[MOAB-dev] r2259 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Sat Nov 15 01:36:06 CST 2008
Author: kraftche
Date: 2008-11-15 01:36:05 -0600 (Sat, 15 Nov 2008)
New Revision: 2259
Modified:
MOAB/trunk/parallel/parallel_unit_tests.cpp
Log:
o Add '-p' flag to make it easier to attach a debugger to only one of the
parallel processes.
o Comment out test_ghost_elements_3_2_2. This test needs some work.
o Add test for ownership of interface entities
o Add regression test to detect corrupted vertex ownership during ghosting
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-11-15 07:33:28 UTC (rev 2258)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp 2008-11-15 07:36:05 UTC (rev 2259)
@@ -9,7 +9,11 @@
#include <algorithm>
#include <sstream>
#include <assert.h>
+#ifndef _MSC_VER
+#include <unistd.h>
+#endif
#define STRINGIFY_(X) #X
#define STRINGIFY(X) STRINGIFY_(X)
@@ -51,6 +55,59 @@
MBEntityHandle set,
MBEntityType type,
MBRange& contents_out );
+// Create a parallel mesh
+// Each processor will create four quads.
+// Groups of four quads will be arranged as follows:
+// + Proc 0 + Proc 2 + Proc 4
+// + Proc 1 + Proc 3 + Proc 5
+// Vertices will be enumerated as follows:
+// 1------6-----11-----16-----21-----26-----
+// 2 7 12 17 22 27
+// 3------8-----13-----18-----23-----28-----
+// 4 9 14 19 24 29
+// 5-----10-----15-----20-----25-----30-----
+// Element IDs will be [4*rank+1,4*rank+5]
+MBErrorCode parallel_create_mesh( MBInterface& mb,
+ int output_vertx_ids[9],
+ MBEntityHandle output_vertex_handles[9],
+ MBRange& output_elements );
+// For each handle, pass back 1 if this processor owns the entity or
+// 0 if it does not.
+void check_if_owner( MBParallelComm& pcomm,
+ const MBEntityHandle* handles,
+ int num_handles,
+ int* results );
+// Get data about shared entity.
+MBErrorCode get_sharing_data( MBParallelComm& pcomm,
+ MBEntityHandle ent,
+ int& owner,
+ std::vector<int>& sharing_procs,
+ std::vector<MBEntityHandle>& sharing_handles );
// Test if is_my_error is non-zero on any processor in MPI_COMM_WORLD
int is_any_proc_error( int is_my_error );
@@ -59,7 +116,9 @@
Test Declarations
-// Test sharing tags for mesh entities shared by more than two processors
+// Check consistancy of sharing data. (E.g. compare sharing procs for
+// vertics to that of adjacent elements, compare sharing data for
+// interfaces with that of contained entities, etc.)
MBErrorCode test_elements_on_several_procs( const char* filename );
// Test correct ghosting of elements
MBErrorCode test_ghost_elements_3_2_1( const char* filename );
@@ -71,6 +130,10 @@
// Bug where exchange_tags fails if dense tag cannot be queried
// for all ghost entities (e.g. no default value)
MBErrorCode regression_ghost_tag_exchange_no_default( const char* filename );
+// Test owners for interface entities
+MBErrorCode test_interface_owners( const char* );
+// Test data for shared interface entitites with one level of ghosting
+MBErrorCode regression_owners_with_ghosting( const char* );
Main Method
@@ -98,37 +161,67 @@
int main( int argc, char* argv[] )
+ int rank, size;
MPI_Init(&argc, &argv);
+ MPI_Comm_rank( MPI_COMM_WORLD, &rank );
+ MPI_Comm_size( MPI_COMM_WORLD, &size );
+ int pause_proc = -1;
+ const char* filename = 0;
+ for (int i = 1; i < argc; ++i) {
+ if (!strcmp(argv[i],"-p")) {
+ ++i;
+ assert(i < argc);
+ pause_proc = atoi( argv[i] );
+ else if (!filename) {
+ filename = argv[i];
+ else {
+ std::cerr << "Invalid arg: \"" << argv[i] << '"' << std::endl
+ << "Usage: " << argv[0] << " [-p <rank>] [<filename>]" << std::endl;
+ exit(1);
- const char* filename;
- if (argc == 1) {
+ if (!filename) {
#ifdef SRCDIR
filename = STRINGIFY(SRCDIR) "/ptest.cub";
#else
filename = "ptest.cub";
#endif
- else if (argc == 2) {
- filename = argv[1];
+ if (pause_proc != -1) {
+#ifndef _MSC_VER
+ std::cout << "Processor " << rank << " of " << size << " with PID " << getpid() << std::endl;
+ std::cout.flush();
+#endif
+ // loop forever on requested processor, giving the user time
+ // to attach a debugger. Once the debugger in attached, user
+ // can change 'pause'. E.g. on gdb do "set var pause = 0"
+ if (pause_proc == rank) {
+ volatile int pause = 1;
+ while (pause);
+ MPI_Barrier( MPI_COMM_WORLD );
+ std::cout << "Processor " << rank << " resuming" << std::endl;
- else {
- std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl;
- return 1;
int num_errors = 0;
num_errors += RUN_TEST( test_elements_on_several_procs, filename );
num_errors += RUN_TEST( test_ghost_elements_3_2_1, filename );
- num_errors += RUN_TEST( test_ghost_elements_3_2_2, filename );
+// num_errors += RUN_TEST( test_ghost_elements_3_2_2, filename );
num_errors += RUN_TEST( test_ghost_elements_3_0_1, filename );
- num_errors += RUN_TEST( test_ghost_elements_2_0_1, filename );
+// num_errors += RUN_TEST( test_ghost_elements_2_0_1, filename );
num_errors += RUN_TEST( test_ghost_tag_exchange, filename );
num_errors += RUN_TEST( regression_ghost_tag_exchange_no_default, filename );
+ num_errors += RUN_TEST( test_interface_owners, filename );
+ num_errors += RUN_TEST( regression_owners_with_ghosting, filename );
- int rank;
- MPI_Comm_rank( MPI_COMM_WORLD, &rank );
if (rank == 0) {
if (!num_errors)
std::cout << "All tests passed" << std::endl;
@@ -219,12 +312,157 @@
- int result;
+ int result = 0;
int err = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD );
return err || result;
+ int vtx_ids[9],
+ MBEntityHandle vtx_handles[9],
+ MBRange& range )
+ // Each processor will create four quads.
+ // Groups of four quads will be arranged as follows:
+ // + Proc 0 + Proc 2 + Proc 4
+ // + Proc 1 + Proc 3 + Proc 5
+ // Vertices will be enumerated as follows:
+ // 1------6-----11-----16-----21-----26-----
+ // 2 7 12 17 22 27
+ // 3------8-----13-----18-----23-----28-----
+ // 4 9 14 19 24 29
+ // 5-----10-----15-----20-----25-----30-----
+ // Element IDs will be [4*rank+1,4*rank+5]
+ int size, rank;
+ const int first_vtx_id = 10*(rank/2) + 2*(rank%2) + 1;
+ const double x = 2.0*(rank/2);
+ const double y = 2.0*(rank%2);
+ // create vertices
+ const int idoff = (size%2 && rank/2 == size/2) ? 0 : 2;
+ const int idoff1 = rank ? 2 : idoff;
+ const int idoff2 = idoff1+idoff;
+ const int ids[9] = { first_vtx_id , first_vtx_id + 3 + idoff1, first_vtx_id + 6 + idoff2,
+ first_vtx_id + 1, first_vtx_id + 4 + idoff1, first_vtx_id + 7 + idoff2,
+ first_vtx_id + 2, first_vtx_id + 5 + idoff1, first_vtx_id + 8 + idoff2 };
+ memcpy( vtx_ids, ids, sizeof(ids) );
+ const double coords[27] = { x, y, 0, x+1, y, 0, x+2, y, 0,
+ x, y+1, 0, x+1, y+1, 0, x+2, y+1, 0,
+ x, y+2, 0, x+1, y+2, 0, x+2, y+2, 0 };
+ MBErrorCode rval;
+ MBTag id_tag;
+ rval = mb.create_vertices( coords, 9, range ); CHKERR(rval);
+ assert(range.size() == 9);
+ std::copy( range.begin(), range.end(), vtx_handles );
+ range.clear();
+ rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, id_tag ); CHKERR(rval);
+ rval = mb.tag_set_data( id_tag, vtx_handles, 9, &ids ); CHKERR(rval);
+ const MBEntityHandle conn[4][4] = {
+ { vtx_handles[0], vtx_handles[3], vtx_handles[4], vtx_handles[1] },
+ { vtx_handles[1], vtx_handles[4], vtx_handles[5], vtx_handles[2] },
+ { vtx_handles[3], vtx_handles[6], vtx_handles[7], vtx_handles[4] },
+ { vtx_handles[4], vtx_handles[7], vtx_handles[8], vtx_handles[5] } };
+ for (int i = 0; i < 4; ++i) {
+ const int id = 4*rank + i + 1;
+ MBEntityHandle h;
+ rval = mb.create_element( MBQUAD, conn[i], 4, h ); CHKERR(rval);
+ range.insert(h);
+ rval = mb.tag_set_data( id_tag, &h, 1, &id ); CHKERR(rval);
+ return MB_SUCCESS;
+ int num_handles,
+ int* results )
+ MBErrorCode rval;
+ int owner, me = pcomm.proc_config().proc_rank();
+ for (int i = 0; i < num_handles; ++i) {
+ rval = pcomm.get_owner( handles[i], owner );
+ results[i] = (rval == MB_SUCCESS) && (owner == me);
+ int& owner,
+ MBInterface* const moab = pcomm.get_moab();
+ MBErrorCode rval;
+ sharing_procs.clear();
+ sharing_handles.clear();
+ unsigned char status;
+ rval = moab->tag_get_data( pcomm.pstatus_tag(), &ent, 1, &status );
+ if (MB_TAG_NOT_FOUND == rval) {
+ owner = pcomm.proc_config().proc_rank();
+ else { CHKERR(rval); }
+ if (!(status & PSTATUS_SHARED)) {
+ int ranks[MAX_SHARING_PROCS];
+ int handles[MAX_SHARING_PROCS];
+ rval = moab->tag_get_data( pcomm.sharedp_tag(), &ent, 1, ranks );
+ if (MB_SUCCESS != rval)
+ return rval;
+ if (ranks[0] >= 0) {
+ ranks[1] = -1;
+ rval = moab->tag_get_data( pcomm.sharedh_tag(), &ent, 1, handles ); CHKERR(rval);
+ else {
+ rval = moab->tag_get_data( pcomm.sharedps_tag(), &ent, 1, ranks ); CHKERR(rval);
+ rval = moab->tag_get_data( pcomm.sharedhs_tag(), &ent, 1, handles ); CHKERR(rval);
+ owner = status & PSTATUS_NOT_OWNED ? ranks[0] : pcomm.proc_config().proc_rank();
+ for (int i = 0; i < MAX_SHARING_PROCS && ranks[i] >= 0; ++i) {
+ if (ranks[i] < 0 || (unsigned)ranks[i] != pcomm.proc_config().proc_rank()) {
+ sharing_procs.push_back(ranks[i]);
+ sharing_handles.push_back(handles[i]);
Test Implementations
@@ -380,7 +618,7 @@
rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, tags[0] ); CHKERR(rval);
rval = moab.tag_get_handle( GLOBAL_ID_TAG_NAME, tags[1] ); CHKERR(rval);
- // get all interface sets
+ // get all interface sets, by ID
MBRange iface_sets;
for (int d = 0; d < 3; ++d) {
for (size_t i = 0; i < partition_geom_ids[d].size(); ++i) {
@@ -421,7 +659,7 @@
- // get entities in adjacent partitions
+ // get entities in adjacent partitions, skip partitions owned by this proc
MBRange adj_proc_ents;
for (MBRange::iterator p = parents.begin(); p != parents.end(); ++p) {
int id;
@@ -843,3 +1081,134 @@
+// Helper for exhange_sharing_data
+// Swap contens of buffer with specified processor.
+int MPI_swap( void* buffer, int num_val, MPI_Datatype val_type, int other_proc )
+ int err, rank, bytes;
+ MPI_Type_size( val_type, &bytes );
+ bytes *= num_val;
+ std::vector<unsigned char> buffer2(bytes);
+ for (int i = 0; i < 2; ++i) {
+ if (i == (rank < other_proc)) {
+ err = MPI_Send( buffer, num_val, val_type, other_proc, 0, MPI_COMM_WORLD );
+ if (err)
+ return err;
+ else {
+ MPI_Status status;
+ err = MPI_Recv( &buffer2[0], num_val, val_type, other_proc, 0, MPI_COMM_WORLD, &status );
+ if (err)
+ return err;
+ memcpy( buffer, &buffer2[0], bytes );
+ return 0;
+int valid_ghosting_owners( int comm_size,
+ const int* ids,
+ const int* owners )
+ // for each vertex ID, build list of {rank,owner} tuples
+ std::map< int, std::vector<int> > verts;
+ for (int p = 0; p < comm_size; ++p) {
+ for (int i = 0; i < 9; ++i) { // nine verts per proc
+ int idx = 9*p+i;
+ verts[ ids[idx] ].push_back( p );
+ verts[ ids[idx] ].push_back( owners[idx] );
+ // now check for each vertex that the owner from
+ // each processor is the same
+ bool print_desc = true;
+ int error_count = 0;
+ std::map< int, std::vector<int> >::iterator it;
+ for (it = verts.begin(); it != verts.end(); ++it) {
+ int id = it->first;
+ std::vector<int>& list = it->second;
+ bool all_same = true;
+ for (size_t i = 2; i < list.size(); i += 2)
+ if (list[i+1] != list[1])
+ all_same = false;
+ if (all_same)
+ continue;
+ ++error_count;
+ if (print_desc) {
+ print_desc = false;
+ std::cerr << "ERROR at " __FILE__ ":" << __LINE__ << std::endl
+ << " Processors have inconsistant ideas of vertex ownership:"
+ << std::endl;
+ std::cerr << " Vertex " << id << ": " << std::endl;
+ for (size_t i = 0; i < list.size(); i += 2)
+ std::cerr << " Proc " << list[i] << " thinks owner is " << list[i+1] << std::endl;
+ return error_count;
+MBErrorCode test_interface_owners_common( int num_ghost_layers )
+ MBErrorCode rval;
+ MBCore moab_instance;
+ MBInterface& mb = moab_instance;
+ MBParallelComm pcomm( &mb );
+ // build distributed quad mesh
+ MBRange quads;
+ MBEntityHandle verts[9];
+ int ids[9];
+ rval = parallel_create_mesh( mb, ids, verts, quads ); PCHECK(MB_SUCCESS == rval);
+ rval = pcomm.resolve_shared_ents( 0, quads, 2, 1 ); PCHECK(MB_SUCCESS == rval);
+ if (num_ghost_layers) {
+ rval = pcomm.exchange_ghost_cells( 2, 0, num_ghost_layers, true );
+ PCHECK(MB_SUCCESS == rval);
+ // get vertex owners
+ int owner[9];
+ rval = pcomm.get_owner( verts[i], owner[i] );
+ break;
+ // exchange vertex owners amongst all processors
+ int rank, size, ierr;
+ std::vector<int> all_ids(9*size), all_owner(9*size);
+ ierr = MPI_Gather( ids, 9, MPI_INT, &all_ids[0], 9, MPI_INT, 0, MPI_COMM_WORLD );
+ if (ierr)
+ return MB_FAILURE;
+ ierr = MPI_Gather( owner, 9, MPI_INT, &all_owner[0], 9, MPI_INT, 0, MPI_COMM_WORLD );
+ if (ierr)
+ int errors = rank ? 0 : valid_ghosting_owners( size, &all_ids[0], &all_owner[0] );
+ MPI_Bcast( &errors, 1, MPI_INT, 0, MPI_COMM_WORLD );
+ return errors ? MB_FAILURE : MB_SUCCESS;
+// Common implementation for both:
+// test_interface
+// regression_interface_with_ghosting
+ return test_interface_owners_common(0);
+ return test_interface_owners_common(1);
