[MOAB-dev] r1722 - MOAB/trunk/test/obb
    kraftche at mcs.anl.gov
    Fri Mar 28 18:11:46 CDT 2008
Author: kraftche
Date: 2008-03-28 18:11:46 -0500 (Fri, 28 Mar 2008)
New Revision: 1722
Added:
   MOAB/trunk/test/obb/obb_tree_tool.cpp
Modified:
   MOAB/trunk/test/obb/Makefile.am
Log:
add a tool to generate OBB tress for testing.  I thought I had one of these already, but couldn't find it.
Modified: MOAB/trunk/test/obb/Makefile.am
--- MOAB/trunk/test/obb/Makefile.am	2008-03-28 23:11:01 UTC (rev 1721)
+++ MOAB/trunk/test/obb/Makefile.am	2008-03-28 23:11:46 UTC (rev 1722)
@@ -1,4 +1,4 @@
-check_PROGRAMS = obb_test obb_time
+check_PROGRAMS = obb_test obb_time obb_tree_tool
 TESTS = obb_test
 DEFS = $(DEFINES)
@@ -7,3 +7,4 @@
 obb_test_SOURCES = obb_test.cpp
 obb_time_SOURCES = obb_time.cpp
+obb_tree_tool_SOURCES = obb_tree_tool.cpp
Added: MOAB/trunk/test/obb/obb_tree_tool.cpp
--- MOAB/trunk/test/obb/obb_tree_tool.cpp	                        (rev 0)
+++ MOAB/trunk/test/obb/obb_tree_tool.cpp	2008-03-28 23:11:46 UTC (rev 1722)
@@ -0,0 +1,545 @@
+#define IS_BUILDING_MB
+#include "MBCore.hpp"
+#include "MBCartVect.hpp"
+#include "MBOrientedBoxTreeTool.hpp"
+#include "MBOrientedBox.hpp"
+#include "MBInternals.hpp"
+#include <iostream>
+#include <iomanip>
+#include <stdlib.h>
+#include <time.h>
+#include <unistd.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+std::string clock_to_string( clock_t t );
+std::string mem_to_string( unsigned long mem );
+const int MAX_TAG_VALUE = 20;
+const char* const TAG_NAME = "OBB_ID";
+const char* const TREE_TAG = "OBB_ROOT";
+const char* root_tag = TREE_TAG;
+MBErrorCode get_root( MBInterface* moab, MBEntityHandle& root );
+void build_tree( MBInterface* interface,
+                 MBOrientedBoxTreeTool::Settings settings );
+void delete_existing_tree( MBInterface* interface );
+void print_stats( MBInterface* interface );
+void tag_triangles( MBInterface* interface );
+void tag_vertices( MBInterface* interface );
+void write_tree_blocks( MBInterface* interface, const char* file );
+static void usage( bool err = true )
+  std::ostream& s = err ? std::cerr : std::cout;
+  s << "obb_tree_tool [-s|-S] [-d <int>] [-n <int>] <input file> <output file>" << std::endl
+    << "obb_tree_tool [-h]" << std::endl;
+  if (!err) {
+    MBOrientedBoxTreeTool::Settings st;
+    s << "Tool to build adaptive kd-Tree from triangles" << std::endl;
+    s << "  -s        Use range-based sets for tree nodes" << std::endl
+      << "  -S        Use vector-based sets for tree nodes" << std::endl
+      << "  -d <int>  Specify maximum depth for tree. Default: " << st.max_depth << std::endl
+      << "  -n <int>  Specify maximum entities per leaf. Default: " << st.max_leaf_entities << std::endl
+      << "  -m <real> Specify worst split ratio. Default: " << st.worst_split_ratio << std::endl
+      << "  -M <real> Specify best split ratio. Default: " << st.best_split_ratio << std::endl
+      << "  -t        Tag triangles will tree cell number." << std::endl
+      << "  -T        Write tree boxes to file." << std::endl
+      << "  -N        Specify mesh tag containing tree root. Default: \"" << TREE_TAG << '"' << std::endl
+      << std::endl;
+  exit( err );
+static void memory_use( unsigned long& vsize, unsigned long& rss )
+  char buffer[512];
+  int filp = open( "/proc/self/stat", O_RDONLY );
+  ssize_t r = read( filp, buffer, sizeof(buffer)-1 );
+  close( filp );
+  if (r < 0) r = 0;
+  vsize = rss = 0;
+  buffer[r] = '\0';
+  sscanf( buffer, "%*d %*s %*c "         // pid command state
+                  "%*d %*d "             // ppid pgrp
+                  "%*d %*d %*d "         // session tty_nr tpgid
+                  "%*u "                // flags
+                  "%*u %*u %*u %*u " // minflt cminflt majflt cmajflt
+                  "%*u %*u %*d %*d " // utime stime cutime cstime
+                  "%*d %*d %*d "      // priority nice (unused)
+                  "%*d %*u "           // itrealval starttime
+                  "%lu %lu",             &vsize, &rss );
+  rss *= getpagesize();
+static int parseint( int& i, int argc, char* argv[] )
+  char* end;
+  ++i;
+  if (i == argc) {
+    std::cerr << "Expected value following '" << argv[i-1] << "'" << std::endl;
+    usage();
+  int result = strtol( argv[i], &end, 0 );
+  if (result < 0 || *end) {
+    std::cerr << "Expected positive integer following '" << argv[i-1] << "'" << std::endl;
+    usage();
+  return result;
+static double parsedouble( int& i, int argc, char* argv[] )
+  char* end;
+  ++i;
+  if (i == argc) {
+    usage();
+  double result = strtod( argv[i], &end );
+    std::cerr << "Expected positive real number following '" << argv[i-1] << "'" << std::endl;
+    usage();
+  return result;
+int main( int argc, char* argv[] )
+  const char* input_file = 0;
+  const char* output_file = 0;
+  const char* tree_file = 0;
+  MBOrientedBoxTreeTool::Settings settings;
+  bool tag_tris = false;
+  clock_t load_time, build_time, stat_time, tag_time, write_time, block_time;
+  for (int i = 1; i < argc; ++i) {
+    if (argv[i][0] != '-') {
+      if (!input_file)
+        input_file = argv[i];
+      else if (!output_file)
+        output_file = argv[i];
+      else
+        usage();
+      continue;
+    if (!argv[i][1] || argv[i][2])
+      usage();
+    switch (argv[i][1]) {
+      case 's': settings.set_options = MESHSET_SET;                        break;
+      case 'S': settings.set_options = MESHSET_ORDERED;                    break;
+      case 'd': settings.max_depth  = parseint( i, argc, argv );           break;
+      case 'n': settings.max_leaf_entities = parseint( i, argc, argv );    break;
+      case 'm': settings.worst_split_ratio = parsedouble( i, argc, argv ); break;
+      case 'M': settings.best_split_ratio = parsedouble( i, argc, argv );  break;
+      case 't': tag_tris = true;                                           break;
+      case 'T': if (++i == argc) usage(); tree_file = argv[i];             break;
+      case 'N': if (++i == argc) usage(); root_tag = argv[i];              break;
+      case 'h': usage(false);
+      default: usage();
+  if (!output_file)
+    usage();
+  MBErrorCode rval;
+  MBCore moab_core;
+  MBInterface* interface = &moab_core;
+  load_time = clock();
+  rval = interface->load_mesh( input_file );
+  if (MB_SUCCESS != rval) {
+    std::cerr << "Error reading file: " << input_file << std::endl;
+    exit(2);
+  load_time = clock() - load_time;
+  delete_existing_tree( interface );
+  std::cout << "Building tree..." << std::endl;
+  build_time = clock();
+  build_tree( interface, settings );
+  build_time = clock() - build_time;
+  std::cout << "Calculating stats..." << std::endl;
+  print_stats( interface );
+  stat_time = clock() - build_time;
+  if (tag_tris) {
+    std::cout << "Tagging tree..." << std::endl;
+    tag_triangles( interface );
+    tag_vertices( interface );
+  tag_time = clock() - stat_time;
+  std::cout << "Writing file... "; std::cout.flush();
+  rval = interface->write_mesh( output_file );
+    std::cerr << "Error writing file: " << output_file << std::endl;
+    exit(3);
+  write_time = clock() - tag_time;
+  std::cout << "Wrote " << output_file << std::endl;
+  if (tree_file) {
+    std::cout << "Writing tree block rep..."; std::cout.flush();
+    write_tree_blocks( interface, tree_file );
+    std::cout << "Wrote " << tree_file << std::endl;
+  block_time = clock() - write_time;
+  std::cout   << "Times:  "
+              << "    Load"
+              << "   Build"
+              << "   Stats"
+              << "   Write";
+  if (tag_tris)
+    std::cout << "Tag Sets";
+  if (tree_file)
+    std::cout << "Block   ";
+  std::cout   << std::endl;
+  std::cout   << "        "
+              << std::setw(8) << clock_to_string(load_time)
+              << std::setw(8) << clock_to_string(build_time)
+              << std::setw(8) << clock_to_string(stat_time)
+              << std::setw(8) << clock_to_string(write_time);
+  if (tag_tris)
+    std::cout << std::setw(8) << clock_to_string(tag_time);
+  if (tree_file)
+    std::cout << std::setw(8) << clock_to_string(block_time);
+  return 0;
+  MBTag tag;
+  MBErrorCode rval;
+  rval = moab->tag_get_handle( root_tag, tag );
+    return rval;
+  int size;
+  rval = moab->tag_get_size( tag, size );
+    return rval;
+  if (size != sizeof(MBEntityHandle))
+    return MB_TAG_NOT_FOUND;
+  MBDataType type;
+  rval = moab->tag_get_data_type( tag, type );
+    return rval;
+  if (MB_TYPE_HANDLE != type)
+  return moab->tag_get_data( tag, 0, 1, &root );
+  MBEntityHandle root;
+  MBErrorCode rval = get_root(interface, root);
+  if (MB_SUCCESS == rval) {
+    MBOrientedBoxTreeTool tool(interface);
+    rval = tool.delete_tree( root );
+      std::cerr << "Failed to destroy existing trees. Aborting" << std::endl;
+      exit( 5 );
+void build_tree( MBInterface* interface, MBOrientedBoxTreeTool::Settings settings )
+  MBErrorCode rval;
+  MBEntityHandle root = 0;
+  MBRange triangles;
+  rval = interface->get_entities_by_type( 0, MBTRI, triangles );
+  if (MB_SUCCESS != rval || triangles.empty()) {
+    std::cerr << "No triangles from which to build tree." << std::endl;
+    exit(4);
+  MBOrientedBoxTreeTool tool( interface );
+  rval = tool.build( triangles, root, &settings );
+  if (MB_SUCCESS != rval || !root) {
+    std::cerr << "Tree construction failed." << std::endl;
+    exit(4);
+  char unit[5] = "s";
+  char buffer[256];
+  double dt = t / (double)CLOCKS_PER_SEC;
+  //if (dt > 300) {
+  //  dt /= 60;
+  //  strcpy( unit, "min" );
+  //if (dt > 300) {
+  //  dt /= 60;
+  //  strcpy( unit, "hr" );
+  //if (dt > 100) {
+  //  dt /= 24;
+  //  strcpy( unit, "days" );
+  sprintf(buffer,"%0.2f%s",dt,unit);
+  return buffer;
+  char unit[3] = "B";
+  if (mem > 9*1024) {
+    mem = (mem + 512) / 1024;
+    strcpy( unit, "kB" );
+    strcpy( unit, "MB" );
+    strcpy( unit, "GB" );
+  char buffer[256];
+  sprintf(buffer, "%lu %s", mem, unit );
+  return buffer;
+template <typename T>
+struct SimpleStat
+  T min, max, sum, sqr;
+  size_t count;
+  SimpleStat();
+  void add( T value );
+  double avg() const { return (double)sum / count; }
+  double rms() const { return sqrt( (double)sqr / count ); }
+  double dev() const { return sqrt( (count * (double)sqr - (double)sum * (double)sum) / ((double)count * (count - 1) ) ); }
+template <typename T> SimpleStat<T>::SimpleStat()
+  : min(  std::numeric_limits<T>::max() ),
+    max(  std::numeric_limits<T>::min() ),
+    sum( 0 ), sqr( 0 ), count( 0 )
+  MBRange range;
+  get_root( interface, root );
+  MBRange tree_sets, triangles, verts;
+  //interface->get_child_meshsets( root, tree_sets, 0 );
+  interface->get_entities_by_type( 0, MBENTITYSET, tree_sets );
+  tree_sets.erase( tree_sets.begin(), MBRange::lower_bound( tree_sets.begin(), tree_sets.end(), root ) );
+  interface->get_entities_by_type( 0, MBTRI, triangles );
+  interface->get_entities_by_type( 0, MBVERTEX, verts );
+  triangles.merge( verts );
+  tree_sets.insert( root );
+  unsigned long set_used, set_amortized, set_store_used, set_store_amortized,
+                set_tag_used, set_tag_amortized, tri_used, tri_amortized;
+  interface->estimated_memory_use( tree_sets,
+                                   &set_used, &set_amortized,
+                                   &set_store_used, &set_store_amortized,
+                                   0, 0, 0, 0,
+                                   &set_tag_used, &set_tag_amortized );
+  interface->estimated_memory_use( triangles,  &tri_used, &tri_amortized );
+  int num_tri = 0;
+  interface->get_number_entities_by_type( 0, MBTRI, num_tri );
+  tool.stats( root, std::cout );
+  unsigned long real_rss, real_vsize;
+  memory_use( real_vsize, real_rss );
+  printf("------------------------------------------------------------------\n");
+  printf("\nmemory:           used  amortized\n");
+  printf("            ---------- ----------\n");
+  printf("triangles   %10s %10s\n",mem_to_string(tri_used).c_str(), mem_to_string(tri_amortized).c_str());
+  printf("sets (total)%10s %10s\n",mem_to_string(set_used).c_str(), mem_to_string(set_amortized).c_str());
+  printf("sets        %10s %10s\n",mem_to_string(set_store_used).c_str(), mem_to_string(set_store_amortized).c_str());
+  printf("set tags    %10s %10s\n",mem_to_string(set_tag_used).c_str(), mem_to_string(set_tag_amortized).c_str());
+  printf("total real  %10s %10s\n",mem_to_string(real_rss).c_str(), mem_to_string(real_vsize).c_str());
+static int hash_handle( MBEntityHandle handle )
+  MBEntityID h = ID_FROM_HANDLE(handle);
+  return (int)((h * 13 + 7) % MAX_TAG_VALUE) + 1;
+class TriTagger : public MBOrientedBoxTreeTool::Op
+private:
+  MBInterface* mMB;
+  MBTag mTag;
+  std::vector<MBEntityHandle> mHandles;
+  std::vector<int> mTagData;
+public:
+  TriTagger( MBTag tag, MBInterface* moab )
+    : mMB(moab), mTag(tag) {}
+  MBErrorCode visit( MBEntityHandle, int, bool& descent )
+    { descent = true; return MB_SUCCESS; }
+  MBErrorCode leaf( MBEntityHandle node ) {
+    mHandles.clear();
+    mMB->get_entities_by_handle( node, mHandles );
+    mTagData.clear();
+    mTagData.resize( mHandles.size(), hash_handle( node ) );
+    mMB->tag_set_data( mTag, &mHandles[0], mHandles.size(), &mTagData[0] );
+    return MB_SUCCESS;
+void tag_triangles( MBInterface* moab )
+  MBErrorCode rval = get_root( moab, root );
+    std::cerr << "Internal error: Failed to retreive tree." << std::endl;
+    exit(5);
+  MBTag tag;
+  int zero = 0;
+  moab->tag_create( TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER, tag, &zero, true );
+  TriTagger op( tag, moab );
+  MBOrientedBoxTreeTool tool(moab);
+  rval = tool.preorder_traverse( root, op );
+    std::cerr << "Internal error tagging triangles" << std::endl;
+    exit(5);
+class VtxTagger : public MBOrientedBoxTreeTool::Op
+private:
+  MBInterface* mMB;
+  MBTag mTag;
+  std::vector<MBEntityHandle> mConn;
+public:
+  VtxTagger( MBTag tag, MBInterface* moab )
+    mHandles.clear();
+    mConn.clear();
+    mMB->get_connectivity( &mHandles[0], mHandles.size(), mConn );
+    mTagData.clear();
+    mTagData.resize( mConn.size(), hash_handle( node ) );
+    mMB->tag_set_data( mTag, &mConn[0], mConn.size(), &mTagData[0] );
+void tag_vertices( MBInterface* moab )
+    exit(5);
+  MBTag tag;
+  int zero = 0;
+  VtxTagger op( tag, moab );
+    std::cerr << "Internal error tagging vertices" << std::endl;
+    exit(5);
+class LeafHexer : public MBOrientedBoxTreeTool::Op
+private:
+  MBOrientedBoxTreeTool* mTool;
+  MBInterface* mOut;
+  MBTag mTag;
+public:
+  LeafHexer( MBOrientedBoxTreeTool* tool, MBInterface* mb2, MBTag tag )
+    : mTool(tool), mOut( mb2 ), mTag(tag) {}
+    MBOrientedBox box;
+    MBErrorCode rval = mTool->box( node, box );
+    MBEntityHandle h;
+    rval = box.make_hex( h, mOut );
+    if (MB_SUCCESS !=rval) return rval;
+    int i = hash_handle( node );
+    return mOut->tag_set_data( mTag, &h, 1, &i );
+  MBErrorCode rval = get_root( interface, root );
+    exit(5);
+  MBCore moab2;
+  MBTag tag;
+  int zero = 0;
+  moab2.tag_create( TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER, tag, &zero, true );
+  LeafHexer op( &tool, &moab2, tag );
+    std::cerr << "Internal error: failed to construct leaf hexes" << std::endl;
+    exit(5);
+  moab2.write_mesh( file );
