[MOAB-dev] r2135 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Tue Oct 7 15:15:04 CDT 2008
Author: kraftche
Date: 2008-10-07 15:15:04 -0500 (Tue, 07 Oct 2008)
New Revision: 2135
Modified:
MOAB/trunk/parallel/parallel_unit_tests.cpp
Log:
- Generalize testing of ghosting to test more configuraions
- Work around dense tag bug in test_ghost_tag_exchange (so we
get to the next bug)
- Add new test to demonstrate dense tag bug in tag exchange
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-07 20:07:55 UTC (rev 2134)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-07 20:15:04 UTC (rev 2135)
@@ -61,11 +61,16 @@
// Test sharing tags for mesh entities shared by more than two processors
MBErrorCode test_elements_on_several_procs( const char* filename );
// Test correct ghosting of elements
-MBErrorCode test_ghost_elements( const char* filename );
+MBErrorCode test_ghost_elements_3_2_1( const char* filename );
+MBErrorCode test_ghost_elements_3_2_2( const char* filename );
+MBErrorCode test_ghost_elements_3_0_1( const char* filename );
+MBErrorCode test_ghost_elements_2_0_1( const char* filename );
// Test exchange of tag data on ghost elements
MBErrorCode test_ghost_tag_exchange( const char* filename );
+// Bug where exchange_tags fails if dense tag cannot be queried
+// for all ghost entities (e.g. no default value)
+MBErrorCode regression_ghost_tag_exchange_no_default( const char* filename );
Main Method
@@ -114,8 +119,12 @@
int num_errors = 0;
num_errors += RUN_TEST( test_elements_on_several_procs, filename );
- num_errors += RUN_TEST( test_ghost_elements, filename );
+ num_errors += RUN_TEST( test_ghost_elements_3_2_1, filename );
+ num_errors += RUN_TEST( test_ghost_elements_3_2_2, filename );
+ num_errors += RUN_TEST( test_ghost_elements_3_0_1, filename );
+ num_errors += RUN_TEST( test_ghost_elements_2_0_1, filename );
num_errors += RUN_TEST( test_ghost_tag_exchange, filename );
+ num_errors += RUN_TEST( regression_ghost_tag_exchange_no_default, filename );
int rank;
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
@@ -336,54 +345,151 @@
+MBErrorCode get_ghost_entities( MBInterface& moab,
+ const std::vector<int> partition_geom_ids[4],
+ std::vector<int>& ghost_entity_ids,
+ int ghost_dimension,
+ int bridge_dimension,
+ int num_layers,
+ MBRange* ghost_handles = 0 )
+ MBErrorCode rval;
+ MBTag tags[2];
+ rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, tags[0] ); CHKERR(rval);
+ rval = moab.tag_get_handle( GLOBAL_ID_TAG_NAME, tags[1] ); CHKERR(rval);
+ // get first set of bridge entities
+ MBRange bridge_ents;
+ for (int dim = 0; dim < 3; ++dim) {
+ for (size_t i = 0; i < partition_geom_ids[dim].size(); ++i) {
+ const void* tag_vals[2] = { &dim, &(partition_geom_ids[dim][i]) };
+ MBRange ents;
+ rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET,
+ tags, tag_vals, 2,
+ ents );
+ CHKERR(rval);
+ for (MBRange::iterator j = ents.begin(); j != ents.end(); ++j) {
+ MBRange tmp;
+ rval = moab.get_entities_by_dimension( *j, bridge_dimension, tmp );
+ CHKERR(rval);
+ bridge_ents.merge(tmp);
+ // get owned entities
+ MBRange owned_ents;
+ for (size_t i = 0; i < partition_geom_ids[3].size(); ++i) {
+ const int three = 3;
+ const void* tag_vals[2] = { &three, &partition_geom_ids[3][i] };
+ MBRange ents;
+ ents );
+ CHKERR(rval);
+ MBRange tmp;
+ rval = moab.get_entities_by_dimension( *j, 3, tmp );
+ CHKERR(rval);
+ owned_ents.merge(tmp);
+ // get entities of ghost dimension adjacent to owned entities
+ // (these cannot be ghost entities because they are either owned
+ // or interface entities.)
+ MBRange owned_and_iface;
+ rval = moab.get_adjacencies( owned_ents, ghost_dimension, false, owned_and_iface, MBInterface::UNION );
+ CHKERR(rval);
+ // find potential ghost entities using adjacency queries
+ MBRange ghost_ents;
+ for (int l = 0; l < num_layers; ++l) {
+ MBRange tmp;
+ rval = moab.get_adjacencies( bridge_ents, ghost_dimension, false, tmp, MBInterface::UNION );
+ CHKERR(rval);
+ ghost_ents.merge(tmp);
+ bridge_ents.clear();
+ rval = moab.get_adjacencies( ghost_ents, bridge_dimension, false, bridge_ents, MBInterface::UNION );
+ CHKERR(rval);
+ // remove from ghost candidates, any entities that are
+ // locally owned or interface entities
+ ghost_ents = ghost_ents.subtract( owned_ents );
+ // get ids
+ ghost_entity_ids.resize( ghost_ents.size() );
+ rval = moab.tag_get_data( tags[1], ghost_ents, &ghost_entity_ids[0] );
+ CHKERR(rval);
+ if (ghost_handles)
+ ghost_handles->swap(ghost_ents);
+ return MB_SUCCESS;
+MBErrorCode test_ghost_elements( const char* filename,
+ int num_layers )
MBCore mb_instance;
MBInterface& moab = mb_instance;
MBErrorCode rval;
MBEntityHandle set;
- rval = moab.load_file( filename, set,
- "PARALLEL=READ_DELETE;"
- "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
- "PARTITION_DISTRIBUTE;"
- "PARALLEL_RESOLVE_SHARED_ENTS;"
- "PARALLEL_GHOSTS=3.2.1" );
+ std::ostringstream file_opts;
+ file_opts << "PARALLEL=READ_DELETE;"
+ << "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
+ << "PARTITION_DISTRIBUTE;"
+ << "PARALLEL_RESOLVE_SHARED_ENTS;"
+ << "PARALLEL_GHOSTS="
+ << ghost_dimension << '.'
+ << bridge_dimension << '.'
+ << num_layers;
+ rval = moab.load_file( filename, set, file_opts.str().c_str() );
CHKERR(rval);
+ MBTag geom_tag, id_tag;
+ rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, geom_tag ); CHKERR(rval);
+ rval = moab.tag_get_handle( GLOBAL_ID_TAG_NAME, id_tag ); CHKERR(rval);
// Get partition sets
+ MBRange partition_geom[4];
MBParallelComm* pcomm = MBParallelComm::get_pcomm(&moab, 0);
- MBRange volumes = pcomm->partition_sets();
- PCHECK( !volumes.empty() );
+ partition_geom[3] = pcomm->partition_sets();
+ PCHECK( !partition_geom[3].empty() );
// Get geometric surfaces
MBRange surfs, tmp;
- for (MBRange::iterator i = volumes.begin(); i != volumes.end(); ++i) {
+ for (MBRange::iterator i = partition_geom[3].begin(); i != partition_geom[3].end(); ++i) {
tmp.clear();
rval = moab.get_child_meshsets( *i, tmp ); CHKERR(rval);
surfs.merge( tmp );
- // Check consistent sharing and ghosting for each surface
+ // Get the set of geometric surfaces that represent the skin
+ // of the union of the parts for this processor. As we partition
+ // based on geometric volumes, the interface must be represented
+ // by some subset of the surfaces and their child geometric topology.
int error = 0;
std::ostringstream error_msg;
- MBRange ghost_elems;
- std::vector<MBEntityHandle> adj_elem;
+ MBRange ents, iface_surfs, iface_curves, iface_vertices;
for (MBRange::iterator i = surfs.begin(); !error && i != surfs.end(); ++i) {
- MBRange faces;
- rval = moab.get_entities_by_dimension( *i, 2, faces ); CHKERR(rval);
- if (faces.empty())
+ ents.clear();
+ rval = moab.get_entities_by_dimension( *i, ghost_dimension-1, ents ); CHKERR(rval);
+ if (ents.empty())
continue;
std::vector<int> procs, tmp_procs;
- MBRange::iterator j = faces.begin();
+ MBRange::iterator j = ents.begin();
rval = get_sharing_processors( moab, *j, procs ); CHKERR(rval);
- for (++j; !error && j != faces.end(); ++j) {
+ for (++j; !error && j != ents.end(); ++j) {
tmp_procs.clear();
rval = get_sharing_processors( moab, *j, tmp_procs ); CHKERR(rval);
if( tmp_procs != procs ) {
error_msg << "Failure at " << __FILE__ << ':' << __LINE__ << std::endl
- << "\tNot all entiities in geometric surface are shared with"
+ << "\tNot all entities in geometric surface are shared with"
<< " same processor." << std::endl;
error = 1;
break;
@@ -406,46 +512,10 @@
if (other_rank == (int)pcomm->proc_config().proc_rank())
continue;
- // for each face on interface, expect two adjacent volume
- // elements, one owned by this proc and one ghosted element
- // owned by the other proc.
- for (j = faces.begin(); !error && j != faces.end(); ++j) {
- adj_elem.clear();
- rval = moab.get_adjacencies( &*j, 1, 3, true, adj_elem ); CHKERR(rval);
- if (2 != adj_elem.size()) {
- error_msg << "Failure at " << __FILE__ << ':' << __LINE__ << std::endl
- << "\t" << adj_elem.size() << " volume elements adjacent to face element" << std::endl;
- error = 1;
- break;
- int owner1, owner2;
- rval = pcomm->get_owner( adj_elem[0], owner1 ); CHKERR(rval);
- rval = pcomm->get_owner( adj_elem[1], owner2 ); CHKERR(rval);
- if (owner1 == (int)pcomm->proc_config().proc_rank()) {
- if (other_rank != owner2) {
- << "\texpected element owner:" << other_rank << std::endl
- << "\tactual element owner:" << owner2 << std::endl;
- error = 1;
- break;
- ghost_elems.insert( adj_elem[1] );
- else {
- if (other_rank != owner1 ||
- (int)pcomm->proc_config().proc_rank() != owner2) {
- << "\tactual element owner:" << owner1 << std::endl
- << "\texpected element owner:" << pcomm->proc_config().proc_rank() << std::endl
- error = 1;
- break;
- ghost_elems.insert( adj_elem[0] );
+ partition_geom[2].insert( *i );
+ ents.clear();
+ rval = moab.get_child_meshsets( *i, ents ); CHKERR(rval);
+ partition_geom[1].merge( ents );
// Don't to global communication until outside
@@ -456,23 +526,156 @@
return MB_FAILURE;
+ for (MBRange::iterator i = partition_geom[1].begin(); i != partition_geom[1].end(); ++i) {
+ ents.clear();
+ partition_geom[0].merge( ents );
- // check that we have no elements other than the ones
- // we own and the requested layer of ghosts;
- MBRange all, internal;
- MBRange tmp;
- rval = moab.get_entities_by_dimension( *i, 3, tmp ); CHKERR(rval);
- internal.merge( tmp );
+ std::vector<int> partn_geom_ids[4];
+ for (int dim = 0; dim <= 3; ++dim) {
+ partn_geom_ids[dim].resize( partition_geom[dim].size() );
+ rval = moab.tag_get_data( id_tag, partition_geom[dim], &(partn_geom_ids[dim][0]) );
+ CHKERR(rval);
- rval = moab.get_entities_by_dimension( 0, 3, all ); CHKERR(rval);
- MBRange diff = all.subtract(internal);
- PCHECK( diff == ghost_elems );
+ // get the global IDs of the ghosted entities
+ std::vector<int> actual_ghost_ent_ids;
+ rval = get_ghost_entities( moab, partn_geom_ids, actual_ghost_ent_ids,
+ ghost_dimension, bridge_dimension, num_layers,
+ &ghost_ents );
+ PCHECK(MB_SUCCESS == rval);
+ // read file in serial
+ MBCore moab2;
+ MBEntityHandle set2;
+ rval = moab2.load_file( filename, set2 );
+ // get the global IDs of teh entities we expect to be ghosted
+ std::vector<int> expected_ghost_ent_ids;
+ rval = get_ghost_entities( moab2, partn_geom_ids, expected_ghost_ent_ids,
+ ghost_dimension, bridge_dimension, num_layers );
+ // check that the correct entities were ghosted
+ std::sort( actual_ghost_ent_ids.begin(), actual_ghost_ent_ids.end() );
+ std::sort( expected_ghost_ent_ids.begin(), expected_ghost_ent_ids.end() );
+ PCHECK( expected_ghost_ent_ids == actual_ghost_ent_ids );
+ // check we only have the partitioned and ghosted entities
+ // on this processor.
+ MBRange myents;
+ ents.clear();
+ rval = moab.get_entities_by_dimension( *i, 3, ents ); CHKERR(rval);
+ myents.merge( ents );
+ if (ghost_dimension != 3) {
+ ents.clear();
+ rval = moab.get_adjacencies( myents, ghost_dimension, false, ents, MBInterface::UNION );
+ myents.swap(ents);
+ myents.merge( ghost_ents );
+ ents.clear();
+ rval = moab.get_entities_by_dimension( 0, ghost_dimension, ents );
+ PCHECK( ents == myents );
+ // Verify correct ownership and sharing of ghost entities.
+ ents.clear();
+ for (MBRange::iterator i = myents.begin(); i != myents.end(); ++i) {
+ int owner;
+ rval = pcomm->get_owner( *i, owner ); CHKERR(rval);
+ if ((unsigned)owner == pcomm->proc_config().proc_rank())
+ ents.insert( *i );
+ std::vector<int> my_ent_ids(ents.size());
+ rval = moab.tag_get_data( id_tag, myents, &my_ent_ids[0] );
+ std::sort( my_ent_ids.begin(), my_ent_ids.end() );
+ int counts[2] = { my_ent_ids.size(), actual_ghost_ent_ids.size() };
+ int totals[2] = {0,0};
+ error = MPI_Allreduce( counts, totals, 2, MPI_INT, MPI_SUM,
+ pcomm->proc_config().proc_comm() );
+ PCHECK(!error);
+ std::vector<int> all_owned(totals[0]), all_ghost(totals[1]),
+ owned_counts(pcomm->proc_config().proc_size()),
+ owned_displs(pcomm->proc_config().proc_size()),
+ ghost_counts(pcomm->proc_config().proc_size()),
+ ghost_displs(pcomm->proc_config().proc_size());
+ error = MPI_Allgatherv( &my_ent_ids[0], my_ent_ids.size(), MPI_INT,
+ &all_owned[0], &owned_counts[0], &owned_displs[0],
+ MPI_INT, pcomm->proc_config().proc_comm() );
+ PCHECK(!error);
+ error = MPI_Allgatherv( &actual_ghost_ent_ids[0], actual_ghost_ent_ids.size(), MPI_INT,
+ &all_ghost[0], &ghost_counts[0], &ghost_displs[0],
+ PCHECK(!error);
+ // for each ghost entity, check owning processor and list of
+ // sharing processors.
+ int k = 0;
+ error = 0;
+ for (MBRange::iterator i = ghost_ents.begin(); !error && i != ghost_ents.end(); ++i) {
+ std::vector<int> act_procs, exp_procs;
+ int act_owner, exp_owner;
+ int id = actual_ghost_ent_ids[k++];
+ for (unsigned j = 0; j < pcomm->proc_config().proc_size(); ++j) {
+ const int* proc_owned_begin = &all_owned[0] + owned_displs[j];
+ const int* proc_owned_end = proc_owned_begin + owned_counts[j];
+ if (std::binary_search( proc_owned_begin, proc_owned_end, id ))
+ exp_owner = j;
+ const int* proc_ghost_begin = &all_ghost[0] + ghost_displs[j];
+ const int* proc_ghost_end = proc_ghost_begin + ghost_counts[j];
+ if (std::binary_search( proc_ghost_begin, proc_ghost_end, id ))
+ exp_procs.push_back(j);
+ rval = pcomm->get_owner( *i, act_owner ); CHKERR(rval);
+ if (exp_owner != act_owner) {
+ error = 1;
+ break;
+ rval = get_sharing_processors( moab, *i, act_procs ); CHKERR(rval);
+ std::sort(act_procs.begin(), act_procs.end());
+ if (exp_procs != act_procs) {
+ error = 1;
+ break;
+ // done
return MB_SUCCESS;
+ return test_ghost_elements( filename, 3, 2, 1 );
+ return test_ghost_elements( filename, 3, 2, 2 );
+ return test_ghost_elements( filename, 3, 0, 1 );
+ return test_ghost_elements( filename, 2, 0, 1 );
MBCore mb_instance;
@@ -507,8 +710,9 @@
// create a tag to exchange
MBTag dense_test_tag;
+ MBEntityHandle defval = 0;
rval = moab.tag_create( "TEST-TAG", sizeof(MBEntityHandle), MB_TAG_DENSE,
- MB_TYPE_HANDLE, dense_test_tag, 0 ); CHKERR(rval);
+ dense_test_tag, &defval ); CHKERR(rval);
// for all entiites that I own, set tag to handle value
std::vector<MBEntityHandle> handles(local.size()), handles2;
@@ -562,4 +766,32 @@
return MB_SUCCESS;
+ MBCore mb_instance;
+ MBInterface& moab = mb_instance;
+ MBErrorCode rval;
+ MBEntityHandle set;
+ "PARALLEL=READ_DELETE;"
+ "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
+ "PARTITION_DISTRIBUTE;"
+ "PARALLEL_RESOLVE_SHARED_ENTS;"
+ "PARALLEL_GHOSTS=3.2.1" );
+ CHKERR(rval);
+ // create a tag to exchange
+ MBTag dense_test_tag;
+ rval = moab.tag_create( "TEST-TAG", sizeof(MBEntityHandle), MB_TAG_DENSE,
+ dense_test_tag, 0 ); CHKERR(rval);
+ // exchange tag data
+ MBParallelComm* pcomm = MBParallelComm::get_pcomm(&moab, 0);
+ rval = pcomm->exchange_tags( dense_test_tag );
