[MOAB-dev] r2258 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Sat Nov 15 01:33:29 CST 2008
Author: kraftche
Date: 2008-11-15 01:33:28 -0600 (Sat, 15 Nov 2008)
New Revision: 2258
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
Log:
Fix bugs:
o Do not try to ghost entities that aren't owned
o Not all sent entities are ghosted, or even owned by the
current processor. Don't stomp on pstatus_tag for non-owned
entities. Fixes vertex ownership corruption during ghosting.
o When appending to sharing data, if previous data was in sharedp_tag
and new data is in sharedps_tag, need to clear sharedp_tag.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-11-14 23:53:17 UTC (rev 2257)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-11-15 07:33:28 UTC (rev 2258)
@@ -1505,11 +1505,21 @@
RRA("Couldn't set sharedhs tag (range)");
std::fill(remote_procs.begin(), remote_procs.end(), -1);
std::fill(remote_handles.begin(), remote_handles.end(), 0);
+ // need to clear sharedp_tag and sharedh_tag if prev
+ // data came from there
+ if (-1 != remote_proc[i]) {
+ remote_proc[i] = -1;
+ remote_handle[i] = 0;
+ result = mbImpl->tag_set_data(sharedp_tag, &*rit, 1, &remote_proc[i] );
+ RRA("Couldn't set sharedp tag");
+ result = mbImpl->tag_set_data(sharedh_tag, &*rit, 1, &remote_handle[i] );
// also update shared flag for these ents
- unsigned int *shared_flags = (unsigned int*) &remote_proc[0];
+ unsigned char *shared_flags = (unsigned char*) &remote_proc[0];
result = mbImpl->tag_get_data(pstatus_tag, local_range, shared_flags);
RRA("Couldn't get pstatus tag (range)");
for (unsigned int i = 0; i < local_range.size(); i++)
@@ -3171,6 +3181,19 @@
result = mbImpl->get_adjacencies(*bridge_ents_ptr, to_dim, false, new_ghosts,
MBInterface::UNION);
RRA("Trouble getting ghost adjacencies in iteration.");
+ // remove from new_ghosts any entities that I don't own
+ MBRange::iterator i = new_ghosts.begin();
+ while (i != new_ghosts.end()) {
+ int owner;
+ result = get_owner( *i, owner );
+ RRA("Trouble getting owner of to-be-ghosted entity");
+ if (owner == proc_config().proc_rank())
+ ++i;
+ else
+ i = new_ghosts.erase( i );
to_ents.merge(new_ghosts);
result = mbImpl->get_adjacencies(new_ghosts, bridge_dim, false, new_bridges,
@@ -3340,8 +3363,16 @@
RRA("Failed to pack-send in ghost exchange.");
if (0 != num_layers) {
- new_ghosted.merge(sent_ents[ind]);
- ghostedEnts[*sit].merge(sent_ents[ind]);
+ MBRange::iterator ins1 = new_ghosted.begin(), ins2 = ghostedEnts[*sit].begin();
+ int owner;
+ for (MBRange::iterator s = sent_ents[ind].begin(); s != sent_ents[ind].end(); ++s) {
+ result = get_owner( *s, owner );
+ RRA("Trouble getting entity owner");
+ if (owner == proc_config().proc_rank()) {
+ ins1 = new_ghosted.insert( ins1, *s, *s );
+ ins2 = ghostedEnts[*sit].insert( ins2, *s, *s );
