBEntityHandle part = itaps_cast(part_handle);
+  MBEntityHandle part = itaps_cast<MBEntityHandle>(part_handle);
   MBRange part_ents;
   result = MBI->get_entities_by_handle( part, part_ents );
   CHKERR(result);
@@ -991,14 +1008,14 @@
                             /*inout*/ int* par_status_size,
                             int *err)
   if (!pcomm)
   MBErrorCode result = MBI->tag_get_data(pcomm->pstatus_tag(),
-                                         itaps_cast(entity_handles),
+                                         itaps_cast<const MBEntityHandle*>(entity_handles),
                                          &pstatus[0]); CHKERR(result);
@@ -1021,14 +1038,14 @@
                           int *num_copies_ent,
                           int *err )
   if (!pcomm)
   int shared_proc;
   MBErrorCode result = MBI->tag_get_data(pcomm->sharedp_tag(),
-                                         itaps_cast(&entity_handle), 1,
+                                         itaps_cast<const MBEntityHandle*>(&entity_handle), 1,
                                          &shared_proc); CHKERR(result);
   if (-1 != shared_proc) {
@@ -1039,7 +1056,7 @@
   const void* data_ptr = 0;
   int data_size = 0;
   result = MBI->tag_get_data( pcomm->sharedps_tag(),
                               1,
                               &data_ptr,
                               &data_size ); CHKERR(result);
@@ -1074,7 +1091,7 @@
     MBParallelComm pc(MBI);
     MBEntityHandle shared_handle;
     MBErrorCode result = MBI->tag_get_data(pc.sharedh_tag(),
                                            &shared_handle);
     if (MB_SUCCESS != result) {
       RETURN(iBase_ERROR_MAP[result]);
@@ -1099,7 +1116,7 @@
       static std::vector<MBEntityHandle> shared_handles(tag_size);
       result = MBI->tag_get_data(pc.sharedhs_tag(),
                                  &shared_handles[0]);
@@ -1110,7 +1127,7 @@
       part_handles.resize(index+1, 0);
       ALLOCATE_ARRAY( copies_entity_handles, index+1 );
       std::copy(&shared_handles[0], &shared_handles[index],
-                itaps_cast(*copies_entity_handles));
+                itaps_cast<MBEntityHandle*>(*copies_entity_handles));
     ALLOCATE_ARRAY(part_ids, part_handles.size());
@@ -1338,7 +1355,7 @@
                              /*out*/   int *part_handles_size,
                              int *err)
     MBParallelComm *pc = MBParallelComm::get_pcomm(MBI, p);
     if (!pc) RETURN(iBase_ERROR_MAP[MB_FAILURE]);
@@ -1363,7 +1380,7 @@
                                 int *err)
