[MOAB-dev] r1967 - MOAB/trunk/parallel
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Jun 30 13:48:50 CDT 2008
Author: kraftche
Date: 2008-06-30 13:48:50 -0500 (Mon, 30 Jun 2008)
New Revision: 1967
Modified:
   MOAB/trunk/parallel/ReadParallel.cpp
Log:
fix error reporting in 1-CPU case
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp	2008-06-30 17:54:42 UTC (rev 1966)
+++ MOAB/trunk/parallel/ReadParallel.cpp	2008-06-30 18:48:50 UTC (rev 1967)
@@ -383,14 +383,16 @@
           return MB_FAILURE;
-    if (MB_SUCCESS != tmp_result &&
-        myPcomm->proc_config().proc_size() != 1) {
+    if (MB_SUCCESS != tmp_result) {
       result = tmp_result;
-      std::ostringstream ostr;
-      ostr << "Failed in step " << ParallelActionsNames[*vit] << std::endl;
-      std::string tmp_str;
-      if (MB_SUCCESS == mbImpl->get_last_error(tmp_str)) ostr << tmp_str << std::endl;
-      RR(ostr.str().c_str());
+      if (myPcomm->proc_config().proc_size() != 1) {
+        std::ostringstream ostr;
+        ostr << "Failed in step " << ParallelActionsNames[*vit] << std::endl;
+        std::string tmp_str;
+        if (MB_SUCCESS == mbImpl->get_last_error(tmp_str)) ostr << tmp_str << std::endl;
+        RR(ostr.str().c_str());
+      break;
     if (cputime) act_times[i] = MPI_Wtime();
