[MOAB-dev] r2130 - in MOAB/trunk: . parallel
kraftche at mcs.anl.gov
Fri Oct 3 17:45:53 CDT 2008
Author: kraftche
Date: 2008-10-03 17:45:52 -0500 (Fri, 03 Oct 2008)
New Revision: 2130
Modified:
MOAB/trunk/TestUtil.hpp
MOAB/trunk/parallel/Makefile.am
MOAB/trunk/parallel/parallel_unit_tests.cpp
Log:
o Add unit test for ghosting during parallal read
o Add unit test for exchanging tag data on ghost entities
NOTE: Second new test fails if run in parallel
Modified: MOAB/trunk/TestUtil.hpp
--- MOAB/trunk/TestUtil.hpp 2008-10-03 20:06:15 UTC (rev 2129)
+++ MOAB/trunk/TestUtil.hpp 2008-10-03 22:45:52 UTC (rev 2130)
@@ -199,7 +199,7 @@
// use a function rather than substituting FLAG_ERROR directly
// so we have a convenient place to set a break point
-void flag_error()
+inline void flag_error()
{ FLAG_ERROR; }
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am 2008-10-03 20:06:15 UTC (rev 2129)
+++ MOAB/trunk/parallel/Makefile.am 2008-10-03 22:45:52 UTC (rev 2130)
@@ -86,3 +86,5 @@
# Other files to clean up (e.g. output from tests)
MOSTLYCLEANFILES = mhdf_ll.h5m
+EXTRA_DIST = ptest.cub
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-03 20:06:15 UTC (rev 2129)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-10-03 22:45:52 UTC (rev 2130)
@@ -21,6 +21,14 @@
} while (false)
+#define PCHECK(A) if (is_any_proc_error(!(A))) return report_error(__FILE__,__LINE__)
+MBErrorCode report_error( const char* file, int line )
+ std::cerr << "Failure at " << file << ':' << line << std::endl;
+ return MB_FAILURE;
Utility Method Declarations
@@ -50,7 +58,12 @@
Test Declarations
+// Test sharing tags for mesh entities shared by more than two processors
MBErrorCode test_elements_on_several_procs( const char* filename );
+// Test correct ghosting of elements
+MBErrorCode test_ghost_elements( const char* filename );
+// Test exchange of tag data on ghost elements
+MBErrorCode test_ghost_tag_exchange( const char* filename );
@@ -101,6 +114,8 @@
int num_errors = 0;
num_errors += RUN_TEST( test_elements_on_several_procs, filename );
+ num_errors += RUN_TEST( test_ghost_elements, filename );
+ num_errors += RUN_TEST( test_ghost_tag_exchange, filename );
int rank;
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
@@ -271,8 +286,7 @@
my_error = 1;
- if (is_any_proc_error(my_error))
- return MB_FAILURE;
+ PCHECK(!my_error);
// now scan the list of geometric entities for
// any for which the higher-dimension entities
@@ -316,8 +330,236 @@
my_error = 1;
+ return MB_SUCCESS;
+ MBCore mb_instance;
+ MBInterface& moab = mb_instance;
+ MBErrorCode rval;
+ MBEntityHandle set;
+ rval = moab.load_file( filename, set,
+ "PARALLEL=READ_DELETE;"
+ "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
+ "PARTITION_DISTRIBUTE;"
+ "PARALLEL_RESOLVE_SHARED_ENTS;"
+ "PARALLEL_GHOSTS=3.2.1" );
+ CHKERR(rval);
+ // Get partition sets
+ MBParallelComm* pcomm = MBParallelComm::get_pcomm(&moab, 0);
+ MBRange volumes = pcomm->partition_sets();
+ PCHECK( !volumes.empty() );
+ // Get geometric surfaces
+ MBRange surfs, tmp;
+ for (MBRange::iterator i = volumes.begin(); i != volumes.end(); ++i) {
+ tmp.clear();
+ rval = moab.get_child_meshsets( *i, tmp ); CHKERR(rval);
+ surfs.merge( tmp );
+ // Check consistent sharing and ghosting for each surface
+ int error = 0;
+ std::ostringstream error_msg;
+ MBRange ghost_elems;
+ std::vector<MBEntityHandle> adj_elem;
+ for (MBRange::iterator i = surfs.begin(); !error && i != surfs.end(); ++i) {
+ MBRange faces;
+ rval = moab.get_entities_by_dimension( *i, 2, faces ); CHKERR(rval);
+ if (faces.empty())
+ continue;
+ std::vector<int> procs, tmp_procs;
+ MBRange::iterator j = faces.begin();
+ rval = get_sharing_processors( moab, *j, procs ); CHKERR(rval);
+ for (++j; !error && j != faces.end(); ++j) {
+ tmp_procs.clear();
+ rval = get_sharing_processors( moab, *j, tmp_procs ); CHKERR(rval);
+ if( tmp_procs != procs ) {
+ error_msg << "Failure at " << __FILE__ << ':' << __LINE__ << std::endl
+ << "\tNot all entiities in geometric surface are shared with"
+ << " same processor." << std::endl;
+ error = 1;
+ break;
+ if (error)
+ break;
+ // if surface is not part of inter-proc interface, skip it.
+ if (procs.empty())
+ continue;
+ if (procs.size() != 1) {
+ << "\tSurface elements shared with" << procs.size() << "processors." << std::endl;
+ error = 1;
+ break;
+ int other_rank = procs[0];
+ if (other_rank == (int)pcomm->proc_config().proc_rank())
+ continue;
+ // for each face on interface, expect two adjacent volume
+ // elements, one owned by this proc and one ghosted element
+ // owned by the other proc.
+ for (j = faces.begin(); !error && j != faces.end(); ++j) {
+ adj_elem.clear();
+ rval = moab.get_adjacencies( &*j, 1, 3, true, adj_elem ); CHKERR(rval);
+ if (2 != adj_elem.size()) {
+ << "\t" << adj_elem.size() << " volume elements adjacent to face element" << std::endl;
+ error = 1;
+ break;
+ int owner1, owner2;
+ rval = pcomm->get_owner( adj_elem[0], owner1 ); CHKERR(rval);
+ rval = pcomm->get_owner( adj_elem[1], owner2 ); CHKERR(rval);
+ if (owner1 == (int)pcomm->proc_config().proc_rank()) {
+ if (other_rank != owner2) {
+ << "\texpected element owner:" << other_rank << std::endl
+ << "\tactual element owner:" << owner2 << std::endl;
+ error = 1;
+ break;
+ ghost_elems.insert( adj_elem[1] );
+ else {
+ if (other_rank != owner1 ||
+ (int)pcomm->proc_config().proc_rank() != owner2) {
+ << "\tactual element owner:" << owner1 << std::endl
+ << "\texpected element owner:" << pcomm->proc_config().proc_rank() << std::endl
+ error = 1;
+ break;
+ ghost_elems.insert( adj_elem[0] );
+ // Don't to global communication until outside
+ // of loops. Otherwise we will deadlock if not all
+ // procs iterate the same number of times.
+ if (is_any_proc_error(error)) {
+ std::cerr << error_msg.str();
return MB_FAILURE;
+ // check that we have no elements other than the ones
+ // we own and the requested layer of ghosts;
+ MBRange all, internal;
+ MBRange tmp;
+ rval = moab.get_entities_by_dimension( *i, 3, tmp ); CHKERR(rval);
+ internal.merge( tmp );
+ rval = moab.get_entities_by_dimension( 0, 3, all ); CHKERR(rval);
+ MBRange diff = all.subtract(internal);
+ PCHECK( diff == ghost_elems );
return MB_SUCCESS;
+ MBErrorCode rval;
+ CHKERR(rval);
+ // Get ghost elements
+ MBRange local, ghosts;
+ rval = moab.get_entities_by_dimension( 0, 3, local ); CHKERR(rval);
+ MBRange::iterator i = local.begin();
+ while (i != local.end()) {
+ int rank;
+ rval = pcomm->get_owner( *i, rank ); CHKERR(rval);
+ if (rank == (int)pcomm->proc_config().proc_rank()) {
+ ++i;
+ else {
+ ghosts.insert( *i );
+ i = local.erase(i);
+ // create a tag to exchange
+ MBTag dense_test_tag;
+ rval = moab.tag_create( "TEST-TAG", sizeof(MBEntityHandle), MB_TAG_DENSE,
+ MB_TYPE_HANDLE, dense_test_tag, 0 ); CHKERR(rval);
+ // for all entiites that I own, set tag to handle value
+ std::vector<MBEntityHandle> handles(local.size()), handles2;
+ std::copy( local.begin(), local.end(), handles.begin() );
+ rval = moab.tag_set_data( dense_test_tag, local, &handles[0] ); CHKERR(rval);
+ // exchange tag data
+ rval = pcomm->exchange_tags( dense_test_tag ); CHKERR(rval);
+ // make sure local values are unchanged
+ handles2.resize( local.size() );
+ rval = moab.tag_get_data( dense_test_tag, local, &handles2[0] ); CHKERR(rval);
+ PCHECK( handles == handles2 );
+ // compare values on ghost entities
+ handles.resize( ghosts.size() );
+ handles2.resize( ghosts.size() );
+ rval = moab.tag_get_data( dense_test_tag, ghosts, &handles2[0] ); CHKERR(rval);
+ rval = moab.tag_get_data( pcomm->sharedh_tag(), ghosts, &handles[0] ); CHKERR(rval);
+ // now do it all again for a sparse tag
+ MBTag sparse_test_tag;
+ rval = moab.tag_create( "TEST-TAG-2", sizeof(int), MB_TAG_DENSE,
+ MB_TYPE_INTEGER, sparse_test_tag, 0 ); CHKERR(rval);
+ // for all entiites that I own, set tag to my rank
+ std::vector<int> procs1(local.size(), pcomm->proc_config().proc_rank());
+ rval = moab.tag_set_data( sparse_test_tag, local, &procs1[0] ); CHKERR(rval);
+ rval = pcomm->exchange_tags( sparse_test_tag ); CHKERR(rval);
+ std::vector<int> procs2(local.size());
+ rval = moab.tag_get_data( sparse_test_tag, local, &procs2[0] ); CHKERR(rval);
+ PCHECK( procs1 == procs2 );
+ procs1.resize( ghosts.size() );
+ procs2.resize( ghosts.size() );
+ rval = moab.tag_get_data( sparse_test_tag, ghosts, &procs2[0] ); CHKERR(rval);
+ std::vector<int>::iterator j = procs1.begin();
+ for (i = ghosts.begin(); i != ghosts.end(); ++i, ++j) {
+ rval = pcomm->get_owner( *i, *j );
+ CHKERR(rval);
