[MOAB-dev] r2240 - in MOAB/trunk: parallel tools/iMesh
kraftche at mcs.anl.gov
Thu Nov 13 15:01:59 CST 2008
Author: kraftche
Date: 2008-11-13 15:01:59 -0600 (Thu, 13 Nov 2008)
New Revision: 2240
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
Log:
fix more bugs: all implemented iMeshP unit tests except one now pass when running on 4 processors
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-11-13 20:01:51 UTC (rev 2239)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-11-13 21:01:59 UTC (rev 2240)
@@ -1522,6 +1522,9 @@
int num_ents,
int other_proc)
+ if (0 == num_ents)
+ return MB_SUCCESS;
// NOTE: THIS IMPLEMENTATION IS JUST LIKE THE RANGE-BASED VERSION, NO REUSE
// AT THIS TIME, SO IF YOU FIX A BUG IN THIS VERSION, IT MAY BE IN THE
// OTHER VERSION TOO!!!
@@ -4208,7 +4211,8 @@
rval = get_sharing_parts( *i, curr, n );
if (MB_SUCCESS != rval)
return rval;
- std::sort( parts, parts+n );
+ std::sort( curr, curr+n );
+ assert( num_neighbors_out < MAX_SHARING_PROCS );
int* k = std::set_union( parts[j], parts[j]+num_neighbors_out,
curr, curr + n, parts[1-j] );
j = 1-j;
Modified: MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp 2008-11-13 20:01:51 UTC (rev 2239)
+++ MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp 2008-11-13 21:01:59 UTC (rev 2240)
@@ -333,10 +333,10 @@
#endif
// loop forever on requested processor, giving the user time
// to attach a debugger. Once the debugger in attached, user
- // can change 'stop'. E.g. on gdb do "set var stop = 1"
+ // can change 'stop'. E.g. on gdb do "set var pause = 0"
if (atoi(argv[2]) == rank) {
- volatile int stop = 0;
- while (!stop);
+ volatile int pause = 1;
+ while (pause);
MPI_Barrier(MPI_COMM_WORLD);
@@ -344,7 +344,7 @@
if (rank == 0) {
ierr = create_mesh( FILENAME, size );
- MPI_Scatter( &ierr, 1, MPI_INT, &ierr, 1, MPI_INT, 0, MPI_COMM_WORLD );
+ MPI_Bcast( &ierr, 1, MPI_INT, 0, MPI_COMM_WORLD );
if (ierr) {
if (rank == 0) {
std::cerr << "Failed to create input test file on root processor. Aborting."
@@ -517,10 +517,10 @@
for (int i = 0; i < num_parts; ++i) {
iMeshP_PartHandle part;
iMeshP_createPart( imesh, partition, &part, &ierr ); CHKERR;
- iBase_EntityHandle quads[] = { elements[i/2 ][2*(i%2) ],
- elements[i/2+1][2*(i%2) ],
- elements[i/2 ][2*(i%2)+1],
- elements[i/2+1][2*(i%2)+1] };
+ iBase_EntityHandle quads[] = { elements[2*(i/2) ][2*(i%2) ],
+ elements[2*(i/2)+1][2*(i%2) ],
+ elements[2*(i/2) ][2*(i%2)+1],
+ elements[2*(i/2)+1][2*(i%2)+1] };
iBase_EntitySetHandle set = part;
iMesh_addEntArrToSet( imesh, quads, 4, &set, &ierr ); CHKERR;
assert(set == part);
