[MOAB-dev] r1806 - MOAB/trunk
dcthomp at mcs.anl.gov
Mon May 12 18:09:12 CDT 2008
Author: dcthomp
Date: 2008-05-12 18:09:12 -0500 (Mon, 12 May 2008)
New Revision: 1806
Modified:
MOAB/trunk/CMakeLists.txt
Log:
ENH: Make this project work with CMake 2.6.
COMP: Add new files to build to keep up with autoconf.
COMP: Create MBCN_FCDefs.h as required.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt 2008-05-12 18:43:28 UTC (rev 1805)
+++ MOAB/trunk/CMakeLists.txt 2008-05-12 23:09:12 UTC (rev 1806)
@@ -1,5 +1,7 @@
project( MOAB )
+ cmake_minimum_required( VERSION 2.4 )
include( ${MOAB_SOURCE_DIR}/cmake/GetAcInitVersion.cmake )
get_ac_init_version()
set ( MOAB_VERSION_MAJOR "${MAJOR_VERSION}" )
@@ -14,7 +16,7 @@
else ( MOAB_VERSION_MINOR EQUAL 99 )
set ( MOAB_VERSION_STRING "${MOAB_VERSION_STRING} (beta)" )
endif ( MOAB_VERSION_MINOR EQUAL 99 )
- endif ( NOT DEFINED PATCH_VERSION )
+ endif ( DEFINED PATCH_VERSION )
set ( CMAKE_MODULE_PATH "${CMAKE_MODULE_PATH};${MOAB_SOURCE_DIR}/cmake" )
set ( EXECUTABLE_OUTPUT_PATH ${MOAB_BINARY_DIR}/bin CACHE PATH "Path to executables" FORCE )
@@ -123,6 +125,7 @@
MBBits.cpp
MBCN.cpp
MBCartVect.cpp
+ MBElemUtil.cpp
MBHandleUtils.cpp
MBMatrix3.cpp
MBCore.cpp
@@ -143,6 +146,7 @@
MeshTopoUtil.cpp
PolyElementSeq.cpp
ReadGmsh.cpp
+ ReadIDEAS.cpp
ReadSTL.cpp
ReadVtk.cpp
ScdElementData.cpp
@@ -270,7 +274,17 @@
endif ( MOAB_BUILD_DAGMC )
# iMesh Babel
+ if ( MOAB_BUILD_IMESH )
+ option( MOAB_IMESH_FORTRAN "Should MOAB include iMesh FORTRAN bindings?" OFF )
+ endif ( MOAB_BUILD_IMESH )
+ if ( MOAB_IMESH_FORTRAN )
+ enable_language( Fortran )
+ # This determines FORTRAN calling conventions and defines FC_FUNC and FC_FUNC_
+ # to macros which can be used from C to call FORTRAN.
+ #include( ${MOAB_SOURCE_DIR}/cmake/FortranCallingConvention.cmake)
+ endif ( MOAB_IMESH_FORTRAN )
include( ${MOAB_SOURCE_DIR}/cmake/AutoconfHeader.cmake )
# Define some more variables so they will be substituted properly in the autoconf files.
set( MB_VERSION "\"${MOAB_VERSION}\"" )
@@ -283,6 +297,7 @@
autoconf_header( ${MOAB_SOURCE_DIR}/MBVersion.h.in ${MOAB_BINARY_DIR}/MBVersion.h )
autoconf_header( ${MOAB_SOURCE_DIR}/MBEntityHandle.h.in ${MOAB_BINARY_DIR}/MBEntityHandle.h )
+ autoconf_header( ${MOAB_SOURCE_DIR}/MBCN_FCDefs.h.in ${MOAB_BINARY_DIR}/MBCN_FCDefs.h )
# Testing
