[MOAB-dev] r1715 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Fri Mar 28 11:42:01 CDT 2008
Author: tautges
Date: 2008-03-28 11:42:01 -0500 (Fri, 28 Mar 2008)
New Revision: 1715
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
MOAB/trunk/parallel/ReadParallel.cpp
Log:
Adding capability to track remote handles on sharing processors for
shared entities.
MBParallelComm:
- added lots more packing/unpacking debug output to help match
packing/unpacking calls
- enhanced to handle communicating/storing remote handle data (option
to the communicate_entities function now)
- added functions for getting remote/local handles given local/remote
handles
- updating mbzoltan for recent parallel changes
- added 4th option to mbparallelcomm_test for testing
packing/unpacking, and added more debug output
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-03-28 14:14:17 UTC (rev 1714)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-03-28 16:42:01 UTC (rev 1715)
@@ -20,6 +20,7 @@
#define MIN(a,b) (a < b ? a : b)
const bool debug = false;
+const bool debug_packing = false;
#include <math.h>
#include <assert.h>
@@ -41,37 +42,61 @@
unsigned char MBParallelComm::PROC_SHARED = 0x1;
unsigned char MBParallelComm::PROC_OWNER = 0x2;
+// #define DEBUG_PACKING 1
+#ifdef DEBUG_PACKING
+unsigned int __PACK_num = 0, __UNPACK_num = 0, __PACK_count = 0, __UNPACK_count = 0;
+std::string __PACK_string, __UNPACK_string;
+#define PC(n, m) {\
+ if (__PACK_num == (unsigned int)n && __PACK_string == m) __PACK_count++;\
+ else {\
+ if (__PACK_count > 1) std::cerr << " (" << __PACK_count << "x)";\
+ __PACK_count = 1; __PACK_string = m; __PACK_num = n;\
+ std::cerr << std::endl << "PACK: " << n << m;\
+#define UPC(n, m) {\
+ if (__UNPACK_num == (unsigned int)n && __UNPACK_string == m) __UNPACK_count++;\
+ else {\
+ if (__UNPACK_count > 1) std::cerr << "(" << __UNPACK_count << "x)";\
+ __UNPACK_count = 1; __UNPACK_string = m; __UNPACK_num = n;\
+ std::cerr << std::endl << "UNPACK: " << n << m;\
+#else
+#define PC(n, m)
+#define UPC(n, m)
+#endif
#define PACK_INT(buff, int_val) {int tmp_val = int_val; PACK_INTS(buff, &tmp_val, 1);}
-#define PACK_INTS(buff, int_val, num) {memcpy(buff, int_val, num*sizeof(int)); buff += num*sizeof(int);}
+#define PACK_INTS(buff, int_val, num) {memcpy(buff, int_val, (num)*sizeof(int)); buff += (num)*sizeof(int); PC(num, " ints");}
-#define PACK_DBL(buff, dbl_val, num) {memcpy(buff, dbl_val, num*sizeof(double)); buff += num*sizeof(double);}
+#define PACK_DBL(buff, dbl_val, num) {memcpy(buff, dbl_val, (num)*sizeof(double)); buff += (num)*sizeof(double); PC(num, " doubles");}
-#define PACK_EH(buff, eh_val, num) {memcpy(buff, eh_val, num*sizeof(MBEntityHandle)); buff += num*sizeof(MBEntityHandle);}
+#define PACK_EH(buff, eh_val, num) {memcpy(buff, eh_val, (num)*sizeof(MBEntityHandle)); buff += (num)*sizeof(MBEntityHandle); PC(num, " handles");}
-#define PACK_CHAR_64(buff, char_val) {strcpy((char*)buff, char_val); buff += 64;}
+#define PACK_CHAR_64(buff, char_val) {strcpy((char*)buff, char_val); buff += 64; PC(64, " chars");}
-#define PACK_VOID(buff, val, num) {memcpy(buff, val, num); buff += num;}
+#define PACK_VOID(buff, val, num) {memcpy(buff, val, num); buff += num; PC(num, " void");}
-#define PACK_RANGE(buff, rng) {int num_subs = num_subranges(rng); PACK_INTS(buff, &num_subs, 1); \
+#define PACK_RANGE(buff, rng) {int num_subs = num_subranges(rng); PACK_INTS(buff, &num_subs, 1); PC(num_subs, "-subranged range"); \
for (MBRange::const_pair_iterator cit = rng.const_pair_begin(); cit != rng.const_pair_end(); cit++) { \
- MBEntityHandle eh = (*cit).first; PACK_EH(buff_ptr, &eh, 1); \
- eh = (*cit).second; PACK_EH(buff_ptr, &eh, 1);}}
+ MBEntityHandle eh = (*cit).first; PACK_EH(buff, &eh, 1); \
+ eh = (*cit).second; PACK_EH(buff, &eh, 1);}; }
#define UNPACK_INT(buff, int_val) {UNPACK_INTS(buff, &int_val, 1);}
-#define UNPACK_INTS(buff, int_val, num) {memcpy(int_val, buff, num*sizeof(int)); buff += num*sizeof(int);}
+#define UNPACK_INTS(buff, int_val, num) {memcpy(int_val, buff, (num)*sizeof(int)); buff += (num)*sizeof(int); UPC(num, " ints");}
-#define UNPACK_DBL(buff, dbl_val, num) {memcpy(dbl_val, buff, num*sizeof(double)); buff += num*sizeof(double);}
+#define UNPACK_DBL(buff, dbl_val, num) {memcpy(dbl_val, buff, (num)*sizeof(double)); buff += (num)*sizeof(double); UPC(num, " doubles");}
-#define UNPACK_EH(buff, eh_val, num) {memcpy(eh_val, buff, num*sizeof(MBEntityHandle)); buff += num*sizeof(MBEntityHandle);}
+#define UNPACK_EH(buff, eh_val, num) {memcpy(eh_val, buff, (num)*sizeof(MBEntityHandle)); buff += (num)*sizeof(MBEntityHandle); UPC(num, " handles");}
-#define UNPACK_CHAR_64(buff, char_val) {strcpy(char_val, (char*)buff); buff += 64;}
+#define UNPACK_CHAR_64(buff, char_val) {strcpy(char_val, (char*)buff); buff += 64; UPC(64, " chars");}
-#define UNPACK_VOID(buff, val, num) {memcpy(val, buff, num); buff += num;}
+#define UNPACK_VOID(buff, val, num) {memcpy(val, buff, num); buff += num; UPC(num, " void");}
-#define UNPACK_RANGE(buff, rng) {int num_subs; UNPACK_INTS(buff, &num_subs, 1); MBEntityHandle _eh[2]; \
- for (int i = 0; i < num_subs; i++) { UNPACK_EH(buff_ptr, _eh, 2); rng.insert(_eh[0], _eh[1]);}}
+#define UNPACK_RANGE(buff, rng) {int num_subs; UNPACK_INTS(buff, &num_subs, 1); UPC(num_subs, "-subranged range"); MBEntityHandle _eh[2]; \
+ for (int i = 0; i < num_subs; i++) { UNPACK_EH(buff, _eh, 2); rng.insert(_eh[0], _eh[1]);}}
#define RR(a) if (MB_SUCCESS != result) {\
dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(a);\
@@ -172,15 +197,19 @@
return MB_SUCCESS;
-MBErrorCode MBParallelComm::communicate_entities(const int from_proc, const int to_proc,
+MBErrorCode MBParallelComm::communicate_entities(const int from_proc,
+ const int to_proc,
MBRange &entities,
const bool adjacencies,
- const bool tags)
+ const bool tags,
+ const bool store_remote_handles)
#ifndef USE_MPI
return MB_FAILURE;
#else
+// xxx - a. flag to include originating handle;
+// b. flag to indicate whether to delete locally afterwards
MBErrorCode result = MB_SUCCESS;
// if I'm the from, do the packing and sending
@@ -198,8 +227,9 @@
int buff_size;
- result = pack_buffer(entities, adjacencies, tags, true,
- whole_range, buff_size);
+ MBErrorCode result = pack_buffer(entities, adjacencies, tags, true,
+ store_remote_handles, to_proc,
+ whole_range, buff_size);
RRA("Failed to compute buffer size in communicate_entities.");
// if the message is large, send a first message to tell how large
@@ -216,7 +246,8 @@
// pack the actual buffer
int actual_buff_size;
- result = pack_buffer(entities, adjacencies, tags, false,
+ result = pack_buffer(whole_range, adjacencies, tags, false,
whole_range, actual_buff_size);
RRA("Failed to pack buffer in communicate_entities.");
@@ -225,6 +256,21 @@
int success = MPI_Isend(&myBuffer[0], actual_buff_size, MPI_UNSIGNED_CHAR, to_proc,
0, procConfig.proc_comm(), &send_req);
if (!success) return MB_FAILURE;
+ // now receive back remote range, if requested
+ if (store_remote_handles) {
+ MPI_Status status;
+ success = MPI_Recv(&myBuffer[0], myBuffer.size(), MPI_UNSIGNED_CHAR, to_proc,
+ MPI_ANY_TAG, procConfig.proc_comm(), &status);
+ if (!success) return MB_FAILURE;
+ MBRange remote_range;
+ unsigned char *buff_ptr = (unsigned char *)&myBuffer[0];
+ UNPACK_RANGE(buff_ptr, remote_range);
+ result = set_remote_data(whole_range, remote_range, to_proc);
+ RRA("Trouble setting remote data range on sent entities.");
else if ((int)procConfig.proc_rank() == to_proc) {
int buff_size;
@@ -245,10 +291,22 @@
success = MPI_Recv(&myBuffer[0], buff_size, MPI_UNSIGNED_CHAR, from_proc,
// unpack the buffer
- result = unpack_buffer(entities);
+ result = unpack_buffer(entities, store_remote_handles, from_proc);
RRA("Failed to unpack buffer in communicate_entities.");
+ MPI_Request send_req;
+ PACK_RANGE(buff_ptr, entities);
+ int range_size = 2*num_subranges(entities)*sizeof(MBEntityHandle) +
+ sizeof(int);
+ success = MPI_Isend(&myBuffer[0], range_size, MPI_UNSIGNED_CHAR, to_proc,
+ 0, procConfig.proc_comm(), &send_req);
return result;
@@ -280,7 +338,9 @@
setPcs.clear();
if ((int)procConfig.proc_rank() == from_proc) {
- result = pack_buffer( entities, adjacencies, tags, true, whole_range, buff_size );
+ result = pack_buffer( entities, adjacencies, tags, true,
+ false, -1,
+ whole_range, buff_size );
RRA("Failed to compute buffer size in broadcast_entities.");
@@ -295,7 +355,8 @@
int actual_buffer_size;
- result = pack_buffer( entities, adjacencies, tags, false,
+ result = pack_buffer( whole_range, adjacencies, tags, false,
+ false, -1,
whole_range, actual_buffer_size );
RRA("Failed to pack buffer in broadcast_entities.");
@@ -305,7 +366,7 @@
return MB_FAILURE;
if ((int)procConfig.proc_rank() != from_proc) {
- result = unpack_buffer( entities );
+ result = unpack_buffer( entities, false, from_proc);
RRA("Failed to unpack buffer in broadcast_entities.");
@@ -317,10 +378,57 @@
const bool tags,
const bool just_count,
+ const bool store_remote_handles,
MBRange &whole_range,
int &buff_size)
// pack the buffer with the entity ranges, adjacencies, and tags sections
+ // Note: new entities used in subsequent connectivity lists, sets, or tags,
+ // are referred to as (MBMAXTYPE + index), where index is into vector
+ // of new entities, 0-based
+ // DATA LAYOUT IN BUFFER:
+ // . w/ handles ? (0-no, 1-yes, range, 2-yes, vector)
+ // ENTITIES:
+ // . for all types:
+ // - ent_type -- end of data indicated by ent_type == MBMAXTYPE
+ // - range(ent type) -- #ents = range.size()
+ // - if (ent_type == MBVERTEX) xxx[#ents], yyy[#ents], zzz[#ents]
+ // - else {
+ // . nodes_per_ent
+ // . connect[#ents * nodes_per_ent]
+ // - if (handles) range/vector of remote handles
+ // SETS:
+ // . range of set handles -- (#sets = range.size())
+ // . options[#sets] (unsigned int)
+ // . if (unordered) set range
+ // . else if ordered
+ // - #ents in set
+ // - handles[#ents]
+ // . #parents
+ // . if (#parents) handles[#parents]
+ // . #children
+ // . if (#children) handles[#children]
+ // ADJACENCIES:
+ // (no adjs for now)
+ // TAGS:
+ // . #tags
+ // . for each tag
+ // - tag size
+ // - tag type
+ // - data type
+ // - if (default value)
+ // . 1
+ // . default value
+ // - else
+ // . 0
+ // - name (null-terminated string, in char[64])
+ // - range (size = #ents)
+ // - tag_vals[#ents]
MBErrorCode result;
buff_size = 0;
@@ -330,19 +438,21 @@
// entities
result = pack_entities(entities, rit, whole_range, buff_ptr,
- buff_size, just_count);
+ buff_size, just_count, store_remote_handles, to_proc);
RRA("Packing entities failed.");
// sets
int tmp_size;
- result = pack_sets(entities, rit, whole_range, buff_ptr, tmp_size, just_count);
+ result = pack_sets(entities, rit, whole_range, buff_ptr, tmp_size, just_count,
+ store_remote_handles, to_proc);
RRA("Packing sets failed.");
buff_size += tmp_size;
// adjacencies
if (adjacencies) {
result = pack_adjacencies(entities, rit, whole_range, buff_ptr,
- tmp_size, just_count);
+ tmp_size, just_count,
RRA("Packing adjs failed.");
@@ -350,7 +460,8 @@
// tags
if (tags) {
result = pack_tags(entities, rit, whole_range, buff_ptr,
RRA("Packing tags failed.");
@@ -358,18 +469,27 @@
return result;
-MBErrorCode MBParallelComm::unpack_buffer(MBRange &entities)
+MBErrorCode MBParallelComm::unpack_buffer(MBRange &entities,
+ int from_proc)
if (myBuffer.capacity() == 0) return MB_FAILURE;
unsigned char *buff_ptr = &myBuffer[0];
- HandleMap handle_map;
- MBErrorCode result = unpack_entities(buff_ptr, entities, handle_map);
+ MBErrorCode result = unpack_entities(buff_ptr, entities,
+ from_proc);
RRA("Unpacking entities failed.");
- result = unpack_sets(buff_ptr, entities, handle_map);
+ result = unpack_sets(buff_ptr, entities, store_remote_handles,
+ from_proc);
RRA("Unpacking sets failed.");
- result = unpack_tags(buff_ptr, entities, handle_map);
+ result = unpack_tags(buff_ptr, entities, store_remote_handles,
+ from_proc);
RRA("Unpacking tags failed.");
+ std::cerr << std::endl;
+#endif
return MB_SUCCESS;
@@ -390,8 +510,23 @@
unsigned char *&buff_ptr,
int &count,
- const bool just_count)
+ const bool just_count,
+ const int to_proc)
+ // (. w/ handles ? (0-no, 1-yes, range, 2-yes, vector))
+ // ENTITIES:
+ // - #ents
+ // - else {
+ if (just_count) allRanges.clear();
count = 0;
unsigned char *orig_buff_ptr = buff_ptr;
MBErrorCode result;
@@ -405,28 +540,38 @@
// pack vertices
if (just_count) {
+ // don't count size of verts until after all entities are included
entTypes.push_back(MBVERTEX);
vertsPerEntity.push_back(1);
allRanges.push_back(entities.subset_by_type(MBVERTEX));
else {
- PACK_INT(buff_ptr, ((int) MBVERTEX));
- PACK_RANGE(buff_ptr, allRanges[0]);
- int num_verts = allRanges[0].size();
- std::vector<double*> coords(3);
- for (int i = 0; i < 3; i++)
- coords[i] = reinterpret_cast<double*>(buff_ptr + i * num_verts * sizeof(double));
+ if (!allRanges[0].empty()) {
+ PACK_INT(buff_ptr, ((int) MBVERTEX));
+ PACK_INT(buff_ptr, ((int) allRanges[0].size()));
+ int num_verts = allRanges[0].size();
+ std::vector<double*> coords(3);
+ for (int i = 0; i < 3; i++)
+ coords[i] = reinterpret_cast<double*>(buff_ptr + i * num_verts * sizeof(double));
- assert(NULL != wu);
+ assert(NULL != wu);
- result = wu->get_node_arrays(3, num_verts, allRanges[0], 0, 0, coords);
- RR("Couldn't allocate node space.");
+ result = wu->get_node_arrays(3, num_verts, allRanges[0], 0, 0, coords);
+ RR("Couldn't allocate node space.");
+ PC(3*num_verts, " doubles");
- buff_ptr += 3 * num_verts * sizeof(double);
+ buff_ptr += 3 * num_verts * sizeof(double);
- whole_range = allRanges[0];
+ PACK_RANGE(buff_ptr, allRanges[0]);
+ std::cerr << "Packed " << allRanges[0].size() << " vertices." << std::endl;
+#endif
// place an iterator at the first non-vertex entity
start_rit = entities.find(*allRanges[0].rbegin());
@@ -459,7 +604,8 @@
eseq = dynamic_cast<ElementSequence*>(seq);
// if type and nodes per element change, start a new range
- if (eseq->type() != *entTypes.rbegin() || (int) eseq->nodes_per_element() != *vertsPerEntity.rbegin()) {
+ if (eseq->type() != *entTypes.rbegin() ||
+ (int) eseq->nodes_per_element() != *vertsPerEntity.rbegin()) {
entTypes.push_back(eseq->type());
vertsPerEntity.push_back(eseq->nodes_per_element());
allRanges.push_back(MBRange());
@@ -477,7 +623,8 @@
start_rit = end_rit;
- // update vertex range and count those data, now that we know which entities get communicated
+ // update vertex range and count those data, now that we know which
+ // entities get communicated
result = mbImpl->get_adjacencies(whole_range, 0, false, allRanges[0],
MBInterface::UNION);
RR("Failed get_adjacencies.");
@@ -492,9 +639,8 @@
// entity type of this range, but passed as int
count += sizeof(int);
- // subranges of entities
- // number of subranges, begin/end handle of each subrange
- count += sizeof(int) + 2*sizeof(MBEntityHandle)*num_subranges(*vit);
+ // number of entities
+ count += sizeof(int);
// nodes per entity
if (iit != vertsPerEntity.begin()) count += sizeof(int);
@@ -503,6 +649,10 @@
if (iit != vertsPerEntity.begin()) {
count += *iit * sizeof(MBEntityHandle)*(*vit).size();
+ // remote handles, if desired
+ count += sizeof(int) + 2*sizeof(MBEntityHandle)*num_subranges(*vit);
// extra entity type at end, passed as int
@@ -518,36 +668,39 @@
for (; allr_it != allRanges.end(); allr_it++, nv_it++, et_it++) {
// pack the entity type
PACK_INT(buff_ptr, ((int)*et_it));
+ // pack # ents
+ PACK_INT(buff_ptr, (*allr_it).size());
- // pack the range
- PACK_RANGE(buff_ptr, (*allr_it));
// pack the nodes per entity
PACK_INT(buff_ptr, *nv_it);
// pack the connectivity
const MBEntityHandle *connect;
int num_connect;
- //if (*et_it == MBPOLYGON || *et_it == MBPOLYHEDRON) {
- // std::vector<int> num_connects;
- // for (MBRange::const_iterator rit = allr_it->begin(); rit != allr_it->end(); rit++) {
- // result = mbImpl->get_connectivity(*rit, connect, num_connect);
- // RR("Failed to get connectivity.");
- // num_connects.push_back(num_connect);
- // PACK_EH(buff_ptr, &connect[0], num_connect);
- // PACK_INTS(buff_ptr, &num_connects[0], num_connects.size());
- //else {
- for (MBRange::const_iterator rit = allr_it->begin(); rit != allr_it->end(); rit++) {
- result = mbImpl->get_connectivity(*rit, connect, num_connect);
- RRA("Failed to get connectivity.");
- assert(num_connect == *nv_it);
- PACK_EH(buff_ptr, &connect[0], num_connect);
+ MBEntityHandle *start_vec = (MBEntityHandle*)buff_ptr;
+ for (MBRange::const_iterator rit = allr_it->begin(); rit != allr_it->end(); rit++) {
+ result = mbImpl->get_connectivity(*rit, connect, num_connect);
+ RRA("Failed to get connectivity.");
+ assert(num_connect == *nv_it);
+ PACK_EH(buff_ptr, &connect[0], num_connect);
- whole_range.merge(*allr_it);
+ // substitute destination handles
+ result = get_remote_handles(store_remote_handles, start_vec, start_vec,
+ *nv_it*(*allr_it).size(), to_proc,
+ whole_range);
+ RR("Trouble getting remote handles when packing entities.");
+ // pack the handles
+ PACK_RANGE(buff_ptr, (*allr_it));
+ std::cerr << "Packed " << (*allr_it).size() << " ents of type "
+ << MBCN::EntityTypeName(TYPE_FROM_HANDLE(*(allr_it->begin()))) << std::endl;
+#endif
// pack MBMAXTYPE to indicate end of ranges
@@ -555,13 +708,189 @@
count = buff_ptr - orig_buff_ptr;
+ if (!just_count) allRanges.clear();
+ if (debug_packing) std::cerr << std::endl << "Done packing entities." << std::endl;
return MB_SUCCESS;
+MBErrorCode MBParallelComm::get_remote_handles(const bool store_remote_handles,
+ MBEntityHandle *from_vec,
+ MBEntityHandle *to_vec_tmp,
+ int num_ents, int to_proc,
+ const MBRange &new_ents)
+ if (0 == num_ents) return MB_FAILURE;
+ // use a local destination ptr in case we're doing an in-place copy
+ std::vector<MBEntityHandle> tmp_vector;
+ MBEntityHandle *to_vec = to_vec_tmp;
+ if (to_vec == from_vec) {
+ tmp_vector.resize(num_ents);
+ to_vec = &tmp_vector[0];
+ if (!store_remote_handles) {
+ int err;
+ // in this case, substitute position in new_ents list
+ for (int i = 0; i < num_ents; i++) {
+ int index = new_ents.index(from_vec[i]);
+ to_vec[i] = CREATE_HANDLE(MBMAXTYPE, index, err);
+ assert(to_vec[i] != 0 && !err && -1 != index);
+ else {
+ MBTag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag;
+ MBErrorCode result = get_shared_proc_tags(sharedp_tag, sharedps_tag,
+ sharedh_tag, sharedhs_tag, pstatus_tag);
+ // get single-proc destination handles and shared procs
+ std::vector<int> sharing_procs(num_ents);
+ result = mbImpl->tag_get_data(sharedh_tag, from_vec, num_ents,
+ to_vec);
+ RRA("Failed to get shared handle tag for remote_handles.");
+ result = mbImpl->tag_get_data(sharedp_tag, from_vec, num_ents, &sharing_procs[0]);
+ RR("Failed to get sharing proc tag in remote_handles.");
+ for (int j = 0; j < num_ents; j++) {
+ if (to_vec[j] && sharing_procs[j] != to_proc)
+ to_vec[j] = 0;
+ MBEntityHandle tmp_handles[MAX_SHARING_PROCS];
+ int tmp_procs[MAX_SHARING_PROCS];
+ int i;
+ // go through results, and for 0-valued ones, look for multiple shared proc
+ MBEntityHandle *tmp_eh;
+ for (tmp_eh = to_vec, i = 0; i < num_ents; i++) {
+ if (!to_vec[i]) {
+ result = mbImpl->tag_get_data(sharedhs_tag, from_vec+i, 1, tmp_handles);
+ RRA("Trouble getting sharedhs tag.");
+ result = mbImpl->tag_get_data(sharedps_tag, from_vec+i, 1, tmp_procs);
+ RRA("Trouble getting sharedps tag.");
+ for (int j = 0; j < MAX_SHARING_PROCS; j++)
+ if (tmp_procs[j] == to_proc) {
+ to_vec[i] = tmp_handles[j];
+ break;
+ if (!to_vec[i]) {
+ int j = new_ents.index(from_vec[i]);
+ if (-1 == j) {
+ result = MB_FAILURE;
+ RRA("Failed to find new entity in send list.");
+ int err;
+ to_vec[i] = CREATE_HANDLE(MBMAXTYPE, j, err);
+ if (err) {
+ RRA("Failed to create handle in remote_handles.");
+ // memcpy over results if from_vec and to_vec are the same
+ if (to_vec_tmp == from_vec)
+ memcpy(from_vec, to_vec, num_ents * sizeof(MBEntityHandle));
+ return MB_SUCCESS;
+ const MBRange &from_range,
+ MBRange &to_range,
+ int to_proc,
+ std::vector<MBEntityHandle> to_vector(from_range.size());
+ get_remote_handles(store_remote_handles, from_range, &to_vector[0],
+ to_proc, new_ents);
+ RRA("Trouble getting remote handles.");
+ std::copy(to_vector.begin(), to_vector.end(), mb_range_inserter(to_range));
+ return result;
+ MBEntityHandle *to_vec,
+ int to_proc,
+ if (from_range.empty()) return MB_FAILURE;
+ int err;
+ MBRange::iterator rit;
+ unsigned int i;
+ for (rit = from_range.begin(), i = 0; rit != from_range.end(); rit++, i++) {
+ int index = new_ents.index(*rit);
+ else {
+ std::vector<int> sharing_procs(from_range.size());
+ result = mbImpl->tag_get_data(sharedh_tag, from_range, to_vec);
+ result = mbImpl->tag_get_data(sharedp_tag, from_range, &sharing_procs[0]);
+ for (unsigned int j = 0; j < from_range.size(); j++) {
+ to_vec[j] = 0;
+ unsigned int i;
+ if (!to_vec[i]) {
+ result = mbImpl->tag_get_data(sharedhs_tag, &(*rit), 1, tmp_handles);
+ result = mbImpl->tag_get_data(sharedps_tag, &(*rit), 1, tmp_procs);
+ break;
+ if (!to_vec[i]) {
+ int j = new_ents.index(*rit);
+ if (-1 == j) {
+ int err;
+ if (err) {
MBErrorCode MBParallelComm::unpack_entities(unsigned char *&buff_ptr,
MBRange &entities,
- HandleMap &handle_map)
+ const int from_proc)
MBErrorCode result;
bool done = false;
@@ -569,10 +898,11 @@
result = mbImpl->query_interface(std::string("MBReadUtilIface"),
reinterpret_cast<void**>(&ru));
RR("Failed to get MBReadUtilIface.");
while (!done) {
MBEntityType this_type;
+ MBEntityHandle actual_start;
UNPACK_INT(buff_ptr, this_type);
assert(this_type >= MBVERTEX &&
(this_type == MBMAXTYPE || this_type < MBENTITYSET));
@@ -580,29 +910,36 @@
// MBMAXTYPE signifies end of entities data
if (MBMAXTYPE == this_type) break;
- // get the range
- MBRange this_range;
- UNPACK_RANGE(buff_ptr, this_range);
+ // get the number of ents
+ int num_ents;
+ UNPACK_INT(buff_ptr, num_ents);
if (MBVERTEX == this_type) {
// unpack coords
- int num_verts = this_range.size();
- if (num_verts) {
+ if (num_ents) {
- MBEntityHandle actual_start;
- result = ru->get_node_arrays(3, num_verts, 0, proc_config().proc_rank(),
+ result = ru->get_node_arrays(3, num_ents, 0, proc_config().proc_rank(),
actual_start, coords);
RR("Failed to allocate node arrays.");
- entities.insert(actual_start, actual_start+num_verts-1);
+ entities.insert(actual_start, actual_start+num_ents-1);
// unpack the buffer data directly into coords
- memcpy(coords[i], buff_ptr+i*num_verts*sizeof(double),
- num_verts*sizeof(double));
- buff_ptr += 3*num_verts * sizeof(double);
+ memcpy(coords[i], buff_ptr+i*num_ents*sizeof(double),
+ num_ents*sizeof(double));
+ buff_ptr += 3*num_ents * sizeof(double);
+ UPC(3*num_ents, " doubles");
- // pack the range map to map from source to local handles
- pack_range_map(this_range, actual_start, handle_map);
+ // unpack source handles
+ MBRange this_range;
+ this_range.insert(actual_start, actual_start+num_ents-1);
+ MBRange dum_range;
+ UNPACK_RANGE(buff_ptr, dum_range);
+ result = set_remote_data(this_range, dum_range, from_proc);
+ RR("Couldn't set sharing data");
@@ -612,32 +949,245 @@
// unpack the nodes per entity
UNPACK_INT(buff_ptr, verts_per_entity);
- int num_elems = this_range.size();
- result = ru->get_element_array(num_elems, verts_per_entity, this_type,
+ result = ru->get_element_array(num_ents, verts_per_entity, this_type,
0, proc_config().proc_rank(), actual_start,
connect);
RR("Failed to allocate element arrays.");
// unpack the connectivity
- UNPACK_EH(buff_ptr, connect, (num_elems*verts_per_entity));
- entities.insert(actual_start, actual_start+num_elems);
+ UNPACK_EH(buff_ptr, connect, (num_ents*verts_per_entity));
- // change the connectivity to be in terms of local handles
- for (int i = 0; i < verts_per_entity*num_elems; i++) {
- connect[i] = handle_map.find(connect[i]);
- assert(0 != connect[i]);
+ // convert to local handles
+ result = get_local_handles(connect, num_ents*verts_per_entity,
+ entities);
+ RR("Couldn't get local handles.");
- // pack the range map for these elems
+ std::cerr << "Unpacked " << num_ents << " ents of type "
+ << MBCN::EntityTypeName(TYPE_FROM_HANDLE(actual_start)) << std::endl;
+#endif
+ if (debug_packing) std::cerr << std::endl << "Done unpacking entities." << std::endl;
+MBErrorCode MBParallelComm::get_local_handles(const MBRange &remote_handles,
+ MBRange &local_handles,
+ std::vector<MBEntityHandle> rh_vec;
+ rh_vec.reserve(remote_handles.size());
+ std::copy(remote_handles.begin(), remote_handles.end(), std::back_inserter(rh_vec));
+ MBErrorCode result = get_local_handles(&rh_vec[0], remote_handles.size(), new_ents);
+ std::copy(rh_vec.begin(), rh_vec.end(), mb_range_inserter(local_handles));
+ return result;
+MBErrorCode MBParallelComm::get_local_handles(MBEntityHandle *from_vec,
+ int num_ents,
+ if (TYPE_FROM_HANDLE(from_vec[i]) == MBMAXTYPE) {
+ assert(ID_FROM_HANDLE(from_vec[i]) < (int) new_ents.size());
+ from_vec[i] = new_ents[ID_FROM_HANDLE(from_vec[i])];
return MB_SUCCESS;
+MBErrorCode MBParallelComm::set_remote_data(MBRange &local_range,
+ MBRange &remote_range,
+ int other_proc)
+ // NOTE: THIS IMPLEMENTATION IS JUST LIKE THE VECTOR-BASED VERSION, NO REUSE
+ // AT THIS TIME, SO IF YOU FIX A BUG IN THIS VERSION, IT MAY BE IN THE
+ // OTHER VERSION TOO!!!
+ // get remote procs tag, if any
+ MBRange tmp_range, tmp_local_range = local_range;
+ std::vector<int> remote_proc(local_range.size());
+ std::vector<int> remote_procs(MAX_SHARING_PROCS);
+ std::vector<MBEntityHandle> remote_handle(local_range.size());
+ std::vector<MBEntityHandle> remote_handles(MAX_SHARING_PROCS);
+ std::fill(remote_procs.begin(), remote_procs.end(), -1);
+ std::fill(remote_handles.begin(), remote_handles.end(), 0);
+ result = mbImpl->tag_get_data(sharedp_tag, local_range,
+ &remote_proc[0]);
+ RRA("Couldn't get sharedp tag.");
+ result = mbImpl->tag_get_data(sharedh_tag, local_range,
+ &remote_handle[0]);
+ RRA("Couldn't get sharedh tag.");
+ MBRange::iterator rit, rit2;
+ int i = 0;
+ for (rit = tmp_local_range.begin(), rit2 = remote_range.begin();
+ rit != tmp_local_range.end(); rit++, rit2++, i++) {
+ remote_procs[0] = remote_proc[i];
+ if (-1 != remote_proc[0]) remote_handles[0] = *rit2;
+ else {
+ &remote_procs[0]);
+ RRA("Couldn't get sharedps tag.");
+ if (-1 != remote_procs[0]) {
+ &remote_handles[0]);
+ RRA("Couldn't get sharedhs tag.");
+ // now insert other_proc, handle into these
+ if (-1 == remote_procs[0]) {
+ remote_procs[0] = other_proc;
+ remote_handles[0] = *rit2;
+ result = mbImpl->tag_set_data(sharedp_tag, &(*rit), 1, &remote_procs[0]);
+ RRA("Couldn't set sharedp tag");
+ result = mbImpl->tag_set_data(sharedh_tag, &(*rit), 1, &remote_handles[0]);
+ RRA("Couldn't set sharedh tag");
+ remote_procs[0] = -1;
+ remote_handles[0] = 0;
+ else {
+ std::vector<int>::iterator vit = remote_procs.begin();
+ std::vector<MBEntityHandle>::iterator vit2 = remote_handles.begin();
+ while (-1 != *vit && vit != remote_procs.end() && other_proc > *vit) {
+ vit++; vit2++;
+ assert(*vit != other_proc);
+ remote_procs.insert(vit, other_proc);
+ remote_handles.insert(vit2, *rit2);
+ result = mbImpl->tag_set_data(sharedps_tag, &(*rit), 1, &remote_procs[0]);
+ RRA("Couldn't set sharedps tag");
+ result = mbImpl->tag_set_data(sharedhs_tag, &(*rit), 1, &remote_handles[0]);
+ RRA("Couldn't set sharedhs tag");
+ // also update shared flag for these ents
+ unsigned int *shared_flags = (unsigned int*) &remote_proc[0];
+ result = mbImpl->tag_get_data(pstatus_tag, local_range, shared_flags);
+ RRA("Couldn't get shared tag");
+ for (unsigned int i = 0; i < local_range.size(); i++)
+ shared_flags[i] |= PROC_SHARED;
+ result = mbImpl->tag_set_data(pstatus_tag, local_range, shared_flags);
+ RRA("Couldn't set shared tag");
+MBErrorCode MBParallelComm::set_remote_data(MBEntityHandle *local_ents,
+ MBEntityHandle *remote_ents,
+ int num_ents,
+ int other_proc)
+ // NOTE: THIS IMPLEMENTATION IS JUST LIKE THE RANGE-BASED VERSION, NO REUSE
+ MBRange tmp_range;
+ std::vector<int> remote_proc(num_ents);
+ std::vector<MBEntityHandle> remote_handle(num_ents);
+ result = mbImpl->tag_get_data(sharedp_tag, local_ents, num_ents,
+ &remote_proc[0]);
+ result = mbImpl->tag_get_data(sharedh_tag, local_ents, num_ents,
+ int rit, rit2;
+ int i;
+ for (rit = 0, rit2 = 0, i = 0;
+ rit != num_ents; rit++, rit2++, i++) {
+ if (-1 != remote_proc[0]) remote_handles[0] = remote_ents[rit2];
+ else {
+ result = mbImpl->tag_get_data(sharedps_tag, &local_ents[rit], 1,
+ result = mbImpl->tag_get_data(sharedhs_tag, &local_ents[rit], 1,
+ remote_handles[0] = remote_ents[rit2];
+ result = mbImpl->tag_set_data(sharedp_tag, &local_ents[rit], 1,
+ result = mbImpl->tag_set_data(sharedh_tag, &local_ents[rit], 1,
+ else {
+ vit++; vit2++;
+ remote_handles.insert(vit2, remote_ents[rit2]);
+ result = mbImpl->tag_set_data(sharedps_tag, &local_ents[rit], 1,
+ result = mbImpl->tag_set_data(sharedhs_tag, &local_ents[rit], 1,
+ result = mbImpl->tag_get_data(pstatus_tag, local_ents, num_ents,
+ shared_flags);
+ result = mbImpl->tag_set_data(pstatus_tag, local_ents,
+ num_ents, shared_flags);
MBErrorCode MBParallelComm::pack_range_map(MBRange &key_range, MBEntityHandle val_start,
@@ -656,8 +1206,22 @@
int &count,
+ // SETS:
+ // . #sets
+ // . for each set:
+ // - options[#sets] (unsigned int)
+ // - if (unordered) set range
+ // - else if ordered
+ // . #ents in set
+ // . handles[#ents]
+ // - #parents
+ // - if (#parents) handles[#parents]
+ // - #children
+ // - if (#children) handles[#children]
// now the sets; assume any sets the application wants to pass are in the entities list
count = 0;
@@ -665,6 +1229,9 @@
MBErrorCode result;
if (just_count) {
+ // num of sets
for (; start_rit != entities.end(); start_rit++) {
setRange.insert(*start_rit);
@@ -672,6 +1239,8 @@
result = mbImpl->get_meshset_options(*start_rit, options);
RR("Failed to get meshset options.");
optionsVec.push_back(options);
+ // option
count += sizeof(unsigned int);
if (options & MESHSET_SET) {
@@ -679,6 +1248,8 @@
setRanges.push_back(MBRange());
result = mbImpl->get_entities_by_handle(*start_rit, *setRanges.rbegin());
RRA("Failed to get set entities.");
+ // set range
count += 2 * sizeof(MBEntityHandle) * num_subranges(*setRanges.rbegin()) + sizeof(int);
else if (options & MESHSET_ORDERED) {
@@ -686,11 +1257,11 @@
int num_ents;
result = mbImpl->get_number_entities_by_handle(*start_rit, num_ents);
RR("Failed to get number entities in ordered set.");
setSizes.push_back(num_ents);
+ // set vec
count += sizeof(MBEntityHandle) * num_ents + sizeof(int);
- whole_range.insert(*start_rit);
// get numbers of parents/children
int num_par, num_ch;
@@ -699,21 +1270,26 @@
result = mbImpl->num_parent_meshsets(*start_rit, &num_par);
RR("Failed to get num parents.");
+ // set children, parents
count += 2*sizeof(int) + (num_par + num_ch) * sizeof(MBEntityHandle);
- count += sizeof(int) + 2*num_subranges(setRange)*sizeof(MBEntityHandle);
+ // set handles
+ if (!setRange.empty())
+ count += sizeof(int) + 2*sizeof(MBEntityHandle)*num_subranges(setRange);
+ whole_range.merge(setRange);
else {
// set handle range
- PACK_RANGE(buff_ptr, setRange);
+ PACK_INT(buff_ptr, setRange.size());
// option values
- PACK_VOID(buff_ptr, &optionsVec[0], setRange.size()*sizeof(unsigned int));
+ PACK_VOID(buff_ptr, &optionsVec[0], setRange.size()*sizeof(unsigned int));
std::vector<unsigned int>::const_iterator opt_it = optionsVec.begin();
std::vector<MBRange>::const_iterator rit = setRanges.begin();
std::vector<int>::const_iterator mem_it = setSizes.begin();
@@ -723,7 +1299,12 @@
set_it++, opt_it++) {
if ((*opt_it) & MESHSET_SET) {
// pack entities as a range
- PACK_RANGE(buff_ptr, (*rit));
+ (*rit), dum_range, to_proc,
+ whole_range);
+ RRA("Trouble getting remote handles for unordered set contents.");
+ PACK_RANGE(buff_ptr, dum_range);
rit++;
else if ((*opt_it) & MESHSET_ORDERED) {
@@ -731,127 +1312,152 @@
PACK_INT(buff_ptr, *mem_it);
members.clear();
result = mbImpl->get_entities_by_handle(*set_it, members);
- RR("Failed to get set entities.");
+ RRA("Failed to get set entities.");
+ &members[0], &members[0],
+ members.size(), to_proc,
+ whole_range);
+ RRA("Trouble getting remote handles for ordered set contents.");
PACK_EH(buff_ptr, &members[0], *mem_it);
mem_it++;
+ // now pack parents/children
+ for (MBRange::const_iterator set_it = setRange.begin(); set_it != setRange.end();
+ set_it++) {
// pack parents
members.clear();
result = mbImpl->get_parent_meshsets(*set_it, members);
- RR("Failed to pack parents.");
- PACK_INT(buff_ptr, members.size());
- if (!members.empty()) {
- PACK_EH(buff_ptr, &members[0], members.size());
- // pack children
- members.clear();
+ RRA("Failed to get parents.");
+ int num_par = members.size();
result = mbImpl->get_child_meshsets(*set_it, members);
- RR("Failed to pack children.");
+ RRA("Failed to get children.");
+ PACK_INT(buff_ptr, num_par);
+ PACK_INT(buff_ptr, members.size() - num_par);
+ whole_range);
+ RRA("Trouble getting remote handles for set parent/child sets.");
+ // check that all handles are either sets or maxtype
+ for (unsigned int __j = 0; __j < members.size(); __j++)
+ assert((TYPE_FROM_HANDLE(members[__j]) == MBMAXTYPE &&
+ ID_FROM_HANDLE(members[__j]) < (int)whole_range.size()) ||
+ TYPE_FROM_HANDLE(members[__j]) == MBENTITYSET);
+#endif
+ if (store_remote_handles && !setRange.empty())
+ PACK_RANGE(buff_ptr, setRange);
+ if (debug_packing) std::cerr << std::endl << "Done packing sets." << std::endl;
return MB_SUCCESS;
MBErrorCode MBParallelComm::unpack_sets(unsigned char *&buff_ptr,
MBRange &entities,
MBErrorCode result;
- MBRange set_handles, new_sets;
- UNPACK_RANGE(buff_ptr, set_handles);
- if (set_handles.empty()) // assertion below fails if no sets, so check now.
- return MB_SUCCESS;
+ MBRange new_sets;
+ int num_sets;
+ UNPACK_INT(buff_ptr, num_sets);
+ if (!num_sets) return MB_SUCCESS;
std::vector<MBEntityHandle> members;
int num_ents;
- optionsVec.resize(set_handles.size());
+ optionsVec.resize(num_sets);
// option value
- UNPACK_VOID(buff_ptr, &optionsVec[0], set_handles.size()*sizeof(unsigned int));
+ if (num_sets)
+ UNPACK_VOID(buff_ptr, &optionsVec[0], num_sets*sizeof(unsigned int));
// create sets
- unsigned int i;
+ int i;
MBRange::const_iterator rit;
- for (rit = set_handles.begin(), i = 0;
- rit != set_handles.end(); rit++, i++) {
+ for (i = 0; i < num_sets; i++) {
// create the set
MBEntityHandle set_handle;
result = mbImpl->create_meshset(optionsVec[i], set_handle);
- RR("Failed to create set in unpack.");
+ RRA("Failed to create set in unpack.");
new_sets.insert(set_handle);
// make sure new sets handles are contiguous
assert(*new_sets.rbegin() - *new_sets.begin() + 1 == new_sets.size());
- pack_range_map(set_handles, *new_sets.begin(), handle_map);
- // now unpack entities and parent/child links; can go through new_sets in same
- // order as set_handles, since they were created contiguously and set_handles
- // were iterated as a range
+ entities.merge(new_sets);
for (rit = new_sets.begin(), i = 0; rit != new_sets.end(); rit++, i++) {
if (optionsVec[i] & MESHSET_SET) {
// unpack entities as a range
MBRange set_range, tmp_range;
UNPACK_RANGE(buff_ptr, tmp_range);
- for (MBRange::iterator rit2 = tmp_range.begin(); rit2 != tmp_range.end(); rit2++) {
- MBEntityHandle tmp_ent = handle_map.find(*rit2);
- assert(0 != tmp_ent);
- set_range.insert(tmp_ent);
+ result = get_local_handles(tmp_range, set_range, entities);
+ RRA("Failed to get local handles for unordered set contents.");
result = mbImpl->add_entities(*rit, set_range);
- RR("Failed to add ents to set in unpack.");
+ RRA("Failed to add ents to unordered set in unpack.");
else if (optionsVec[i] & MESHSET_ORDERED) {
// unpack entities as vector, with length
members.resize(num_ents);
- UNPACK_EH(buff_ptr, &members[0], num_ents);
- for (int j = 0; j < num_ents; j++) {
- members[j] = handle_map.find(members[j]);
- assert(0 != members[j]);
+ if (num_ents) UNPACK_EH(buff_ptr, &members[0], num_ents);
+ result = get_local_handles(&members[0], num_ents, entities);
+ RRA("Failed to get local handles for ordered set contents.");
result = mbImpl->add_entities(*rit, &members[0], num_ents);
- RR("Failed to add ents to ordered set in unpack.");
+ RRA("Failed to add ents to ordered set in unpack.");
+ for (rit = new_sets.begin(); rit != new_sets.end(); rit++) {
// unpack parents/children
- UNPACK_INT(buff_ptr, num_ents);
- members.resize(num_ents);
- for (int i = 0; i < num_ents; i++) {
- members[i] = handle_map.find(members[i]);
- assert(0 != members[i]);
- result = mbImpl->add_parent_meshset(*rit, members[i]);
- RR("Failed to add parent to set in unpack.");
+ int num_par, num_child;
+ UNPACK_INT(buff_ptr, num_par);
+ UNPACK_INT(buff_ptr, num_child);
+ if (num_par+num_child) {
+ members.resize(num_par+num_child);
+ UNPACK_EH(buff_ptr, &members[0], num_par+num_child);
+ result = get_local_handles(&members[0], num_par+num_child, entities);
+ RRA("Couldn't get local handle for parent/child sets.");
+ for (i = 0; i < num_par; i++) {
+ assert(0 != members[i]);
+ result = mbImpl->add_parent_meshset(*rit, members[i]);
+ RRA("Failed to add parent to set in unpack.");
+ for (i = num_par; i < num_par+num_child; i++) {
+ result = mbImpl->add_child_meshset(*rit, members[i]);
+ RRA("Failed to add child to set in unpack.");
- result = mbImpl->add_child_meshset(*rit, members[i]);
- RR("Failed to add child to set in unpack.");
- entities.merge(new_sets);
+ if (store_remote_handles && !new_sets.empty()) {
+ result = set_remote_data(new_sets, dum_range, from_proc);
+ RR("Couldn't set sharing data for sets");
+ if (debug_packing) std::cerr << std::endl << "Done unpacking sets." << std::endl;
return MB_SUCCESS;
@@ -860,13 +1466,17 @@
int &count,
+ const bool store_handles,
return MB_FAILURE;
MBErrorCode MBParallelComm::unpack_adjacencies(unsigned char *&buff_ptr,
- MBRange &entities)
+ MBRange &entities,
return MB_FAILURE;
@@ -876,7 +1486,9 @@
int &count,
// tags
// get all the tags
@@ -895,7 +1507,6 @@
result = tagServer->get_tags(all_tags);
RR("Failed to get tags in pack_tags.");
for (std::vector<MBTag>::iterator tag_it = all_tags.begin(); tag_it != all_tags.end(); tag_it++) {
const TagInfo *tinfo = tagServer->get_tag_info(*tag_it);
MBRange tmp_range;
@@ -921,27 +1532,31 @@
count += tinfo->get_name().size();
- tagRanges.push_back(tmp_range);
+ if (!tmp_range.empty()) {
+ tagRanges.push_back(tmp_range);
// range of tag
- count += sizeof(int) + 2 * num_subranges(tmp_range) * sizeof(MBEntityHandle);
+ count += sizeof(int) + tmp_range.size() * sizeof(MBEntityHandle);
- if (tinfo->get_size() == MB_VARIABLE_LENGTH) {
- const int num_ent = tmp_range.size();
- // send a tag size for each entity
- count += num_ent * sizeof(int);
- // send tag data for each entity
- var_len_sizes.resize( num_ent );
- var_len_values.resize( num_ent );
- result = tagServer->get_data( *tag_it, tmp_range, &var_len_values[0], &var_len_sizes[0] );
- RR("Failed to get lenghts of variable-length tag values.");
- count += std::accumulate( var_len_sizes.begin(), var_len_sizes.end(), 0 );
- else {
+ if (tinfo->get_size() == MB_VARIABLE_LENGTH) {
+ const int num_ent = tmp_range.size();
+ // send a tag size for each entity
+ count += num_ent * sizeof(int);
+ // send tag data for each entity
+ var_len_sizes.resize( num_ent );
+ var_len_values.resize( num_ent );
+ result = tagServer->get_data( *tag_it, tmp_range, &var_len_values[0],
+ &var_len_sizes[0] );
+ RR("Failed to get lenghts of variable-length tag values.");
+ count += std::accumulate( var_len_sizes.begin(), var_len_sizes.end(), 0 );
+ else {
// tag data values for range or vector
- count += tmp_range.size() * tinfo->get_size();
+ count += tmp_range.size() * tinfo->get_size();
// number of tags
@@ -976,22 +1591,33 @@
PACK_INT(buff_ptr, tinfo->get_name().size() );
PACK_VOID(buff_ptr, tinfo->get_name().c_str(), tinfo->get_name().size());
+ std::cerr << "Packing tag " << tinfo->get_name() << std::endl;
+#endif
+ // pack entities
+ PACK_INT(buff_ptr, (*tr_it).size());
+ (*tr_it), (MBEntityHandle*)buff_ptr, to_proc,
+ whole_range);
+ RR("Trouble getting remote handles for tagged entities.");
+ buff_ptr += (*tr_it).size() * sizeof(MBEntityHandle);
const size_t num_ent = tr_it->size();
- PACK_RANGE(buff_ptr, (*tr_it));
var_len_sizes.resize( num_ent, 0 );
var_len_values.resize( num_ent, 0 );
- result = mbImpl->tag_get_data(*tag_it, *tr_it, &var_len_values[0], &var_len_sizes[0] );
+ result = mbImpl->tag_get_data(*tag_it, *tr_it, &var_len_values[0],
RR("Failed to get variable-length tag data in pack_tags.");
PACK_INTS(buff_ptr, &var_len_sizes[0], num_ent);
- for (int i = 0; i < num_ent; ++i)
+ for (unsigned int i = 0; i < num_ent; ++i)
PACK_VOID(buff_ptr, var_len_values[i], var_len_sizes[i]);
else {
- tag_data.resize(num_ent * tinfo->get_size());
- result = mbImpl->tag_get_data(*tag_it, *tr_it, &tag_data[0]);
+ result = mbImpl->tag_get_data(*tag_it, *tr_it, buff_ptr);
RR("Failed to get tag data in pack_tags.");
- PACK_VOID(buff_ptr, &tag_data[0], num_ent*tinfo->get_size());
+ buff_ptr += num_ent * tinfo->get_size();
+ UPC(num_ent*tinfo->get_size(), " void");
tr_it++;
@@ -999,12 +1625,15 @@
+ if (debug_packing) std::cerr << std::endl << "Done packing tags." << std::endl;
return MB_SUCCESS;
MBErrorCode MBParallelComm::unpack_tags(unsigned char *&buff_ptr,
MBRange &entities,
// tags
// get all the tags
@@ -1037,6 +1666,7 @@
if (def_val_size) {
def_val_ptr = buff_ptr;
buff_ptr += def_val_size;
+ UPC(tag_size, " void");
// name
@@ -1044,6 +1674,10 @@
UNPACK_INT(buff_ptr, name_len);
std::string tag_name( reinterpret_cast<char*>(buff_ptr), name_len );
buff_ptr += name_len;
+ UPC(64, " chars");
+ std::cerr << "Unpacking tag " << tag_name << std::endl;
+#endif
// create the tag
if (tag_size == MB_VARIABLE_LENGTH)
@@ -1068,33 +1702,23 @@
else if (MB_SUCCESS != result) return result;
- // set the tag data; don't have to worry about dense tags with default
- // values, as those aren't sent
- MBRange tag_range;
- UNPACK_RANGE(buff_ptr, tag_range);
- // if it's a handle type, need to convert handles to local values
+ // go through handle vec (in buffer) and convert to local handles in-place
+ size_t num_ents;
+ MBEntityHandle *handle_vec = (MBEntityHandle*)buff_ptr;
+ result = get_local_handles(handle_vec, num_ents, entities);
+ RRA("Failed to get local handles for tagged entities.");
+ buff_ptr += num_ents * sizeof(MBEntityHandle);
+ // if it's a handle type, also convert tag vals in-place in buffer
if (MB_TYPE_HANDLE == tag_type) {
- int *tag_vals = (int*) buff_ptr;
- for (unsigned int i = 0; i < tag_range.size(); i++) {
- if (0 != tag_vals[i]) {
- tag_vals[i] = handle_map.find(tag_vals[i]);
- assert(0 != tag_vals[i]);
+ MBEntityHandle *val_vec = (MBEntityHandle*)buff_ptr;
+ result = get_local_handles(val_vec, num_ents, entities);
+ RRA("Failed to get local handles for tag vals.");
- // also need to convert the actual entities on which the tag is set
- tag_ents.resize(tag_range.size());
- std::vector<MBEntityHandle>::iterator vit = tag_ents.begin();
- for (MBRange::iterator rit = tag_range.begin(); rit != tag_range.end(); rit++, vit++) {
- *vit = handle_map.find(*rit);
- assert(0 != *vit);
if (tag_size == MB_VARIABLE_LENGTH) {
- const size_t num_ents = tag_ents.size();
// Be careful of alignment here. If the integers are aligned
// in the buffer, we can use them directly. Otherwise we must
// copy them.
@@ -1108,25 +1732,30 @@
size_arr = reinterpret_cast<const int*>(buff_ptr);
buff_ptr += sizeof(int) * num_ents;
+ UPC(sizeof(int) * num_ents, " void");
// get pointers into buffer for each tag value
- var_len_vals.resize(tag_ents.size());
- for (std::vector<MBEntityHandle>::size_type i = 0; i < tag_ents.size(); ++i) {
+ var_len_vals.resize(num_ents);
+ for (std::vector<MBEntityHandle>::size_type i = 0; i < num_ents; ++i) {
var_len_vals[i] = buff_ptr;
buff_ptr += size_arr[i];
+ UPC(size_arr[i], " void");
- result = mbImpl->tag_set_data( tag_handle, &tag_ents[0], tag_ents.size(),
+ result = mbImpl->tag_set_data( tag_handle, handle_vec, num_ents,
&var_len_vals[0], size_arr );
RR("Trouble setting tag data when unpacking variable-length tag.");
else {
- result = mbImpl->tag_set_data(tag_handle, &tag_ents[0],
- tag_range.size(), buff_ptr);
+ result = mbImpl->tag_set_data(tag_handle, handle_vec,
+ num_ents, buff_ptr);
RR("Trouble setting range-based tag data when unpacking tag.");
- buff_ptr += tag_range.size() * tag_size;
+ buff_ptr += num_ents * tag_size;
+ UPC(num_ents * tag_size, " void");
+ if (debug_packing) std::cerr << std::endl << "Done unpacking tags." << std::endl;
return MB_SUCCESS;
@@ -1292,7 +1921,7 @@
- RRA(" ");
+ RRA("Couldn't get shared proc tags.");
// load shared vertices into a tuple, then sort by index
tuple_list shared_verts;
@@ -1322,81 +1951,79 @@
std::map<std::vector<int>, MBRange> proc_nranges;
result = tag_shared_verts(shared_verts, skin_ents,
proc_nranges);
- RRA(" ");
+ RRA("Trouble tagging shared vertices.");
// get entities shared by 1 or n procs
result = tag_shared_ents(shared_dim, shared_verts, skin_ents,
proc_nranges);
- RRA(" ");
+ RRA("Trouble tagging shared entities.");
// create the sets for each interface
- result = create_interface_sets(proc_nranges);
- RRA(" ");
+ MBRange iface_sets;
+ result = create_interface_sets(proc_nranges, iface_sets);
+ RRA("Trouble creating iface sets.");
+ // resolve shared ent remote handles
+ result = resolve_ent_remote_handles(iface_sets);
+ RRA("Trouble resolving shared entity remote handles.");
if (0 == shared_dim) return MB_SUCCESS;
- // now send handles for shared non-vertex ents
- // pack tuple_list; tuple: dest proc, gid, handle
- tuple_list_free(&shared_verts);
- tuple_list_init_max(&shared_verts, 1, 2, 0,
- skin_ents[0].size()*MAX_SHARING_PROCS);
- MBRange::iterator rit;
+ // done
+ return result;
- for (dim = shared_dim; dim > 0; dim--) {
- // pack tuples for 1proc interface ents
- result = mbImpl->tag_get_data(sharedp_tag, shared_verts_1proc,
- &sort_buffer[0]);
- result = mbImpl->tag_get_data(gid_tag, shared_verts_1proc,
- &gid_data[0]);
- for (rit = shared_verts_1proc.begin(), i = 0; rit != shared_verts_1proc.end();
- rit++, i++) {
- // skip if this vertex isn't owned by this proc
- if (sort_buffer[2*i] != proc_rk) continue;
- shared_verts.vl[j++] = sort_buffer[2*i+1];
- shared_verts.vl[j++] = gid_data[i];
- shared_verts.vl[j++] = *rit;
- shared_verts.n++;
+MBErrorCode MBParallelComm::resolve_ent_remote_handles(MBRange &iface_sets)
+ std::vector<unsigned char> pstatus_flags(iface_sets.size());
+ MBErrorCode result = mbImpl->tag_get_data(pstatus_tag(), iface_sets,
+ &pstatus_flags[0]);
+ std::vector<int> sharing_proc(iface_sets.size());
+ result = mbImpl->tag_get_data(sharedp_tag(), iface_sets,
+ &sharing_proc[0]);
+ RRA("Couldn't get sharedp tag for iface sets.");
- // pack tuples for nproc interface vertices
- result = mbImpl->tag_get_data(sharedps_tag, shared_verts_nproc,
- &sort_buffer[0]);
- result = mbImpl->tag_get_data(gid_tag, shared_verts_nproc,
- &gid_data[0]);
- for (rit = shared_verts_nproc.begin(), i = 0; rit != shared_verts_nproc.end();
- rit++, i++) {
- if (sort_buffer[MAX_SHARING_PROCS*i] != proc_rk) continue;
- unsigned int k = 1;
- while (sort_buffer[MAX_SHARING_PROCS*i+k] != -1) {
- shared_verts.vl[j++] = sort_buffer[MAX_SHARING_PROCS*i+k];
- shared_verts.n++;
+ std::vector<int> sharing_procs(MAX_SHARING_PROCS);
- // exchange tuples
- gs_transfer(1, &shared_verts, 0, cd);
- // process arriving tuples: match gid to local handle,
- // set pgid to remote handle
+ MBRange::iterator if_it;
+ unsigned int i;
+ for (if_it = iface_sets.begin(), i = 0; if_it != iface_sets.end(); if_it++, i++) {
+ // for each set/iface:
+ sharing_procs[0] = sharing_proc[i];
+ if (-1 == sharing_procs[0]) {
+ result = mbImpl->tag_get_data(sharedps_tag(), &(*if_it), 1,
+ &sharing_procs[0]);
+ RRA("Couldn't get sharedps tag for iface set.");
+ assert(-1 != sharing_procs[0]); // should be at least one sharing proc
+ // if owner:
+ if (procConfig.proc_rank() < sharing_
+ // - assemble connectivity of non-vertex ents
+ // - replace with remote handles of verts
+ // - Isend to procs sharing that iface
+ // - recv vectors of remote handles from sharing procs
+ // else
+ // - recv from owner connectivity of shared ents
+ // - get local ent handles for those ents
+ // - Isend vector of local handles to all other sharing procs
+ // - recv vector of remote handles from all non-owning other procs
- // done
- return result;
-MBErrorCode MBParallelComm::create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges)
+MBErrorCode MBParallelComm::create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges,
+ MBRange &iface_sets)
pstatus_tag);
- RRA(" ");
+ RRA("Trouble getting shared proc tags in create_interface_sets.");
MBTag tmp_iface_tag;
@@ -1404,17 +2031,17 @@
result = mbImpl->tag_create("__tmp_iface", sizeof(MBEntityHandle),
MB_TAG_DENSE, MB_TYPE_HANDLE,
tmp_iface_tag, &tmp_iface_set);
- RR("Failed to create temporary iface set tag.");
+ RRA("Failed to create temporary iface set tag.");
// get all partition sets and mark contents with iface set tag
MBTag pset_tag;
- MBRange iface_sets, tmp_ents, tmp_ents2;
+ MBRange tmp_ents, tmp_ents2;
result = mbImpl->tag_get_handle(PARALLEL_PARTITION_TAG_NAME, pset_tag);
- RR("Couldn't get PARALLEL_PARTITION tag, needed to create iface sets.");
+ RRA("Couldn't get PARALLEL_PARTITION tag, needed to create iface sets.");
result = mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, &pset_tag, NULL, 1,
iface_sets);
- RR("Couldn't get PARALLEL_PARTITION sets.");
+ RRA("Couldn't get PARALLEL_PARTITION sets.");
for (rit = iface_sets.begin(); rit != iface_sets.end(); rit++) {
result = mbImpl->get_entities_by_handle(*rit, tmp_ents);
RR("Failed to get entities in partition set.");
@@ -1438,9 +2065,13 @@
// add entities
result = mbImpl->add_entities(new_set, (*mit).second);
RR("Failed to add entities to interface set.");
- // tag set with the proc ranks
- result = mbImpl->tag_set_data(sharedps_tag, &new_set, 1,
- &((*mit).first)[0]);
+ // tag set with the proc rank(s)
+ if (((*mit).first).size() == 1)
+ result = mbImpl->tag_set_data(sharedp_tag, &new_set, 1,
+ &((*mit).first)[0]);
+ else
+ result = mbImpl->tag_set_data(sharedps_tag, &new_set, 1,
RR("Failed to tag interface set with procs.");
// tag entities with interface set
tag_vals.resize((*mit).second.size());
@@ -1452,7 +2083,7 @@
// get the owning proc, then set the pstatus tag
int min_proc = ((*mit).first)[0];
unsigned char pstatus = PSTATUS_SHARED;
- if (min_proc != (int) procConfig.proc_rank()) pstatus |= PSTATUS_NOT_OWNED;
+ if (min_proc < (int) procConfig.proc_rank()) pstatus |= PSTATUS_NOT_OWNED;
result = mbImpl->tag_set_data(pstatus_tag, &new_set, 1, &pstatus);
RR("Failed to tag interface set with pstatus.");
@@ -1501,7 +2132,7 @@
- RRA(" ");
+ RRA("Trouble getting shared proc tags in tag_shared_ents.");
const MBEntityHandle *connect; int num_connect;
std::fill(sharing_procs.begin(), sharing_procs.end(), -1);
@@ -1554,6 +2185,16 @@
+ // build range for each sharing proc
+ std::map<int, MBRange> proc_ranges;
+ for (std::map<std::vector<int>, MBRange>::iterator mit = proc_nranges.begin();
+ mit != proc_nranges.end(); mit++) {
+ for (unsigned int i = 0; i < (*mit).first.size(); i++)
+ proc_ranges[(*mit).first[i]].merge((*mit).second);
+ // for each sharing proc, send handles, then post receive to get sharing handles back
return MB_SUCCESS;
@@ -1564,7 +2205,7 @@
- RRA(" ");
+ RRA("Trouble getting shared proc tags in tag_shared_verts.");
unsigned int j = 0, i = 0;
@@ -1752,93 +2393,20 @@
return MB_SUCCESS;
-MBErrorCode MBParallelComm::exchange_ghost_cells(int to_dim, int bridge_dim)
+MBErrorCode MBParallelComm::exchange_ghost_cells(int to_dim, int bridge_dim,
+ int num_layers,
+ int with_proc)
- MBTag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag;
- MBErrorCode result = get_shared_proc_tags(sharedp_tag, sharedps_tag,
- sharedh_tag, sharedhs_tag, pstatus_tag);
- RR(" ");
+ // get the b-dimensional interface(s) with with_proc, where b = bridge_dim
- MBRange proc_sets, procs_sets;
- result = get_iface_sets(proc_sets, procs_sets);
- RR("Failed to get interface sets.");
- std::vector<int> other_procs(iface_sets.size()), other_procs2(MAX_SHARING_PROCS);
- result = mbImpl->tag_get_data(sharedp_tag, iface_sets, &other_procs[0]);
- RR("Failed to get shared_proc tag for interface sets.");
- // map stores proc communicated with and ghost entities/new vertices on that proc
- struct
- MBRange ghost_ents;
- MBRange newverts;
- MPI_Request mpireq;
- } proc_struct;
- std::map<int,proc_struct> pstructs;
+ // for each layer, get non-ghost bridge entities and accumulate
- // get vertices shared with each proc
- MBRange::iterator ifsit, rit;
- std::vector<int>::iterator vit, vit2;
- MeshTopoUtils mtu(mbImpl);
- std::vector<MBEntityHandle> tmp_handles;
- MBRange iface_ents;
- for (ifsit = proc_sets.begin(), vit = other_procs.begin();
- ifsit != proc_sets.end(); ifsit++, vit++) {
- iface_ents.clear();
- result = mbImpl->get_entities_by_type(*ifsit, MBVERTEX, iface_ents);
- RR("Failed to get vertices in iface set.");
- pstructs[*vit].newverts.merge(iface_ents);
- for (ifsit = procs_sets.begin(); ifsit != procs_sets.end(); ifsit++) {
- result = mbImpl->tag_get_data(sharedps_tag, &(*ifset), 1, &other_procs2[0]);
- RR("Failed to get sharedps_tag for iface set.");
- int i = 0;
- while (i < MAX_SHARING_PROCS && other_procs2[i] >= 0)
- pstructs[other_procs2[i]].newverts.merge(iface_ents);
- // get 1st order adjs of to_dim; only work for single-proc interfaces for now
- // get the entities on the interface
- result = mbImpl->get_entities_by_handle(*ifsit, iface_ents);
- RR("Failed to get entities in iface set.");
- MBRange &ghostents = &pstructs[*vit].ghostents;
- MBRange &newverts = &pstructs[*vit].newverts;
- result = mbImpl->get_adjacencies(iface_ents, to_dim, true, ghostents);
- RR("Failed to get 1st order adjs from interface.");
+ // send those entities, then receive entities from that proc
+ return MB_FAILURE;
- if (-1 != bridge_dim) {
- // get bridge adjs; reuse iface_ents
- result = mtu.get_bridge_adjacencies(ghostents, bridge_dim, to_dim, iface_ents);
- RR("Failed to get bridge adjs from interface.");
- ghostents.merge(iface_ents);
- // get vertices, and filter out ones shared already; reuse iface_ents
- result = mbImpl->get_adjacencies(ghostents, 0, false, iface_ents, MBInterface::UNION);
- RR("Failed to get vertex adjs to ghost entities.");
- newverts = iface_ents.subtract(newverts);
- // Isend # new vertices
- int num_verts = newverts.size();
- int success = MPI_Isend(&num_verts, 1, MPI_INTEGER, *vit,
- 0, procConfig.proc_comm(), &(pstructs[*vit].mpireq));
- if (!success) return MB_FAILURE;
#ifdef TEST_PARALLELCOMM
#include <iostream>
@@ -1913,7 +2481,7 @@
// unpack the results
all_mesh.clear();
- result = pcomm2.unpack_buffer(all_mesh);
+ result = pcomm2.unpack_buffer(all_mesh, store_remote_handles, from_proc);
PM;
std::cout << "ENTITIES UNPACKED:" << std::endl;
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2008-03-28 14:14:17 UTC (rev 1714)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2008-03-28 16:42:01 UTC (rev 1715)
@@ -78,7 +78,8 @@
MBErrorCode communicate_entities(const int from_proc, const int to_proc,
MBRange &entities,
const bool adjacencies = false,
- const bool tags = true);
+ const bool tags = true,
+ const bool store_remote_handles = true);
MBErrorCode broadcast_entities( const int from_proc,
MBRange& entities,
@@ -133,11 +134,15 @@
const bool tags,
int &buff_size);
//! unpack a buffer; assume information is already in myBuffer
- MBErrorCode unpack_buffer(MBRange &entities);
+ MBErrorCode unpack_buffer(MBRange &entities,
+ int from_proc);
//! set the buffer size; return true if size actually changed
bool buffer_size(const unsigned int new_size);
@@ -154,7 +159,74 @@
MBTag &sharedh_tag,
MBTag &sharedhs_tag,
MBTag &pstatus_tag);
+ //! return sharedp tag
+ MBTag sharedp_tag();
+ //! return sharedps tag
+ MBTag sharedps_tag();
+ //! return sharedh tag
+ MBTag sharedh_tag();
+ //! return sharedhs tag
+ MBTag sharedhs_tag();
+ //! return pstatus tag
+ MBTag pstatus_tag();
+ //! replace handles in from_vec with corresponding handles on
+ //! to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag;
+ //! if no remote handle and new_ents is non-null, substitute
+ //! instead CREATE_HANDLE(MBMAXTYPE, index) where index is handle's
+ //! position in new_ents
+ MBErrorCode get_remote_handles(const bool store_remote_handles,
+ const MBRange &new_ents);
+ //! same as other version, except from_range and to_range should be
+ //! different here
+ int to_proc,
+ //! same as other version, except packs range into vector
+ int to_proc,
+ //! goes through from_vec, and for any with type MBMAXTYPE, replaces with
+ //! new_ents value at index corresponding to id of entity in from_vec
+ MBErrorCode get_local_handles(MBEntityHandle *from_vec,
+ int num_ents,
+ //! same as above except puts results in range
+ MBErrorCode get_local_handles(const MBRange &remote_handles,
+ //! adjust shared proc tags/handles to incude from_proc and remote_range
+ MBErrorCode set_remote_data(MBRange &local_range,
+ int from_proc);
+ MBErrorCode set_remote_data(MBEntityHandle *local_ents,
+ int num_ents,
+ int other_proc);
+ //! exchange ghost cells with with_proc, going through bridge_dim to to_dim
+ MBErrorCode exchange_ghost_cells(int to_dim, int bridge_dim,
+ int num_layers, int to_proc);
private:
int num_subranges(const MBRange &this_range);
@@ -164,43 +236,56 @@
int &count,
- const bool just_count);
+ const int from_proc);
MBErrorCode unpack_entities(unsigned char *&buff_ptr,
MBRange &entities,
- HandleMap &handle_map);
MBErrorCode pack_sets(MBRange &entities,
MBRange::const_iterator &start_rit,
int &count,
+ const int to_proc);
MBErrorCode unpack_sets(unsigned char *&buff_ptr,
MBRange &entities,
MBErrorCode pack_adjacencies(MBRange &entities,
int &count,
MBErrorCode unpack_adjacencies(unsigned char *&buff_ptr,
- MBRange &entities);
MBErrorCode pack_tags(MBRange &entities,
int &count,
MBErrorCode unpack_tags(unsigned char *&buff_ptr,
MBRange &entities,
MBErrorCode tag_shared_verts(tuple_list &shared_verts,
MBRange *skin_ents,
@@ -211,8 +296,13 @@
MBRange *skin_ents,
std::map<std::vector<int>, MBRange> &proc_nranges);
- MBErrorCode create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges);
+ MBErrorCode create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges,
+ MBRange &iface_sets);
+ //! resolve remote handles for shared non-vertex ents, assuming
+ //! this has already been done for vertices
+ MBErrorCode resolve_ent_remote_handles(MBRange &iface_sets);
//! pack a range map with keys in this_range and values a contiguous series
//! of handles starting at actual_start
MBErrorCode pack_range_map(MBRange &this_range, MBEntityHandle actual_start,
@@ -277,4 +367,24 @@
+inline MBTag MBParallelComm::sharedp_tag()
+{return sharedpTag;}
+inline MBTag MBParallelComm::sharedps_tag()
+{return sharedpsTag;}
+inline MBTag MBParallelComm::sharedh_tag()
+{return sharedhTag;}
+inline MBTag MBParallelComm::sharedhs_tag()
+{return sharedhsTag;}
+inline MBTag MBParallelComm::pstatus_tag()
+{return pstatusTag;}
#endif
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2008-03-28 14:14:17 UTC (rev 1714)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2008-03-28 16:42:01 UTC (rev 1715)
@@ -221,7 +221,7 @@
std::cout << "Getting fileset entities." << std::endl;
if (0 == file_set_tag) {
- tmp_result = mbImpl->tag_get_handle("FILE_SET", file_set_tag);
+ tmp_result = mbImpl->tag_get_handle("__file_set", file_set_tag);
if (MB_SUCCESS == tmp_result) {
other_file_sets.clear();
file_sets.clear();
