[MOAB-dev] r1835 - in MOAB/trunk: . parallel
tautges at mcs.anl.gov
Thu May 22 11:51:23 CDT 2008
Author: tautges
Date: 2008-05-22 11:51:23 -0500 (Thu, 22 May 2008)
New Revision: 1835
Modified:
MOAB/trunk/mbparallelcomm_test.cpp
MOAB/trunk/parallel/MBParallelComm.cpp
Log:
Better reporting of shared entities, and turning off a debug flag.
Modified: MOAB/trunk/mbparallelcomm_test.cpp
--- MOAB/trunk/mbparallelcomm_test.cpp 2008-05-22 16:17:40 UTC (rev 1834)
+++ MOAB/trunk/mbparallelcomm_test.cpp 2008-05-22 16:51:23 UTC (rev 1835)
@@ -175,20 +175,22 @@
// now figure out which vertices are shared
MBParallelComm *pcomm = new MBParallelComm(mbImpl);
- MBRange shared_ents;
- tmp_result = pcomm->get_shared_entities(0, shared_ents);
+ MBRange shared_ents[4];
+ for (int i = 0; i < 4; i++) {
+ tmp_result = pcomm->get_shared_entities(i, shared_ents[i]);
- if (MB_SUCCESS != tmp_result) {
- std::cerr << "get_shared_entities returned error on proc "
- << rank << "; message: " << std::endl;
- PRINT_LAST_ERROR
- result = tmp_result;
+ if (MB_SUCCESS != tmp_result) {
+ std::cerr << "get_shared_entities returned error on proc "
+ << rank << "; message: " << std::endl;
+ PRINT_LAST_ERROR
+ result = tmp_result;
if (0 == rank) setime = MPI_Wtime();
// check # shared entities
- if (0 <= nshared && nshared != (int) shared_ents.size()) {
+ if (0 <= nshared && nshared != (int) shared_ents[0].size()) {
std::cerr << "Didn't get correct number of shared vertices on "
<< "processor " << rank << std::endl;
result = MB_FAILURE;
@@ -198,17 +200,20 @@
std::cerr << "Proc " << rank << " option " << this_opt
<< " succeeded." << std::endl;
- if (-1 == nshared)
- std::cerr << "Proc " << rank << " " << shared_ents.size()
- << " shared vertices." << std::endl;
+ if (-1 == nshared) {
+ std::cerr << "Proc " << rank << " shared entities: " << std::endl;
+ std::cerr << " " << shared_ents[i].size() << " "
+ << i << "d shared entities." << std::endl;
if (debug && 2 == nprocs) {
// if I'm root, get and print handles on other procs
- std::vector<MBEntityHandle> sharedh_tags(shared_ents.size());
+ std::vector<MBEntityHandle> sharedh_tags(shared_ents[0].size());
std::fill(sharedh_tags.begin(), sharedh_tags.end(), 0);
MBTag dumt, sharedh_tag;
result = pcomm->get_shared_proc_tags(dumt, dumt, sharedh_tag, dumt, dumt);
- result = mbImpl->tag_get_data(sharedh_tag, shared_ents, &sharedh_tags[0]);
+ result = mbImpl->tag_get_data(sharedh_tag, shared_ents[0], &sharedh_tags[0]);
if (MB_SUCCESS != result) {
std::cerr << "Couldn't get shared handle tag." << std::endl;
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-05-22 16:17:40 UTC (rev 1834)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-05-22 16:51:23 UTC (rev 1835)
@@ -19,7 +19,7 @@
#include <numeric>
#define MIN(a,b) (a < b ? a : b)
-const bool debug = true;
+const bool debug = false;
const bool debug_packing = false;
#include <math.h>
