[MOAB-dev] [patch] Remove entity sets from counts for iMesh_getNumOfType/Topo
Jed Brown
jed at 59A2.org
Tue Oct 7 06:43:33 CDT 2008
On Mon 2008-10-06 16:17, Jason Kraftcheck wrote:
> 0001-Closed-a-memory-leak-in-ReadParallel-due-to-unresolv.patch
> - Not applied: It is typical for an application to keep its MBParallelComm
> instance for the life of the application, even if that instance is
> created from default values when the file is read in. So a) this change
> breaks existing code that expects to be able to query the MBParallelComm
> instance used during file import and b) is not that serious of an issue
> because the instances are usually kept anyway. This will be fixed
> eventually, but a correct fix is much more complicated.
Thanks for the explanation. I made this naive change because valgrind
was warning about this while I was debugging some of my own code. I
suppose you want to eventually either have reference counting in
MBParallelComm or use a shared pointer?
> 0002-Make-the-ITAPS-opaque-handles-use-incomplete-types-i.patch
> - Not applied (yet): awaiting approval of ITAPS work group for API change.
Cool.
> 0003-Required-for-automake-1.10.patch
> - Applied. Which version of autoconf broke with spaces around the AC_SUBST
> argument?
I have autoconf-2.63, it seems to think the space was part of the identifier.
> 0005-iMesh_MOAB.cpp-Remove-entity-sets-from-counts-for-i.patch
> - Not applied: fixes bug for "recursive == false", but introduces
> new bug for "recursive == true". Thanks for finding this. I'll
> check in (what I think is) the correct fix.
Doh, I should have seen that. Thanks for fixing this.
Jed
Name: not available
Desc: not available
URL: <https://lists.mcs.anl.gov/mailman/private/moab-dev/attachments/20081007/7eb3aac6/attachment.pgp>
