[MOAB-dev] r1630 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Mar 3 12:09:44 CST 2008
Author: kraftche
Date: 2008-03-03 12:09:44 -0600 (Mon, 03 Mar 2008)
New Revision: 1630
Modified:
MOAB/trunk/FileOptions.hpp
Log:
fix outdated documentation
Modified: MOAB/trunk/FileOptions.hpp
--- MOAB/trunk/FileOptions.hpp 2008-03-03 17:47:33 UTC (rev 1629)
+++ MOAB/trunk/FileOptions.hpp 2008-03-03 18:09:44 UTC (rev 1630)
@@ -49,7 +49,7 @@
/**\brief Check for option with no value
- * Check for and remove an option w/out a value.
+ * Check for an option w/out a value.
*\param name The option name
*\return - MB_SUCCESS if option is found
* - MB_TYPE_OUT_OF_RANGE if options is found, but has value
@@ -59,7 +59,7 @@
/**\brief Check for option with an integer value.
- * Check for and remove an option with an integer value
+ * Check for an option with an integer value
*\param value Output. The value.
@@ -70,10 +70,9 @@
/**\brief Check for option with a double value.
- * Check for and remove an option with a double value
+ * Check for an option with a double value
- *\param remove If true (default), remove the option from the list.
* - MB_TYPE_OUT_OF_RANGE if options is found, but does not have a double value
* - MB_ENTITY_NOT_FOUND if option is not found.
@@ -82,10 +81,9 @@
/**\brief Check for option with any value.
- * Check for and remove an option with any value.
+ * Check for aan option with any value.
* - MB_TYPE_OUT_OF_RANGE if options is found, but does not have a value
@@ -94,10 +92,9 @@
- * Check for and remove and option
*\param value The option value, or an empty string if no value.
- *\param remove If true (default), remove the option from teh list.
*\return MB_SUCCESS or MB_ENTITY_NOT_FOUND
MBErrorCode get_option( const char* name, std::string& value ) const;
@@ -118,15 +115,13 @@
/**\brief Check for option for which the value is a list of ints
- * Check for and remove an options which is an int list. The value is
- * expected to
+ * Check for an option which is an int list. The value is expected to
* be a comma-separated list of int ranges, where an int range can be
* either a single integer value or a range of integer values separated
* by a dash ('-').
- *\param value Output. The value.
+ *\param values Output. The list of integer values.
* - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain an ID list
@@ -148,10 +143,9 @@
MBErrorCode get_option( const char* name, const char*& value) const;
