[MOAB-dev] MOAB distcheck failed.
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Mon Mar 31 11:08:30 CDT 2008
Apologies for the noise on moab-dev.  "make distcheck" is working fine.
This message was a test to verify that the nightly test script is working
correctly.
Updates to nightly testing:
 - Fix valgrind error suppressions for 32-bit HDF5 library.  Corrects
   bogus claims that nightly test for x86 is failing.
 - Better 'From:' address for nightly test messages
 - Set "Reply-To:" to moab-dev for nightly test messages
 - Remove noise in logs from valgrind: use '--quiet' to print only errors
