[MOAB-dev] r2129 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov
Fri Oct 3 15:06:16 CDT 2008
Author: kraftche
Date: 2008-10-03 15:06:15 -0500 (Fri, 03 Oct 2008)
New Revision: 2129
Modified:
MOAB/trunk/tools/iMesh/iMeshP.h
MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
Log:
update to latest iMeshP.h
Modified: MOAB/trunk/tools/iMesh/iMeshP.h
--- MOAB/trunk/tools/iMesh/iMeshP.h 2008-10-03 13:56:15 UTC (rev 2128)
+++ MOAB/trunk/tools/iMesh/iMeshP.h 2008-10-03 20:06:15 UTC (rev 2129)
@@ -1,13 +1,31 @@
#ifndef iMeshP_H
#define iMeshP_H
-#include "iBase.h"
+#include "iMesh.h"
#include "iMeshP_protos.h"
+#include <mpi.h>
#ifdef __cplusplus
extern "C" {
#endif
+#define ITAPS_DECLARE_HANDLE( NAME ) typedef struct NAME##DummyStruct *NAME
+ITAPS_DECLARE_HANDLE( iMeshP_PartitionHandle );
+ITAPS_DECLARE_HANDLE( iMeshP_PartHandle );
+ITAPS_DECLARE_HANDLE( iMeshP_RequestHandle );
+ITAPS_DECLARE_HANDLE( iMeshP_Status );
+typedef unsigned iMeshP_Part;
+enum iMeshP_EntStatus
+ iMeshP_INTERNAL,
+ iMeshP_BOUNDARY,
+ iMeshP_GHOST
Background and Terminology:
@@ -110,7 +128,7 @@
* be NULL.
* COMMUNICATION: Collective.*/
void iMeshP_createPartitionAll(iMesh_Instance instance,
- /*in*/ MPI_Comm *communicator,
+ /*in*/ MPI_Comm communicator,
/*out*/ iMeshP_PartitionHandle *partition_handle,
int *err);
@@ -177,7 +195,8 @@
const iMeshP_PartitionHandle partition_handle,
int *num_local_part,
iMeshP_PartHandle *part_handles,
- int part_handles_allocated,
+ int *part_handles_allocated,
+ int *part_handles_size,
int *err);
/** Map from parts to processes:
@@ -196,6 +215,7 @@
/*in*/ const int part_ids_size,
/*inout*/ int **rank,
/*inout*/ int *rank_allocated,
+ int *rank_size,
int *err);
/** Provide global mesh information about a partition.
@@ -244,36 +264,38 @@
* return an error.
* COMMUNICATION: None.*/
-void iMeshP_getPartFromPartHandle(iMesh_Instance instance,
+void iMeshP_getPartIdFromPartHandle(iMesh_Instance instance,
/*in*/ const iMeshP_PartHandle part_handle,
/*out*/ iMeshP_Part *part_id,
int *err);
-void iMeshP_getPartFromPartHandlesArr(iMesh_Instance instance,
+void iMeshP_getPartIdsFromPartHandlesArr(iMesh_Instance instance,
/*in*/ const iMeshP_PartHandle *part_handles,
/*in*/ const int part_handles_size,
/*inout*/ iMeshP_Part **part_ids,
/*inout*/ int *part_ids_allocated,
+ /*out*/ int *part_ids_size,
int *err);
/** Given a partition handle and a part ID, return the part handle
* if the part is local; otherwise, return error code.
-void iMeshP_getPartHandleFromPart(iMesh_Instance instance,
+void iMeshP_getPartHandleFromPartId(iMesh_Instance instance,
/*in*/ iMeshP_Part part_id,
/*out*/ iMeshP_PartHandle *part_handle,
int *err);
-void iMeshP_getPartHandlesFromPartsArr(iMesh_Instance instance,
+void iMeshP_getPartHandlesFromPartsIdsArr(iMesh_Instance instance,
/*in*/ const iMeshP_Part *part_ids,
/*inout*/ iMeshP_PartHandle **part_handles,
/*inout*/ int *part_handles_allocated,
+ /*out*/ int *part_handles_size,
int *err);
/** Add/remove on-process entities to/from on-process part: Given
@@ -313,6 +335,7 @@
/*in*/ int entity_type,
/*inout*/ int **num_part_nbors,
/*inout*/ int *num_part_nbors_allocated,
+ /*out*/ int *num_part_nbors_size,
int *err);
/** Given a partition handle, a part handle, and an entity type,
@@ -339,6 +362,7 @@
/*inout*/ iMeshP_Part **nbor_part_ids,
/*inout*/ int *nbor_part_ids_allocated,
/*out*/ int *nbor_part_ids_size,
@@ -545,6 +569,7 @@
/*in*/ const int entity_handles_size,
int* err);
/** Provide entity categorization within part.
@@ -565,6 +590,7 @@
/*inout*/ int** is_owner,
/*inout*/ int* is_owner_allocated,
+ /*inout*/ int* is_owner_size,
int *err);
/** Given a partition handle, a part handle, and an entity handle, return a
@@ -576,15 +602,16 @@
/*in*/ const iMeshP_PartitionHandle partition_handle,
/*in*/ const iBase_EntityHandle entity_handle,
- /*out*/ int* par_status, // Values=INTERNAL,BOUNDARY,GHOST
+ /*out*/ int* par_status, /* enum iMeshP_EntStatus */
int *err);
void iMeshP_getEntStatusArr(iMesh_Instance instance,
/*in*/ const iBase_EntityHandle *entity_handles,
- /*inout*/ int** par_status, // Values=INTERNAL,BOUNDARY,GHOST
+ /*inout*/ int** par_status, /* enum iMeshP_EntStatus */
/*inout*/ int* par_status_allocated,
+ /*inout*/ int* par_status_size,
int *err);
/** Provide information about copies of entities.
@@ -622,6 +649,7 @@
/*inout*/ iBase_EntityHandle **copies_entity_handles,
/*inout*/ int *copies_entity_handles_allocated,
+ int *copies_entity_handles_size,
int *err);
/** Given a partition handle, an entity handle and a part ID, return the
@@ -666,8 +694,8 @@
void iMeshP_Wait(iMesh_Instance instance,
/*in*/ iMeshP_RequestHandle req,
- /*out*/ iMeshP_Status stat,
- /*out*/ int *err)
+ /*out*/ iMeshP_Status *stat,
+ /*out*/ int *err);
/**\brief Wait for any of the specified requests to complete
@@ -685,7 +713,7 @@
/*in*/ int req_size,
/*out*/ int *index,
- /*out*/ int *err)
/**\brief Wait for all of the specified requests to complete
@@ -701,7 +729,7 @@
/*in*/ iMeshP_RequestHandle *req,
- /*out*/ int *err)
/**\brief Wait for specified request to complete
@@ -721,7 +749,7 @@
/*inout*/ iBase_EntityHandle **out_entities,
/*inout*/ int *out_entities_alloc,
/*inout*/ int *out_entities_size,
- /*out*/ int *err)
/**\brief Test for whether specified request has completed
@@ -737,7 +765,7 @@
/*out*/ int *flag,
- /*out*/ int *err)
/** Poll for requests. The internals of this function are going to have
* to cover a lot of ground. The array in the return is there as a
@@ -783,8 +811,8 @@
/*in*/ const iMeshP_Part *target_part_ids,
- /*in*/ int command_code, // e.g., MIGRATE,COPY
- /*in*/ int update_ghost, // e.g., YES,NO
+ /*in*/ int command_code, /* e.g., MIGRATE,COPY */
+ /*in*/ int update_ghost, /* e.g., YES,NO */
/*out*/ iMeshP_RequestHandle *request,
int *err);
@@ -901,7 +929,7 @@
/*in*/ iBase_TagHandle tag,
/*in*/ int entity_topo,
- /*out*/ int *err)
/**\brief Synchronously send tag data for entities and part
@@ -914,16 +942,16 @@
* data type, size, etc. This call blocks until communication is
* completed
* \param tag Tag handle to exchange
- * \param entities Entities for which to exchange data
+ * \param entities Owned entities for which to send data
* \param entities_size Number of entities
* \param err Error returned from function
void iMeshP_pushTagsEnt(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle *entities,
+ /*in*/ const iBase_EntityHandle *entities,
/*in*/ int entities_size,
- /*out*/ int *err)
/**\brief Asynchronously send tag data for entity type/topo
@@ -953,7 +981,7 @@
/*out*/ iMeshP_RequestHandle *req,
- /*out*/ int *err)
/**\brief Asynchronously send tag data for entities and part
@@ -966,7 +994,7 @@
* data type, size, etc. Applications can call iMeshP_Wait or
* iMeshP_WaitEnt to block until associated call completes
* \param iMeshP_RequestHandle Request object used in call to
* iMeshP_Wait or iMeshP_WaitEnt
@@ -975,10 +1003,10 @@
void iMeshP_iPushTagsEnt(iMesh_Instance instance,
- /*out*/ int *err)
/* GHOST ENTITY SUPPORT */
@@ -1038,6 +1066,7 @@
/* \brief Return information about all ghosting on a partition.
* \param instance iMesh instance
* \param partition_handle Partition on which ghost entities are deleted
+ * \param num_ghost_rules Number of ghosting rules currently registered
* \param ghost_dim Dimension of ghost entities
* \param bridge_dim Dimension of bridge entities
* \param num_layers Number of layers of ghost entities
@@ -1046,7 +1075,7 @@
void iMeshP_ghostEntInfo(/*in*/ iMesh_Instance instance,
/*in*/ iMeshP_PartitionHandle partition_handle,
- /*out*/ int num_ghost_rules,
+ /*out*/ int *num_ghost_rules,
/*inout*/ int *ghost_rules_allocated,
/*inout*/ int *ghost_rules_size,
/*out*/ int **ghost_dim,
@@ -1369,16 +1398,15 @@
-CVS File Information
- $RCSfile: DraftInterface.h,v $
- $Author: kddevin $
- $Date: 2008/09/15 17:50:05 $
- $Revision: 1.31 $
+//SVN File Information
+// $Author:$
+// $Date:$
+// $Revision:$
#ifdef __cplusplus
} // extern "C"
#endif
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-10-03 13:56:15 UTC (rev 2128)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-10-03 20:06:15 UTC (rev 2129)
@@ -16,18 +16,6 @@
#define RETURN(a) {iMesh_LAST_ERROR.error_type = a; *err = a;return;}
#define iMesh_processError(a, b) {sprintf(iMesh_LAST_ERROR.description, "%s", b); iMesh_LAST_ERROR.error_type = a; *err = a;}
-#define CHECK_SIZE(array, allocated, size, type, retval) \
- if (0 != allocated && NULL != array && allocated < (size)) {\
- iMesh_processError(iBase_MEMORY_ALLOCATION_FAILED, \
- "Allocated array not large enough to hold returned contents.");\
- RETURN(iBase_MEMORY_ALLOCATION_FAILED);\
- if (allocated == 0 || NULL == array) {\
- array = (type*)malloc((size)*sizeof(type));\
- allocated=(size);\
- if (NULL == array) {iMesh_processError(iBase_MEMORY_ALLOCATION_FAILED, \
- "Couldn't allocate array.");RETURN(iBase_MEMORY_ALLOCATION_FAILED); }\
// TAG_CHECK_SIZE is like CHECK_SIZE except it checks for and makes the allocated memory
// size a multiple of sizeof(void*), and the pointer is assumed to be type char*
#define TAG_CHECK_SIZE(array, allocated, size) \
@@ -50,7 +38,6 @@
#define ENTITY_HANDLE(handle) reinterpret_cast<MBEntityHandle>(handle)
#define CONST_ENTITY_HANDLE(handle) reinterpret_cast<const MBEntityHandle>(handle)
#define RANGE_ITERATOR(it) reinterpret_cast<RangeIterator*>(it)
-#define CAST_TO_VOID(ptr) reinterpret_cast<void*>(ptr)
const iBase_ErrorType iBase_ERROR_MAP[] =
@@ -70,17 +57,53 @@
extern iBase_Error iMesh_LAST_ERROR;
+template <typename ArrType> inline bool
+allocate_itaps_array( ArrType*& array, int& allocated, int& size, int requested )
+ size = requested;
+ if (allocated) {
+ return (allocated >= requested);
+ else {
+ array = (ArrType*)malloc( requested * sizeof(ArrType) );
+ allocated = requested;
+ return (array != 0);
+inline int allocate_itaps_array_failed()
+ strcpy( iMesh_LAST_ERROR.description,
+ "Insufficient allocated array size or insufficient "
+ "memory to allocate array." );
+ iMesh_LAST_ERROR.error_type = iBase_MEMORY_ALLOCATION_FAILED;
+ return iBase_MEMORY_ALLOCATION_FAILED;
+#define ALLOCATE_ARRAY( NAME, SIZE ) \
+ if (!allocate_itaps_array( *NAME, *NAME##_allocated, *NAME##_size, (SIZE) )) \
+ RETURN(allocate_itaps_array_failed())
#ifdef __cplusplus
extern "C" {
#endif
+void iMeshP_createPartitionAll( iMesh_Instance /*instance*/,
+ /*in*/ MPI_Comm /*communicator*/,
+ /*out*/ iMeshP_PartitionHandle */*partition_handle*/,
+ int *err )
+ RETURN(iBase_NOT_SUPPORTED);
// Given a partition handle, a part handle, and an entity handle, return a
// flag indicating whether the entity is strictly internal, on a
// boundary, or a ghost.
// If part_handle is remote, an error is returned.
// COMMUNICATION: None.
void iMeshP_getEntStatus(iMesh_Instance instance,
- /*in*/ const iMeshP_PartHandle part_handle,
+ /*in*/ const iMeshP_PartitionHandle,
+ /*in*/ const iMeshP_PartHandle,
int *err)
@@ -99,6 +122,7 @@
@@ -114,9 +138,8 @@
&pstatus[0]);
if (MB_SUCCESS != result) RETURN(result);
- *par_status_size = entity_handles_size;
- CHECK_SIZE(*par_status, *par_status_allocated, *par_status_size, int, );
+ ALLOCATE_ARRAY( par_status, entity_handles_size );
for (int i = 0; i < entity_handles_size; i++) {
if (!pstatus[i]) (*par_status)[i] = iMeshP_INTERNAL;
@@ -144,13 +167,12 @@
MBRange part_sets;
- *part_handles_size = pc->partition_sets().size();
- CHECK_SIZE(*part_handles, *part_handles_allocated, *part_handles_size, iMeshP_PartHandle,);
+ ALLOCATE_ARRAY( part_handles, pc->partition_sets().size() );
MBRange::iterator rit;
int i;
for (i = 0, rit = pc->partition_sets().begin();
rit != pc->partition_sets().end(); rit++, i++)
- (*part_handles)[i] = CAST_TO_VOID(*rit);
+ (*part_handles)[i] = reinterpret_cast<iMeshP_PartHandle>(*rit);
RETURN(iBase_SUCCESS);
@@ -182,6 +204,7 @@
void iMeshP_isEntOwner(iMesh_Instance instance,
/*out*/ int* is_owner,
@@ -201,6 +224,7 @@
void iMeshP_isEntOwnerArr(iMesh_Instance instance,
@@ -216,9 +240,8 @@
&pstatus[0]);
- *is_owner_size = entity_handles_size;
- CHECK_SIZE(*is_owner, *is_owner_allocated, *is_owner_size, int, );
+ ALLOCATE_ARRAY( is_owner, entity_handles_size );
if (pstatus[i] & PSTATUS_NOT_OWNED) (*is_owner)[i] = 0;
@@ -282,9 +305,9 @@
void iMeshP_getCopies(iMesh_Instance instance,
- /*inout*/ iMeshP_PartHandle **part_handles,
- /*inout*/ int *part_handles_allocated,
- /*out*/ int *part_handles_size,
+ /*inout*/ iMeshP_Part **part_ids,
+ /*inout*/ int *part_ids_allocated,
/*inout*/ int *copies_entity_handles_size,
@@ -299,48 +322,48 @@
RETURN(iBase_ERROR_MAP[result]);
+ std::vector<iMeshP_PartHandle> part_handles;
if (0 != shared_handle) {
- *part_handles_size = 1;
- *copies_entity_handles_size = 1;
- iMeshP_PartHandle, );
- CHECK_SIZE(*copies_entity_handles, *copies_entity_handles_allocated,
- *copies_entity_handles_size, iBase_EntityHandle, );
- (*part_handles)[0] = 0;
- (*copies_entity_handles)[0] = CAST_TO_VOID(shared_handle);
- RETURN(iBase_SUCCESS);
+ part_handles.resize( 1 );
+ ALLOCATE_ARRAY(copies_entity_handles, 1);
+ part_handles[0] = 0;
+ (*copies_entity_handles)[0] = reinterpret_cast<iBase_EntityHandle>(shared_handle);
+ else {
- static int tag_size = 0;
- if (!tag_size) {
- result = MBI->tag_get_size(pc.sharedhs_tag(), tag_size);
+ static int tag_size = 0;
+ if (!tag_size) {
+ result = MBI->tag_get_size(pc.sharedhs_tag(), tag_size);
+ if (MB_SUCCESS != result) {
+ RETURN(iBase_ERROR_MAP[result]);
+ static std::vector<MBEntityHandle> shared_handles(tag_size);
+ result = MBI->tag_get_data(pc.sharedhs_tag(),
+ CONST_HANDLE_ARRAY_PTR(&entity_handle), 1,
+ &shared_handles[0]);
- static std::vector<MBEntityHandle> shared_handles(tag_size);
- result = MBI->tag_get_data(pc.sharedhs_tag(),
- CONST_HANDLE_ARRAY_PTR(&entity_handle), 1,
- &shared_handles[0]);
- if (MB_SUCCESS != result) {
- RETURN(iBase_ERROR_MAP[result]);
+ int index = std::find(shared_handles.begin(), shared_handles.end(), -1) - shared_handles.begin();
+ part_handles.resize(index+1, 0);
+ ALLOCATE_ARRAY( copies_entity_handles, index+1 );
+ std::copy(&shared_handles[0], &shared_handles[index],
+ HANDLE_ARRAY_PTR(*copies_entity_handles));
- int index = std::find(shared_handles.begin(), shared_handles.end(), -1) - shared_handles.begin();
- *part_handles_size = index+1;
- *copies_entity_handles_size = index+1;
- *copies_entity_handles_size, iMeshP_PartHandle, );
- std::copy(&shared_handles[0], &shared_handles[index],
- HANDLE_ARRAY_PTR(*copies_entity_handles));
- std::fill(*part_handles, *part_handles+index, CAST_TO_VOID(0));
+ ALLOCATE_ARRAY(part_ids, part_handles.size());
+ iMeshP_getPartIdsFromPartHandlesArr( instance, partition_handle,
+ &part_handles[0], part_handles.size(),
+ part_ids, part_ids_allocated,
+ part_ids_size, err );
+ *part_ids_size = part_handles.size();
+ RETURN(*err);
#ifdef __cplusplus
} // extern "C"
