[MOAB-dev] r1724 - MOAB/trunk/test/obb
kraftche at mcs.anl.gov
Mon Mar 31 12:01:06 CDT 2008
Author: kraftche
Date: 2008-03-31 12:01:06 -0500 (Mon, 31 Mar 2008)
New Revision: 1724
Modified:
MOAB/trunk/test/obb/obb_tree_tool.cpp
Log:
fix bugs
Modified: MOAB/trunk/test/obb/obb_tree_tool.cpp
--- MOAB/trunk/test/obb/obb_tree_tool.cpp 2008-03-29 01:06:32 UTC (rev 1723)
+++ MOAB/trunk/test/obb/obb_tree_tool.cpp 2008-03-31 17:01:06 UTC (rev 1724)
@@ -21,8 +21,8 @@
const char* root_tag = TREE_TAG;
MBErrorCode get_root( MBInterface* moab, MBEntityHandle& root );
-void build_tree( MBInterface* interface,
- MBOrientedBoxTreeTool::Settings settings );
+MBEntityHandle build_tree( MBInterface* interface,
+ MBOrientedBoxTreeTool::Settings settings );
void delete_existing_tree( MBInterface* interface );
void print_stats( MBInterface* interface );
void tag_triangles( MBInterface* interface );
@@ -181,6 +181,7 @@
tag_time = clock() - stat_time;
std::cout << "Writing file... "; std::cout.flush();
rval = interface->write_mesh( output_file );
if (MB_SUCCESS != rval) {
@@ -245,7 +246,7 @@
if (MB_TYPE_HANDLE != type)
return MB_TAG_NOT_FOUND;
- return moab->tag_get_data( tag, 0, 1, &root );
+ return moab->tag_get_data( tag, 0, 0, &root );
@@ -263,7 +264,7 @@
-void build_tree( MBInterface* interface, MBOrientedBoxTreeTool::Settings settings )
+MBEntityHandle build_tree( MBInterface* interface, MBOrientedBoxTreeTool::Settings settings )
MBErrorCode rval;
MBEntityHandle root = 0;
@@ -281,6 +282,21 @@
std::cerr << "Tree construction failed." << std::endl;
exit(4);
+ // store tree root
+ MBTag roottag;
+ rval = interface->tag_create( root_tag, sizeof(MBEntityHandle), MB_TAG_SPARSE, MB_TYPE_HANDLE, roottag, 0, true );
+ if (MB_SUCCESS != rval) {
+ std::cout << "Failed to create root tag: \"" << root_tag << '"' << std::endl;
+ exit(2);
+ rval = interface->tag_set_data( roottag, 0, 0, &root );
+ std::cout << "Failed to set root tag: \"" << root_tag << '"' << std::endl;
+ exit(2);
+ return root;
std::string clock_to_string( clock_t t )
