[MOAB-dev] r1716 - in MOAB/trunk: . tools/mbzoltan
tautges at mcs.anl.gov
Fri Mar 28 11:42:32 CDT 2008
Author: tautges
Date: 2008-03-28 11:42:32 -0500 (Fri, 28 Mar 2008)
New Revision: 1716
Modified:
MOAB/trunk/mbparallelcomm_test.cpp
MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
MOAB/trunk/tools/mbzoltan/main.cpp
Log:
Adding capability to track remote handles on sharing processors for
shared entities.
MBParallelComm:
- added lots more packing/unpacking debug output to help match
packing/unpacking calls
- enhanced to handle communicating/storing remote handle data (option
to the communicate_entities function now)
- added functions for getting remote/local handles given local/remote
handles
- updating mbzoltan for recent parallel changes
- added 4th option to mbparallelcomm_test for testing
packing/unpacking, and added more debug output
Modified: MOAB/trunk/mbparallelcomm_test.cpp
--- MOAB/trunk/mbparallelcomm_test.cpp 2008-03-28 16:42:01 UTC (rev 1715)
+++ MOAB/trunk/mbparallelcomm_test.cpp 2008-03-28 16:42:32 UTC (rev 1716)
@@ -13,6 +13,7 @@
#include "ScdVertexData.hpp"
#include "StructuredElementSeq.hpp"
#include "SequenceManager.hpp"
+#include "MBError.hpp"
#include "mpi.h"
#include <iostream>
#include <sstream>
@@ -20,7 +21,7 @@
#define REALTFI 1
-const bool debug = true;
+const bool debug = false;
#define ERROR(a, b) {std::cerr << a << std::endl; return b;}
@@ -30,6 +31,12 @@
if (last_error.empty()) std::cerr << "(none)" << std::endl;\
else std::cerr << last_error << std::endl;\
+#define RRA(a) if (MB_SUCCESS != result) {\
+ std::string tmp_str; mbImpl->get_last_error(tmp_str);\
+ tmp_str.append("\n"); tmp_str.append(a);\
+ dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(tmp_str.c_str()); \
+ return result;}
MBErrorCode create_linear_mesh(MBInterface *mbImpl,
int N, int M, int &nshared);
@@ -40,6 +47,8 @@
const char *tag_name, int tag_val, int distrib,
int parallel_option);
+MBErrorCode test_packing(MBInterface *mbImpl, const char *filename);
MBErrorCode report_nsets(MBInterface *mbImpl);
int main(int argc, char **argv)
@@ -141,6 +150,17 @@
nshared = -1;
break;
+ case 4:
+ filename = argv[npos++];
+ tmp_result = test_packing(mbImpl, filename);
+ if (MB_SUCCESS != tmp_result) {
+ result = tmp_result;
+ std::cerr << "Packing test failed; error message:" << std::endl;
+ PRINT_LAST_ERROR
+ break;
default:
std::cerr << "Unrecognized option \"" << this_opt
<< "\"; skipping." << std::endl;
@@ -149,7 +169,7 @@
if (0 == rank) rtime = MPI_Wtime();
- if (MB_SUCCESS == tmp_result) {
+ if (MB_SUCCESS == tmp_result && 4 != this_opt) {
// now figure out which vertices are shared
MBParallelComm *pcomm = new MBParallelComm(mbImpl);
tmp_result = pcomm->resolve_shared_ents();
@@ -266,20 +286,42 @@
std::vector<int> ids( b .size());\
result = mbImpl->tag_get_data(gidtag, b, &ids[0]); \
if (MB_SUCCESS == result) {\
- std::cout << "Proc " << rank << ": " << c << ids[0]; \
+ std::cout << "Proc " << rank << ": " << c \
+ << " (total " << b.size() << "): " \
+ << ids[0]; \
for (unsigned int i = 1; i < b .size(); i++) \
std::cout << ", " << ids[i]; \
std::cout << std::endl; \
- PRINTSETS(mtag, matsets, "material sets: ", NULL);
+ PRINTSETS(mtag, matsets, "material sets", NULL);
int tval = 3;
void *pval = &tval;
- PRINTSETS(gtag, geomsets, "geom sets: ", &pval);
+ PRINTSETS(gtag, geomsets, "geom sets (vols)", &pval);
+ tval = 2;
+ geomsets.clear();
+ PRINTSETS(gtag, geomsets, "geom sets (surfs)", &pval);
+ tval = 1;
+ geomsets.clear();
+ PRINTSETS(gtag, geomsets, "geom sets (curves)", &pval);
+ tval = 0;
+ geomsets.clear();
+ PRINTSETS(gtag, geomsets, "geom sets (verts)", &pval);
- PRINTSETS(ptag, parsets, "partition sets: ", NULL);
+ PRINTSETS(ptag, parsets, "partition sets", NULL);
+ if (debug) {
+ // list info on all ent sets, reuse parsets
+ parsets.clear();
+ result = mbImpl->get_entities_by_type(0, MBENTITYSET, parsets);
+ if (MB_SUCCESS == result) {
+ std::cout << "Total sets (by range): " << parsets.size() << "; sets: " << std::endl;
+ parsets.print(" ");
+ mbImpl->list_entities(parsets);
return MB_SUCCESS;
@@ -662,3 +704,36 @@
+ // read the mesh
+ MBEntityHandle file_set;
+ MBErrorCode result = mbImpl->load_file(filename, file_set, NULL);
+ if (MB_SUCCESS != result) {
+ std::cerr << "Reading file failed; message:" << std::endl;
+ PRINT_LAST_ERROR;
+ return result;
+ // get 3d entities and pack a buffer with them
+ MBRange ents, new_ents, whole_range;
+ result = mbImpl->get_entities_by_dimension(0, 3, ents);
+ RRA("Getting 3d ents failed.");
+ MBParallelComm *pcomm = new MBParallelComm(mbImpl);
+ int buff_size;
+ result = pcomm->pack_buffer(ents, false, true, true, false, -1,
+ whole_range, buff_size);
+ RRA("Packing buffer count (non-stored handles) failed.");
+ pcomm->buffer_size(buff_size);
+ result = pcomm->pack_buffer(ents, false, true, false, false, -1,
+ RRA("Packing buffer (non-stored handles) failed.");
+ result = pcomm->unpack_buffer(new_ents, false, -1);
+ RRA("Unacking buffer (non-stored handles) failed.");
+ return MB_SUCCESS;
Modified: MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
--- MOAB/trunk/tools/mbzoltan/MBZoltan.cpp 2008-03-28 16:42:01 UTC (rev 1715)
+++ MOAB/trunk/tools/mbzoltan/MBZoltan.cpp 2008-03-28 16:42:32 UTC (rev 1716)
@@ -30,7 +30,7 @@
#include "MBRange.hpp"
#include "MBWriteUtilIface.hpp"
#include "MeshTopoUtil.hpp"
-#include "MBParallelComm.hpp"
+#include "parallel/MBParallelComm.hpp"
#include "MBTagConventions.hpp"
#include "MBCN.hpp"
@@ -58,7 +58,7 @@
!strcmp(zmethod, "PHG") && !strcmp(zmethod, "PARMETIS") &&
!strcmp(zmethod, "OCTPART"))
- std::cout << "ERROR node " << mbImpl->proc_config().rank() << ": Method must be "
+ std::cout << "ERROR node " << mbImpl->proc_rank() << ": Method must be "
<< "RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART"
<< std::endl;
return MB_FAILURE;
@@ -73,7 +73,7 @@
MBErrorCode result;
- if (mbImpl->proc_config().rank() == 0) {
+ if (mbImpl->proc_rank() == 0) {
result = assemble_graph(3, pts, ids, adjs, length, elems); RR;
@@ -161,8 +161,8 @@
mbFinalizePoints((int)ids.size(), numExport, exportLocalIds,
exportProcs, &assignment);
- MBErrorCode result = write_partition(mbImpl->proc_config().size(), elems, assignment);
+ MBErrorCode result = write_partition(mbImpl->proc_size(), elems, assignment);
if (MB_SUCCESS != result) return result;
@@ -193,14 +193,14 @@
const char *other_method)
// should only be called in serial
- if (mbImpl->proc_config().size() != 1) return MB_FAILURE;
+ if (mbImpl->proc_size() != 1) return MB_FAILURE;
if (NULL != zmethod && strcmp(zmethod, "RCB") && strcmp(zmethod, "RIB") &&
strcmp(zmethod, "HSFC") && strcmp(zmethod, "Hypergraph") &&
strcmp(zmethod, "PHG") && strcmp(zmethod, "PARMETIS") &&
<< std::endl;
return MB_FAILURE;
@@ -317,8 +317,8 @@
if (MB_SUCCESS != result || elems.empty()) return result;
// assign global ids
- MBParallelComm mbpc(mbImpl, NULL, NULL);
- result = mbpc.assign_global_ids(dimension, 1); RR;
+ MBParallelComm mbpc(mbImpl);
+ result = mbpc.assign_global_ids(0, dimension); RR;
// now assemble the graph, calling MeshTopoUtil to get bridge adjacencies through d-1 dimensional
// neighbors
@@ -449,7 +449,7 @@
void MBZoltan::SetRCB_Parameters()
- if (mbImpl->proc_config().rank() == 0) std::cout << "\nRecursive Coordinate Bisection" << std::endl;
+ if (mbImpl->proc_rank() == 0) std::cout << "\nRecursive Coordinate Bisection" << std::endl;
// General parameters:
myZZ->Set_Param("DEBUG_LEVEL", "0"); // no debug messages
@@ -464,7 +464,7 @@
void MBZoltan::SetRIB_Parameters()
- if (mbImpl->proc_config().rank() == 0) std::cout << "\nRecursive Inertial Bisection" << std::endl;
+ if (mbImpl->proc_rank() == 0) std::cout << "\nRecursive Inertial Bisection" << std::endl;
@@ -478,7 +478,7 @@
void MBZoltan::SetHSFC_Parameters()
- if (mbImpl->proc_config().rank() == 0) std::cout << "\nHilbert Space Filling Curve" << std::endl;
+ if (mbImpl->proc_rank() == 0) std::cout << "\nHilbert Space Filling Curve" << std::endl;
@@ -491,7 +491,7 @@
void MBZoltan::SetHypergraph_Parameters(const char *phg_method)
- if (mbImpl->proc_config().rank() == 0) std::cout << "\nHypergraph (or PHG): " << std::endl;
+ if (mbImpl->proc_rank() == 0) std::cout << "\nHypergraph (or PHG): " << std::endl;
@@ -503,7 +503,7 @@
void MBZoltan::SetPARMETIS_Parameters(const char *parmetis_method)
- if (mbImpl->proc_config().rank() == 0) std::cout << "\nPARMETIS: " << parmetis_method << std::endl;
+ if (mbImpl->proc_rank() == 0) std::cout << "\nPARMETIS: " << parmetis_method << std::endl;
@@ -516,7 +516,7 @@
void MBZoltan::SetOCTPART_Parameters(const char *oct_method)
- if (mbImpl->proc_config().rank() == 0) std::cout << "\nOctree Partitioning: " << oct_method
+ if (mbImpl->proc_rank() == 0) std::cout << "\nOctree Partitioning: " << oct_method
<< std::endl;
@@ -543,23 +543,23 @@
int *sendNborId;
int *sendProcs;
/* divide pts to start */
- numPts = (int *)malloc(sizeof(int) * mbImpl->proc_config().size());
- ptsPerProc = npts / mbImpl->proc_config().size();
+ numPts = (int *)malloc(sizeof(int) * mbImpl->proc_size());
+ ptsPerProc = npts / mbImpl->proc_size();
ptsAssigned = 0;
- for (i=0; i<mbImpl->proc_config().size()-1; i++)
+ for (i=0; i<mbImpl->proc_size()-1; i++)
numPts[i] = ptsPerProc;
ptsAssigned += ptsPerProc;
- numPts[mbImpl->proc_config().size()-1] = npts - ptsAssigned;
+ numPts[mbImpl->proc_size()-1] = npts - ptsAssigned;
- mySize = numPts[mbImpl->proc_config().rank()];
+ mySize = numPts[mbImpl->proc_rank()];
sendPts = pts + (3 * numPts[0]);
sendIds = ids + numPts[0];
sendEdges = length + numPts[0];
@@ -576,14 +576,14 @@
nborProcs = (int *)malloc(sizeof(int) * sum);
for (j=0; j<sum; j++)
- if ((i = adjs[j]/ptsPerProc) < mbImpl->proc_config().size())
+ if ((i = adjs[j]/ptsPerProc) < mbImpl->proc_size())
nborProcs[j] = i;
else
- nborProcs[j] = mbImpl->proc_config().size() - 1;
+ nborProcs[j] = mbImpl->proc_size() - 1;
sendProcs = nborProcs + (sendNborId - adjs);
- for (i=1; i<mbImpl->proc_config().size(); i++)
+ for (i=1; i<mbImpl->proc_size(); i++)
MPI_Send(&numPts[i], 1, MPI_INT, i, 0x00,MPI_COMM_WORLD);
MPI_Send(sendPts, 3 * numPts[i], MPI_DOUBLE, i, 0x01,MPI_COMM_WORLD);
@@ -647,24 +647,24 @@
/* assign pts to start */
MyAssignment = (int *)malloc(sizeof(int) * npts);
else
MyAssignment = (int *)malloc(sizeof(int) * NumPoints);
for (i=0; i<NumPoints; i++)
- MyAssignment[i] = mbImpl->proc_config().rank();
+ MyAssignment[i] = mbImpl->proc_rank();
for (i=0; i<numExport; i++)
MyAssignment[exportLocalIDs[i]] = exportProcs[i];
/* collect pts */
recvA = MyAssignment + NumPoints;
- for (i=1; i< (int) mbImpl->proc_config().size(); i++)
+ for (i=1; i< (int) mbImpl->proc_size(); i++)
MPI_Recv(&numPts, 1, MPI_INT, i, 0x04, MPI_COMM_WORLD, &stat);
MPI_Recv(recvA, numPts, MPI_INT, i, 0x05, MPI_COMM_WORLD, &stat);
@@ -685,13 +685,13 @@
int fail = 0;
unsigned int i;
- int *vals = (int *)malloc(mbImpl->proc_config().size() * sizeof(int));
+ int *vals = (int *)malloc(mbImpl->proc_size() * sizeof(int));
MPI_Allgather(&rc, 1, MPI_INT, vals, 1, MPI_INT, MPI_COMM_WORLD);
- for (i=0; i<mbImpl->proc_config().size(); i++){
+ for (i=0; i<mbImpl->proc_size(); i++){
if (vals[i] != ZOLTAN_OK){
- if (0 == mbImpl->proc_config().rank()){
+ if (0 == mbImpl->proc_rank()){
mbShowError(vals[i], "Result on process ");
fail = 1;
@@ -715,15 +715,15 @@
v1[2] = exp;
v1[3] = change;
- if (mbImpl->proc_config().rank() == 0){
- v2 = (int *)malloc(4 * mbImpl->proc_config().size() * sizeof(int));
+ if (mbImpl->proc_rank() == 0){
+ v2 = (int *)malloc(4 * mbImpl->proc_size() * sizeof(int));
MPI_Gather(v1, 4, MPI_INT, v2, 4, MPI_INT, 0, MPI_COMM_WORLD);
fprintf(stdout,"======%s======\n",s);
- for (i=0, v=v2; i<mbImpl->proc_config().size(); i++, v+=4){
+ for (i=0, v=v2; i<mbImpl->proc_size(); i++, v+=4){
fprintf(stdout,"%d: originally had %d, import %d, exp %d, %s\n",
i, v[0], v[1], v[2],
v[3] ? "a change of partitioning" : "no change");
@@ -746,19 +746,19 @@
switch (val)
case ZOLTAN_OK:
- printf("%d: SUCCESSFUL\n", mbImpl->proc_config().rank());
+ printf("%d: SUCCESSFUL\n", mbImpl->proc_rank());
break;
case ZOLTAN_WARN:
- printf("%d: WARNING\n", mbImpl->proc_config().rank());
+ printf("%d: WARNING\n", mbImpl->proc_rank());
break;
case ZOLTAN_FATAL:
- printf("%d: FATAL ERROR\n", mbImpl->proc_config().rank());
+ printf("%d: FATAL ERROR\n", mbImpl->proc_rank());
break;
case ZOLTAN_MEMERR:
- printf("%d: MEMORY ALLOCATION ERROR\n", mbImpl->proc_config().rank());
+ printf("%d: MEMORY ALLOCATION ERROR\n", mbImpl->proc_rank());
break;
default:
- printf("%d: INVALID RETURN CODE\n", mbImpl->proc_config().rank());
+ printf("%d: INVALID RETURN CODE\n", mbImpl->proc_rank());
break;
return;
Modified: MOAB/trunk/tools/mbzoltan/main.cpp
--- MOAB/trunk/tools/mbzoltan/main.cpp 2008-03-28 16:42:01 UTC (rev 1715)
+++ MOAB/trunk/tools/mbzoltan/main.cpp 2008-03-28 16:42:32 UTC (rev 1716)
@@ -37,7 +37,16 @@
return 1;
- MBInterface *mbImpl = new MBCore();
+ // need to init MPI first, to tell how many procs and rank
+ int err = MPI_Init(&argc, &argv);
+ int nprocs, rank;
+ err = MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+ err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+ // create MOAB instance based on that
+ MBInterface *mbImpl = new MBCore(rank, nprocs);
+ if (NULL == mbImpl) return 1;
MBErrorCode result = mbImpl->load_mesh(argv[2]); RR;
