[MOAB-dev] r2209 - in MOAB/trunk: parallel tools/iMesh
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Nov 4 13:15:01 CST 2008
Author: kraftche
Date: 2008-11-04 13:15:01 -0600 (Tue, 04 Nov 2008)
New Revision: 2209
Modified:
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/parallel/MBParallelComm.hpp
   MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
Log:
iMeshP_loadFile & iMeshP_saveFile
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2008-11-04 17:42:04 UTC (rev 2208)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2008-11-04 19:15:01 UTC (rev 2209)
@@ -3725,6 +3725,66 @@
   return result;
+MBErrorCode MBParallelComm::set_partitioning( MBEntityHandle set)
+  MBErrorCode rval;
+  MBTag prtn_tag;
+  rval = mbImpl->tag_create( PARTITIONING_PCOMM_TAG_NAME,
+                           sizeof(int),
+                           MB_TAG_SPARSE,
+                           MB_TYPE_INTEGER,
+                           prtn_tag,
+                           0, true );
+  if (MB_SUCCESS != rval)
+    return rval;
+    // get my id
+  MBParallelComm* pcomm_arr[MAX_SHARING_PROCS];
+  MBTag pc_tag = pcomm_tag(mbImpl, false);
+  if (0 == pc_tag)
+    return MB_FAILURE;
+  MBErrorCode result = mbImpl->tag_get_data(pc_tag, 0, 0, pcomm_arr);
+  if (MB_SUCCESS != result)
+  int id = std::find(pcomm_arr,pcomm_arr+MAX_SHARING_PROCS,this) - pcomm_arr;
+  if (id == MAX_SHARING_PROCS)
+  MBEntityHandle old = partitioningSet;
+  if (old) {
+    rval = mbImpl->tag_delete_data( prtn_tag, &old, 1 );
+      return rval;
+    partitioningSet = 0;
+  if (!set)
+    return MB_SUCCESS;
+  MBRange contents;
+  if (old) {
+    rval = mbImpl->get_entities_by_handle( old, contents );
+      return rval;
+  else {
+    contents = partition_sets();
+  rval = mbImpl->add_entities( set, contents );
+    return rval;
+    // store pcomm id on new partition set
+  rval = mbImpl->tag_set_data( prtn_tag, &set, 1, &id );
+    return rval;
+  partitioningSet = set;
   //! return all the entities in parts owned locally
 MBErrorCode MBParallelComm::get_part_entities(MBRange &ents, int dim)
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp	2008-11-04 17:42:04 UTC (rev 2208)
+++ MOAB/trunk/parallel/MBParallelComm.hpp	2008-11-04 19:15:01 UTC (rev 2209)
@@ -362,7 +362,7 @@
                                   bool shared_test = false );
   MBEntityHandle get_partitioning() const { return partitioningSet; }
-  void set_partitioning( MBEntityHandle h ) { partitioningSet = h; }
+  MBErrorCode set_partitioning( MBEntityHandle h );
   MBErrorCode get_global_part_count( int& count_out ) const;
   MBErrorCode get_part_owner( int part_id, int& owner_out ) const;
   MBErrorCode get_part_id( MBEntityHandle part, int& id_out ) const;
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp	2008-11-04 17:42:04 UTC (rev 2208)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp	2008-11-04 19:15:01 UTC (rev 2209)
@@ -1403,6 +1403,63 @@
                           int *err )
 { FIXME; RETURN(iBase_NOT_SUPPORTED); }
+static std::string append_option( const char* options,
+                          int options_len,
+                          const char* option,
+                          const char* default_value = 0 )
+  std::string::size_type i;
+    // construct a std::string containing at least the leading
+    // separator.
+  std::string opt( options, options_len );
+  if (opt.empty())
+    opt = ";";
+  char sep = opt[0];
+    // make sure that the separator is ok (not contained in the option)
+  const char separators[] = ";:,.!@$#%&*^|/\"'\\~%";
+  if (strchr(option,sep) || (default_value && (sep == '=' || strchr(default_value,sep)))) {
+      // need a new separator.
+    int c, e = sizeof(separators)-1;
+    for (c = 0; c < e; ++c)
+      if (!strchr(opt.c_str(),separators[c]) &&
+          !strchr(option,separators[c]) &&
+          (!default_value || !strchr(default_value,separators[c])))
+        break;
+    if (c == e)
+      return std::string();
+    i = 0;
+    while (std::string::npos != (i = opt.find(sep,i)))
+      opt[i] = separators[c];
+    sep = separators[c];
+    // search for the required option
+  std::string search(&sep,1);
+  search += option;
+  const std::string::size_type sl = search.length();
+  i = opt.find( search );
+  while (i != std::string::npos) {
+    std::string::size_type end = i + sl;
+    if (end == opt.size() || opt[end] == sep || opt[end] == '=')
+      break;
+    i = end;
+    // if string doesn't already contain the option, append it.
+  if (i == std::string::npos) {
+    opt += search;
+    if (default_value) {
+      opt += "=";
+      opt += default_value;
+  return opt;
 void iMeshP_load( iMesh_Instance instance,
                   const iMeshP_PartitionHandle partition,
                   const iBase_EntitySetHandle entity_set_handle,
@@ -1411,8 +1468,41 @@
                   int *err,
                   int name_len,
                   int options_len )
-{ FIXME; RETURN(iBase_NOT_SUPPORTED); }
+  MBErrorCode rval;
+    // make sure 'options' string contains 'PARALLEL'
+  std::string opt = append_option( options, options_len, "PARALLEL" );
+  if (opt.empty())
+    RETURN(iBase_FAILURE);
+    // load the file
+  iMesh_load( instance, entity_set_handle, name, opt.c_str(), err, name_len, opt.length() );
+  if (*err) return;
+    // look for most recent pcomm instance
+  MBParallelComm* pcomm = 0;
+  for (int i = 0; i < MAX_SHARING_PROCS; ++i) {
+    MBParallelComm* tmp_pcomm = MBParallelComm::get_pcomm( MBI, i );
+    if (tmp_pcomm)
+      pcomm = tmp_pcomm;
+  if (!pcomm) {
+    RETURN (iBase_FAILURE);
+    // if user-specified partition set, use it instead
+  if (partition) {
+    MBEntityHandle old_partition = pcomm->get_partitioning();
+    if (old_partition)
+      MBI->delete_entities( &old_partition, 1 );
+    rval = pcomm->set_partitioning( itaps_cast<MBEntityHandle>(partition) );
+    CHKERR(rval);
+  RETURN (iBase_SUCCESS);
 void iMeshP_save( iMesh_Instance instance,
@@ -1421,11 +1511,18 @@
                   int *err,
                   const int name_len,
                   int options_len )
+  MBEntityHandle set;
+  set = entity_set_handle ? itaps_cast<MBEntityHandle>(entity_set_handle)
+                          : itaps_cast<MBEntityHandle>(partition);
+  iMesh_save( instance, itaps_cast<iBase_EntitySetHandle>(set),
+              name, options, err, name_len, options_len );
 //  Map from processes to parts:
 //  Given a partition handle and a process rank,
 //  return the part handles owned by the process.
