[MOAB-dev] r2250 - MOAB/trunk/tools/dagmc
kraftche at mcs.anl.gov
Fri Nov 14 13:43:12 CST 2008
Author: kraftche
Date: 2008-11-14 13:43:12 -0600 (Fri, 14 Nov 2008)
New Revision: 2250
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/Makefile.am
MOAB/trunk/tools/dagmc/main.cc
Log:
update for changes to cgm.make.in and InitCGMA
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2008-11-14 19:42:28 UTC (rev 2249)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2008-11-14 19:43:12 UTC (rev 2250)
@@ -868,8 +868,7 @@
#ifdef CGM
// initialize cgm
- InitCGMA::initialize_cgma();
- InitCGMA::initialize_engine("ACIS");
+ InitCGMA::initialize_cgma("ACIS");
CGMApp::instance()->attrib_manager()->set_all_auto_read_flags(true);
CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags(true);
CubitStatus s = GeometryQueryTool::instance()->import_solid_model( scfile.c_str(), "ACIS_SAT");
Modified: MOAB/trunk/tools/dagmc/Makefile.am
--- MOAB/trunk/tools/dagmc/Makefile.am 2008-11-14 19:42:28 UTC (rev 2249)
+++ MOAB/trunk/tools/dagmc/Makefile.am 2008-11-14 19:43:12 UTC (rev 2250)
@@ -19,7 +19,7 @@
bin_PROGRAMS = cgm2moab
cgm2moab_SOURCES = main.cc cubfile.c
-cgm2moab_LDFLAGS = $(CGM_LIBS_LTFLAGS)
+cgm2moab_LDFLAGS = $(CGM_LTFLAGS)
cgm2moab_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LINK)
cgm2moab_DEPENDENCIES = libdagmc.la $(top_builddir)/libMOAB.la
dist_man1_MANS = cgm2moab.man
@@ -36,8 +36,8 @@
TESTS = test_geom
check_PROGRAMS = $(TESTS) pt_vol_test
test_geom_SOURCES = test_geom.cc
-test_geom_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LTFLAGS) $(CGM_LIBS_LINK)
+test_geom_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS) $(CGM_LIBS_LINK)
pt_vol_test_SOURCES = pt_vol_test.cc
-pt_vol_test_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LTFLAGS) $(CGM_LIBS_LINK)
+pt_vol_test_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS) $(CGM_LIBS_LINK)
Modified: MOAB/trunk/tools/dagmc/main.cc
--- MOAB/trunk/tools/dagmc/main.cc 2008-11-14 19:42:28 UTC (rev 2249)
+++ MOAB/trunk/tools/dagmc/main.cc 2008-11-14 19:43:12 UTC (rev 2250)
@@ -113,8 +113,7 @@
// Initialize CGM
if (actuate_attribs) {
CGMApp::instance()->attrib_manager()->set_all_auto_read_flags( actuate_attribs );
CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags( actuate_attribs );
