[MOAB-dev] r2134 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Tue Oct 7 15:07:55 CDT 2008
Author: kraftche
Date: 2008-10-07 15:07:55 -0500 (Tue, 07 Oct 2008)
New Revision: 2134
Modified:
MOAB/trunk/parallel/pcomm_unit.cpp
Log:
fix overly-long test_pack_tag_data into three separate tests
Modified: MOAB/trunk/parallel/pcomm_unit.cpp
--- MOAB/trunk/parallel/pcomm_unit.cpp 2008-10-06 21:32:21 UTC (rev 2133)
+++ MOAB/trunk/parallel/pcomm_unit.cpp 2008-10-07 20:07:55 UTC (rev 2134)
@@ -24,7 +24,9 @@
/** Test pack/unpack of set parent/child relations */
void test_pack_set_parent_child();
/** Test pack/unpack tag values*/
-void test_pack_tag_data();
+void test_pack_tag_data_sparse();
+void test_pack_tag_data_dense();
+void test_pack_tag_data_default_value();
void test_pack_bit_tag_data();
/** Test pack/unpack of variable length tag values*/
@@ -47,7 +49,9 @@
num_err += RUN_TEST( test_pack_set_contents );
num_err += RUN_TEST( test_pack_sets_of_sets );
num_err += RUN_TEST( test_pack_set_parent_child );
- num_err += RUN_TEST( test_pack_tag_data );
+ num_err += RUN_TEST( test_pack_tag_data_sparse );
+ num_err += RUN_TEST( test_pack_tag_data_dense );
+ num_err += RUN_TEST( test_pack_tag_data_default_value );
//num_err += RUN_TEST( test_pack_bit_tag_data );
num_err += RUN_TEST( test_pack_variable_length_tag );
num_err += RUN_TEST( test_pack_tag_handle_data );
@@ -1000,7 +1004,7 @@
CHECK_EQUAL( set3, parents[1] );
MBRange::iterator i;
int size;
@@ -1011,10 +1015,7 @@
MBErrorCode rval;
create_simple_grid( mb, 3 );
- MBRange verts, elems, sets;
- rval = mb.get_entities_by_type( 0, MBVERTEX, verts );
- CHECK_ERR(rval);
- CHECK( !verts.empty() );
+ MBRange elems;
rval = mb.get_entities_by_type( 0, MBHEX, elems );
CHECK_ERR(rval);
CHECK( !elems.empty() );
@@ -1048,57 +1049,12 @@
CHECK_ERR(rval);
- // Define a dense tag containing a single double-precision floating
- // point value. For each vertex, store the distance from the origin
- // in this tag.
- const char dense_1_double_tag_name[] = "test tag 2";
- MBTag dense_1_double_tag;
- rval = mb.tag_create( dense_1_double_tag_name,
- sizeof(double),
- MB_TAG_DENSE,
- MB_TYPE_DOUBLE,
- dense_1_double_tag,
- 0 );
- CHECK_ERR(rval);
- for (i = verts.begin(); i != verts.end(); ++i) {
- double coords[3];
- rval = mb.get_coords( &*i, 1, coords );
- CHECK_ERR(rval);
- double val = sqrt(coords[0]*coords[0] + coords[1]*coords[1] + coords[2]*coords[2]);
- rval = mb.tag_set_data( dense_1_double_tag, &*i, 1, &val );
- CHECK_ERR(rval);
- // Define a dense, opaque tag with a default value of "DEFLT".
- // Set the tag on one element, one vertex,and one set to "TAGGD".
- const char dense_5_opaque_tag_name[] = "This is intentionally a very long tag name in an attempt to test for an arbitrary limitations on tag name length.";
- MBTag dense_5_opaque_tag;
- rval = mb.tag_create( dense_5_opaque_tag_name,
- 5,
- MB_TAG_DENSE,
- dense_5_opaque_tag,
- "DEFLT" );
- CHECK_ERR(rval);
- MBEntityHandle set;
- rval = mb.create_meshset( MESHSET_SET, set );
- CHECK_ERR(rval);
- const MBEntityHandle handles[3] = { verts.front(), elems.front(), set };
- const char data[] = "TAGGDTAGGDTAGGD";
- rval = mb.tag_set_data( dense_5_opaque_tag, handles, 3, data );
- CHECK_ERR(rval);
// pack and unpack
MBRange ents;
pack_unpack_mesh( moab, ents );
elems.clear();
- verts.clear();
- sets.clear();
- CHECK_ERR(rval);
CHECK_ERR(rval);
- rval = mb.get_entities_by_type( 0, MBENTITYSET, sets );
- CHECK_ERR(rval);
// check tag meta for sparse_2_int_tag
@@ -1138,7 +1094,54 @@
CHECK_EQUAL( (int)(coords[0]), intdata[0] );
CHECK_EQUAL( (int)(coords[1]), intdata[1] );
+ MBRange::iterator i;
+ int size;
+ MBDataType type;
+ MBTagType storage;
+ MBCore moab;
+ MBInterface& mb = moab;
+ MBErrorCode rval;
+ create_simple_grid( mb, 3 );
+ MBRange verts;
+ rval = mb.get_entities_by_type( 0, MBVERTEX, verts );
+ CHECK_ERR(rval);
+ CHECK( !verts.empty() );
+ // Define a dense tag containing a single double-precision floating
+ // point value. For each vertex, store the distance from the origin
+ // in this tag.
+ const char dense_1_double_tag_name[] = "test tag 2";
+ MBTag dense_1_double_tag;
+ rval = mb.tag_create( dense_1_double_tag_name,
+ sizeof(double),
+ MB_TAG_DENSE,
+ MB_TYPE_DOUBLE,
+ dense_1_double_tag,
+ 0 );
+ CHECK_ERR(rval);
+ for (i = verts.begin(); i != verts.end(); ++i) {
+ double coords[3];
+ rval = mb.get_coords( &*i, 1, coords );
+ CHECK_ERR(rval);
+ double val = sqrt(coords[0]*coords[0] + coords[1]*coords[1] + coords[2]*coords[2]);
+ rval = mb.tag_set_data( dense_1_double_tag, &*i, 1, &val );
+ CHECK_ERR(rval);
+ // pack and unpack
+ MBRange ents;
+ pack_unpack_mesh( moab, ents );
+ verts.clear();
+ CHECK_ERR(rval);
// check tag meta for dense_1_double_tag
rval = mb.tag_get_handle( dense_1_double_tag_name, dense_1_double_tag );
CHECK_ERR(rval);
@@ -1165,7 +1168,58 @@
CHECK_ERR(rval);
CHECK_REAL_EQUAL( expected, dval, 1e-6 );
+ int size;
+ MBDataType type;
+ MBCore moab;
+ MBErrorCode rval;
+ MBRange verts, elems, sets;
+ CHECK_ERR(rval);
+ rval = mb.get_entities_by_type( 0, MBHEX, elems );
+ CHECK_ERR(rval);
+ CHECK( !elems.empty() );
+ // Define a dense, opaque tag with a default value of "DEFLT".
+ // Set the tag on one element, one vertex,and one set to "TAGGD".
+ const char dense_5_opaque_tag_name[] = "This is intentionally a very long tag name in an attempt to test for an arbitrary limitations on tag name length.";
+ MBTag dense_5_opaque_tag;
+ rval = mb.tag_create( dense_5_opaque_tag_name,
+ 5,
+ MB_TAG_DENSE,
+ dense_5_opaque_tag,
+ "DEFLT" );
+ CHECK_ERR(rval);
+ MBEntityHandle set;
+ rval = mb.create_meshset( MESHSET_SET, set );
+ CHECK_ERR(rval);
+ const MBEntityHandle handles[3] = { verts.front(), elems.front(), set };
+ const char data[] = "TAGGDTAGGDTAGGD";
+ rval = mb.tag_set_data( dense_5_opaque_tag, handles, 3, data );
+ CHECK_ERR(rval);
+ MBRange ents;
+ elems.clear();
+ verts.clear();
+ sets.clear();
+ CHECK_ERR(rval);
+ CHECK_ERR(rval);
+ rval = mb.get_entities_by_type( 0, MBENTITYSET, sets );
+ CHECK_ERR(rval);
// check tag meta for dense_5_opaque_tag
rval = mb.tag_get_handle( dense_5_opaque_tag_name, dense_5_opaque_tag );
CHECK_ERR(rval);
@@ -1213,7 +1267,6 @@
CHECK_EQUAL( 1, scount );
