[MOAB-dev] r1804 - MOAB/trunk/tools/mcnpmit
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Sun May 11 16:49:37 CDT 2008
Author: kraftche
Date: 2008-05-11 16:49:37 -0500 (Sun, 11 May 2008)
New Revision: 1804
Removed:
   MOAB/trunk/tools/mcnpmit/Makefile.in
Modified:
   MOAB/trunk/tools/mcnpmit/Makefile.am
Log:
fix build issues
Modified: MOAB/trunk/tools/mcnpmit/Makefile.am
--- MOAB/trunk/tools/mcnpmit/Makefile.am	2008-05-10 18:11:32 UTC (rev 1803)
+++ MOAB/trunk/tools/mcnpmit/Makefile.am	2008-05-11 21:49:37 UTC (rev 1804)
@@ -2,6 +2,6 @@
 DEFS = $(DEFINES)
 INCLUDES += -I$(top_srcdir) -I$(top_builddir)
 bin_PROGRAMS = mcnpmit
-mcnpmit_SOURCES = mcnpmit.cpp main.cpp
+mcnpmit_SOURCES = mcnpmit.hpp mcnpmit.cpp main.cpp
 LDADD = $(top_builddir)/libMOAB.la
 mcnpmit_DEPENDENCIES = $(top_builddir)/libMOAB.la
Deleted: MOAB/trunk/tools/mcnpmit/Makefile.in
--- MOAB/trunk/tools/mcnpmit/Makefile.in	2008-05-10 18:11:32 UTC (rev 1803)
+++ MOAB/trunk/tools/mcnpmit/Makefile.in	2008-05-11 21:49:37 UTC (rev 1804)
@@ -1,544 +0,0 @@
-# Makefile.in generated by automake 1.9.6 from Makefile.am.
-# @configure_input@
-# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
-# 2003, 2004, 2005  Free Software Foundation, Inc.
-# This Makefile.in is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
- at SET_MAKE@
-srcdir = @srcdir@
-top_srcdir = @top_srcdir@
-VPATH = @srcdir@
-pkgdatadir = $(datadir)/@PACKAGE@
-pkglibdir = $(libdir)/@PACKAGE@
-pkgincludedir = $(includedir)/@PACKAGE@
-top_builddir = ../..
-am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
-INSTALL = @INSTALL@
-install_sh_DATA = $(install_sh) -c -m 644
-install_sh_PROGRAM = $(install_sh) -c
-install_sh_SCRIPT = $(install_sh) -c
-INSTALL_HEADER = $(INSTALL_DATA)
-transform = $(program_transform_name)
-NORMAL_INSTALL = :
-PRE_INSTALL = :
-POST_INSTALL = :
-NORMAL_UNINSTALL = :
-PRE_UNINSTALL = :
-POST_UNINSTALL = :
-build_triplet = @build@
-host_triplet = @host@
-target_triplet = @target@
-bin_PROGRAMS = mcnpmit$(EXEEXT)
-subdir = tools/mcnpmit
-DIST_COMMON = README $(srcdir)/Makefile.am $(srcdir)/Makefile.in
-ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
-am__aclocal_m4_deps = $(top_srcdir)/m4/compiler.m4 \
-	$(top_srcdir)/m4/cplusplus.m4 $(top_srcdir)/m4/hdf5.m4 \
-	$(top_srcdir)/m4/netcdf.m4 $(top_srcdir)/configure.in
-am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
-	$(ACLOCAL_M4)
-mkinstalldirs = $(install_sh) -d
-CONFIG_HEADER = $(top_builddir)/config.h $(top_builddir)/MBVersion.h \
-	$(top_builddir)/MBEntityHandle.h $(top_builddir)/MBCN_FCDefs.h
-CONFIG_CLEAN_FILES =
-am__installdirs = "$(DESTDIR)$(bindir)"
-binPROGRAMS_INSTALL = $(INSTALL_PROGRAM)
-PROGRAMS = $(bin_PROGRAMS)
-am_mcnpmit_OBJECTS = mcnpmit.$(OBJEXT) main.$(OBJEXT)
-mcnpmit_OBJECTS = $(am_mcnpmit_OBJECTS)
-mcnpmit_LDADD = $(LDADD)
-DEFAULT_INCLUDES = -I. -I$(srcdir) -I$(top_builddir) -I$(top_builddir) -I$(top_builddir) -I$(top_builddir)
-depcomp = $(SHELL) $(top_srcdir)/depcomp
-am__depfiles_maybe = depfiles
-CXXCOMPILE = $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \
-	$(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CXXFLAGS) $(CXXFLAGS)
-LTCXXCOMPILE = $(LIBTOOL) --tag=CXX --mode=compile $(CXX) $(DEFS) \
-	$(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) \
-	$(AM_CXXFLAGS) $(CXXFLAGS)
-CXXLD = $(CXX)
-CXXLINK = $(LIBTOOL) --tag=CXX --mode=link $(CXXLD) $(AM_CXXFLAGS) \
-	$(CXXFLAGS) $(AM_LDFLAGS) $(LDFLAGS) -o $@
-SOURCES = $(mcnpmit_SOURCES)
-DIST_SOURCES = $(mcnpmit_SOURCES)
-ETAGS = etags
-CTAGS = ctags
-DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
-ACLOCAL = @ACLOCAL@
-AMDEP_FALSE = @AMDEP_FALSE@
-AMDEP_TRUE = @AMDEP_TRUE@
-AMTAR = @AMTAR@
-AM_CFLAGS = @AM_CFLAGS@
-AM_CPPFLAGS = @AM_CPPFLAGS@
-AM_CXXFLAGS = @AM_CXXFLAGS@
-AM_LDFLAGS = @AM_LDFLAGS@
-AR = @AR@
-AUTOCONF = @AUTOCONF@
-AUTOHEADER = @AUTOHEADER@
-AUTOMAKE = @AUTOMAKE@
-AWK = @AWK@
-BABEL_DIR = @BABEL_DIR@
-CC = @CC@
-CCDEPMODE = @CCDEPMODE@
-CFLAGS = @CFLAGS@
-CGM_CONFIG_OPTIONS = @CGM_CONFIG_OPTIONS@
-CGM_DIR = @CGM_DIR@
-CHACO_INCLUDES = @CHACO_INCLUDES@
-CHACO_LIBS = @CHACO_LIBS@
-CPP = @CPP@
-CPPFLAGS = @CPPFLAGS@
-CXX = @CXX@
-CXXCPP = @CXXCPP@
-CXXDEPMODE = @CXXDEPMODE@
-CXXFLAGS = @CXXFLAGS@
-CYGPATH_W = @CYGPATH_W@
-DAGMC_CONFIG_OPTIONS = @DAGMC_CONFIG_OPTIONS@
-DEFINES = @DEFINES@
-DEFS = $(DEFINES)
-DEPDIR = @DEPDIR@
-DISTCHECK_CONFIGURE_FLAGS = @DISTCHECK_CONFIGURE_FLAGS@
-DOXYGEN = @DOXYGEN@
-ECHO = @ECHO@
-ECHO_C = @ECHO_C@
-ECHO_N = @ECHO_N@
-ECHO_T = @ECHO_T@
-EGREP = @EGREP@
-ENABLE_DOXYGEN_FALSE = @ENABLE_DOXYGEN_FALSE@
-ENABLE_DOXYGEN_TRUE = @ENABLE_DOXYGEN_TRUE@
-ENABLE_dagmc_FALSE = @ENABLE_dagmc_FALSE@
-ENABLE_dagmc_TRUE = @ENABLE_dagmc_TRUE@
-ENABLE_hexmodops_FALSE = @ENABLE_hexmodops_FALSE@
-ENABLE_hexmodops_TRUE = @ENABLE_hexmodops_TRUE@
-ENABLE_imesh_FALSE = @ENABLE_imesh_FALSE@
-ENABLE_imesh_TRUE = @ENABLE_imesh_TRUE@
-ENABLE_mbchaco_FALSE = @ENABLE_mbchaco_FALSE@
-ENABLE_mbchaco_TRUE = @ENABLE_mbchaco_TRUE@
-ENABLE_mbconvert_FALSE = @ENABLE_mbconvert_FALSE@
-ENABLE_mbconvert_TRUE = @ENABLE_mbconvert_TRUE@
-ENABLE_mbperf_FALSE = @ENABLE_mbperf_FALSE@
-ENABLE_mbperf_TRUE = @ENABLE_mbperf_TRUE@
-ENABLE_mbsize_FALSE = @ENABLE_mbsize_FALSE@
-ENABLE_mbsize_TRUE = @ENABLE_mbsize_TRUE@
-ENABLE_mbskin_FALSE = @ENABLE_mbskin_FALSE@
-ENABLE_mbskin_TRUE = @ENABLE_mbskin_TRUE@
-ENABLE_mbsurfplot_FALSE = @ENABLE_mbsurfplot_FALSE@
-ENABLE_mbsurfplot_TRUE = @ENABLE_mbsurfplot_TRUE@
-ENABLE_mbtagprop_FALSE = @ENABLE_mbtagprop_FALSE@
-ENABLE_mbtagprop_TRUE = @ENABLE_mbtagprop_TRUE@
-ENABLE_mbzoltan_FALSE = @ENABLE_mbzoltan_FALSE@
-ENABLE_mbzoltan_TRUE = @ENABLE_mbzoltan_TRUE@
-ENABLE_mcnpmit_FALSE = @ENABLE_mcnpmit_FALSE@
-ENABLE_mcnpmit_TRUE = @ENABLE_mcnpmit_TRUE@
-ENABLE_qvdual_FALSE = @ENABLE_qvdual_FALSE@
-ENABLE_qvdual_TRUE = @ENABLE_qvdual_TRUE@
-ENABLE_spheredecomp_FALSE = @ENABLE_spheredecomp_FALSE@
-ENABLE_spheredecomp_TRUE = @ENABLE_spheredecomp_TRUE@
-EXEEXT = @EXEEXT@
-F77 = @F77@
-FC = @FC@
-FCFLAGS = @FCFLAGS@
-FCLIBS = @FCLIBS@
-FFLAGS = @FFLAGS@
-GREP = @GREP@
-HAVE_CGM_FALSE = @HAVE_CGM_FALSE@
-HAVE_CGM_TRUE = @HAVE_CGM_TRUE@
-HAVE_ZCAT_FALSE = @HAVE_ZCAT_FALSE@
-HAVE_ZCAT_TRUE = @HAVE_ZCAT_TRUE@
-HDF5_FILE_FALSE = @HDF5_FILE_FALSE@
-HDF5_FILE_TRUE = @HDF5_FILE_TRUE@
-HDF5_LIBS = @HDF5_LIBS@
-INCLUDES = @INCLUDES@ -I$(top_srcdir) -I$(top_builddir)
-INSTALL_DATA = @INSTALL_DATA@
-INSTALL_PROGRAM = @INSTALL_PROGRAM@
-INSTALL_SCRIPT = @INSTALL_SCRIPT@
-INSTALL_STRIP_PROGRAM = @INSTALL_STRIP_PROGRAM@
-LDFLAGS = @LDFLAGS@
-LIBOBJS = @LIBOBJS@
-LIBS = @LIBS@
-LIBTOOL = @LIBTOOL@
-LN_S = @LN_S@
-LTLIBOBJS = @LTLIBOBJS@
-MAKEINFO = @MAKEINFO@
-MOAB_CXX_LDFLAGS = @MOAB_CXX_LDFLAGS@
-MOAB_CXX_LIBS = @MOAB_CXX_LIBS@
-MOC = @MOC@
-NETCDF_FILE_FALSE = @NETCDF_FILE_FALSE@
-NETCDF_FILE_TRUE = @NETCDF_FILE_TRUE@
-NETCDF_LIBS = @NETCDF_LIBS@
-OBJEXT = @OBJEXT@
-PACKAGE = @PACKAGE@
-PACKAGE_BUGREPORT = @PACKAGE_BUGREPORT@
-PACKAGE_NAME = @PACKAGE_NAME@
-PACKAGE_STRING = @PACKAGE_STRING@
-PACKAGE_TARNAME = @PACKAGE_TARNAME@
-PACKAGE_VERSION = @PACKAGE_VERSION@
-PARALLEL_FALSE = @PARALLEL_FALSE@
-PARALLEL_HDF5_FALSE = @PARALLEL_HDF5_FALSE@
-PARALLEL_HDF5_TRUE = @PARALLEL_HDF5_TRUE@
-PARALLEL_TRUE = @PARALLEL_TRUE@
-PATH_SEPARATOR = @PATH_SEPARATOR@
-QTDIR = @QTDIR@
-QVDUAL_INCLUDES = @QVDUAL_INCLUDES@
-QVDUAL_LIBS = @QVDUAL_LIBS@
-RANLIB = @RANLIB@
-SET_MAKE = @SET_MAKE@
-SHELL = @SHELL@
-STRIP = @STRIP@
-UIC = @UIC@
-USE_BABEL = @USE_BABEL@
-USE_BABEL_FALSE = @USE_BABEL_FALSE@
-USE_BABEL_TRUE = @USE_BABEL_TRUE@
-USE_MPI_FALSE = @USE_MPI_FALSE@
-USE_MPI_TRUE = @USE_MPI_TRUE@
-VERSION = @VERSION@
-VTK_LIB_DIR = @VTK_LIB_DIR@
-XMKMF = @XMKMF@
-X_CFLAGS = @X_CFLAGS@
-X_EXTRA_LIBS = @X_EXTRA_LIBS@
-X_LIBS = @X_LIBS@
-X_PRE_LIBS = @X_PRE_LIBS@
-ZCAT = @ZCAT@
-ZOLTAN_ARCH = @ZOLTAN_ARCH@
-ZOLTAN_DIR = @ZOLTAN_DIR@
-ZOLTAN_INCLUDES = @ZOLTAN_INCLUDES@
-ZOLTAN_LIBS = @ZOLTAN_LIBS@
-ac_ct_CC = @ac_ct_CC@
-ac_ct_CXX = @ac_ct_CXX@
-ac_ct_F77 = @ac_ct_F77@
-ac_ct_FC = @ac_ct_FC@
-am__fastdepCC_FALSE = @am__fastdepCC_FALSE@
-am__fastdepCC_TRUE = @am__fastdepCC_TRUE@
-am__fastdepCXX_FALSE = @am__fastdepCXX_FALSE@
-am__fastdepCXX_TRUE = @am__fastdepCXX_TRUE@
-am__include = @am__include@
-am__leading_dot = @am__leading_dot@
-am__quote = @am__quote@
-am__tar = @am__tar@
-am__untar = @am__untar@
-bindir = @bindir@
-build = @build@
-build_alias = @build_alias@
-build_cpu = @build_cpu@
-build_os = @build_os@
-build_vendor = @build_vendor@
-datadir = @datadir@
-datarootdir = @datarootdir@
-docdir = @docdir@
-dvidir = @dvidir@
-exec_prefix = @exec_prefix@
-host = @host@
-host_alias = @host_alias@
-host_cpu = @host_cpu@
-host_os = @host_os@
-host_vendor = @host_vendor@
-htmldir = @htmldir@
-includedir = @includedir@
-infodir = @infodir@
-install_sh = @install_sh@
-libdir = @libdir@
-libexecdir = @libexecdir@
-localedir = @localedir@
-localstatedir = @localstatedir@
-mandir = @mandir@
-mkdir_p = @mkdir_p@
-oldincludedir = @oldincludedir@
-pdfdir = @pdfdir@
-prefix = @prefix@
-program_transform_name = @program_transform_name@
-psdir = @psdir@
-sbindir = @sbindir@
-sharedstatedir = @sharedstatedir@
-sysconfdir = @sysconfdir@
-target = @target@
-target_alias = @target_alias@
-target_cpu = @target_cpu@
-target_os = @target_os@
-target_vendor = @target_vendor@
-AUTOMAKE_OPTIONS = foreign
-LDADD = $(top_builddir)/libMOAB.la
-mcnpmit_DEPENDENCIES = $(top_builddir)/libMOAB.la
-all: all-am
-.SUFFIXES:
-.SUFFIXES: .cpp .lo .o .obj
-$(srcdir)/Makefile.in:  $(srcdir)/Makefile.am  $(am__configure_deps)
-	@for dep in $?; do \
-	  case '$(am__configure_deps)' in \
-	    *$$dep*) \
-	      cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh \
-		&& exit 0; \
-	      exit 1;; \
-	  esac; \
-	done; \
-	echo ' cd $(top_srcdir) && $(AUTOMAKE) --foreign  tools/mcnpmit/Makefile'; \
-	cd $(top_srcdir) && \
-	  $(AUTOMAKE) --foreign  tools/mcnpmit/Makefile
-.PRECIOUS: Makefile
-Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
-	@case '$?' in \
-	  *config.status*) \
-	    cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh;; \
-	    echo ' cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)'; \
-	    cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);; \
-	esac;
-$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
-$(top_srcdir)/configure:  $(am__configure_deps)
-$(ACLOCAL_M4):  $(am__aclocal_m4_deps)
-install-binPROGRAMS: $(bin_PROGRAMS)
-	@$(NORMAL_INSTALL)
-	test -z "$(bindir)" || $(mkdir_p) "$(DESTDIR)$(bindir)"
-	@list='$(bin_PROGRAMS)'; for p in $$list; do \
-	  p1=`echo $$p|sed 's/$(EXEEXT)$$//'`; \
-	  if test -f $$p \
-	     || test -f $$p1 \
-	  ; then \
-	    f=`echo "$$p1" | sed 's,^.*/,,;$(transform);s/$$/$(EXEEXT)/'`; \
-	   echo " $(INSTALL_PROGRAM_ENV) $(LIBTOOL) --mode=install $(binPROGRAMS_INSTALL) '$$p' '$(DESTDIR)$(bindir)/$$f'"; \
-	   $(INSTALL_PROGRAM_ENV) $(LIBTOOL) --mode=install $(binPROGRAMS_INSTALL) "$$p" "$(DESTDIR)$(bindir)/$$f" || exit 1; \
-	  else :; fi; \
-	done
-uninstall-binPROGRAMS:
-	@$(NORMAL_UNINSTALL)
-	  f=`echo "$$p" | sed 's,^.*/,,;s/$(EXEEXT)$$//;$(transform);s/$$/$(EXEEXT)/'`; \
-	  echo " rm -f '$(DESTDIR)$(bindir)/$$f'"; \
-	  rm -f "$(DESTDIR)$(bindir)/$$f"; \
-	done
-clean-binPROGRAMS:
-	  f=`echo $$p|sed 's/$(EXEEXT)$$//'`; \
-	  echo " rm -f $$p $$f"; \
-	  rm -f $$p $$f ; \
-	done
-mcnpmit$(EXEEXT): $(mcnpmit_OBJECTS) $(mcnpmit_DEPENDENCIES)
-	@rm -f mcnpmit$(EXEEXT)
-	$(CXXLINK) $(mcnpmit_LDFLAGS) $(mcnpmit_OBJECTS) $(mcnpmit_LDADD) $(LIBS)
-mostlyclean-compile:
-	-rm -f *.$(OBJEXT)
-distclean-compile:
-	-rm -f *.tab.c
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/main.Po at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/mcnpmit.Po at am__quote@
-.cpp.o:
- at am__fastdepCXX_TRUE@	if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \
- at am__fastdepCXX_TRUE@	then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Po"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi
- at AMDEP_TRUE@@am__fastdepCXX_FALSE@	source='$<' object='$@' libtool=no @AMDEPBACKSLASH@
- at AMDEP_TRUE@@am__fastdepCXX_FALSE@	DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) @AMDEPBACKSLASH@
- at am__fastdepCXX_FALSE@	$(CXXCOMPILE) -c -o $@ $<
-.cpp.obj:
- at am__fastdepCXX_TRUE@	if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ `$(CYGPATH_W) '$<'`; \
- at am__fastdepCXX_FALSE@	$(CXXCOMPILE) -c -o $@ `$(CYGPATH_W) '$<'`
-.cpp.lo:
- at am__fastdepCXX_TRUE@	if $(LTCXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \
- at am__fastdepCXX_TRUE@	then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Plo"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi
- at AMDEP_TRUE@@am__fastdepCXX_FALSE@	source='$<' object='$@' libtool=yes @AMDEPBACKSLASH@
- at am__fastdepCXX_FALSE@	$(LTCXXCOMPILE) -c -o $@ $<
-mostlyclean-libtool:
-	-rm -f *.lo
-clean-libtool:
-	-rm -rf .libs _libs
-distclean-libtool:
-	-rm -f libtool
-uninstall-info-am:
-ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
-	list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
-	unique=`for i in $$list; do \
-	    if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
-	  done | \
-	  $(AWK) '    { files[$$0] = 1; } \
-	       END { for (i in files) print i; }'`; \
-	mkid -fID $$unique
-tags: TAGS
-TAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
-		$(TAGS_FILES) $(LISP)
-	tags=; \
-	here=`pwd`; \
-	  done | \
-	if test -z "$(ETAGS_ARGS)$$tags$$unique"; then :; else \
-	  test -n "$$unique" || unique=$$empty_fix; \
-	  $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
-	    $$tags $$unique; \
-	fi
-ctags: CTAGS
-CTAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
-	tags=; \
-	here=`pwd`; \
-	  done | \
-	test -z "$(CTAGS_ARGS)$$tags$$unique" \
-	  || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
-	     $$tags $$unique
-GTAGS:
-	here=`$(am__cd) $(top_builddir) && pwd` \
-	  && cd $(top_srcdir) \
-	  && gtags -i $(GTAGS_ARGS) $$here
-distclean-tags:
-	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
-distdir: $(DISTFILES)
-	@srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; \
-	topsrcdirstrip=`echo "$(top_srcdir)" | sed 's|.|.|g'`; \
-	list='$(DISTFILES)'; for file in $$list; do \
-	  case $$file in \
-	    $(srcdir)/*) file=`echo "$$file" | sed "s|^$$srcdirstrip/||"`;; \
-	    $(top_srcdir)/*) file=`echo "$$file" | sed "s|^$$topsrcdirstrip/|$(top_builddir)/|"`;; \
-	  esac; \
-	  if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
-	  dir=`echo "$$file" | sed -e 's,/[^/]*$$,,'`; \
-	  if test "$$dir" != "$$file" && test "$$dir" != "."; then \
-	    dir="/$$dir"; \
-	    $(mkdir_p) "$(distdir)$$dir"; \
-	  else \
-	    dir=''; \
-	  fi; \
-	  if test -d $$d/$$file; then \
-	    if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
-	      cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \
-	    fi; \
-	    cp -pR $$d/$$file $(distdir)$$dir || exit 1; \
-	  else \
-	    test -f $(distdir)/$$file \
-	    || cp -p $$d/$$file $(distdir)/$$file \
-	    || exit 1; \
-	  fi; \
-	done
-check-am: all-am
-check: check-am
-all-am: Makefile $(PROGRAMS)
-installdirs:
-	for dir in "$(DESTDIR)$(bindir)"; do \
-	  test -z "$$dir" || $(mkdir_p) "$$dir"; \
-	done
-install: install-am
-install-exec: install-exec-am
-install-data: install-data-am
-uninstall: uninstall-am
-install-am: all-am
-	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
-installcheck: installcheck-am
-install-strip:
-	$(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
-	  install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
-	  `test -z '$(STRIP)' || \
-	    echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install
-mostlyclean-generic:
-clean-generic:
-distclean-generic:
-	-test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES)
-maintainer-clean-generic:
-	@echo "This command is intended for maintainers to use"
-	@echo "it deletes files that may require special tools to rebuild."
-clean: clean-am
-clean-am: clean-binPROGRAMS clean-generic clean-libtool mostlyclean-am
-distclean: distclean-am
-	-rm -rf ./$(DEPDIR)
-	-rm -f Makefile
-distclean-am: clean-am distclean-compile distclean-generic \
-	distclean-libtool distclean-tags
-dvi: dvi-am
-dvi-am:
-html: html-am
-info: info-am
-info-am:
-install-data-am:
-install-exec-am: install-binPROGRAMS
-install-info: install-info-am
-install-man:
-installcheck-am:
-maintainer-clean: maintainer-clean-am
-	-rm -f Makefile
-maintainer-clean-am: distclean-am maintainer-clean-generic
-mostlyclean: mostlyclean-am
-mostlyclean-am: mostlyclean-compile mostlyclean-generic \
-	mostlyclean-libtool
-pdf: pdf-am
-pdf-am:
-ps: ps-am
-ps-am:
-uninstall-am: uninstall-binPROGRAMS uninstall-info-am
-.PHONY: CTAGS GTAGS all all-am check check-am clean clean-binPROGRAMS \
-	clean-generic clean-libtool ctags distclean distclean-compile \
-	distclean-generic distclean-libtool distclean-tags distdir dvi \
-	dvi-am html html-am info info-am install install-am \
-	install-binPROGRAMS install-data install-data-am install-exec \
-	install-exec-am install-info install-info-am install-man \
-	install-strip installcheck installcheck-am installdirs \
-	maintainer-clean maintainer-clean-generic mostlyclean \
-	mostlyclean-compile mostlyclean-generic mostlyclean-libtool \
-	pdf pdf-am ps ps-am tags uninstall uninstall-am \
-	uninstall-binPROGRAMS uninstall-info-am
-# Tell versions [3.59,3.63) of GNU make to not export all variables.
-# Otherwise a system limit (for SysV at least) may be exceeded.
-.NOEXPORT:
