[MOAB-dev] r1966 - in MOAB/trunk: . parallel
dcthomp at mcs.anl.gov
Mon Jun 30 12:54:42 CDT 2008
Author: dcthomp
Date: 2008-06-30 12:54:42 -0500 (Mon, 30 Jun 2008)
New Revision: 1966
Modified:
MOAB/trunk/CMakeLists.txt
MOAB/trunk/parallel/CMakeLists.txt
Log:
COMP: mbparallelcomm_test.cpp is now in parallel subdir.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt 2008-06-30 17:53:54 UTC (rev 1965)
+++ MOAB/trunk/CMakeLists.txt 2008-06-30 17:54:42 UTC (rev 1966)
@@ -315,14 +315,6 @@
# Point to the input decks for the tests
configure_file( ${MOAB_SOURCE_DIR}/cmake/TestingConfig.h.in ${MOAB_BINARY_DIR}/testdir.h )
- if ( MOAB_USE_MPI AND MPI_FOUND )
- add_executable ( mbparallelcomm_test mbparallelcomm_test.cpp )
- target_link_libraries( mbparallelcomm_test MOAB )
- add_test( TestParallelCommunications ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test )
- set_source_files_properties( mbparallelcomm_test.cpp
- COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
- endif ( MOAB_USE_MPI AND MPI_FOUND )
add_executable( moab_test MBTest.cpp )
target_link_libraries( moab_test MOAB )
add_test( TestMOAB ${EXECUTABLE_OUTPUT_PATH}/moab_test -nostress )
Modified: MOAB/trunk/parallel/CMakeLists.txt
--- MOAB/trunk/parallel/CMakeLists.txt 2008-06-30 17:53:54 UTC (rev 1965)
+++ MOAB/trunk/parallel/CMakeLists.txt 2008-06-30 17:54:42 UTC (rev 1966)
@@ -42,3 +42,12 @@
${MPI_LIBRARY}
${MPI_EXTRA_LIBRARY}
+if ( MOAB_USE_MPI AND MPI_FOUND )
+ add_executable ( mbparallelcomm_test mbparallelcomm_test.cpp )
+ target_link_libraries( mbparallelcomm_test MOAB )
+ add_test( TestParallelCommunications ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test )
+ set_source_files_properties( mbparallelcomm_test.cpp
+ COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
+endif ( MOAB_USE_MPI AND MPI_FOUND )
