[MOAB-dev] r1834 - in MOAB/trunk: . parallel
tautges at mcs.anl.gov
Thu May 22 11:17:40 CDT 2008
Author: tautges
Date: 2008-05-22 11:17:40 -0500 (Thu, 22 May 2008)
New Revision: 1834
Modified:
MOAB/trunk/MBInterface.hpp
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
Log:
MBInterface: adding some comments about get_entities_...
MBParallelComm: fixing some bugs resolving shared non-vertex entities between procs. Not quite there yet.
Passes make check.
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp 2008-05-21 18:54:59 UTC (rev 1833)
+++ MOAB/trunk/MBInterface.hpp 2008-05-22 16:17:40 UTC (rev 1834)
@@ -593,7 +593,8 @@
//! Retrieves all entities of a given topological dimension in the database or meshset.
- /** \param meshset Meshset whose entities are being queried (zero if query is for entire mesh).
+ /** Appends entities to list passed in.
+ \param meshset Meshset whose entities are being queried (zero if query is for entire mesh).
\param dimension Topological dimension of entities desired.
\param entities Range in which entities of dimension <em>dimension</em> are returned.
\param recursive If true, meshsets containing meshsets are queried recursively. Returns
@@ -611,7 +612,8 @@
const bool recursive = false) const = 0;
//! Retrieve all entities of a given type in the database or meshset.
\param type Type of entities to be returned
\param entities Range in which entities of type <em>type</em> are returned.
@@ -671,7 +673,8 @@
//! Returns all entities in the data base or meshset, in a range (order not preserved)
- /** \param meshset Meshset whose entities are being queried (zero if query is for the entire mesh).
+ \param meshset Meshset whose entities are being queried (zero if query is for the entire mesh).
\param entities Range in which entities are returned.
the contents of meshsets, but not the meshsets themselves if true.
@@ -687,7 +690,8 @@
//! Returns all entities in the data base or meshset, in a vector (order preserved)
\param entities STL vector in which entities are returned.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-05-21 18:54:59 UTC (rev 1833)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-05-22 16:17:40 UTC (rev 1834)
@@ -111,7 +111,8 @@
enum MBMessageTag {MB_MESG_ANY=MPI_ANY_TAG,
MB_MESG_SIZE,
MB_MESG_ENTS,
- MB_MESG_REMOTE_HANDLES
+ MB_MESG_REMOTE_HANDLES_RANGE,
+ MB_MESG_REMOTE_HANDLES_VECTOR
MBParallelComm::MBParallelComm(MBInterface *impl, MPI_Comm comm)
@@ -221,7 +222,7 @@
MPI_Request req_vec[2] = {MPI_REQUEST_NULL, // send req (ownerSBuff)
MPI_REQUEST_NULL}; // recv req (remote handles)
MBErrorCode result = pack_send_entities(to_proc, orig_ents,
- adjs, tags, store_remote_handles,
+ adjs, tags, store_remote_handles, false,
ownerSBuffs[index], ownerRBuffs[index],
req_vec[0], req_vec[1], final_ents);
RRA("Failed to pack-send entities.");
@@ -283,7 +284,7 @@
// ok, got the actual entities, now unpack
- result = recv_unpack_entities(from_proc, store_remote_handles,
+ result = recv_unpack_entities(from_proc, store_remote_handles, false,
ghostRBuffs[index], ghostSBuffs[index],
req, final_ents);
RRA("Failed to recv-unpack message.");
@@ -325,6 +326,7 @@
const bool adjacencies,
const bool tags,
const bool store_remote_handles,
+ const bool iface_layer,
std::vector<unsigned char> &send_buff,
std::vector<unsigned char> &recv_buff,
MPI_Request &send_req,
@@ -347,11 +349,19 @@
// now that we know how many entities, post a receive for the
// remote range, if requested
int success;
- if (store_remote_handles) {
+ if (store_remote_handles && iface_layer) {
+ recv_buff.resize(final_ents.size()*sizeof(MBEntityHandle) + sizeof(int));
+ success = MPI_Irecv(&recv_buff[0], recv_buff.size(), MPI_UNSIGNED_CHAR, to_proc,
+ MB_MESG_REMOTE_HANDLES_VECTOR, procConfig.proc_comm(),
+ &recv_req);
+ if (success != MPI_SUCCESS) return MB_FAILURE;
+ else if (store_remote_handles && !iface_layer) {
recv_buff.resize(2*num_subranges(final_ents)*sizeof(MBEntityHandle) + sizeof(int));
- MB_MESG_REMOTE_HANDLES, procConfig.proc_comm(),
+ MB_MESG_REMOTE_HANDLES_RANGE, procConfig.proc_comm(),
&recv_req);
@@ -391,6 +401,7 @@
MBErrorCode MBParallelComm::recv_unpack_entities(const int from_proc,
@@ -403,23 +414,44 @@
MBErrorCode result = MB_SUCCESS;
// unpack the buffer
- result = unpack_buffer(&recv_buff[0], store_remote_handles, from_proc, recd_ents);
- RRA("Failed to unpack buffer in recv_unpack.");
- int range_size = 2*num_subranges(recd_ents)*sizeof(MBEntityHandle) +
- sizeof(int);
- send_buff.resize(range_size);
- unsigned char *buff_ptr = &send_buff[0];
- PACK_RANGE(buff_ptr, recd_ents);
- int success = MPI_Isend(&send_buff[0], range_size, MPI_UNSIGNED_CHAR, from_proc,
- MB_MESG_REMOTE_HANDLES, procConfig.proc_comm(), &send_req);
- if (success != MPI_SUCCESS) {
- result = MB_FAILURE;
- RRA("Failed to send handles in recv_unpack.");
+ if (iface_layer) {
+ std::vector<MBEntityHandle> recd_ents_tmp;
+ unsigned char *buff_ptr = &recv_buff[0];
+ result = unpack_iface_entities(buff_ptr, from_proc, recd_ents_tmp);
+ RRA("Failed to unpack buffer in recv_unpack.");
+ if (store_remote_handles) {
+ int recd_size = recd_ents_tmp.size()*sizeof(MBEntityHandle) +
+ sizeof(int);
+ send_buff.resize(recd_size);
+ unsigned char *buff_ptr = &send_buff[0];
+ PACK_INT(buff_ptr, recd_ents_tmp.size());
+ PACK_EH(buff_ptr, &recd_ents_tmp[0], recd_ents_tmp.size());
+ int success = MPI_Isend(&send_buff[0], recd_size, MPI_UNSIGNED_CHAR, from_proc,
+ MB_MESG_REMOTE_HANDLES_VECTOR, procConfig.proc_comm(), &send_req);
+ if (success != MPI_SUCCESS) {
+ result = MB_FAILURE;
+ RRA("Failed to send handles in recv_unpack.");
+ std::copy(recd_ents_tmp.begin(), recd_ents_tmp.end(), mb_range_inserter(recd_ents));
+ else {
+ result = unpack_buffer(&recv_buff[0], store_remote_handles, from_proc, recd_ents);
+ int recd_size = 2*num_subranges(recd_ents)*sizeof(MBEntityHandle) + sizeof(int);
+ PACK_RANGE(buff_ptr, recd_ents);
+ MB_MESG_REMOTE_HANDLES_RANGE, procConfig.proc_comm(), &send_req);
return result;
#endif
@@ -643,9 +675,8 @@
#ifdef DEBUG_PACKING
unsigned char *tmp_buff = buff_ptr;
#endif
- MBErrorCode result = unpack_entities(buff_ptr, final_ents,
- store_remote_handles,
- from_proc);
+ MBErrorCode result = unpack_entities(buff_ptr, store_remote_handles,
+ from_proc, final_ents);
RRA("Unpacking entities failed.");
std::cerr << "unpack_entities buffer space: " << buff_ptr - tmp_buff << " bytes." << std::endl;
@@ -1088,9 +1119,9 @@
MBErrorCode MBParallelComm::unpack_entities(unsigned char *&buff_ptr,
- MBRange &entities,
- const int from_proc)
+ const int from_proc,
+ MBRange &entities)
MBErrorCode result;
bool done = false;
@@ -1161,7 +1192,7 @@
// convert to local handles
result = get_local_handles(connect, num_ents*verts_per_entity,
- entities);
+ entities);
RR("Couldn't get local handles.");
@@ -1188,6 +1219,74 @@
return MB_SUCCESS;
+MBErrorCode MBParallelComm::unpack_iface_entities(unsigned char *&buff_ptr,
+ std::vector<MBEntityHandle> &recd_ents)
+ // for all the entities in the received buffer; for each, save
+ // entities in this instance which match connectivity, or zero if none found
+ MBErrorCode result;
+ bool done = false;
+ std::vector<MBEntityHandle> connect;
+ while (!done) {
+ MBEntityType this_type;
+ UNPACK_INT(buff_ptr, this_type);
+ assert(this_type > MBVERTEX &&
+ (this_type == MBMAXTYPE || this_type < MBENTITYSET));
+ // MBMAXTYPE signifies end of entities data
+ if (MBMAXTYPE == this_type) break;
+ // get the number of ents
+ int num_ents;
+ UNPACK_INT(buff_ptr, num_ents);
+ int verts_per_entity;
+ // unpack the verts per entity
+ UNPACK_INT(buff_ptr, verts_per_entity);
+ connect.resize(verts_per_entity * num_ents);
+ // unpack the connectivity
+ UNPACK_EH(buff_ptr, &connect[0], (num_ents*verts_per_entity));
+ // unpack source handles
+ MBRange source_range, tmp_range;
+ UNPACK_RANGE(buff_ptr, source_range);
+ // save matching local entities, or 0 if none found
+ for (int i = 0; i < num_ents; i++) {
+ // test for existing entity
+ result = mbImpl->get_adjacencies(&connect[0]+i*verts_per_entity, verts_per_entity,
+ MBCN::Dimension(this_type), false, tmp_range);
+ if (MB_MULTIPLE_ENTITIES_FOUND == result) {
+ RRA("Multiple entities found.");
+ if (!tmp_range.empty()) {
+ // found a corresponding entity - save target
+ assert(1 == tmp_range.size());
+ recd_ents.push_back(*tmp_range.begin());
+ tmp_range.clear();
+ else
+ recd_ents.push_back(0);
+#ifdef DEBUG_PACKING
+ std::cerr << "Unpacked " << num_ents << " ents of type "
+ << MBCN::EntityTypeName(TYPE_FROM_HANDLE(actual_start)) << std::endl;
+#endif
+ if (debug_packing) std::cerr << std::endl << "Done unpacking iface entities." << std::endl;
+ return MB_SUCCESS;
MBErrorCode MBParallelComm::get_local_handles(const MBRange &remote_handles,
MBRange &local_handles,
const MBRange &new_ents)
@@ -1242,10 +1341,14 @@
RRA("Couldn't get sharedh tag.");
MBRange::iterator rit, rit2;
int i = 0;
+ // for each pair of local/remote handles:
for (rit = tmp_local_range.begin(), rit2 = remote_range.begin();
rit != tmp_local_range.end(); rit++, rit2++, i++) {
+ // get existing remote proc(s), handle(s) for this local handle
remote_procs[0] = remote_proc[i];
- if (-1 != remote_proc[0]) remote_handles[0] = *rit2;
+ if (-1 != remote_procs[0]) remote_handles[0] = remote_handle[i];
else {
result = mbImpl->tag_get_data(sharedps_tag, &(*rit), 1,
&remote_procs[0]);
@@ -1256,7 +1359,7 @@
- // now insert other_proc, handle into these
+ // now insert other_proc, handle into these, and set the tags
if (-1 == remote_procs[0]) {
remote_procs[0] = other_proc;
@@ -1276,6 +1379,9 @@
assert(*vit != other_proc);
remote_procs.insert(vit, other_proc);
remote_handles.insert(vit2, *rit2);
+ // need to pop 'cuz we're using an insert above
+ remote_procs.pop_back();
+ remote_handles.pop_back();
result = mbImpl->tag_set_data(sharedps_tag, &(*rit), 1, &remote_procs[0]);
RRA("Couldn't set sharedps tag");
result = mbImpl->tag_set_data(sharedhs_tag, &(*rit), 1, &remote_handles[0]);
@@ -1313,79 +1419,151 @@
// get remote procs tag, if any
MBRange tmp_range;
std::vector<int> remote_proc(num_ents);
- std::vector<int> remote_procs(MAX_SHARING_PROCS);
+ int remote_procs[MAX_SHARING_PROCS];
std::vector<MBEntityHandle> remote_handle(num_ents);
- std::vector<MBEntityHandle> remote_handles(MAX_SHARING_PROCS);
+ MBEntityHandle remote_handles[MAX_SHARING_PROCS];
+ std::vector<unsigned char> pstatus_vals(num_ents);
result = mbImpl->tag_get_data(sharedp_tag, local_ents, num_ents,
&remote_proc[0]);
RRA("Couldn't get sharedp tag.");
result = mbImpl->tag_get_data(sharedh_tag, local_ents, num_ents,
&remote_handle[0]);
- int rit, rit2;
- int i;
- for (rit = 0, rit2 = 0, i = 0;
- rit != num_ents; rit++, rit2++, i++) {
- remote_procs[0] = remote_proc[i];
- if (-1 != remote_proc[0]) remote_handles[0] = remote_ents[rit2];
+ result = mbImpl->tag_get_data(pstatus_tag, local_ents, num_ents,
+ &pstatus_vals[0]);
+ RRA("Couldn't get sharedh tag.");
+ // for each local/remote handle pair
+ for (int i = 0; i != num_ents; i++) {
+ if (-1 != remote_proc[i]) {
+ remote_procs[0] = remote_proc[i];
+ remote_handles[0] = remote_handle[i];
+ std::fill(remote_procs+1, remote_procs+MAX_SHARING_PROCS, -1);
+ std::fill(remote_handles+1, remote_handles+MAX_SHARING_PROCS, 0);
else {
- result = mbImpl->tag_get_data(sharedps_tag, &local_ents[rit], 1,
- &remote_procs[0]);
+ result = mbImpl->tag_get_data(sharedps_tag, local_ents+i, 1,
+ remote_procs);
if (MB_SUCCESS == result) {
- result = mbImpl->tag_get_data(sharedhs_tag, &local_ents[rit], 1,
- &remote_handles[0]);
+ result = mbImpl->tag_get_data(sharedhs_tag, local_ents+i, 1,
+ remote_handles);
RRA("Couldn't get sharedhs tag.");
- if (-1 == remote_procs[0]) {
- remote_procs[0] = other_proc;
- remote_handles[0] = remote_ents[rit2];
- result = mbImpl->tag_set_data(sharedp_tag, &local_ents[rit], 1,
- RRA("Couldn't set sharedp tag");
- result = mbImpl->tag_set_data(sharedh_tag, &local_ents[rit], 1,
- RRA("Couldn't set sharedh tag");
- remote_procs[0] = -1;
- remote_handles[0] = 0;
+ // now either insert other_proc, handle into these, or remove if
+ // remote handle is 0
+ if (0 == remote_ents[i]) {
+ result = rmv_remote_proc(local_ents[i], remote_procs, remote_handles,
+ other_proc);
+ RRA(" ");
+ if (-1 == remote_procs[0])
+ pstatus_vals[i] = (pstatus_vals[i] & (!PSTATUS_SHARED));
else {
- std::vector<int>::iterator vit = remote_procs.begin();
- std::vector<MBEntityHandle>::iterator vit2 = remote_handles.begin();
- while (-1 != *vit && vit != remote_procs.end() && other_proc > *vit) {
- vit++; vit2++;
- assert(*vit != other_proc);
- remote_procs.insert(vit, other_proc);
- remote_handles.insert(vit2, remote_ents[rit2]);
- result = mbImpl->tag_set_data(sharedps_tag, &local_ents[rit], 1,
- RRA("Couldn't set sharedps tag");
- result = mbImpl->tag_set_data(sharedhs_tag, &local_ents[rit], 1,
- RRA("Couldn't set sharedhs tag");
- std::fill(remote_procs.begin(), remote_procs.end(), -1);
- std::fill(remote_handles.begin(), remote_handles.end(), 0);
+ result = add_remote_proc(local_ents[i], remote_procs, remote_handles,
+ other_proc, remote_ents[i]);
+ RRA(" ");
+ pstatus_vals[i] |= PSTATUS_SHARED;
- // also update shared flag for these ents
- unsigned int *shared_flags = (unsigned int*) &remote_proc[0];
- result = mbImpl->tag_get_data(pstatus_tag, local_ents, num_ents,
- shared_flags);
- RRA("Couldn't get shared tag");
- for (int i = 0; i < num_ents; i++)
- shared_flags[i] |= PSTATUS_SHARED;
result = mbImpl->tag_set_data(pstatus_tag, local_ents,
- num_ents, shared_flags);
+ num_ents, &pstatus_vals[0]);
RRA("Couldn't set shared tag");
+MBErrorCode MBParallelComm::rmv_remote_proc(MBEntityHandle ent,
+ int *remote_procs,
+ MBEntityHandle *remote_hs,
+ int remote_proc)
+ int i = std::find(remote_procs, remote_procs+MAX_SHARING_PROCS, -1) - remote_procs;
+ int j = std::find(remote_procs, remote_procs+i, remote_proc) - remote_procs;
+ // remote_proc must be in this list
+ assert(j != i);
+ for (; j != i; j++) {
+ remote_procs[j] = remote_procs[j+1];
+ remote_hs[j] = remote_hs[j+1];
+ if (i == 1) {
+ // only had one proc, and now have none; have to set the values,
+ // since they're sparse tags
+ result = mbImpl->tag_set_data(sharedp_tag(), &ent, 1, remote_procs);
+ result = mbImpl->tag_set_data(sharedh_tag(), &ent, 1, remote_hs);
+ else if (i == 2) {
+ // went from 2 to 1, need to unset 1 and set the other
+ RRA("Couldn't set sharedp tag");
+ RRA("Couldn't set sharedh tag");
+ result = mbImpl->tag_delete_data(sharedps_tag(), &ent, 1);
+ RRA("Couldn't remove sharedps tag");
+ result = mbImpl->tag_delete_data(sharedhs_tag(), &ent, 1);
+ RRA("Couldn't remove sharedhs tag");
+ else {
+ result = mbImpl->tag_set_data(sharedps_tag(), &ent, 1, remote_procs);
+ RRA("Couldn't set sharedps tag");
+ result = mbImpl->tag_set_data(sharedhs_tag(), &ent, 1, remote_hs);
+ RRA("Couldn't set sharedhs tag");
return MB_SUCCESS;
+MBErrorCode MBParallelComm::add_remote_proc(MBEntityHandle ent,
+ int remote_proc,
+ MBEntityHandle remote_handle)
+ int i = 0;
+ bool more = (remote_procs[0] != -1);
+ while (-1 != remote_procs[i] && i < MAX_SHARING_PROCS &&
+ remote_proc > remote_procs[i]) i++;
+ if (remote_procs[i] == remote_proc) return MB_SUCCESS;
+ assert(i < MAX_SHARING_PROCS-1);
+ if (-1 != remote_procs[i]) {
+ for (int j = MAX_SHARING_PROCS-1; j > i; j--) {
+ remote_procs[j] = remote_procs[j-1];
+ remote_hs[j] = remote_hs[j-1];
+ remote_procs[i] = remote_proc;
+ remote_hs[i] = remote_handle;
+ MBErrorCode result = mbImpl->tag_set_data((more ? sharedps_tag() : sharedp_tag()),
+ &ent, 1, remote_procs);
+ result = mbImpl->tag_set_data((more ? sharedhs_tag() : sharedh_tag()), &ent, 1, remote_hs);
+ // if we went from 1 to 2, need to unset sharedp_tag
+ if (1 == i) {
+ remote_proc = -1;
+ result = mbImpl->tag_set_data(sharedp_tag(), &ent, 1, &remote_proc);
+ remote_handle = 0;
+ result = mbImpl->tag_set_data(sharedh_tag(), &ent, 1, &remote_handle);
MBErrorCode MBParallelComm::pack_range_map(MBRange &key_range, MBEntityHandle val_start,
HandleMap &handle_map)
@@ -2234,59 +2412,19 @@
&iface_sets);
RRA("Trouble creating iface sets.");
- // resolve shared ent remote handles
- result = resolve_ent_remote_handles(iface_sets);
+ // resolve shared entity remote handles; implemented in ghost cell exchange
+ // code because it's so similar
+ result = exchange_ghost_cells(-1, -1, 0, true, true);
RRA("Trouble resolving shared entity remote handles.");
+ // now build parent/child links for interface sets
+ result = create_iface_pc_links(iface_sets);
+ RRA("Trouble creating interface parent/child links.");
- if (0 == shared_dim) return MB_SUCCESS;
// done
return result;
-MBErrorCode MBParallelComm::resolve_ent_remote_handles(MBRange &iface_sets)
- std::vector<unsigned char> pstatus_flags(iface_sets.size());
- MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), iface_sets,
- &pstatus_flags[0]);
- std::vector<int> sharing_proc(iface_sets.size());
- result = mbImpl->tag_get_data(sharedp_tag(), iface_sets,
- &sharing_proc[0]);
- RRA("Couldn't get sharedp tag for iface sets.");
- std::vector<int> sharing_procs(MAX_SHARING_PROCS);
- MBRange::iterator if_it;
- unsigned int i;
- for (if_it = iface_sets.begin(), i = 0; if_it != iface_sets.end(); if_it++, i++) {
- // for each set/iface:
- sharing_procs[0] = sharing_proc[i];
- if (-1 == sharing_procs[0]) {
- result = mbImpl->tag_get_data(sharedps_tag(), &(*if_it), 1,
- &sharing_procs[0]);
- RRA("Couldn't get sharedps tag for iface set.");
- assert(-1 != sharing_procs[0]); // should be at least one sharing proc
- // if owner:
- if (procConfig.proc_rank() < sharing_
- // - assemble connectivity of non-vertex ents
- // - replace with remote handles of verts
- // - Isend to procs sharing that iface
- // - recv vectors of remote handles from sharing procs
- // else
- // - recv from owner connectivity of shared ents
- // - get local ent handles for those ents
- // - Isend vector of local handles to all other sharing procs
- // - recv vector of remote handles from all non-owning other procs
- return MB_SUCCESS;
MBErrorCode MBParallelComm::create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges,
int resolve_dim, int shared_dim,
MBRange *iface_sets_ptr)
@@ -2300,13 +2438,6 @@
RRA("Trouble getting shared proc tags in create_interface_sets.");
MBRange::iterator rit;
- MBTag tmp_iface_tag;
- MBEntityHandle tmp_iface_set = 0;
- result = mbImpl->tag_create("__tmp_iface", sizeof(MBEntityHandle),
- MB_TAG_DENSE, MB_TYPE_HANDLE,
- tmp_iface_tag, &tmp_iface_set);
- RRA("Failed to create temporary iface set tag.");
MBRange psets;
if (!iface_sets_ptr) iface_sets_ptr = &psets;
@@ -2319,19 +2450,6 @@
psets);
RRA("Couldn't get PARALLEL_PARTITION sets.");
- if (resolve_dim < shared_dim) {
- for (rit = psets.begin(); rit != psets.end(); rit++) {
- result = mbImpl->get_entities_by_handle(*rit, tmp_ents, true);
- RR("Failed to get entities in partition set.");
- std::vector<MBEntityHandle> tag_vals(tmp_ents.size());
- std::fill(tag_vals.begin(), tag_vals.end(), *rit);
- result = mbImpl->tag_set_data(tmp_iface_tag, tmp_ents, &tag_vals[0]);
- RR("Failed to set iface tag on partition ents.");
- tmp_ents.clear();
// create interface sets, tag them, and tag their contents with iface set tag
std::vector<MBEntityHandle> tag_vals;
for (std::map<std::vector<int>,MBRange>::iterator mit = proc_nranges.begin();
@@ -2356,14 +2474,8 @@
result = mbImpl->tag_set_data(sharedps_tag, &new_set, 1,
&((*mit).first)[0]);
RR("Failed to tag interface set with procs.");
- // tag entities with interface set
- tag_vals.resize((*mit).second.size());
- std::fill(tag_vals.begin(), tag_vals.end(), new_set);
- result = mbImpl->tag_set_data(tmp_iface_tag, (*mit).second,
- &tag_vals[0]);
- RR("Failed to tag iface entities with interface set.");
- // get the owning proc, then set the pstatus tag
+ // get the owning proc, then set the pstatus tag on iface set
int min_proc = ((*mit).first)[0];
unsigned char pstatus = PSTATUS_SHARED;
if (min_proc < (int) procConfig.proc_rank()) pstatus |= PSTATUS_NOT_OWNED;
@@ -2371,31 +2483,69 @@
RR("Failed to tag interface set with pstatus.");
+ // set tag on interface instance holding all interface sets for this instance
+ MBEntityHandle tmp_iface_sets[MAX_SHARING_PROCS];
+ std::fill(tmp_iface_sets, tmp_iface_sets+MAX_SHARING_PROCS, 0);
+ unsigned int i;
+ for (rit = iface_sets_ptr->begin(), i = 0; rit != iface_sets_ptr->end();
+ rit++, i++)
+ tmp_iface_sets[i] = *rit;
+ result = mbImpl->tag_set_data(iface_sets_tag(), NULL, 0,
+ tmp_iface_sets);
+ RRA("Couldn't set iface sets tag on MOAB interface.");
+MBErrorCode MBParallelComm::create_iface_pc_links(MBRange &iface_sets)
+ // now that we've resolved the entities in the iface sets,
+ // set parent/child links between the iface sets
+ // first tag all entities in the iface sets
+ MBTag tmp_iface_tag;
+ MBEntityHandle tmp_iface_set = 0;
+ MBErrorCode result = mbImpl->tag_create("__tmp_iface", sizeof(MBEntityHandle),
+ MB_TAG_DENSE, MB_TYPE_HANDLE,
+ tmp_iface_tag, &tmp_iface_set);
+ RRA("Failed to create temporary iface set tag.");
+ MBRange iface_ents;
+ std::vector<MBEntityHandle> tag_vals;
+ MBRange::iterator rit;
+ for (rit = iface_sets.begin(); rit != iface_sets.end(); rit++) {
+ // tag entities with interface set
+ iface_ents.clear();
+ result = mbImpl->get_entities_by_handle(*rit, iface_ents);
+ RRA("Couldn't get entities in iface set.");
+ if (iface_ents.empty()) continue;
+ tag_vals.resize(iface_ents.size());
+ std::fill(tag_vals.begin(), tag_vals.end(), *rit);
+ result = mbImpl->tag_set_data(tmp_iface_tag, iface_ents, &tag_vals[0]);
+ RRA("Failed to tag iface entities with interface set.");
// now go back through interface sets and add parent/child links
+ MBRange tmp_ents2;
for (int d = 2; d >= 0; d--) {
- tag_vals.clear();
- std::copy(psets.begin(), psets.end(), std::back_inserter(tag_vals));
- for (rit = iface_sets_ptr->begin(); rit != iface_sets_ptr->end();
- rit++) {
- tmp_ents.clear();
+ // get entities on this interface
+ result = mbImpl->get_entities_by_handle(*rit, iface_ents, true);
RR("Couldn't get entities by dimension.");
- if (tmp_ents.empty() || (resolve_dim > shared_dim &&
- mbImpl->dimension_from_handle(*tmp_ents.rbegin()) != d)) continue;
+ if (iface_ents.empty() ||
+ mbImpl->dimension_from_handle(*iface_ents.rbegin()) != d) continue;
- if (resolve_dim > shared_dim) {
- // get higher-dimensional entities and their interface sets
- result = mbImpl->get_adjacencies(&(*tmp_ents.begin()), 1, d+1,
- false, tmp_ents2);
- RR("Couldn't get adjacencies for interface sets.");
- tag_vals.resize(tmp_ents2.size());
- result = mbImpl->tag_get_data(tmp_iface_tag, tmp_ents2, &tag_vals[0]);
- RR("Couldn't get iface set tag for interface sets.");
+ // get higher-dimensional entities and their interface sets
+ result = mbImpl->get_adjacencies(&(*iface_ents.begin()), 1, d+1,
+ false, tmp_ents2);
+ RRA("Couldn't get adjacencies for interface sets.");
+ tag_vals.resize(tmp_ents2.size());
+ result = mbImpl->tag_get_data(tmp_iface_tag, tmp_ents2, &tag_vals[0]);
+ RRA("Couldn't get iface set tag for interface sets.");
// go through and for any on interface make it a parent
MBEntityHandle last_set = 0;
@@ -2413,18 +2563,6 @@
result = mbImpl->tag_delete(tmp_iface_tag);
RR("Couldn't delete tmp iface tag.");
- // get interface sets tag, reuse tmp_iface_tag
- tmp_iface_tag = iface_sets_tag();
- MBEntityHandle tmp_iface_sets[MAX_SHARING_PROCS];
- std::fill(tmp_iface_sets, tmp_iface_sets+MAX_SHARING_PROCS, 0);
- unsigned int i;
- for (rit = iface_sets_ptr->begin(), i = 0; rit != iface_sets_ptr->end();
- rit++, i++)
- tmp_iface_sets[i] = *rit;
- result = mbImpl->tag_set_data(iface_sets_tag(), NULL, 0,
- tmp_iface_sets);
- RRA("Couldn't set iface sets tag on MOAB interface.");
return MB_SUCCESS;
@@ -2471,6 +2609,10 @@
bool and_zero = false;
for (int nc = 0; nc < num_connect; nc++) {
+ // only have to initialize the 2nd one; if sharedps tag is used,
+ // all get initialized
+ sharing_procs2[1] = -1;
// get sharing procs
result = mbImpl->tag_get_data(sharedp_tag, connect+nc, 1, sharing_procs2);
RR("Couldn't get sharedp_tag on skin vertices in entity.");
@@ -2496,7 +2638,7 @@
sp_range = sp_range.intersect(vp_range);
// need to also save rank zero, since ranges don't handle that
- if (and_zero && sharing_procs[0] != 0) and_zero = false;
+ if (and_zero && sharing_procs2[0] != 0) and_zero = false;
if (sp_range.empty() && resolve_dim < shared_dim) continue;
@@ -2522,17 +2664,19 @@
RR("Failed to set sharedp(s)_tag on non-vertex skin entity.");
- unsigned char share_flag = PSTATUS_SHARED;
- if ((int) procConfig.proc_rank() > sharing_procs[0])
- share_flag |= PSTATUS_NOT_OWNED;
- result = mbImpl->tag_set_data(pstatus_tag, &(*rit), 1, &share_flag);
- RRA("Couldn't set shared tag on shared entity.");
// reset sharing proc(s) tags
std::fill(sharing_procs.begin(), sharing_procs.end(), -1);
+ // build range for each sharing proc
+ std::map<int, MBRange> proc_ranges;
+ for (std::map<std::vector<int>, MBRange>::iterator mit = proc_nranges.begin();
+ mit != proc_nranges.end(); mit++) {
+ for (unsigned int i = 0; i < (*mit).first.size(); i++)
+ proc_ranges[(*mit).first[i]].merge((*mit).second);
return MB_SUCCESS;
@@ -2681,25 +2825,32 @@
int num_layers,
MBRange &to_ents)
- MBRange bridge_ents;
- MBErrorCode result = mbImpl->get_entities_by_dimension(iface_set, bridge_dim,
- bridge_ents,
- MBInterface::UNION);
+ MBRange bridge_ents, *bridge_ents_ptr = &bridge_ents;
+ // if 0 layers, put bridge_ents in to_ents, to avoid range copy later
+ if (0 == num_layers) bridge_ents_ptr = &to_ents;
+ if (bridge_dim == -1)
+ result = mbImpl->get_entities_by_handle(iface_set, *bridge_ents_ptr);
+ else
+ result = mbImpl->get_entities_by_dimension(iface_set, bridge_dim, *bridge_ents_ptr);
RRA("Couldn't get bridge ents in the set.");
- if (bridge_ents.empty()) return MB_SUCCESS;
+ if (bridge_ents_ptr->empty()) return MB_SUCCESS;
// for each layer, get bridge-adj entities and accumulate
for (int nl = 0; nl < num_layers; nl++) {
MBRange new_ghosts, new_bridges;
- result = mbImpl->get_adjacencies(bridge_ents, to_dim, false, new_ghosts,
+ result = mbImpl->get_adjacencies(*bridge_ents_ptr, to_dim, false, new_ghosts,
RRA("Trouble getting ghost adjacencies in iteration.");
to_ents.merge(new_ghosts);
result = mbImpl->get_adjacencies(new_ghosts, bridge_dim, false, new_bridges,
if (nl < num_layers-1)
- bridge_ents = new_bridges.subtract(bridge_ents);
+ *bridge_ents_ptr = new_bridges.subtract(*bridge_ents_ptr);
return MB_SUCCESS;
@@ -2825,17 +2976,16 @@
MBErrorCode MBParallelComm::exchange_ghost_cells(int ghost_dim, int bridge_dim,
int num_layers,
- bool wait_all)
+ bool wait_all)
+ // if we're only finding out about existing ents, we have to be storing
+ // remote handles too
+ assert(num_layers > 0 || store_remote_handles);
// get the b-dimensional interface(s) with with_proc, where b = bridge_dim
MBErrorCode result;
int success;
- if (bridge_dim != 0) {
- result = MB_NOT_IMPLEMENTED;
- RRA("Exchanging ghost cells only works with bridge_dim = 0 for now.");
// get all procs interfacing to this proc
MBRange iface_sets;
std::vector<int> iface_procs;
@@ -2862,7 +3012,7 @@
// pack and send ghosts from this proc to others
// make sendReqs vector to simplify initialization
std::fill(sendReqs, sendReqs+2*MAX_SHARING_PROCS, MPI_REQUEST_NULL);
- MBRange sent_ents[MAX_SHARING_PROCS], recd_ents[MAX_SHARING_PROCS];
+ MBRange recd_ents[MAX_SHARING_PROCS], sent_ents[MAX_SHARING_PROCS];
for (vit = iface_procs.begin(); vit != iface_procs.end(); vit++) {
int ind = get_buffers(*vit);
@@ -2873,13 +3023,21 @@
rit++) {
if (!is_iface_proc(*rit, *vit)) continue;
- result = get_ghost_layers(*rit, ghost_dim, bridge_dim, num_layers,
- bridge_ents);
+ result = get_ghost_layers(*rit, ghost_dim, bridge_dim, num_layers, bridge_ents);
RRA("Failed to get ghost layers.");
+ if (0 == num_layers) {
+ // just sending iface ents - take out vertices, since these are always known
+ std::pair<MBRange::const_iterator, MBRange::const_iterator> its =
+ bridge_ents.equal_range(MBVERTEX);
+ bridge_ents.erase((MBRange::iterator)its.first,
+ (MBRange::iterator)its.second);
// pack-send; this also posts receives if store_remote_handles is true
- result = pack_send_entities(*vit, bridge_ents, false, true, store_remote_handles,
+ result = pack_send_entities(*vit, bridge_ents, false, true,
+ store_remote_handles, (0 == num_layers),
ownerSBuffs[ind], ownerRBuffs[MAX_SHARING_PROCS+ind],
sendReqs[ind], recv_reqs[MAX_SHARING_PROCS+ind],
sent_ents[ind]);
@@ -2903,8 +3061,9 @@
// ok, received something; decrement incoming counter
num_incoming--;
- MBRange remote_range;
- int new_size;
+ std::vector<MBEntityHandle> remote_handles_v, sent_ents_tmp;
+ MBRange remote_handles_r;
+ int new_size, num_eh;
unsigned char *buff_ptr;
// branch on message type
@@ -2922,18 +3081,43 @@
case MB_MESG_ENTS:
// incoming ghost entities; process
result = recv_unpack_entities(buffProcs[ind], store_remote_handles,
+ (0 == num_layers),
ghostRBuffs[ind], ghostSBuffs[ind],
sendReqs[ind], recd_ents[ind]);
break;
- case MB_MESG_REMOTE_HANDLES:
+ case MB_MESG_REMOTE_HANDLES_VECTOR:
// incoming remote handles; use to set remote handles
+ // this version only called if we're exchanging iface layer...
+ assert(0 == num_layers);
buff_ptr = &ownerRBuffs[ind][0];
assert(ind >= MAX_SHARING_PROCS);
- UNPACK_RANGE(buff_ptr, remote_range);
- result = set_remote_data(sent_ents[ind-MAX_SHARING_PROCS], remote_range, *vit);
+ UNPACK_INT(buff_ptr, num_eh);
+ remote_handles_v.resize(num_eh);
+ UNPACK_EH(buff_ptr, &remote_handles_v[0], num_eh);
+ std::copy(sent_ents[ind-MAX_SHARING_PROCS].begin(),
+ sent_ents[ind-MAX_SHARING_PROCS].end(),
+ std::back_inserter(sent_ents_tmp));
+ assert(!sent_ents_tmp.empty());
+ result = set_remote_data(&sent_ents_tmp[0], &remote_handles_v[0], sent_ents_tmp.size(),
+ buffProcs[ind-MAX_SHARING_PROCS]);
RRA("Trouble setting remote data range on sent entities in ghost exchange.");
+ result = update_iface_sets(iface_sets, sent_ents[ind-MAX_SHARING_PROCS],
+ remote_handles_v, buffProcs[ind-MAX_SHARING_PROCS]);
+ RRA("Trouble updating iface sets.");
break;
+ case MB_MESG_REMOTE_HANDLES_RANGE:
+ // incoming remote handles; use to set remote handles
+ // this version only called if we're NOT exchanging iface layer...
+ assert(0 != num_layers);
+ buff_ptr = &ownerRBuffs[ind][0];
+ assert(ind >= MAX_SHARING_PROCS);
+ UNPACK_RANGE(buff_ptr, remote_handles_r);
+ assert(!sent_ents[ind-MAX_SHARING_PROCS].empty());
+ result = set_remote_data(sent_ents[ind-MAX_SHARING_PROCS], remote_handles_r,
+ RRA("Trouble setting remote data range on sent entities in ghost exchange.");
+ break;
@@ -2950,6 +3134,27 @@
return MB_SUCCESS;
+MBErrorCode MBParallelComm::update_iface_sets(MBRange &iface_sets,
+ MBRange &sent_ents,
+ std::vector<MBEntityHandle> &remote_handles,
+ int from_proc)
+ std::vector<MBEntityHandle>::iterator remote_it = remote_handles.begin();
+ MBRange::iterator sent_it = sent_ents.begin();
+ MBRange ents_to_remove;
+ for (; sent_it != sent_ents.end(); sent_it++, remote_it++) {
+ if (!*remote_it) ents_to_remove.insert(*sent_it);
+ for (MBRange::iterator set_it = iface_sets.begin(); set_it != iface_sets.end(); set_it++) {
+ if (!is_iface_proc(*set_it, from_proc)) continue;
+ MBErrorCode result = mbImpl->remove_entities(*set_it, ents_to_remove);
+ RRA("Couldn't remove entities from iface set in update_iface_sets.");
//! return sharedp tag
MBTag MBParallelComm::sharedp_tag()
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2008-05-21 18:54:59 UTC (rev 1833)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2008-05-22 16:17:40 UTC (rev 1834)
@@ -257,6 +257,7 @@
const bool tags,
@@ -271,14 +272,23 @@
//! process contents of receive buffer to get new entities; if store_remote_handles
//! is true, also Isend (using send_buff) handles for these entities back to
- //! source proc, returning request handle in &send_req
+ //! source proc, returning request handle in &send_req; if iface_layer is true,
+ //! don't instantiate the entities, just check to see if they correspond to
+ //! existing entities, and if not, set corresponding recd_ents handle to zero
MBErrorCode recv_unpack_entities(const int from_proc,
MBRange &recd_ents);
+ //! for all the entities in the received buffer; for each, save
+ //! entities in this instance which match connectivity, or zero if none found
+ MBErrorCode unpack_iface_entities(unsigned char *&buff_ptr,
+ std::vector<MBEntityHandle> &recd_ents);
MBErrorCode pack_entities(MBRange &entities,
MBRange::const_iterator &start_rit,
MBRange &whole_range,
@@ -292,9 +302,9 @@
std::vector<int> &verts_per_entity);
MBErrorCode unpack_entities(unsigned char *&buff_ptr,
- const int from_proc);
+ MBRange &entities);
MBErrorCode pack_sets(MBRange &entities,
@@ -355,10 +365,18 @@
MBRange *skin_ents,
std::map<std::vector<int>, MBRange> &proc_nranges);
+ // each iterate in proc_nranges contains a set of procs and the entities *possibly*
+ // on the interface between those procs; this function makes sets for each,
+ // and tags the set with the procs sharing it; interface sets are optionally
+ // returned; NOTE: a subsequent step is used to verify entities on the interface
+ // and remove them if they're not shared
MBErrorCode create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges,
MBRange *iface_sets_ptr = NULL);
+ // after verifying shared entities, now parent/child links between sets can be established
+ MBErrorCode create_iface_pc_links(MBRange &iface_sets);
//! resolve remote handles for shared non-vertex ents, assuming
//! this has already been done for vertices
MBErrorCode resolve_ent_remote_handles(MBRange &iface_sets);
@@ -384,6 +402,13 @@
//! returns true if the set is an interface shared with to_proc
bool is_iface_proc(MBEntityHandle this_set, int to_proc);
+ //! for any remote_handles set to zero, remove corresponding sent_ents from
+ //! iface_sets corresponding to from_proc
+ MBErrorCode update_iface_sets(MBRange &iface_sets,
+ int from_proc);
//! replace handles in from_vec with corresponding handles on
//! to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag;
//! if no remote handle and new_ents is non-null, substitute
@@ -432,6 +457,19 @@
int num_ents,
int other_proc);
+ //! remove a remote processor and the entity's handle
+ MBErrorCode rmv_remote_proc(MBEntityHandle ent,
+ int remote_proc);
+ //! add a remote processor and the entity's handle
+ MBErrorCode add_remote_proc(MBEntityHandle ent,
+ int remote_proc,
+ MBEntityHandle remote_handle);
//! returns the interface sets and union of sharing procs
MBErrorCode get_iface_sets_procs(MBRange &iface_sets,
std::vector<int> &sharing_procs);
