[MOAB-dev] r2207 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Nov 4 09:18:35 CST 2008
Author: kraftche
Date: 2008-11-04 09:18:34 -0600 (Tue, 04 Nov 2008)
New Revision: 2207
Modified:
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
add special case for root set to isEntArrContained
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2008-11-03 22:15:53 UTC (rev 2206)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2008-11-04 15:18:34 UTC (rev 2207)
@@ -1317,10 +1317,15 @@
                (int)num_entity_handles, int, iBase_MEMORY_ALLOCATION_FAILED);
     *is_contained_size = num_entity_handles;
-    for (int i = 0; i < num_entity_handles; ++i) {
-      MBEntityHandle h = ENTITY_HANDLE(entity_handles[i]);
-      (*is_contained)[i] = MBI->contains_entities( set, &h, 1 );
+    if (containing_set) {
+      for (int i = 0; i < num_entity_handles; ++i) {
+        MBEntityHandle h = ENTITY_HANDLE(entity_handles[i]);
+        (*is_contained)[i] = MBI->contains_entities( set, &h, 1 );
+    else {
+      std::fill( *is_contained, (*is_contained)+num_entity_handles, 1 );
     RETURN(iBase_SUCCESS);
