[MOAB-dev] r1631 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Mar 3 12:10:57 CST 2008
Author: kraftche
Date: 2008-03-03 12:10:57 -0600 (Mon, 03 Mar 2008)
New Revision: 1631
Added:
MOAB/trunk/README.IO
Log:
This was supposed to be checked in back when the "options" parameter was added to the file I/O functions. Update it for recent changes and check it in.
Added: MOAB/trunk/README.IO
--- MOAB/trunk/README.IO (rev 0)
+++ MOAB/trunk/README.IO 2008-03-03 18:10:57 UTC (rev 1631)
@@ -0,0 +1,115 @@
+This document describes file formats supported by MOAB and options
+controlling file input and output.
+Supported File Formats
+Some of the file formats listed below may not be supported by a particular
+build of MOAB depending on the availability of external libraries. An
+up-to-date list of file formats supported in a particular build of MOAB
+can be obtained programatically using the MBReaderWriterSet API or as
+a simple list using the '-l' option of the mbconvert utility.
+Format Name Read Write File name suffixes
+MOAB native MOAB yes yes h5m mhdf
+Exodus II EXODUS yes yes exo exoII exo2 g gen
+Kitware VTK VTK up to v3.0 v3.0 vtk
+Cubit CUBIT yes no cub
+SLAC SLAC no yes slac
+GMV GMV no yes gmv
+Ansys ANSYS no yes ans
+Gmsh GMSH v1.0, v2.0 v2.0 msh gmsh
+Stereo Lithography STL yes yes stl
+Any of the values from the 'Name' column may be passed as an option
+to the file IO methods to request a particular file. If no file
+format is specified, the default is to choose the write format using
+the file extension and to try all file readers until one succeeds.
+File IO Options
+An options list as passed to MOAB file IO routines is a single C-style
+string containing the concatenation of a list of string options, were
+individual options are separated by a designated separator character.
+The default separator character is a semicolon (;). To specify an alternate
+separator character, begin the options string with a semicolon followed
+by the desired separator. Options are not case sensitive.
+Common Options
+ PRECISION=<N>
+Specify the precision to use when writing float and double values
+(such as node coordinates) to text-based file formats.
+ CREATE
+Do not overwrite existing file.
+Parallel IO Options
+MOAB must be built with parallel support enabled before these options
+can be used.
+Parallel Read Options:
+ PARALLEL={NONE|BCAST|BCAST_DELETE|READ_DELETE|READ_PARALLEL|FORMAT}
+Set parallel read mode. Options are:
+ - NONE - force serial read/write on each processor (default)
+ - BCAST - read on one processor and broadcast a copy to all others
+ - BCAST_DELETE - ?
+ - READ_DELETE - read file on all processors and partition by deleting
+ mesh from non-local partitions.
+ - READ_PARALLEL - ?
+ - FORMAT- use format-specific parallel IO capabilities, if available
+ PARTITION
+ PARTITION=<tag_name>
+Specify that mesh should be partitioned using partition IDs stored
+in a tag. If the tag name is not specified, the default ("PARTITION")
+is used.
+ PARTITION_VALS=<int_list>
+Specify, for each processor, the list of partition IDs.
+ PARTITION_DISTRIBUTE
+ MPI_IO_RANK=<RANK>
+For IO modes in which a single processor handles all disk access, the
+MPI rank of the processor to use. Default is 0.
+Format-specific options
+Stereo Lithography (STL) files
+ BINARY|ASCII
+Write binary or text STL file. Default is text.
+ BIG_ENDIAN|LITTLE_ENDIAN
+Force byte ordering of binary data. Default is BIG_ENDIAN for writing
+and autodetection for reading (BIG_ENDIAN if autodetect fails).
