[MOAB-dev] r1951 - in MOAB/trunk: . parallel tools/mbcoupler tools/size
tautges at mcs.anl.gov tautges at mcs.anl.gov
Sat Jun 28 19:44:35 CDT 2008
Author: tautges
Date: 2008-06-28 19:44:33 -0500 (Sat, 28 Jun 2008)
New Revision: 1951
Added:
   MOAB/trunk/parallel/mbparallelcomm_test.cpp
Removed:
   MOAB/trunk/mbparallelcomm_test.cpp
Modified:
   MOAB/trunk/Makefile.am
   MOAB/trunk/SequenceManager.cpp
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/parallel/Makefile.am
   MOAB/trunk/parallel/ReadParallel.cpp
   MOAB/trunk/tools/mbcoupler/Makefile.am
   MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
   MOAB/trunk/tools/size/size.cpp
Log:
- changing default tag to geom_dimension for coupler test, for
cases where no material sets are defined, and using READ_DELETE instead
of BCAST_DELETE to save time (at least on low #'s procs)
- removing phdf5 writing from coupling test for now
- making coupler test build whenever mbcoupler is enabled and parallel is on
- changed assert to warning in mbsize
- removed lots of old perf test stuff from mbparallelcomm_test
- moved mbparallelcomm_test down to parallel, where it belongs
- fixing a bug setting iface tag on 2nd file read
- error checking on bcast return value
- adding some more diagnostics to mbparallelcomm_test
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/Makefile.am	2008-06-29 00:44:33 UTC (rev 1951)
@@ -41,10 +41,6 @@
 		 kd_tree_tool \
 		 kd_tree_time
-if PARALLEL
-  check_PROGRAMS += mbparallelcomm_test
-endif
 #noinst_PROGRAMS = scdseq_timing
@@ -337,10 +333,6 @@
 bsp_tree_test_SOURCES = bsp_tree_test.cpp
 bsp_tree_test_LDADD = $(top_builddir)/libMOAB.la
-mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
-mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
-mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
 file_options_test_SOURCES = TestUtil.hpp FileOptions.cpp
 file_options_test_CPPFLAGS = -DTEST
Modified: MOAB/trunk/SequenceManager.cpp
--- MOAB/trunk/SequenceManager.cpp	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/SequenceManager.cpp	2008-06-29 00:44:33 UTC (rev 1951)
@@ -451,6 +451,8 @@
     return requested_size;
   MBEntityHandle last = typeData[TYPE_FROM_HANDLE(start)].last_free_handle( start );
+// tjt - when start is 41427, last comes back 41685, when there's really an entity
+    // at 41673, and 41467+246-1=41672
   if (!last) {
     assert( false );
     return 0;
@@ -519,7 +521,8 @@
     else
       sequence = new UnstructuredElemSeq( handle, count, size,
            new_sequence_size( handle, count, DEFAULT_ELEMENT_SEQUENCE_SIZE ) );
+      // tjt calling new_sequence_size 'cuz don't have a sequence data;
+      // start 41467, count 246
     break;
Deleted: MOAB/trunk/mbparallelcomm_test.cpp
--- MOAB/trunk/mbparallelcomm_test.cpp	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/mbparallelcomm_test.cpp	2008-06-29 00:44:33 UTC (rev 1951)
@@ -1,839 +0,0 @@
-/** test of MBParallelComm functionality
- * To run:
- * mpirun -np <#procs> mbparallelcomm_test
-#include "MBParallelComm.hpp"
-#include "MBParallelConventions.h"
-#include "ReadParallel.hpp"
-#include "FileOptions.hpp"
-#include "MBTagConventions.hpp"
-#include "MBCore.hpp"
-#include "ScdVertexData.hpp"
-#include "StructuredElementSeq.hpp"
-#include "SequenceManager.hpp"
-#include "MBError.hpp"
-#include "mpi.h"
-#include <iostream>
-#include <sstream>
-#include <assert.h>
-#define REALTFI 1
-const bool debug = false;
-#define ERROR(a, b) {std::cerr << a << std::endl; return b;}
-#define PRINT_LAST_ERROR {\
-        std::string last_error;\
-        result = mbImpl->get_last_error(last_error);\
-        if (last_error.empty()) std::cerr << "(none)" << std::endl;\
-        else std::cerr << last_error << std::endl;\
-#define RRA(a) if (MB_SUCCESS != result) {\
-      std::string tmp_str; mbImpl->get_last_error(tmp_str);\
-      tmp_str.append("\n"); tmp_str.append(a);\
-      dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(tmp_str.c_str()); \
-      return result;}
-MBErrorCode create_linear_mesh(MBInterface *mbImpl,
-                               int N, int M, int &nshared);
-MBErrorCode create_scd_mesh(MBInterface *mbImpl,
-                            int IJK, int &nshared);
-MBErrorCode read_file(MBInterface *mbImpl, std::vector<std::string> &filenames,
-                      const char *tag_name, int tag_val, int distrib,
-                      int parallel_option, int resolve_shared, int with_ghosts);
-MBErrorCode test_packing(MBInterface *mbImpl, const char *filename);
-MBErrorCode report_nsets(MBInterface *mbImpl);
-MBErrorCode report_iface_ents(MBInterface *mbImpl,
-                              std::vector<MBParallelComm *> &pcs);
-int main(int argc, char **argv)
-    // need to init MPI first, to tell how many procs and rank
-  int err = MPI_Init(&argc, &argv);
-  int nprocs, rank;
-  err = MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
-  err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
-    // start time
-  double stime, rtime, setime, dtime, ltime;
-  if (0 == rank) stime = MPI_Wtime();
-    // create MOAB instance based on that
-  MBInterface *mbImpl = new MBCore(rank, nprocs);
-  if (NULL == mbImpl) return 1;
-  MBErrorCode result = MB_SUCCESS;
-    // each interior proc has a vector of N+M vertices, sharing
-    // M vertices each with lower- and upper-rank processors, except
-    // procs on the end
-    // get N, M from command line
-  int N, M;
-  if (argc < 3) {
-    if (0 == rank)
-      std::cerr
-        << "Usage: " << argv[0]
-        << " [readpar_option] <opt> <input> [...] where:" << std::endl
-        << " readpar_option = 0 (BCAST_DELETE) (default), -1 (READ_DELETE), " << std::endl
-        << "                 -2 (READ_PARALLEL), -3 (BCAST)" << std::endl
-        << "opt   input" << std::endl
-        << "===   =====" << std::endl
-        << " 1     <linear_ints> <shared_verts> " << std::endl
-        << " 2     <n_ints> " << std::endl
-        << " 3*    <file_name> [<tag_name>=\"MATERIAL_SET\" [tag_val] [distribute=1] [resolve_shared=1] [with_ghosts=1]" << std::endl
-        << " 4    <file_name> " << std::endl
-        << "*Note: if opt 3 is used, it must be the last one." << std::endl;
-    err = MPI_Finalize();
-    return 1;
-  int npos = 1, tag_val, distrib, with_ghosts = 1, resolve_shared = 1;
-  const char *tag_name;
-  std::vector<std::string> filenames;
-  int parallel_option = 0;
-  while (npos < argc) {
-    MBErrorCode tmp_result;
-    int nshared = -1;
-    int this_opt = strtol(argv[npos++], NULL, 0);
-    switch (this_opt) {
-      case 0:
-      case -1:
-      case -2:
-      case -3:
-        parallel_option = this_opt;
-        continue;
-      case 1:
-        N = atoi(argv[npos++]);
-        M = atoi(argv[npos++]);
-        tmp_result = create_linear_mesh(mbImpl, N, M, nshared);
-        if (MB_SUCCESS != tmp_result) {
-          result = tmp_result;
-          std::cerr << "Couldn't create linear mesh; error message:."
-                    << std::endl;
-          PRINT_LAST_ERROR
-        break;
-      case 2:
-        tmp_result = create_scd_mesh(mbImpl, N, nshared);
-          std::cerr << "Couldn't create structured mesh; error message:"
-                    << std::endl;
-          PRINT_LAST_ERROR
-        break;
-      case 3:
-          // read a file in parallel from the filename on the command line
-        tag_name = "MATERIAL_SET";
-        tag_val = -1;
-        filenames.push_back(std::string(argv[npos++]));
-        if (npos < argc) tag_name = argv[npos++];
-        if (npos < argc) tag_val = strtol(argv[npos++], NULL, 0);
-        if (npos < argc) distrib = strtol(argv[npos++], NULL, 0);
-        else distrib = 1;
-        if (npos < argc) resolve_shared = strtol(argv[npos++], NULL, 0);
-        if (npos < argc) with_ghosts = strtol(argv[npos++], NULL, 0);
-        tmp_result = read_file(mbImpl, filenames, tag_name, tag_val,
-                               distrib, parallel_option,
-                               resolve_shared, with_ghosts);
-          std::cerr << "Couldn't read mesh; error message:" << std::endl;
-          PRINT_LAST_ERROR
-        nshared = -1;
-        break;
-      case 4:
-        filenames.push_back(argv[npos++]);
-        tmp_result = test_packing(mbImpl, filenames[0].c_str());
-          std::cerr << "Packing test failed; error message:" << std::endl;
-          PRINT_LAST_ERROR
-        break;
-      case 5:
-        distrib = 1;
-        tag_val = -1;
-        with_ghosts = 0;
-        resolve_shared = 1;
-                               distrib, parallel_option, resolve_shared,
-                               with_ghosts);
-          PRINT_LAST_ERROR
-        nshared = -1;
-        break;
-      default:
-        std::cerr << "Unrecognized option \"" << this_opt
-                  << "\"; skipping." << std::endl;
-        tmp_result = MB_FAILURE;
-    if (0 == rank) rtime = MPI_Wtime();
-    if (MB_SUCCESS == tmp_result && 4 != this_opt && false) {
-        // now figure out which vertices are shared
-      MBParallelComm *pcomm = MBParallelComm::get_pcomm(mbImpl, 0);
-      assert(pcomm);
-      MBRange iface_ents[7];
-      for (int i = 0; i < 4; i++) {
-        tmp_result = pcomm->get_iface_entities(-1, i, iface_ents[i]);
-          std::cerr << "get_iface_entities returned error on proc "
-                    << rank << "; message: " << std::endl;
-          PRINT_LAST_ERROR;
-        if (0 != i) iface_ents[4].merge(iface_ents[i]);
-      result = pcomm->get_part_entities(iface_ents[6], -1);
-      PRINT_LAST_ERROR;
-      std::cerr << "Proc " << rank << " partition entities:" << std::endl;
-      iface_ents[6].print("   ");
-      if (0 == rank) setime = MPI_Wtime();
-        // check # iface entities
-      if (0 <= nshared && nshared != (int) iface_ents[0].size()) {
-        std::cerr << "Didn't get correct number of iface vertices on "
-                  << "processor " << rank << std::endl;
-        result = MB_FAILURE;
-      else
-        std::cerr << "Proc " << rank << " option " << this_opt
-                << " succeeded." << std::endl;
-      if (-1 == nshared) {
-        result = mbImpl->get_adjacencies(iface_ents[4], 0, false, iface_ents[5],
-                                         MBInterface::UNION);
-        std::cerr << "Proc " << rank << " iface entities: " << std::endl;
-          std::cerr << "    " << iface_ents[i].size() << " "
-                    << i << "d iface entities." << std::endl;
-        std::cerr << "    (" << iface_ents[5].size()
-                  << " verts adj to other iface ents)" << std::endl;
-      if (debug && false) {
-//      if (debug && 2 == nprocs) {
-          // if I'm root, get and print handles on other procs
-        std::vector<MBEntityHandle> sharedh_tags(iface_ents[0].size());
-        std::fill(sharedh_tags.begin(), sharedh_tags.end(), 0);
-        MBTag dumt, sharedh_tag;
-        result = pcomm->get_shared_proc_tags(dumt, dumt, sharedh_tag, dumt, dumt);
-        result = mbImpl->tag_get_data(sharedh_tag, iface_ents[0], &sharedh_tags[0]);
-        if (MB_SUCCESS != result) {
-          std::cerr << "Couldn't get shared handle tag." << std::endl;
-        else {
-          MBRange dum_range;
-          std::copy(sharedh_tags.begin(), sharedh_tags.end(), mb_range_inserter(dum_range));
-          std::cerr << "Shared handles: " << std::endl;
-          dum_range.print();
-      result = report_nsets(mbImpl);
-      if (0 == rank) ltime = MPI_Wtime();
-      delete pcomm;
-      tmp_result = mbImpl->delete_mesh();
-        std::cerr << "Couldn't delete mesh on rank " << rank
-                  << "; error message: " << std::endl;
-        PRINT_LAST_ERROR
-  if (0 == rank) dtime = MPI_Wtime();
-  if (MB_SUCCESS == result)
-    std::cerr << "Proc " << rank << ": Success." << std::endl;
-  if (0 == rank) std::cout << "Times: "
-                           << dtime-stime << " "
-                           << rtime-stime << " "
-                           << setime-rtime << " "
-                           << ltime-setime << " "
-                           << dtime - ltime
-                           << " (total/read/shared/report/delete)"
-                           << std::endl;
-  return (MB_SUCCESS == result ? 0 : 1);
-    // get and report various numbers...
-  int rank = mbImpl->proc_rank();
-  MBRange matsets, geomsets, parsets;
-  int nsets;
-  MBTag mtag = 0, gtag = 0, ptag = 0, gidtag;
-  MBErrorCode result = mbImpl->tag_get_handle("MATERIAL_SET", mtag);
-  result = mbImpl->tag_get_handle("GEOM_DIMENSION", gtag);
-  result = mbImpl->tag_get_handle("PARALLEL_PARTITION", ptag);
-  result = mbImpl->tag_get_handle("GLOBAL_ID", gidtag);
-  result = mbImpl->get_number_entities_by_type(0, MBENTITYSET, nsets);
-  std::cout << "Proc " << rank << ": Total of " << nsets
-            << " entity sets." << std::endl;
-#define PRINTSETS(a, b, c, p) \
-  if (a) {\
-    result = mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, & a,\
-                                                  p, 1, b); \
-    if (! b .empty()) {\
-      std::vector<int> ids( b .size());\
-      result = mbImpl->tag_get_data(gidtag, b, &ids[0]); \
-      if (MB_SUCCESS == result) {\
-        std::cout << "Proc " << rank << ": " << c \
-          << " (total " << b.size() << "): " \
-           << ids[0]; \
-        for (unsigned int i = 1; i < b .size(); i++) \
-          std::cout << ", " << ids[i]; \
-        std::cout << std::endl; \
-  PRINTSETS(mtag, matsets, "material sets", NULL);
-  int tval = 3;
-  void *pval = &tval;
-  PRINTSETS(gtag, geomsets, "geom sets (vols)", &pval);
-  tval = 2;
-  geomsets.clear();
-  PRINTSETS(gtag, geomsets, "geom sets (surfs)", &pval);
-  tval = 1;
-  geomsets.clear();
-  PRINTSETS(gtag, geomsets, "geom sets (curves)", &pval);
-  tval = 0;
-  geomsets.clear();
-  PRINTSETS(gtag, geomsets, "geom sets (verts)", &pval);
-  PRINTSETS(ptag, parsets, "partition sets", NULL);
-  if (debug) {
-      // list info on all ent sets, reuse parsets
-    parsets.clear();
-    result = mbImpl->get_entities_by_type(0, MBENTITYSET, parsets);
-      std::cout << "Total sets (by range): " << parsets.size() << "; sets: " << std::endl;
-      parsets.print("  ");
-      mbImpl->list_entities(parsets);
-  return MB_SUCCESS;
-                      std::vector<std::string> &filenames,
-                      int distrib, int parallel_option, int resolve_shared,
-                      int with_ghosts)
-  std::ostringstream options;
-  switch (parallel_option) {
-    case 0:
-      options << "PARALLEL=BCAST_DELETE;PARTITION=" << tag_name;
-      break;
-    case -1:
-      options << "PARALLEL=READ_DELETE;PARTITION=" << tag_name;
-      break;
-    case -2:
-      options << "PARALLEL=READ_PARALLEL;PARTITION=" << tag_name;
-      break;
-    case -3:
-      options << "PARALLEL=BCAST;PARTITION=" << tag_name;
-      break;
-    default:
-      return MB_FAILURE;
-  if (-1 != tag_val)
-    options << ";PARTITION_VAL=" << tag_val;
-  if (1 == distrib)
-    options << ";PARTITION_DISTRIBUTE";
-  if (1 == resolve_shared)
-    options << ";PARALLEL_RESOLVE_SHARED_ENTS";
-  if (1 == with_ghosts)
-    options << ";PARALLEL_GHOSTS=3.0.1";
-  options << ";CPUTIME";
-  std::vector<MBEntityHandle> filesets(filenames.size());
-  std::vector<MBParallelComm*> pcs(filenames.size());
-  std::vector<ReadParallel*> rps(filenames.size());
-  MBErrorCode result;
-  for (unsigned int i = 0; i < filenames.size(); i++) {
-    pcs[i] = new MBParallelComm(mbImpl);
-    rps[i] = new ReadParallel(mbImpl, pcs[i]);
-    result = rps[i]->load_file(filenames[i].c_str(), filesets[i],
-                               FileOptions(options.str().c_str()), NULL, 0);
-    PRINT_LAST_ERROR;
-  report_iface_ents(mbImpl, pcs);
-  return result;
-#define RR(a, b) {std::cerr << a; return b;}
-    /* create a mesh where each processor owns N vertices and shares
-     * M vertices with processors on either end; for non-root procs,
-     * that works out to N+M vertices.
-     * Number of vertices shared should be M on end procs, 2M on others
-  int my_rank = mbImpl->proc_rank();
-  int my_size = mbImpl->proc_size();
-  int nverts = N + M;
-  if (0 == my_rank) nverts = N;
-    // create my vertices and give them the right global ids
-  MBRange my_verts;
-  std::vector<double> coords(3*(nverts));
-  std::fill(coords.begin(), coords.end(), 0.0);
-  MBErrorCode result = mbImpl->create_vertices(&coords[0], nverts,
-                                               my_verts);
-  if (MB_SUCCESS != 0)
-    RR("Failed to create vertices.", MB_FAILURE);
-  std::vector<int> global_ids(N+M);
-  for (int i = 0; i < nverts; i++)
-    global_ids[i] = my_rank*N - (nverts-N) + i;
-  int def_val = -1;
-  MBTag gid_tag;
-  result = mbImpl->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
-                              MB_TYPE_INTEGER, gid_tag,
-                              &def_val, true);
-  if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result)
-    RR("Failed to create tag.", MB_FAILURE);
-  result = mbImpl->tag_set_data(gid_tag, my_verts, &global_ids[0]);
-  if (MB_SUCCESS != result) RR("Failed to set global_id tag.", MB_FAILURE);
-  nshared = ((my_rank == 0 || my_rank == my_size-1) ? M : 2*M);
-double LENGTH = 1.0;
-void build_coords(const int nelem, double *&coords);
-    /* Create a 3d mesh of hexes, parameterized in i, j, k, where
-     * on processor of rank R the K parameterization starts at
-     * i=0, j=0, k=RK, and there are I+1, J+1, K+1 vertices in the
-     * i, j, k directions, resp.; for now, make I, J, K equal
-     * Should share (I+1)(J+1) vertices on end procs, or twice that
-     * on interior procs.
-    // make a 3d block of vertices
-  EntitySequence *dum_seq = NULL;
-  ScdVertexData *vseq = NULL;
-  StructuredElementSeq *eseq = NULL;
-  SequenceManager *seq_mgr =
-    dynamic_cast<MBCore*>(mbImpl)->sequence_manager();
-  HomCoord vseq_minmax[2] = {HomCoord(0,0,0),
-                             HomCoord(IJK, IJK, IJK)};
-  MBEntityHandle vstart, estart;
-    seq_mgr->create_scd_sequence(vseq_minmax[0], vseq_minmax[1],
-                                 MBVERTEX, 1, -1, vstart, dum_seq);
-  if (NULL != dum_seq) vseq = dynamic_cast<ScdVertexData*>(dum_seq->data());
-  assert (MB_FAILURE != result && vstart != 0 && dum_seq != NULL &&
-          vseq != NULL);
-    // now the element sequence
-  result = seq_mgr->create_scd_sequence(vseq_minmax[0], vseq_minmax[1],
-                                        MBHEX, 1, -1, estart, dum_seq);
-  if (NULL != dum_seq) eseq = dynamic_cast<StructuredElementSeq*>(dum_seq);
-  assert (MB_FAILURE != result && estart != 0 && dum_seq != NULL &&
-          eseq != NULL);
-    // only need to add one vseq to this, unity transform
-    // trick: if I know it's going to be unity, just input 3 sets of equivalent points
-  result = eseq->sdata()->add_vsequence(vseq, vseq_minmax[0], vseq_minmax[0],
-                               vseq_minmax[0],
-                               vseq_minmax[0], vseq_minmax[0], vseq_minmax[0]);
-  assert(MB_SUCCESS == result);
-    // set the coordinates of the vertices
-  double *coords = NULL;
-  build_coords(IJK, coords);
-    // offset coords by starting z distance
-  double deltaz = my_rank*LENGTH;
-  int num_verts = (IJK + 1)*(IJK + 1)*(IJK + 1);
-  for (int k = 0; k < num_verts; k++)
-    coords[3*k+2] += deltaz;
-  MBRange vrange(vstart, vstart+num_verts-1);
-  result = mbImpl->set_coords(vrange, coords);
-  if (MB_SUCCESS != result) RR("Couldn't build coords array.", MB_FAILURE);
-    // set global ids for vertices; reuse coords space
-  int *gids = (int*) coords;
-  int start_gid = 1 + my_rank * (IJK)*(IJK+1)*(IJK+1);
-  for (int i = 0; i < num_verts; i++)
-    gids[i] = start_gid++;
-  int def_val = -1;
-  MBTag gid_tag;
-                              &def_val, true);
-  result = mbImpl->tag_set_data(gid_tag, vrange, gids);
-  nshared = (IJK+1) * (IJK+1);
-  if (my_rank != 0 && my_rank != mbImpl->proc_size()-1) nshared *= 2;
-  return result;
-void compute_edge(double *start, const int nelem,  const double xint,
-                  const int stride)
-  for (int i = 1; i < nelem; i++) {
-    start[i*stride] = start[0]+i*xint;
-    start[nelem+1+i*stride] = start[nelem+1]+i*xint;
-    start[2*(nelem+1)+i*stride] = start[2*(nelem+1)]+i*xint;
-void compute_face(double *a, const int nelem,  const double xint,
-                  const int stride1, const int stride2)
-    // 2D TFI on a face starting at a, with strides stride1 in ada and stride2 in tse
-  for (int j = 1; j < nelem; j++) {
-    double tse = j * xint;
-      double ada = i * xint;
-      a[i*stride1+j*stride2] = (1.0 - ada)*a[i*stride1]
-        + ada*a[i*stride1+nelem*stride2]
-        + (1.0 - tse)*a[j*stride2]
-        + tse*a[j*stride2+nelem*stride1]
-        - (1.0 - tse)*(1.0 - ada)*a[0]
-        - (1.0 - tse)*ada*a[nelem*stride1]
-        - tse*(1.0 - ada)*a[nelem*stride2]
-        - tse*ada*a[nelem*(stride1+stride2)];
-      a[nelem+1+i*stride1+j*stride2] = (1.0 - ada)*a[nelem+1+i*stride1]
-        + ada*a[nelem+1+i*stride1+nelem*stride2]
-        + (1.0 - tse)*a[nelem+1+j*stride2]
-        + tse*a[nelem+1+j*stride2+nelem*stride1]
-        - (1.0 - tse)*(1.0 - ada)*a[nelem+1+0]
-        - (1.0 - tse)*ada*a[nelem+1+nelem*stride1]
-        - tse*(1.0 - ada)*a[nelem+1+nelem*stride2]
-        - tse*ada*a[nelem+1+nelem*(stride1+stride2)];
-      a[2*(nelem+1)+i*stride1+j*stride2] = (1.0 - ada)*a[2*(nelem+1)+i*stride1]
-        + ada*a[2*(nelem+1)+i*stride1+nelem*stride2]
-        + (1.0 - tse)*a[2*(nelem+1)+j*stride2]
-        + tse*a[2*(nelem+1)+j*stride2+nelem*stride1]
-        - (1.0 - tse)*(1.0 - ada)*a[2*(nelem+1)+0]
-        - (1.0 - tse)*ada*a[2*(nelem+1)+nelem*stride1]
-        - tse*(1.0 - ada)*a[2*(nelem+1)+nelem*stride2]
-        - tse*ada*a[2*(nelem+1)+nelem*(stride1+stride2)];
-    // allocate the memory
-  int numv = nelem+1;
-  int numv_sq = numv*numv;
-  int tot_numv = numv*numv*numv;
-  coords = new double[3*tot_numv];
-// use FORTRAN-like indexing
-#define VINDEX(i,j,k) (i + (j*numv) + (k*numv_sq))
-  int idx;
-  double scale1, scale2, scale3;
-    // use these to prevent optimization on 1-scale, etc (real map wouldn't have
-    // all these equal)
-  scale1 = LENGTH/nelem;
-  scale2 = LENGTH/nelem;
-  scale3 = LENGTH/nelem;
-#ifdef REALTFI
-    // use a real TFI xform to compute coordinates
-    // compute edges
-    // i (stride=1)
-  compute_edge(&coords[VINDEX(0,0,0)], nelem, scale1, 1);
-  compute_edge(&coords[VINDEX(0,nelem,0)], nelem, scale1, 1);
-  compute_edge(&coords[VINDEX(0,0,nelem)], nelem, scale1, 1);
-  compute_edge(&coords[VINDEX(0,nelem,nelem)], nelem, scale1, 1);
-    // j (stride=numv)
-  compute_edge(&coords[VINDEX(0,0,0)], nelem, scale1, numv);
-  compute_edge(&coords[VINDEX(nelem,0,0)], nelem, scale1, numv);
-  compute_edge(&coords[VINDEX(0,0,nelem)], nelem, scale1, numv);
-  compute_edge(&coords[VINDEX(nelem,0,nelem)], nelem, scale1, numv);
-    // k (stride=numv^2)
-  compute_edge(&coords[VINDEX(0,0,0)], nelem, scale1, numv_sq);
-  compute_edge(&coords[VINDEX(nelem,0,0)], nelem, scale1, numv_sq);
-  compute_edge(&coords[VINDEX(0,nelem,0)], nelem, scale1, numv_sq);
-  compute_edge(&coords[VINDEX(nelem,nelem,0)], nelem, scale1, numv_sq);
-    // compute faces
-    // i=0, nelem
-  compute_face(&coords[VINDEX(0,0,0)], nelem, scale1, numv, numv_sq);
-  compute_face(&coords[VINDEX(nelem,0,0)], nelem, scale1, numv, numv_sq);
-    // j=0, nelem
-  compute_face(&coords[VINDEX(0,0,0)], nelem, scale1, 1, numv_sq);
-  compute_face(&coords[VINDEX(0,nelem,0)], nelem, scale1, 1, numv_sq);
-    // k=0, nelem
-  compute_face(&coords[VINDEX(0,0,0)], nelem, scale1, 1, numv);
-  compute_face(&coords[VINDEX(0,0,nelem)], nelem, scale1, 1, numv);
-    // initialize corner indices
-  int i000 = VINDEX(0,0,0);
-  int ia00 = VINDEX(nelem,0,0);
-  int i0t0 = VINDEX(0,nelem,0);
-  int iat0 = VINDEX(nelem,nelem,0);
-  int i00g = VINDEX(0,0,nelem);
-  int ia0g = VINDEX(nelem,0,nelem);
-  int i0tg = VINDEX(0,nelem,nelem);
-  int iatg = VINDEX(nelem,nelem,nelem);
-  double cX, cY, cZ;
-  int adaInts = nelem;
-  int tseInts = nelem;
-  int gammaInts = nelem;
-  for (int i=1; i < nelem; i++) {
-    for (int j=1; j < nelem; j++) {
-      for (int k=1; k < nelem; k++) {
-        idx = VINDEX(i,j,k);
-        double tse = i*scale1;
-        double ada = j*scale2;
-        double gamma = k*scale3;
-        double tm1 = 1.0 - tse;
-        double am1 = 1.0 - ada;
-        double gm1 = 1.0 - gamma;
-        cX = gm1 *   (am1*(tm1*coords[i000] + tse*coords[i0t0])  +
-                      ada*(tm1*coords[ia00] + tse*coords[iat0])) +
-          gamma * (am1*(tm1*coords[i00g] + tse*coords[i0tg])  +
-                   ada*(tm1*coords[ia0g] + tse*coords[iatg]));
-        cY = gm1 *   (am1*(tm1*coords[i000] + tse*coords[i0t0])  +
-        cZ = gm1 *   (am1*(tm1*coords[i000] + tse*coords[i0t0])  +
-        double *ai0k = &coords[VINDEX(k,0,i)];
-        double *aiak = &coords[VINDEX(k,adaInts,i)];
-        double *a0jk = &coords[VINDEX(k,j,0)];
-        double *atjk = &coords[VINDEX(k,j,tseInts)];
-        double *aij0 = &coords[VINDEX(0,j,i)];
-        double *aijg = &coords[VINDEX(gammaInts,j,i)];
-        coords[VINDEX(i,j,k)] = (   am1*ai0k[0]
-                                    + ada*aiak[0]
-                                    + tm1*a0jk[0]
-                                    + tse*atjk[0]
-                                    + gm1*aij0[0]
-                                    + gamma*aijg[0] )/2.0 - cX/2.0;
-        coords[nelem+1+VINDEX(i,j,k)] = (   am1*ai0k[nelem+1]
-                                            + ada*aiak[nelem+1]
-                                            + tm1*a0jk[nelem+1]
-                                            + tse*atjk[nelem+1]
-                                            + gm1*aij0[nelem+1]
-                                            + gamma*aijg[nelem+1] )/2.0 - cY/2.0;
-        coords[2*(nelem+1)+VINDEX(i,j,k)] = (   am1*ai0k[2*(nelem+1)]
-                                                + ada*aiak[2*(nelem+1)]
-                                                + tm1*a0jk[2*(nelem+1)]
-                                                + tse*atjk[2*(nelem+1)]
-                                                + gm1*aij0[2*(nelem+1)]
-                                                + gamma*aijg[2*(nelem+1)] )/2.0 - cZ/2.0;
-#else
-  for (int i=0; i < numv; i++) {
-    for (int j=0; j < numv; j++) {
-      for (int k=0; k < numv; k++) {
-          // blocked coordinate ordering
-        coords[idx] = i*scale1;
-        coords[tot_numv+idx] = j*scale2;
-        coords[2*tot_numv+idx] = k*scale3;
-#endif
-void build_connect(const int nelem, const MBEntityHandle vstart, MBEntityHandle *&connect)
-  int nume_tot = nelem*nelem*nelem;
-  connect = new MBEntityHandle[8*nume_tot];
-  MBEntityHandle vijk;
-  int numv = nelem + 1;
-  int idx = 0;
-  for (int i=0; i < nelem; i++) {
-    for (int j=0; j < nelem; j++) {
-      for (int k=0; k < nelem; k++) {
-        vijk = vstart+VINDEX(i,j,k);
-        connect[idx++] = vijk;
-        connect[idx++] = vijk+1;
-        connect[idx++] = vijk+1+numv;
-        connect[idx++] = vijk+numv;
-        connect[idx++] = vijk+numv*numv;
-        connect[idx++] = vijk+1+numv*numv;
-        connect[idx++] = vijk+1+numv+numv*numv;
-        connect[idx++] = vijk+numv+numv*numv;
-        assert(i <= numv*numv*numv);
-    // read the mesh
-  MBEntityHandle file_set;
-  MBErrorCode result = mbImpl->load_file(filename, file_set, NULL);
-    std::cerr << "Reading file failed; message:" << std::endl;
-    PRINT_LAST_ERROR;
-    return result;
-    // get 3d entities and pack a buffer with them
-  MBRange ents, new_ents, whole_range;
-  result = mbImpl->get_entities_by_handle(file_set, ents);
-  RRA("Getting 3d ents failed.");
-  ents.insert(file_set);
-  MBParallelComm *pcomm = new MBParallelComm(mbImpl);
-  std::vector<unsigned char> buff(1024);
-  int buff_size;
-  result = pcomm->pack_buffer(ents, false, true, false, false, -1,
-                              whole_range, buff, buff_size);
-  RRA("Packing buffer count (non-stored handles) failed.");
-  result = pcomm->unpack_buffer(&buff[0], false, -1, new_ents);
-  RRA("Unacking buffer (non-stored handles) failed.");
-  MBRange iface_ents[6];
-  MBErrorCode result = MB_SUCCESS, tmp_result;
-  for (unsigned int p = 0; p < pcs.size(); p++) {
-      tmp_result = pcs[p]->get_iface_entities(-1, i, iface_ents[i]);
-                  << pcs[p]->proc_config().proc_rank() << "; message: " << std::endl;
-    // report # iface entities
-  int rank;
-  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
-  return result;
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2008-06-29 00:44:33 UTC (rev 1951)
@@ -548,8 +548,10 @@
   success = MPI_Bcast( &buff_size, 1, MPI_INT, from_proc, procConfig.proc_comm() );
-  if (MPI_SUCCESS != success)
+  if (MPI_SUCCESS != success) {
+    result = MB_FAILURE;
+    RRA("MPI_Bcast of buffer size failed.");
   if (!buff_size) // no data
     return MB_SUCCESS;
@@ -558,9 +560,11 @@
     buff.resize(buff_size);
   success = MPI_Bcast( &buff[0], buff_size, MPI_UNSIGNED_CHAR, from_proc, procConfig.proc_comm() );
+    RRA("MPI_Bcast of buffer failed.");
   if ((int)procConfig.proc_rank() != from_proc) {
     result = unpack_buffer(&buff[0], false, from_proc, entities);
     RRA("Failed to unpack buffer in broadcast_entities.");
@@ -2623,7 +2627,8 @@
   MBErrorCode result = mbImpl->tag_create("__tmp_iface", sizeof(MBEntityHandle),
                                           MB_TAG_DENSE, MB_TYPE_HANDLE,
                                           tmp_iface_tag, &tmp_iface_set);
-  RRA("Failed to create temporary iface set tag.");
+  if (MB_ALREADY_ALLOCATED != result && MB_SUCCESS != result)
+    RRA("Failed to create temporary iface set tag.");
   MBRange iface_ents;
   std::vector<MBEntityHandle> tag_vals;
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/parallel/Makefile.am	2008-06-29 00:44:33 UTC (rev 1951)
@@ -43,6 +43,11 @@
   MOAB_PARALLEL_HDRS += WriteHDF5Parallel.hpp
 endif
+  bin_PROGRAMS = mbparallelcomm_test
+  mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
+  mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
+  mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
   MOAB_PARALLEL_TEST += pcomm_unit
 endif
@@ -56,6 +61,7 @@
 # Tests and such
 check_PROGRAMS = $(MOAB_PARALLEL_TEST)
 TESTS = $(MOAB_PARALLEL_TEST)
 pcomm_unit_SOURCES = pcomm_unit.cpp
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/parallel/ReadParallel.cpp	2008-06-29 00:44:33 UTC (rev 1951)
@@ -12,30 +12,31 @@
 #include <iostream>
 #include <sstream>
 #include <algorithm>
+#include <assert.h>
 const bool debug = true;
-#define RR(a) if (MB_SUCCESS != result) {\
-          dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(a);\
-          return result;}
+#define RR(a) if (MB_SUCCESS != result) {                               \
+      dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(a); \
+      return result;}
 enum ParallelActions {PA_READ=0, PA_BROADCAST, PA_DELETE_NONLOCAL,
                       PA_CHECK_GIDS_SERIAL, PA_GET_FILESET_ENTS,
                       PA_RESOLVE_SHARED_ENTS,
                       PA_EXCHANGE_GHOSTS};
 const char *ParallelActionsNames[] = {
-  "PARALLEL READ",
-  "PARALLEL BROADCAST",
-  "PARALLEL DELETE NONLOCAL",
-  "PARALLEL CHECK_GIDS_SERIAL",
-  "PARALLEL GET_FILESET_ENTS",
-  "PARALLEL RESOLVE_SHARED_ENTS",
-  "PARALLEL EXCHANGE_GHOSTS"
+    "PARALLEL READ",
+    "PARALLEL BROADCAST",
+    "PARALLEL DELETE NONLOCAL",
+    "PARALLEL CHECK_GIDS_SERIAL",
+    "PARALLEL GET_FILESET_ENTS",
+    "PARALLEL RESOLVE_SHARED_ENTS",
+    "PARALLEL EXCHANGE_GHOSTS"
 ReadParallel::ReadParallel(MBInterface* impl,
                            MBParallelComm *pc)
-    : mbImpl(impl), myPcomm(pc)
+        : mbImpl(impl), myPcomm(pc)
   if (!myPcomm) {
     myPcomm = MBParallelComm::get_pcomm(mbImpl, 0);
@@ -62,7 +63,7 @@
                      POPT_FORMAT, POPT_LAST};
   MBErrorCode result = opts.match_option( "PARALLEL", parallel_opts,
-                                        parallel_mode );
+                                          parallel_mode );
   if (MB_FAILURE == result) {
     merror->set_last_error( "Unexpected value for 'PARALLEL' option\n" );
     return MB_FAILURE;
@@ -100,7 +101,7 @@
   else if (MB_SUCCESS == result) {
     int num_fields =
-      sscanf(ghost_str.c_str(), "%d.%d.%d", &ghost_dim, &bridge_dim, &num_layers);
+        sscanf(ghost_str.c_str(), "%d.%d.%d", &ghost_dim, &bridge_dim, &num_layers);
     if (3 != num_fields) {
       merror->set_last_error( "Didn't read 3 fields from PARALLEL_GHOSTS string\n" );
       return MB_FAILURE;
@@ -117,7 +118,7 @@
     int num_fields =
-      sscanf(shared_str.c_str(), "%d.%d", &resolve_dim, &shared_dim);
+        sscanf(shared_str.c_str(), "%d.%d", &resolve_dim, &shared_dim);
     if (2 != num_fields) {
       merror->set_last_error( "Didn't read 2 fields from PARALLEL_RESOLVE_SHARED_ENTS string\n" );
       return MB_FAILURE;
@@ -141,42 +142,42 @@
   switch (parallel_mode) {
     case POPT_BCAST:
-      if (is_reader) {
-        pa_vec.push_back(PA_READ);
-        pa_vec.push_back(PA_CHECK_GIDS_SERIAL);
-        pa_vec.push_back(PA_GET_FILESET_ENTS);
-      pa_vec.push_back(PA_BROADCAST);
-      if (!is_reader) pa_vec.push_back(PA_GET_FILESET_ENTS);
+        if (is_reader) {
+          pa_vec.push_back(PA_READ);
+          pa_vec.push_back(PA_CHECK_GIDS_SERIAL);
+          pa_vec.push_back(PA_GET_FILESET_ENTS);
+        pa_vec.push_back(PA_BROADCAST);
+        if (!is_reader) pa_vec.push_back(PA_GET_FILESET_ENTS);
-      break;
+        break;
     case POPT_BCAST_DELETE:
-      if (is_reader) {
+        if (is_reader) {
+        pa_vec.push_back(PA_DELETE_NONLOCAL);
+        break;
+    case POPT_READ_DELETE:
-      pa_vec.push_back(PA_DELETE_NONLOCAL);
-      break;
+        break;
-    case POPT_READ_DELETE:
-      break;
     case POPT_FORMAT:
-      merror->set_last_error( "Access to format-specific parallel read not implemented.\n");
-      return MB_NOT_IMPLEMENTED;
+        merror->set_last_error( "Access to format-specific parallel read not implemented.\n");
+        return MB_NOT_IMPLEMENTED;
     case POPT_READ_PARALLEL:
-      merror->set_last_error( "Partitioning for PARALLEL=READ_PARALLEL not supported yet.\n");
+        merror->set_last_error( "Partitioning for PARALLEL=READ_PARALLEL not supported yet.\n");
     default:
+        return MB_FAILURE;
   if (-2 != resolve_dim) pa_vec.push_back(PA_RESOLVE_SHARED_ENTS);
@@ -217,11 +218,10 @@
   MBRange entities;
   MBTag file_set_tag = 0;
-  int other_sets;
+  int other_sets = 0;
   MBReaderIface* reader;
   MBReaderWriterSet::iterator iter;
   MBRange other_file_sets, file_sets;
-  int tag_val, *tag_val_ptr = &tag_val;
   MBCore *impl = dynamic_cast<MBCore*>(mbImpl);
   std::vector<double> act_times(pa_vec.size()+1);
@@ -230,8 +230,12 @@
   std::vector<int>::iterator vit;
   int i, j;
   act_times[0] = MPI_Wtime();
-  MBRange all_ents, all_ents2;
+    // make a new set for the parallel read
+  result = mbImpl->create_meshset(MESHSET_SET, file_set);
+  if (MB_SUCCESS != result) return result;
+  bool i_read = false;
   for (i = 1, vit = pa_vec.begin();
        vit != pa_vec.end(); vit++, i++) {
@@ -239,172 +243,148 @@
     switch (*vit) {
       case PA_READ:
-        for (j = 0; j < num_files; j++) {
-          if (debug)
-            std::cout << "Reading file " << file_names[j] << std::endl;
+          i_read = true;
+          for (j = 0; j < num_files; j++) {
+            if (debug)
+              std::cout << "Reading file " << file_names[j] << std::endl;
-          MBEntityHandle new_file_set;
+            MBEntityHandle new_file_set = 0;
-          reader = impl->reader_writer_set()->
-            get_file_extension_reader( file_names[j] );
-          if (reader)
-            tmp_result = reader->load_file( file_names[j], new_file_set, opts,
-                                            material_set_list, num_material_sets );
-            delete reader;
-          else
-              // Try all the readers
-            for (iter = impl->reader_writer_set()->begin();
-                 iter != impl->reader_writer_set()->end(); ++iter)
-              reader = iter->make_reader( mbImpl );
-              if (NULL != reader)
+            reader = impl->reader_writer_set()->
+                get_file_extension_reader( file_names[j] );
+            if (reader)
+              tmp_result = reader->load_file( file_names[j], new_file_set, opts,
+                                              material_set_list, num_material_sets );
+              delete reader;
+            else
+                // Try all the readers
+              for (iter = impl->reader_writer_set()->begin();
+                   iter != impl->reader_writer_set()->end(); ++iter)
-                delete reader;
-                if (MB_SUCCESS == tmp_result)
-                  break;
+                reader = iter->make_reader( mbImpl );
+                if (NULL != reader)
+                  delete reader;
+                  if (MB_SUCCESS == tmp_result)
+                    break;
-          if (MB_SUCCESS != tmp_result) break;
-            // accumulate all the entities
-          tmp_result = mbImpl->get_entities_by_handle(new_file_set, all_ents2);
-          all_ents.merge(all_ents2);
+            if (MB_SUCCESS != tmp_result) break;
-          // make a new set for the parallel read, if necessary,
-          // and put ents in that
-        if (0 == file_set) {
-          tmp_result = mbImpl->create_meshset(MESHSET_SET, file_set);
+              // put the contents of each file set for the reader into the
+              // file set for the parallel read
+            assert(0 != new_file_set);
+            MBRange all_ents;
+            tmp_result = mbImpl->get_entities_by_handle(new_file_set, all_ents);
+            all_ents.insert(new_file_set);
+            tmp_result = mbImpl->add_entities(file_set, all_ents);
-        tmp_result = mbImpl->add_entities(file_set, all_ents);
-          // mark the file set
-        other_sets = 0;
-        tmp_result = mbImpl->tag_create("__file_set", sizeof(int),
-                                        MB_TAG_SPARSE,
-                                        MB_TYPE_INTEGER, file_set_tag,
-                                        0, true);
-        if (MB_ALREADY_ALLOCATED == tmp_result) {
-          tmp_result = mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET,
-                                                            &file_set_tag, NULL, 1,
-                                                            other_file_sets);
-          if (MB_SUCCESS == tmp_result) other_sets = other_file_sets.size();
+            // mark the file set for this parallel reader
+          tmp_result = mbImpl->tag_create("__file_set", sizeof(int),
+                                          MB_TAG_SPARSE,
+                                          MB_TYPE_INTEGER, file_set_tag,
+                                          0, true);
           tmp_result = mbImpl->tag_set_data(file_set_tag, &file_set, 1,
                                             &other_sets);
-        break;
+          break;
       case PA_GET_FILESET_ENTS:
-        if (debug)
-          std::cout << "Getting fileset entities." << std::endl;
+          if (debug)
+            std::cout << "Getting fileset entities." << std::endl;
-        if (0 == file_set_tag) {
-          tmp_result = mbImpl->tag_get_handle("__file_set", file_set_tag);
-          if (MB_SUCCESS == tmp_result) {
-            other_file_sets.clear();
-            file_sets.clear();
-                                                              &file_set_tag,
-                                                              NULL, 1,
-                                                              other_file_sets);
-            if (MB_SUCCESS == tmp_result && other_file_sets.size() > 1) {
-              tag_val = other_file_sets.size();
-                                                            &file_set_tag,
-                                                            (void*const*)
-                                                            &tag_val_ptr, 1,
-                                                            file_sets);
-              if (!file_sets.empty()) other_file_sets = file_sets;
-            if (!other_file_sets.empty()) file_set = *other_file_sets.rbegin();
-          // get entities in the file set, and add actual file set to it;
-          // mark the file set to make sure any receiving procs know which it
-          // is
-        tmp_result = mbImpl->get_entities_by_handle( file_set, entities );
-          entities.clear();
+            // get entities in the file set, and add actual file set to it;
+            // mark the file set to make sure any receiving procs know which it
+            // is
+          tmp_result = mbImpl->get_entities_by_handle( file_set, entities );
+            entities.clear();
-          // add actual file set to entities too
-        entities.insert(file_set);
-        break;
+            // add actual file set to entities too
+          entities.insert(file_set);
+          break;
       case PA_BROADCAST:
-          // do the actual broadcast; if single-processor, ignore error
-        if (debug)
-          std::cout << "Broadcasting mesh." << std::endl;
+            // do the actual broadcast; if single-processor, ignore error
+          if (debug)
+            std::cout << "Broadcasting mesh." << std::endl;
-        if (myPcomm->proc_config().proc_size() > 1)
-          tmp_result = myPcomm->broadcast_entities( reader_rank, entities );
+          if (myPcomm->proc_config().proc_size() > 1)
+            tmp_result = myPcomm->broadcast_entities( reader_rank, entities );
-        if (debug) {
-          std::cerr << "Bcast done; entities:" << std::endl;
-          mbImpl->list_entities(0, 0);
-        break;
+          if (debug) {
+            std::cerr << "Bcast done; entities:" << std::endl;
+            mbImpl->list_entities(0, 0);
+            // add the received entities to this fileset if I wasn't the reader
+          if (!i_read)
+            tmp_result = mbImpl->add_entities(file_set, entities);
+          break;
       case PA_DELETE_NONLOCAL:
-        if (debug)
-          std::cout << "Deleting nonlocal entities." << std::endl;
+          if (debug)
+            std::cout << "Deleting nonlocal entities." << std::endl;
-        tmp_result = delete_nonlocal_entities(partition_tag_name,
-                                              partition_tag_vals,
-                                              distrib,
-                                              file_set);
-        if (debug) {
-          std::cerr << "Delete nonlocal done; entities:" << std::endl;
-        break;
+          tmp_result = delete_nonlocal_entities(partition_tag_name,
+                                                partition_tag_vals,
+                                                distrib,
+                                                file_set);
+          if (debug) {
+            std::cerr << "Delete nonlocal done; entities:" << std::endl;
+          break;
       case PA_CHECK_GIDS_SERIAL:
-        if (debug)
-          std::cout << "Checking global ids." << std::endl;
+          if (debug)
+            std::cout << "Checking global ids." << std::endl;
-        tmp_result = myPcomm->check_global_ids(file_set, 0, 1, true, false);
-        break;
+          tmp_result = myPcomm->check_global_ids(file_set, 0, 1, true, false);
+          break;
       case PA_RESOLVE_SHARED_ENTS:
-        if (debug)
-          std::cout << "Resolving shared entities." << std::endl;
+          if (debug)
+            std::cout << "Resolving shared entities." << std::endl;
-        tmp_result = myPcomm->resolve_shared_ents(file_set, resolve_dim, shared_dim);
-        break;
+          tmp_result = myPcomm->resolve_shared_ents(file_set, resolve_dim, shared_dim);
+          break;
       case PA_EXCHANGE_GHOSTS:
-        if (debug)
-          std::cout << "Exchanging ghost entities." << std::endl;
+          if (debug)
+            std::cout << "Exchanging ghost entities." << std::endl;
-        tmp_result = myPcomm->exchange_ghost_cells(ghost_dim, bridge_dim,
-                                                   num_layers, true);
-        break;
+          tmp_result = myPcomm->exchange_ghost_cells(ghost_dim, bridge_dim,
+                                                     num_layers, true);
+          break;
       default:
     if (MB_SUCCESS != tmp_result &&
-        (*vit != PA_BROADCAST || myPcomm->proc_config().proc_size() != 1)) {
+        myPcomm->proc_config().proc_size() != 1) {
       std::ostringstream ostr;
       ostr << "Failed in step " << ParallelActionsNames[*vit] << std::endl;
@@ -478,12 +458,16 @@
     MBRange tmp_sets;
       // distribute the partition sets
+    unsigned int tot_sets = myPcomm->partition_sets().size();
     unsigned int num_sets = myPcomm->partition_sets().size() / proc_sz;
     if (proc_rk < (int) (myPcomm->partition_sets().size() % proc_sz)) num_sets++;
-    for (unsigned int i = 0; i < num_sets; i++)
-      tmp_sets.insert(myPcomm->partition_sets()[i*proc_sz + proc_rk]);
+    for (unsigned int i = 0; i < num_sets; i++) {
+// drop round-robin      tmp_sets.insert(myPcomm->partition_sets()[i*proc_sz + proc_rk]);
+      if (num_sets*proc_rk+i < tot_sets)
+        tmp_sets.insert(myPcomm->partition_sets()[num_sets*proc_rk+i]);
     myPcomm->partition_sets().swap(tmp_sets);
@@ -547,6 +531,11 @@
   result = mbImpl->get_entities_by_handle(file_set, file_ents);
   RR("Couldn't get pre-existing entities.");
+  if (myPcomm->proc_config().proc_rank() == 0) {
+    std::cout << "File entities: " << std::endl;
+    file_ents.print("ff  ");
     // get deletable entities by subtracting partition ents from file ents
   MBRange deletable_ents = file_ents.subtract(partition_ents);
@@ -564,13 +553,24 @@
   if (debug) std::cout << "Deleting deletable entities." << std::endl;
+    std::cout << "Deletable sets: " << std::endl;
+    deletable_sets.print("ff  ");
     // delete sets, then ents
   if (!deletable_sets.empty())
     result = mbImpl->delete_entities(deletable_sets);
   RR("Failure deleting sets in delete_nonlocal_entities.");
   deletable_ents = deletable_ents.subtract(deletable_sets);
+    std::cout << "Deletable entities: " << std::endl;
+    deletable_ents.print("ff  ");
   if (!deletable_ents.empty())
     result = mbImpl->delete_entities(deletable_ents);
   RR("Failure deleting entities in delete_nonlocal_entities.");
Added: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp	                        (rev 0)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp	2008-06-29 00:44:33 UTC (rev 1951)
@@ -0,0 +1,482 @@
+/** test of MBParallelComm functionality
+ * To run:
+ * mpirun -np <#procs> mbparallelcomm_test
+#include "MBParallelComm.hpp"
+#include "MBParallelConventions.h"
+#include "ReadParallel.hpp"
+#include "FileOptions.hpp"
+#include "MBTagConventions.hpp"
+#include "MBCore.hpp"
+#include "ScdVertexData.hpp"
+#include "StructuredElementSeq.hpp"
+#include "SequenceManager.hpp"
+#include "MBError.hpp"
+#include "mpi.h"
+#include <iostream>
+#include <sstream>
+#define REALTFI 1
+const bool debug = false;
+#define ERROR(a, b) {std::cerr << a << std::endl; return b;}
+#define PRINT_LAST_ERROR {\
+        std::string last_error;\
+        result = mbImpl->get_last_error(last_error);\
+        if (last_error.empty()) std::cerr << "(none)" << std::endl;\
+        else std::cerr << last_error << std::endl;\
+#define RRA(a) if (MB_SUCCESS != result) {\
+      std::string tmp_str; mbImpl->get_last_error(tmp_str);\
+      tmp_str.append("\n"); tmp_str.append(a);\
+      dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(tmp_str.c_str()); \
+      return result;}
+MBErrorCode create_linear_mesh(MBInterface *mbImpl,
+                               int N, int M, int &nshared);
+MBErrorCode create_scd_mesh(MBInterface *mbImpl,
+                            int IJK, int &nshared);
+MBErrorCode read_file(MBInterface *mbImpl, std::vector<std::string> &filenames,
+                      const char *tag_name, int tag_val, int distrib,
+                      int parallel_option, int resolve_shared, int with_ghosts);
+MBErrorCode test_packing(MBInterface *mbImpl, const char *filename);
+MBErrorCode report_nsets(MBInterface *mbImpl);
+MBErrorCode report_iface_ents(MBInterface *mbImpl,
+                              std::vector<MBParallelComm *> &pcs);
+int main(int argc, char **argv)
+    // need to init MPI first, to tell how many procs and rank
+  int err = MPI_Init(&argc, &argv);
+  int nprocs, rank;
+  err = MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+  err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+    // start time
+  double stime, rtime, setime, dtime, ltime;
+  if (0 == rank) stime = MPI_Wtime();
+    // create MOAB instance based on that
+  MBInterface *mbImpl = new MBCore(rank, nprocs);
+  if (NULL == mbImpl) return 1;
+  MBErrorCode result = MB_SUCCESS;
+    // each interior proc has a vector of N+M vertices, sharing
+    // M vertices each with lower- and upper-rank processors, except
+    // procs on the end
+    // get N, M from command line
+  int N, M;
+  if (argc < 3) {
+    if (0 == rank)
+      std::cerr
+        << "Usage: " << argv[0]
+        << " [readpar_option] <opt> <input> [...] where:" << std::endl
+        << " readpar_option = 0 (BCAST_DELETE) (default), -1 (READ_DELETE), " << std::endl
+        << "                 -2 (READ_PARALLEL), -3 (BCAST)" << std::endl
+        << "opt   input" << std::endl
+        << "===   =====" << std::endl
+        << " 1     <linear_ints> <shared_verts> " << std::endl
+        << " 2     <n_ints> " << std::endl
+        << " 3*    <file_name> [<tag_name>=\"MATERIAL_SET\" [tag_val] [distribute=1] [resolve_shared=1] [with_ghosts=1]" << std::endl
+        << " 4    <file_name> " << std::endl
+        << "*Note: if opt 3 is used, it must be the last one." << std::endl;
+    err = MPI_Finalize();
+    return 1;
+  int npos = 1, tag_val, distrib, with_ghosts = 1, resolve_shared = 1;
+  const char *tag_name;
+  std::vector<std::string> filenames;
+  int parallel_option = 0;
+  while (npos < argc) {
+    MBErrorCode tmp_result;
+    int nshared = -1;
+    int this_opt = strtol(argv[npos++], NULL, 0);
+    switch (this_opt) {
+      case 0:
+      case -1:
+      case -2:
+      case -3:
+        parallel_option = this_opt;
+        continue;
+      case 3:
+          // read a file in parallel from the filename on the command line
+        tag_name = "MATERIAL_SET";
+        tag_val = -1;
+        filenames.push_back(std::string(argv[npos++]));
+        if (npos < argc) tag_name = argv[npos++];
+        if (npos < argc) tag_val = strtol(argv[npos++], NULL, 0);
+        if (npos < argc) distrib = strtol(argv[npos++], NULL, 0);
+        else distrib = 1;
+        if (npos < argc) resolve_shared = strtol(argv[npos++], NULL, 0);
+        if (npos < argc) with_ghosts = strtol(argv[npos++], NULL, 0);
+        tmp_result = read_file(mbImpl, filenames, tag_name, tag_val,
+                               distrib, parallel_option,
+                               resolve_shared, with_ghosts);
+        if (MB_SUCCESS != tmp_result) {
+          result = tmp_result;
+          std::cerr << "Couldn't read mesh; error message:" << std::endl;
+          PRINT_LAST_ERROR;
+          MPI_Abort(MPI_COMM_WORLD, result);
+        nshared = -1;
+        break;
+      case 4:
+        filenames.push_back(argv[npos++]);
+        tmp_result = test_packing(mbImpl, filenames[0].c_str());
+          std::cerr << "Packing test failed; error message:" << std::endl;
+          PRINT_LAST_ERROR
+        break;
+      case 5:
+        distrib = 1;
+        tag_val = -1;
+        with_ghosts = 0;
+        resolve_shared = 1;
+                               distrib, parallel_option, resolve_shared,
+                               with_ghosts);
+          PRINT_LAST_ERROR;
+        nshared = -1;
+        break;
+      default:
+        std::cerr << "Unrecognized option \"" << this_opt
+                  << "\"; skipping." << std::endl;
+        tmp_result = MB_FAILURE;
+    if (0 == rank) rtime = MPI_Wtime();
+    if (MB_SUCCESS == tmp_result && 4 != this_opt && false) {
+        // now figure out which vertices are shared
+      MBParallelComm *pcomm = MBParallelComm::get_pcomm(mbImpl, 0);
+      assert(pcomm);
+      MBRange iface_ents[7];
+      for (int i = 0; i < 4; i++) {
+        tmp_result = pcomm->get_iface_entities(-1, i, iface_ents[i]);
+          std::cerr << "get_iface_entities returned error on proc "
+                    << rank << "; message: " << std::endl;
+          PRINT_LAST_ERROR;
+        if (0 != i) iface_ents[4].merge(iface_ents[i]);
+      result = pcomm->get_part_entities(iface_ents[6], -1);
+      PRINT_LAST_ERROR;
+      std::cerr << "Proc " << rank << " partition entities:" << std::endl;
+      iface_ents[6].print("   ");
+      if (0 == rank) setime = MPI_Wtime();
+        // check # iface entities
+      if (0 <= nshared && nshared != (int) iface_ents[0].size()) {
+        std::cerr << "Didn't get correct number of iface vertices on "
+                  << "processor " << rank << std::endl;
+      else
+        std::cerr << "Proc " << rank << " option " << this_opt
+                << " succeeded." << std::endl;
+      if (-1 == nshared) {
+        result = mbImpl->get_adjacencies(iface_ents[4], 0, false, iface_ents[5],
+                                         MBInterface::UNION);
+        std::cerr << "Proc " << rank << " iface entities: " << std::endl;
+          std::cerr << "    " << iface_ents[i].size() << " "
+                    << i << "d iface entities." << std::endl;
+        std::cerr << "    (" << iface_ents[5].size()
+                  << " verts adj to other iface ents)" << std::endl;
+      if (debug && false) {
+//      if (debug && 2 == nprocs) {
+          // if I'm root, get and print handles on other procs
+        std::vector<MBEntityHandle> sharedh_tags(iface_ents[0].size());
+        std::fill(sharedh_tags.begin(), sharedh_tags.end(), 0);
+        MBTag dumt, sharedh_tag;
+        result = pcomm->get_shared_proc_tags(dumt, dumt, sharedh_tag, dumt, dumt);
+        result = mbImpl->tag_get_data(sharedh_tag, iface_ents[0], &sharedh_tags[0]);
+        if (MB_SUCCESS != result) {
+          std::cerr << "Couldn't get shared handle tag." << std::endl;
+        else {
+          MBRange dum_range;
+          std::copy(sharedh_tags.begin(), sharedh_tags.end(), mb_range_inserter(dum_range));
+          std::cerr << "Shared handles: " << std::endl;
+          dum_range.print();
+      result = report_nsets(mbImpl);
+      if (0 == rank) ltime = MPI_Wtime();
+      delete pcomm;
+      tmp_result = mbImpl->delete_mesh();
+        std::cerr << "Couldn't delete mesh on rank " << rank
+                  << "; error message: " << std::endl;
+        PRINT_LAST_ERROR
+  if (0 == rank) dtime = MPI_Wtime();
+  if (MB_SUCCESS == result)
+    std::cerr << "Proc " << rank << ": Success." << std::endl;
+  if (0 == rank) std::cout << "Times: "
+                           << dtime-stime << " "
+                           << rtime-stime << " "
+                           << setime-rtime << " "
+                           << ltime-setime << " "
+                           << dtime - ltime
+                           << " (total/read/shared/report/delete)"
+                           << std::endl;
+  return (MB_SUCCESS == result ? 0 : 1);
+    // get and report various numbers...
+  int rank = mbImpl->proc_rank();
+  MBRange matsets, geomsets, parsets;
+  int nsets;
+  MBTag mtag = 0, gtag = 0, ptag = 0, gidtag;
+  MBErrorCode result = mbImpl->tag_get_handle("MATERIAL_SET", mtag);
+  result = mbImpl->tag_get_handle("GEOM_DIMENSION", gtag);
+  result = mbImpl->tag_get_handle("PARALLEL_PARTITION", ptag);
+  result = mbImpl->tag_get_handle("GLOBAL_ID", gidtag);
+  result = mbImpl->get_number_entities_by_type(0, MBENTITYSET, nsets);
+  std::cout << "Proc " << rank << ": Total of " << nsets
+            << " entity sets." << std::endl;
+#define PRINTSETS(a, b, c, p) \
+  if (a) {\
+    result = mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, & a,\
+                                                  p, 1, b); \
+    if (! b .empty()) {\
+      std::vector<int> ids( b .size());\
+      result = mbImpl->tag_get_data(gidtag, b, &ids[0]); \
+      if (MB_SUCCESS == result) {\
+        std::cout << "Proc " << rank << ": " << c \
+          << " (total " << b.size() << "): " \
+           << ids[0]; \
+        for (unsigned int i = 1; i < b .size(); i++) \
+          std::cout << ", " << ids[i]; \
+        std::cout << std::endl; \
+  PRINTSETS(mtag, matsets, "material sets", NULL);
+  int tval = 3;
+  void *pval = &tval;
+  PRINTSETS(gtag, geomsets, "geom sets (vols)", &pval);
+  tval = 2;
+  geomsets.clear();
+  PRINTSETS(gtag, geomsets, "geom sets (surfs)", &pval);
+  tval = 1;
+  geomsets.clear();
+  PRINTSETS(gtag, geomsets, "geom sets (curves)", &pval);
+  tval = 0;
+  geomsets.clear();
+  PRINTSETS(gtag, geomsets, "geom sets (verts)", &pval);
+  PRINTSETS(ptag, parsets, "partition sets", NULL);
+  if (debug) {
+      // list info on all ent sets, reuse parsets
+    parsets.clear();
+    result = mbImpl->get_entities_by_type(0, MBENTITYSET, parsets);
+      std::cout << "Total sets (by range): " << parsets.size() << "; sets: " << std::endl;
+      parsets.print("  ");
+      mbImpl->list_entities(parsets);
+  return MB_SUCCESS;
+                      std::vector<std::string> &filenames,
+                      int distrib, int parallel_option, int resolve_shared,
+                      int with_ghosts)
+  std::ostringstream options;
+  switch (parallel_option) {
+    case 0:
+      options << "PARALLEL=BCAST_DELETE;PARTITION=" << tag_name;
+      break;
+    case -1:
+      options << "PARALLEL=READ_DELETE;PARTITION=" << tag_name;
+      break;
+    case -2:
+      options << "PARALLEL=READ_PARALLEL;PARTITION=" << tag_name;
+      break;
+    case -3:
+      options << "PARALLEL=BCAST;PARTITION=" << tag_name;
+      break;
+    default:
+  if (-1 != tag_val)
+    options << ";PARTITION_VAL=" << tag_val;
+  if (1 == distrib)
+    options << ";PARTITION_DISTRIBUTE";
+  if (1 == resolve_shared)
+    options << ";PARALLEL_RESOLVE_SHARED_ENTS";
+  if (1 == with_ghosts)
+    options << ";PARALLEL_GHOSTS=3.0.1";
+  options << ";CPUTIME";
+  std::vector<MBEntityHandle> filesets(filenames.size());
+  std::vector<MBParallelComm*> pcs(filenames.size());
+  std::vector<ReadParallel*> rps(filenames.size());
+  MBErrorCode result;
+  for (unsigned int i = 0; i < filenames.size(); i++) {
+    pcs[i] = new MBParallelComm(mbImpl);
+    rps[i] = new ReadParallel(mbImpl, pcs[i]);
+    result = rps[i]->load_file(filenames[i].c_str(), filesets[i],
+                               FileOptions(options.str().c_str()), NULL, 0);
+    PRINT_LAST_ERROR;
+      break;
+  if (MB_SUCCESS == result) report_iface_ents(mbImpl, pcs);
+  return result;
+    // read the mesh
+  MBEntityHandle file_set;
+  MBErrorCode result = mbImpl->load_file(filename, file_set, NULL);
+    std::cerr << "Reading file failed; message:" << std::endl;
+    PRINT_LAST_ERROR;
+    return result;
+    // get 3d entities and pack a buffer with them
+  MBRange ents, new_ents, whole_range;
+  result = mbImpl->get_entities_by_handle(file_set, ents);
+  RRA("Getting 3d ents failed.");
+  ents.insert(file_set);
+  MBParallelComm *pcomm = new MBParallelComm(mbImpl);
+  std::vector<unsigned char> buff(1024);
+  int buff_size;
+  result = pcomm->pack_buffer(ents, false, true, false, false, -1,
+                              whole_range, buff, buff_size);
+  RRA("Packing buffer count (non-stored handles) failed.");
+  result = pcomm->unpack_buffer(&buff[0], false, -1, new_ents);
+  RRA("Unacking buffer (non-stored handles) failed.");
+  MBRange iface_ents[6];
+  MBErrorCode result = MB_SUCCESS, tmp_result;
+  for (unsigned int p = 0; p < pcs.size(); p++) {
+      tmp_result = pcs[p]->get_iface_entities(-1, i, iface_ents[i]);
+                  << pcs[p]->proc_config().proc_rank() << "; message: " << std::endl;
+    // report # iface entities
+  int rank;
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  return result;
Modified: MOAB/trunk/tools/mbcoupler/Makefile.am
--- MOAB/trunk/tools/mbcoupler/Makefile.am	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/tools/mbcoupler/Makefile.am	2008-06-29 00:44:33 UTC (rev 1951)
@@ -41,9 +41,11 @@
 elem_util_test_SOURCES = ElemUtilTest.cpp
 elem_util_test_LDADD = libmbcoupler.la $(top_builddir)/libMOAB.la
+bin_PROGRAMS =
 if PARALLEL
-  TESTS += mbcoupler_test
-  check_PROGRAMS += mbcoupler_test
+#  TESTS += mbcoupler_test
+#  check_PROGRAMS += mbcoupler_test
+  bin_PROGRAMS += mbcoupler_test
   mbcoupler_test_SOURCES = mbcoupler_test.cpp
   mbcoupler_test_LDADD = libmbcoupler.la $(top_builddir)/libMOAB.la
   INCLUDES += -I$(srcdir)/parallel
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-29 00:44:33 UTC (rev 1951)
@@ -50,7 +50,7 @@
     std::cerr << "nfiles        : number of mesh files" << std::endl;
     std::cerr << "fname1..fnamen: mesh files" << std::endl;
     std::cerr << "interp_tag    : name of tag interpolated to target mesh []" << std::endl;
-    std::cerr << "tag_name      : name of tag used to define partitions [MATERIAL_SET]" << std::endl;
+    std::cerr << "tag_name      : name of tag used to define partitions [GEOM_DIMENSION]" << std::endl;
     std::cerr << "tag_val       : tag values denoting partition sets [--]" << std::endl;
     std::cerr << "distrib       : if non-zero, distribute the partition sets with tag_val round-robin" << std::endl;
     std::cerr << "with_ghosts   : if non-zero, after initializing in parallel, also exchange one layer of ghost elements" << std::endl;
@@ -111,9 +111,13 @@
     // output mesh
   const char *outfile = "output.h5m";
-  result = mbImpl->write_file(outfile, NULL, "PARALLEL=FORMAT",
-			      pcs[1]->partition_sets());
+  const char *out_option =
+//      "PARALLEL_FORMAT";
+      NULL;
+  if (pcs[1]->proc_config().proc_rank() == 0)
+    result = mbImpl->write_file(outfile, NULL, out_option,
+                                pcs[1]->partition_sets());
   PRINT_LAST_ERROR;
   std::cout << "Wrote " << outfile << std::endl;
@@ -187,7 +191,7 @@
   if (npos < argc) interp_tag = argv[npos++];
     // get partition information
-  const char *tag_name = "MATERIAL_SET";
+  const char *tag_name = "GEOM_DIMENSION";
   int tag_val = -1;
   int distrib = 1;
   int with_ghosts = 0;
@@ -196,8 +200,11 @@
+  if (-1 == tag_val && !strcmp(tag_name, "GEOM_DIMENSION"))
+    tag_val = 3;
   if (-1 != tag_val)
Modified: MOAB/trunk/tools/size/size.cpp
--- MOAB/trunk/tools/size/size.cpp	2008-06-28 15:35:19 UTC (rev 1950)
+++ MOAB/trunk/tools/size/size.cpp	2008-06-29 00:44:33 UTC (rev 1951)
@@ -272,7 +272,8 @@
     double tmp_dbl = s.sqr / s.count - s.sum*s.sum / (double)s.count / (double)s.count;
     if (tmp_dbl < 0.0) {
-      assert(-tmp_dbl < 100.0*DBL_EPSILON);
+      if (-tmp_dbl < 100.0*DBL_EPSILON)
+        std::cout << "WARNING: stat values dubious, s^2 - sig_s = " << tmp_dbl << std::endl;
       tmp_dbl = 0.0;
