[MOAB-dev] r1681 - in MOAB/trunk: . mhdf/include mhdf/src
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Mar 21 20:31:49 CDT 2008
Author: kraftche
Date: 2008-03-21 20:31:49 -0500 (Fri, 21 Mar 2008)
New Revision: 1681
Modified:
   MOAB/trunk/WriteHDF5.cpp
   MOAB/trunk/mhdf/include/mhdf.h
   MOAB/trunk/mhdf/src/tags.c
Log:
fix mhdf bug: don't assume default and mesh values for handle-type tags are passed in as arrays of 32-bit integers
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp	2008-03-22 01:29:42 UTC (rev 1680)
+++ MOAB/trunk/WriteHDF5.cpp	2008-03-22 01:31:49 UTC (rev 1681)
@@ -1497,6 +1497,7 @@
   MBTagType mb_type;
   MBDataType mb_data_type;
   long table_size;
+  hid_t value_type = 0;
     //get tag properties from moab
   if (MB_SUCCESS != iFace->tag_get_name( tag_data.tag_id, name )    ||
@@ -1530,6 +1531,23 @@
   size_t chunk_size = bufferSize / mb_size;
   assert( chunk_size > 0 );
   char* tag_buffer = (char*)dataBuffer;
+  if (mb_data_type == MB_TYPE_HANDLE) {
+    hsize_t len = mb_size / sizeof(MBEntityHandle);
+    if (len == 1)
+      value_type = id_type;
+    else {
+#if defined(H5Tarray_create_vers) && H5Tarray_create_vers > 1
+      value_type = H5Tarray_create( id_type, 1, &len );
+#else
+      value_type = H5Tarray_create( id_type, 1, &len, 0 );
+#endif
+      if (value_type < 0) {
+        mhdf_closeData( filePtr, tables[1], &status );
+        return MB_FAILURE;
     // Write the tag values
   size_t remaining = tag_data.range.size();
@@ -1562,7 +1580,12 @@
       rval = iFace->tag_get_data( tag_data.tag_id, range, tag_buffer );
-    CHK_MB_ERR_1(rval, tables[1], status);
+    if (MB_SUCCESS != rval) {
+      if (value_type && value_type != id_type)
+        H5Tclose( value_type );
+      return rval;
       // Convert MBEntityHandles to file ids
@@ -1570,12 +1593,16 @@
       // write the data
     mhdf_writeSparseTagValues( tables[1], offset, count,
-                               0, tag_buffer, &status );
+                               value_type, tag_buffer, &status );
+    if (mhdf_isError(&status) && value_type && value_type != id_type)
     CHK_MHDF_ERR_1(status, tables[1]);
     offset += count;
   } // while (remaining)
   CHK_MHDF_ERR_0(status);
@@ -2368,6 +2395,7 @@
                     def_value,
                     mesh_value,
                     hdf_type,
+                    mb_type == MB_TYPE_HANDLE ? id_type : 0,
                     &status );
@@ -2392,7 +2420,7 @@
                           storage,
                           def_value, def_val_len / elem_size,
                           mesh_value, mesh_val_len / elem_size,
-                          hdf_type,
+                          hdf_type, mb_type == MB_TYPE_HANDLE ? id_type : 0,
                           &status );
Modified: MOAB/trunk/mhdf/include/mhdf.h
--- MOAB/trunk/mhdf/include/mhdf.h	2008-03-22 01:29:42 UTC (rev 1680)
+++ MOAB/trunk/mhdf/include/mhdf.h	2008-03-22 01:31:49 UTC (rev 1681)
@@ -1546,6 +1546,12 @@
  *\param hdf_type       If non-zero, assumed to be a user-specified type
  *                      for opaque data.  Ignored if tag_type is not
  *                      mhdf_OPAQUE.
+ *\param hdf_base_type  Ignored if hdf_type is non-zero.  If hdf_type is
+ *                      zero and this type is non-zero, it is used either
+ *                      as the type or as the base type for an array type for
+ *                      default_value and global_value, respectively.  Typically
+ *                      used to specify the input data type for mhdf_ENTITY_ID
+ *                      tags.
 void
 mhdf_createTag( mhdf_FileHandle file_handle,
@@ -1556,6 +1562,7 @@
                 const void* default_value,
                 const void* global_value,
                 hid_t hdf_type,
+                hid_t mhdf_base_type,
                 mhdf_Status* status );
 /** \brief Add variable-length tag to file
@@ -1576,6 +1583,12 @@
  *                      mhdf_OPAQUE.
+ *                      tags.
 void
 mhdf_createVarLenTag( mhdf_FileHandle file_handle,
@@ -1587,6 +1600,7 @@
                       int global_value_length,
                       hid_t hdf_type,
+                      hid_t hdf_base_type,
Modified: MOAB/trunk/mhdf/src/tags.c
--- MOAB/trunk/mhdf/src/tags.c	2008-03-22 01:29:42 UTC (rev 1680)
+++ MOAB/trunk/mhdf/src/tags.c	2008-03-22 01:31:49 UTC (rev 1681)
@@ -245,6 +245,7 @@
                          int global_value_size_in,
                          hid_t hdf_type,
   hid_t temp_id, group_id, tag_id;
@@ -255,6 +256,7 @@
   int one = 1, var_len=0;
   hsize_t default_value_size = default_value_size_in;
   hsize_t global_value_size = global_value_size_in;
+  int close_base_type = 0;
     /* Validate input */
@@ -377,7 +379,7 @@
       case mhdf_ENTITY_ID:
         arr_len = abs(size);
-        hdf_type = H5Tcopy( H5T_NATIVE_INT );
+        hdf_type = H5Tcopy( H5T_NATIVE_ULONG );
         break;
       case mhdf_BOOLEAN:
@@ -404,6 +406,12 @@
     return -1;
+  if (hdf_base_type && H5Tget_class(hdf_type) != H5Tget_class(hdf_base_type)) {
+    mhdf_setFail( status, "Invalid base type for tag default/global data" );
+    H5Gclose( tag_id );
+    return -1;
   if (size < -1 || !arr_len)
     mhdf_setFail( status, "Invalid 'size' parameter passed to mhdf_createTag (%d)", (int)size);
@@ -434,11 +442,34 @@
       return -1;
     hdf_type = temp_id;
+    if (hdf_base_type) {
+      if (H5Tequal( hdf_base_type, hdf_type ) > 0) {
+        hdf_base_type = hdf_type;
+      else {
+        temp_id = H5Tarray_create2( hdf_base_type, 1, &arr_len);
+#else
+        temp_id = H5Tarray_create( hdf_base_type, 1, &arr_len, NULL );
+#endif
+        if (temp_id < 0)
+          mhdf_setFail( status, "Failed to create tag type object." );
+          H5Tclose( hdf_type );
+          return -1;
+        hdf_base_type = temp_id;
+        close_base_type = 1;
+  if (!hdf_base_type)
     /* Create tag type object, or write attribute if opaque */
 #if defined(H5Tcommit_vers) && H5Tcommit_vers > 1
@@ -449,6 +480,8 @@
   if (rval < 0)
     mhdf_setFail( status, "H5Tcommit failed for tag \"%s\"", tag_name );
+    if (close_base_type)
+      H5Tclose( hdf_base_type );
     H5Gclose( tag_id );
     return -1;
@@ -464,6 +497,8 @@
                                       status );
     if (!rval)
       H5Gclose( tag_id );
       return -1;
@@ -476,9 +511,12 @@
   if (default_value)
-    rval = store_tag_val_in_attrib( tag_id, TAG_DEFAULT_ATTRIB, hdf_type, default_value,
+    rval = store_tag_val_in_attrib( tag_id, TAG_DEFAULT_ATTRIB, hdf_base_type,
+                                    default_value,
                                     var_len ? default_value_size : 1, status );
     if (!rval) {
       H5Gclose( tag_id );
       return -1;
@@ -489,15 +527,20 @@
   if (global_value)
-    rval = store_tag_val_in_attrib( tag_id, TAG_GLOBAL_ATTRIB, hdf_type, global_value,
+    rval = store_tag_val_in_attrib( tag_id, TAG_GLOBAL_ATTRIB, hdf_base_type,
+                                    global_value,
                                     var_len ? global_value_size : 1, status );
     if (!rval) {
       H5Gclose( tag_id );
       return -1;
   mhdf_setOkay( status );
   return tag_id;
@@ -513,12 +556,14 @@
                 hid_t hdf_type,
   hid_t tag_id;
   API_BEGIN;
   tag_id = create_tag_common( file_handle, tag_name, tag_type, size, storage,
-                     default_value, 1, global_value, 1, hdf_type, status );
+                     default_value, 1, global_value, 1, hdf_type,
+                     hdf_base_type, status );
   if (tag_id >= 0)
     H5Gclose( tag_id );
   API_END;
@@ -534,6 +579,7 @@
                       hid_t hdf_type,
   herr_t rval;
@@ -544,7 +590,7 @@
   tag_id = create_tag_common( file_handle, tag_name, tag_type, -1, storage,
                               default_value, default_value_length,
                               global_value, global_value_length,
-                              hdf_type, status );
+                              hdf_type, hdf_base_type, status );
   if (tag_id >= 0) {
     rval = mhdf_create_scalar_attrib( tag_id,
                                       TAG_VARLEN_ATTRIB,
