[MOAB-dev] r2251 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Fri Nov 14 15:14:05 CST 2008
Author: kraftche
Date: 2008-11-14 15:14:05 -0600 (Fri, 14 Nov 2008)
New Revision: 2251
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
Log:
fix abort() when communicating higher-order elements
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-11-14 19:43:12 UTC (rev 2250)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-11-14 21:14:05 UTC (rev 2251)
@@ -1010,7 +1010,7 @@
int num_connect;
MBEntityHandle *start_vec = (MBEntityHandle*)buff_ptr;
for (MBRange::const_iterator rit = allr_it->begin(); rit != allr_it->end(); rit++) {
- result = mbImpl->get_connectivity(*rit, connect, num_connect, true,
+ result = mbImpl->get_connectivity(*rit, connect, num_connect, false,
&dum_connect);
RRA("Failed to get connectivity.");
assert(num_connect == *nv_it);
