[MOAB-dev] r1711 - MOAB/trunk
kraftche at mcs.anl.gov
Thu Mar 27 13:55:08 CDT 2008
Author: kraftche
Date: 2008-03-27 13:55:08 -0500 (Thu, 27 Mar 2008)
New Revision: 1711
Modified:
MOAB/trunk/kd_tree_time.cpp
Log:
add options and fix bug
Modified: MOAB/trunk/kd_tree_time.cpp
--- MOAB/trunk/kd_tree_time.cpp 2008-03-27 18:53:17 UTC (rev 1710)
+++ MOAB/trunk/kd_tree_time.cpp 2008-03-27 18:55:08 UTC (rev 1711)
@@ -4,22 +4,73 @@
#include <stdio.h>
#include <stdlib.h>
+void usage( const char* argv0 )
+ fprintf(stderr, "usage: %s [-t] [-d <result_file>] <tree_file> <point_file> [<count>]\n", argv0);
+ exit(1);
+void print_file_stats( MBInterface& moab )
+ MBErrorCode rval;
+ int num_tri;
+ MBRange sets;
+ unsigned long set_mem, set_am, tag_mem, tag_am;
+ rval = moab.get_number_entities_by_type( 0, MBTRI, num_tri );
+ if (MB_SUCCESS != rval)
+ num_tri = -1;
+ rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );
+ sets.clear();
+ moab.estimated_memory_use( sets, 0, 0, &set_mem, &set_am, 0, 0, 0, 0, &tag_mem, &tag_am );
+ printf( "Triangles: %d\n", num_tri );
+ printf( "Sets: %lu\n", (unsigned long)sets.size() );
+ printf( "Set storage: %lu (%lu)\n", set_mem, set_am );
+ printf( "Tag storage: %lu (%lu)\n", tag_mem, tag_am );
int main( int argc, char* argv[] )
double* values;
unsigned long length;
- FILE* file;
- unsigned long count;
+ FILE *file, *rfile = 0;
+ unsigned long count = 0;
clock_t t;
- if (argc != 4 && argc != 3) {
- fprintf(stderr,"usage: %s <tree_file> <point_file> <count>\n",argv[0]);
- return 1;
+ const char* tree_file = 0;
+ const char* point_file = 0;
+ const char* result_file = 0;
+ bool query_triangles = false;
+ if (argc < 3 || argc > 7)
+ usage(argv[0]);
+ for (int i = 1; i < argc; ++i) {
+ if (!strcmp("-t", argv[i]))
+ query_triangles = true;
+ else if (!strcmp("-d", argv[i])) {
+ ++i;
+ if (i == argc)
+ usage(argv[0]);
+ result_file = argv[i];
+ else if (!tree_file)
+ tree_file = argv[i];
+ else if (!point_file)
+ point_file = argv[i];
+ else {
+ char* endptr;
+ count = strtol( argv[i], &endptr, 0 );
+ if (*endptr || count < 1)
+ usage(argv[0]);
- file = fopen( argv[2], "rb" );
+ file = fopen( point_file, "rb" );
if (!file) {
- perror(argv[1]);
+ perror(point_file);
return 2;
fseek( file, 0, SEEK_END );
@@ -32,23 +83,27 @@
fclose( file );
- if (argc == 4)
- count = strtol( argv[3], 0, 0 );
- else
+ if (result_file) {
+ rfile = fopen( result_file, "w" );
+ if (!rfile) {
+ perror(result_file);
+ return 2;
+ if (!count)
count = length;
printf("Loading tree..."); fflush( stdout );
t = clock();
MBCore moab;
- MBErrorCode rval = moab.load_mesh( argv[1], 0, 0 );
+ MBErrorCode rval = moab.load_mesh( tree_file, 0, 0 );
if (MB_SUCCESS != rval) {
- fprintf(stderr,"Failed to read file: %s\n", argv[1] );
+ fprintf(stderr,"Failed to read file: %s\n", tree_file );
return 2;
printf("%0.2f seconds\n", (clock()-t)/(double)CLOCKS_PER_SEC); fflush( stdout );
- printf("Retrieving tree..."); fflush( stdout );
- t = clock();
MBRange range;
MBAdaptiveKDTree tool(&moab);
tool.find_all_trees(range);
@@ -57,20 +112,32 @@
return 3;
const MBEntityHandle root = range.front();
- printf("%0.2f seconds\n", (clock()-t)/(double)CLOCKS_PER_SEC); fflush( stdout );
+ print_file_stats( moab );
printf("Running point queries..."); fflush( stdout );
t = clock();
MBEntityHandle leaf;
double pt[3];
for (unsigned long i = 0; i < count; ++i) {
- const double* coords = values + 3 * (count % length);
- rval = tool.leaf_containing_point( root, coords, leaf );
- //rval = tool.closest_triangle( root, coords, pt, leaf );
+ const double* coords = values + 3 * (i % length);
+ if (query_triangles)
+ rval = tool.closest_triangle( root, coords, pt, leaf );
+ else
+ rval = tool.leaf_containing_point( root, coords, leaf );
fprintf(stderr, "Failure (MBErrorCode == %d) for point %d (%f, %f, %f)\n",
(int)rval, (int)(count % length), coords[0], coords[1], coords[2] );
+ else if (rfile) {
+ fprintf( rfile, "%f %f %f %f %f %f %lu\n",
+ coords[0], coords[1], coords[2],
+ pt[0], pt[1], pt[2], (unsigned long)leaf );
+ else
+ fprintf( rfile, "%f %f %f %lu\n",
+ coords[0], coords[1], coords[2], (unsigned long)leaf );
