[MOAB-dev] r2115 - MOAB/trunk
kraftche at mcs.anl.gov
Wed Oct 1 13:33:42 CDT 2008
Author: kraftche
Date: 2008-10-01 13:33:41 -0500 (Wed, 01 Oct 2008)
New Revision: 2115
Modified:
MOAB/trunk/TestUtil.hpp
Log:
call a function to handle flagging test errors because it provides a convenient spot to set a break point
Modified: MOAB/trunk/TestUtil.hpp
--- MOAB/trunk/TestUtil.hpp 2008-10-01 18:24:56 UTC (rev 2114)
+++ MOAB/trunk/TestUtil.hpp 2008-10-01 18:33:41 UTC (rev 2115)
@@ -1,6 +1,11 @@
#ifndef TEST_UTIL_HPP
#define TEST_UTIL_HPP
+/* Define these here because they are used by many tests
+ * to find the add directory for input files */
+#define STRINGIFY_(X) #X
+#define STRINGIFY(X) STRINGIFY_(X)
/* How to use this test suite utility:
* 1) Write tests that use the CHECK and CHECK_* macros defined below to assert test conditions.
* 2) Write a main routine that invokes each test through the RUN_TEST macro
@@ -17,6 +22,7 @@
#define CHECK_REAL_EQUAL( EXP, ACT, EPS ) check_equal( (EXP), (ACT), (EPS), #EXP, #ACT, __LINE__, __FILE__ )
/** Run a test
* Argument should be a function with the signature: void func(void)
+ * Evaluates to zero if test is successful, one otherwise.
#define RUN_TEST( FUNC ) run_test( &FUNC, #FUNC )
@@ -188,6 +194,16 @@
+ * Function to handle failed tests
+// use a function rather than substituting FLAG_ERROR directly
+// so we have a convenient place to set a break point
+void flag_error()
+ { FLAG_ERROR; }
* The Code to Run Tests
@@ -304,7 +320,7 @@
printf( " Expected value: %" #TYPE "\n", A ); \
printf( " Actual value: %" #TYPE "\n", B ); \
printf( "\n" ); \
- FLAG_ERROR; \
+ flag_error(); \
void check_equal( int A, int B, const char* sA, const char* sB, int line, const char* file )
@@ -368,7 +384,7 @@
printf( " Expected value: %s (%d)\n", mb_error_str(A), (int)A );
printf( " Actual value: %s (%d)\n", mb_error_str(B), (int)B );
printf( "\n" );
- FLAG_ERROR;
+ flag_error();
const char* mb_type_str( MBEntityType type )
@@ -410,7 +426,7 @@
else
printf( " Actual value: 0\n" );
printf( "\n" );
- FLAG_ERROR;
+ flag_error();
@@ -420,7 +436,7 @@
printf( "Test Failed: %s\n", str );
printf( " at line %d of '%s'\n", line, file );
printf( "\n" );
- FLAG_ERROR;
+ flag_error();
