[MOAB-dev] r1721 - MOAB/trunk
    kraftche at mcs.anl.gov
    Fri Mar 28 18:11:01 CDT 2008
Author: kraftche
Date: 2008-03-28 18:11:01 -0500 (Fri, 28 Mar 2008)
New Revision: 1721
Modified:
   MOAB/trunk/MBAdaptiveKDTree.cpp
   MOAB/trunk/kd_tree_tool.cpp
Log:
o Fix bug testing candidate split planes
o Greatly reduce size of calls to get_adjacencies when
  building trees using the VERTEX_SAMPLE algoritm
o Don't use get_adjacencies when calculating the bounding
  box of the tree
o Add options to kd_tree_tool
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp	2008-03-28 21:09:10 UTC (rev 1720)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp	2008-03-28 23:11:01 UTC (rev 1721)
@@ -744,8 +744,8 @@
         // loop with increasing tolerance until we intersect something
       double tol = std::numeric_limits<double>::epsilon();
       while (!lo && !ro) {
-        lo = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i), left_cen,tol*max_dim* left_dim );
-        ro = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i),right_cen,tol*max_dim*right_dim );
+        lo = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i), left_cen,tol*max_dim+ left_dim );
+        ro = MBGeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE(*i),right_cen,tol*max_dim+right_dim );
         tol *= 10.0;
         if (tol > 1e-3)
           return MB_FAILURE;
@@ -982,9 +982,10 @@
                                            MBRange& best_both,
                                            MBAdaptiveKDTree::Plane& best_plane,
                                            std::vector<double>& coords,
-                                           std::vector<size_t>& indices,
+                                           std::vector<MBEntityHandle>& indices,
                                            double eps )
+  const size_t random_elem_threshold = 20*num_planes;
   double metric_val = std::numeric_limits<unsigned>::max();
   MBErrorCode r;
@@ -995,10 +996,30 @@
   r = iter.tool()->moab()->get_entities_by_handle( iter.handle(), entities );
   if (MB_SUCCESS != r)
     return r;
+    // We are selecting random vertex coordinates to use for candidate split
+    // planes.  So if element list is large, begin by selecting random elements.
   const size_t p_count = entities.size();
-  r = iter.tool()->moab()->get_adjacencies( entities, 0, false, vertices, MBInterface::UNION );
-  if (MB_SUCCESS != r)
-    return r;
+  coords.resize( 3*num_planes );
+  if (p_count < random_elem_threshold) {
+    r = iter.tool()->moab()->get_adjacencies( entities, 0, false, vertices, MBInterface::UNION );
+    if (MB_SUCCESS != r)
+      return r;
+  else {
+    indices.resize(random_elem_threshold);
+    const int num_rand = p_count / RAND_MAX + 1;
+    for (size_t j = 0; j < random_elem_threshold; ++j) {
+      size_t rnd = rand();
+      for (int i = num_rand; i > 1; --i)
+        rnd *= rand();
+      rnd %= p_count;
+      indices[j] = entities[rnd];
+    r = iter.tool()->moab()->get_adjacencies( &indices[0], random_elem_threshold, 0, false, vertices, MBInterface::UNION );
+      return r;
   coords.resize( vertices.size() );
   for (int axis = 0; axis < 3; ++axis) {
@@ -1069,10 +1090,63 @@
   return MB_SUCCESS;
+static inline void box_accum( const MBCartVect& point,
+                              MBCartVect& bmin,
+                              MBCartVect& bmax )
+  for (unsigned j = 0; j < 3; ++j) {
+    if (point[j] < bmin[j])
+      bmin[j] = point[j];
+    if (point[j] > bmax[j])
+      bmax[j] = point[j];
+static MBErrorCode bounding_box( MBInterface* moab,
+                                 MBRange& elems,
+                                 MBCartVect& bmin,
+  MBErrorCode rval;
+  bmin = MBCartVect(HUGE_VAL);
+  bmax = MBCartVect(-HUGE_VAL);
+  MBCartVect coords;
+  MBEntityHandle const *conn, *conn2;
+  int len, len2;
+  for (MBRange::const_iterator i = elems.begin(); i != elems.end(); ++i) {
+    rval = moab->get_connectivity( *i, conn, len, true );
+    if (MB_SUCCESS != rval)
+      return rval;
+    if (TYPE_FROM_HANDLE(*i) != MBPOLYHEDRON) {
+      for (int j = 0; j < len; ++j) {
+        rval = moab->get_coords( conn+j, 1, coords.array() );
+          return rval;
+        box_accum( coords, bmin, bmax );
+    else {
+        rval = moab->get_connectivity( conn[j], conn2, len2 );
+        for (int k = 0; k < len2; ++k) {
+          rval = moab->get_coords( conn2+k, 1, coords.array() );
+            return rval;
+  return MB_SUCCESS;
 MBErrorCode MBAdaptiveKDTree::build_tree( MBRange& elems,
                                        MBEntityHandle& root_set_out,
                                        const Settings* settings_ptr )
+  MBErrorCode rval;
   Settings settings;
   if (settings_ptr)
     settings = *settings_ptr;
@@ -1084,27 +1158,11 @@
     settings.candidateSplitsPerDir = 1;
     // calculate bounding box of elements
-  std::vector<double> tmp_data;
-  std::vector<size_t> tmp_data2;
-  MBRange vertices;
-  MBErrorCode rval = moab()->get_adjacencies( elems, 0, false, vertices, MBInterface::UNION );
+  MBCartVect bmin, bmax;
+  rval = bounding_box( moab(), elems, bmin, bmax );
     return rval;
-  MBCartVect bmin(HUGE_VAL), bmax(-HUGE_VAL), coords;
-  for (MBRange::iterator i = vertices.begin(); i != vertices.end(); ++i) {
-    rval = moab()->get_coords( &*i, 1, coords.array() );
-    if (MB_SUCCESS != rval)
-      return rval;
-    for (unsigned j = 0; j < 3; ++j) {
-      if (coords[j] < bmin[j])
-        bmin[j] = coords[j];
-      if (coords[j] > bmax[j])
-        bmax[j] = coords[j];
     // create tree root
   rval = create_tree( bmin.array(), bmax.array(), root_set_out );
@@ -1116,6 +1174,8 @@
   MBAdaptiveKDTreeIter iter;
   iter.initialize( this, root_set_out, bmin.array(), bmax.array(), MBAdaptiveKDTreeIter::LEFT );
+  std::vector<double> tmp_data;
+  std::vector<MBEntityHandle> tmp_data2;
   for (;;) {
     int pcount;
Modified: MOAB/trunk/kd_tree_tool.cpp
--- MOAB/trunk/kd_tree_tool.cpp	2008-03-28 21:09:10 UTC (rev 1720)
+++ MOAB/trunk/kd_tree_tool.cpp	2008-03-28 23:11:01 UTC (rev 1721)
@@ -30,10 +30,18 @@
 void tag_vertices( MBInterface* interface );
 void write_tree_blocks( MBInterface* interface, const char* file );
+static const char* ds( MBAdaptiveKDTree::CandidatePlaneSet scheme )
+  static const char def[] = " (default)";
+  const static char non[] = "";
+  MBAdaptiveKDTree::Settings st;
+  return scheme == st.candidatePlaneSet ? def : non;
 static void usage( bool err = true )
   std::ostream& s = err ? std::cerr : std::cout;
-  s << "kd_tree_tool [-s|-S] [-d <int>] [-n <int>] <input file> <output file>" << std::endl
+  s << "kd_tree_tool [-s|-S] [-d <int>] [-n <int>] [-u|-p|-m|-v] [-N <int>] <input file> <output file>" << std::endl
     << "kd_tree_tool [-s|-S] [-d <int>] -G <dims> <output file>" << std::endl
     << "kd_tree_tool [-h]" << std::endl;
   if (!err) {
@@ -43,6 +51,11 @@
       << "  -S        Use vector-based sets for tree nodes" << std::endl
       << "  -d <int>  Specify maximum depth for tree. Default: " << st.maxTreeDepth << std::endl
       << "  -n <int>  Specify maximum entities per leaf. Default: " << st.maxEntPerLeaf << std::endl
+      << "  -u        Use 'SUBDIVISION' scheme for tree construction" << ds(MBAdaptiveKDTree::SUBDIVISION) << std::endl
+      << "  -p        Use 'SUBDIVISION_SNAP' tree construction algorithm." << ds(MBAdaptiveKDTree::SUBDIVISION_SNAP) << std::endl
+      << "  -m        Use 'VERTEX_MEDIAN' tree construction algorithm." << ds(MBAdaptiveKDTree::VERTEX_MEDIAN) << std::endl
+      << "  -v        Use 'VERTEX_SAMPLE' tree construction algorithm." << ds(MBAdaptiveKDTree::VERTEX_SAMPLE) << std::endl
+      << "  -N <int>  Specify candidate split planes per axis.  Default: " << st.candidateSplitsPerDir << std::endl
       << "  -t        Tag triangles will tree cell number." << std::endl
       << "  -T        Write tree boxes to file." << std::endl
       << "  -G <dims> Generate grid - no input triangles.  Dims must be " << std::endl
@@ -160,6 +173,11 @@
       case 'S': meshset_flags = MESHSET_ORDERED;                    break;
       case 'd': settings.maxTreeDepth  = parseint( i, argc, argv ); break;
       case 'n': settings.maxEntPerLeaf = parseint( i, argc, argv ); break;
+      case 'u': settings.candidatePlaneSet = MBAdaptiveKDTree::SUBDIVISION;      break;
+      case 'p': settings.candidatePlaneSet = MBAdaptiveKDTree::SUBDIVISION_SNAP; break;
+      case 'm': settings.candidatePlaneSet = MBAdaptiveKDTree::VERTEX_MEDIAN;    break;
+      case 'v': settings.candidatePlaneSet = MBAdaptiveKDTree::VERTEX_SAMPLE;    break;
+      case 'N': settings.candidateSplitsPerDir = parseint( i, argc, argv );      break;
       case 't': tag_tris = true;                                    break;
       case 'T': tree_file = argv[++i];                              break;
       case 'G': make_grid = true; parsedims( i, argc, argv, dims ); break;
