[MOAB-dev] r1680 - in MOAB/trunk: . m4
kraftche at mcs.anl.gov
Fri Mar 21 20:29:43 CDT 2008
Author: kraftche
Date: 2008-03-21 20:29:42 -0500 (Fri, 21 Mar 2008)
New Revision: 1680
Modified:
MOAB/trunk/configure.in
MOAB/trunk/m4/hdf5.m4
Log:
fix problems detecting parallel hdf5 support
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in 2008-03-21 22:19:08 UTC (rev 1679)
+++ MOAB/trunk/configure.in 2008-03-22 01:29:42 UTC (rev 1680)
@@ -122,9 +122,13 @@
HAVE_HDF5_PARALLEL=no
if test "xno" != "x$HAVE_HDF5"; then
if test "xno" != "x$WITH_MPI"; then
+ old_LDFLAGS="$LDFLAGS"
+ LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
AC_CHECK_LIB( [hdf5], [H5Pset_fapl_mpio], [HAVE_HDF5_PARALLEL=yes],
- [AC_MSG_WARN("libhdf5 library does not include parallel support. Parallel HDF5 I/O disabled")]
+ [AC_MSG_WARN("libhdf5 library does not include parallel support. Parallel HDF5 I/O disabled")],
+ [$HDF5_LIBS]
+ LDFLAGS="$old_LDFLAGS"
fi
fi
AM_CONDITIONAL(PARALLEL_HDF5, [test "xno" != "x$HAVE_HDF5_PARALLEL"])
Modified: MOAB/trunk/m4/hdf5.m4
--- MOAB/trunk/m4/hdf5.m4 2008-03-21 22:19:08 UTC (rev 1679)
+++ MOAB/trunk/m4/hdf5.m4 2008-03-22 01:29:42 UTC (rev 1680)
@@ -4,7 +4,7 @@
# If HAVE_HDF5 == yes, then sets:
# HDF5_CPPFLAGS
# HDF5_LDFLAGS
-# HDF5_LINK
+# HDF5_LIBS
AC_DEFUN([SNL_CHECK_HDF5],[
