[MOAB-dev] r2241 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Thu Nov 13 16:39:52 CST 2008
Author: kraftche
Date: 2008-11-13 16:39:52 -0600 (Thu, 13 Nov 2008)
New Revision: 2241
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
Log:
fix bug getting owner of entity shared amongst more than 2 processors
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-11-13 21:01:59 UTC (rev 2240)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-11-13 22:39:52 UTC (rev 2241)
@@ -4259,21 +4259,56 @@
MBErrorCode MBParallelComm::get_owning_part( MBEntityHandle handle,
int& owning_part_id,
- MBEntityHandle* owning_handle )
+ MBEntityHandle* remote_handle )
- // assume get_sharing_parts returns owner first in list.
- MBErrorCode result;
- int n, parts[MAX_SHARING_PROCS];
- if (owning_handle) {
- MBEntityHandle handles[MAX_SHARING_PROCS];
- result = get_sharing_parts( handle, parts, n, handles );
- *owning_handle = handles[0];
+ // FIXME : assumes one part per proc, and therefore part_id == rank
+ // If entity is not shared, then we're the owner.
+ unsigned char pstat;
+ MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), &handle, 1,
+ &pstat);
+ if (!(pstat & PSTATUS_NOT_OWNED)) {
+ owning_part_id = proc_config().proc_rank();
+ if (remote_handle)
+ *remote_handle = handle;
+ return MB_SUCCESS;
- else {
- result = get_sharing_parts( handle, parts, n );
+ // If entity is shared with one other proc, then
+ // sharedp_tag will contain a positive value.
+ result = mbImpl->tag_get_data( sharedp_tag(), &handle, 1, &owning_part_id );
+ if (MB_SUCCESS != result)
+ return result;
+ if (owning_part_id != -1) {
+ // done?
+ if (!remote_handle)
+ // get handles on remote processors (and this one)
+ return mbImpl->tag_get_data( sharedh_tag(), &handle, 1, remote_handle );
- owning_part_id = parts[0];
- return result;
+ // If here, then the entity is shared with at least two other processors.
+ // Get the list from the sharedps_tag
+ const void* part_id_list = 0;
+ result = mbImpl->tag_get_data( sharedps_tag(), &handle, 1, &part_id_list );
+ return result;
+ owning_part_id = ((const int*)part_id_list)[0];
+ // done?
+ // get remote handles
+ const void* handle_list = 0;
+ result = mbImpl->tag_get_data( sharedhs_tag(), &handle, 1, &handle_list );
+ return result;
+ *remote_handle = ((const MBEntityHandle*)handle_list)[0];
MBErrorCode MBParallelComm::get_sharing_parts( MBEntityHandle entity,
@@ -4290,35 +4325,29 @@
&pstat);
if (!(pstat & PSTATUS_SHARED)) {
part_ids_out[0] = proc_config().proc_rank();
- num_part_ids_out = 1;
if (remote_handles)
remote_handles[0] = entity;
+ num_part_ids_out = 1;
return MB_SUCCESS;
- int other_proc;
- result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, &other_proc );
+ result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, part_ids_out );
return result;
- if (-1 != other_proc) {
- // make sure we return owner first, as other functions
- // (e.g. get_owning_part) assume that behavior
- const int other_idx = !(pstat & PSTATUS_NOT_OWNED);
- const int my_idx = 1 - other_idx;
- // return this processor and the other one
+ if (part_ids_out[0] != -1) {
num_part_ids_out = 2;
- part_ids_out[my_idx] = proc_config().proc_rank();
- part_ids_out[other_idx] = other_proc;
+ part_ids_out[1] = proc_config().proc_rank();
// done?
if (!remote_handles)
return MB_SUCCESS;
- remote_handles[my_idx] = entity;
- return mbImpl->tag_get_data( sharedh_tag(), &entity, 1, remote_handles + other_idx );
+ remote_handles[1] = entity;
+ return mbImpl->tag_get_data( sharedh_tag(), &entity, 1, remote_handles );
@@ -4329,12 +4358,14 @@
// Count number of valid (positive) entries in sharedps_tag
for (num_part_ids_out = 0; num_part_ids_out < MAX_SHARING_PROCS &&
part_ids_out[num_part_ids_out] >= 0; ++num_part_ids_out);
+ part_ids_out[num_part_ids_out++] = proc_config().proc_rank();
// done?
return MB_SUCCESS;
+ remote_handles[num_part_ids_out-1] = entity;
return mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, remote_handles );
