[MOAB-dev] r1709 - MOAB/trunk/test/h5file
kraftche at mcs.anl.gov
Thu Mar 27 12:39:57 CDT 2008
Author: kraftche
Date: 2008-03-27 12:39:57 -0500 (Thu, 27 Mar 2008)
New Revision: 1709
Modified:
MOAB/trunk/test/h5file/h5legacy.cpp
Log:
use TestUtil.hpp
Modified: MOAB/trunk/test/h5file/h5legacy.cpp
--- MOAB/trunk/test/h5file/h5legacy.cpp 2008-03-27 17:39:22 UTC (rev 1708)
+++ MOAB/trunk/test/h5file/h5legacy.cpp 2008-03-27 17:39:57 UTC (rev 1709)
@@ -1,28 +1,23 @@
#include "MBCore.hpp"
#include "testdir.h"
+#include "TestUtil.hpp"
#include <iostream>
#include <stdlib.h>
#include <math.h>
-// define our own assert so it doesn't get compiled out during release builds
-#define assert( A ) if (!(A)) { \
- std::cerr << "Assertion failed at line " << __LINE__ << " : " << #A << std::endl; \
- abort(); \
void calc_centroid( MBInterface* iface, MBEntityHandle pent, double result[3] )
int len;
const MBEntityHandle* conn;
MBErrorCode rval;
rval = iface->get_connectivity( pent, conn, len );
- assert(MB_SUCCESS == rval && 5 == len);
+ CHECK_ERR(rval);
+ CHECK_EQUAL( 5, len );
double coords[15];
rval = iface->get_coords( conn, len, coords );
- assert(MB_SUCCESS == rval);
+ CHECK_ERR(rval);
for (int d = 0; d < 3; ++d) {
result[d] = 0;
@@ -40,30 +35,30 @@
// load file containing a dodecahedron
rval = mb.load_mesh( "../../" TEST_DIR "/v3_dodec.h5m" );
- assert( MB_SUCCESS == rval );
+ CHECK_ERR(rval);
// get entities from file
MBRange verts, faces, polyhedrons;
rval = mb.get_entities_by_type( 0, MBVERTEX, verts );
+ CHECK_ERR(rval);
rval = mb.get_entities_by_type( 0, MBPOLYGON, faces );
+ CHECK_ERR(rval);
rval = mb.get_entities_by_type( 0, MBPOLYHEDRON, polyhedrons );
+ CHECK_ERR(rval);
// check expected number of entities
- assert( 20 == verts.size() );
- assert( 12 == faces.size() );
- assert( 1 == polyhedrons.size() );
+ CHECK_EQUAL( (MBEntityHandle)20, verts.size() );
+ CHECK_EQUAL( (MBEntityHandle)12, faces.size() );
+ CHECK_EQUAL( (MBEntityHandle)1, polyhedrons.size() );
const MBEntityHandle polyhedron = polyhedrons.front();
// check the polyhedron connectivity list
std::vector<MBEntityHandle> faces1, faces2;
std::copy( faces.begin(), faces.end(), std::back_inserter(faces1) );
rval = mb.get_connectivity( &polyhedron, 1, faces2 );
+ CHECK_ERR(rval);
std::sort( faces2.begin(), faces2.end() );
- assert( faces1 == faces2 );
+ CHECK( faces1 == faces2 );
// each polygonshould have a tag value storing its centroid.
// compare this value against the centroid calculated from
@@ -72,17 +67,17 @@
// get tag for saved values
MBTag centroid;
rval = mb.tag_get_handle( "CENTROID", centroid );
+ CHECK_ERR(rval);
// for each face...
for (MBRange::iterator i = faces.begin(); i != faces.end(); ++i) {
double saved[3], calc[3];
rval = mb.tag_get_data( centroid, &*i, 1, saved );
+ CHECK_ERR(rval);
calc_centroid( &mb, *i, calc );
- assert( fabs(saved[0] - calc[0]) < 1e-6 );
- assert( fabs(saved[1] - calc[1]) < 1e-6 );
- assert( fabs(saved[2] - calc[2]) < 1e-6 );
+ CHECK_REAL_EQUAL( saved[0], calc[0], 1e-6 );
+ CHECK_REAL_EQUAL( saved[1], calc[1], 1e-6 );
+ CHECK_REAL_EQUAL( saved[2], calc[2], 1e-6 );
@@ -93,8 +88,7 @@
// only one test so far... should probably add second test
// for really-old-format entityset parent/child links
- test_moab_v3_poly_format();
- return 0;
+ return RUN_TEST( test_moab_v3_poly_format );
