[MOAB-dev] r1950 - MOAB/trunk/tools/mbcoupler
tautges at mcs.anl.gov
Sat Jun 28 10:35:19 CDT 2008
Author: tautges
Date: 2008-06-28 10:35:19 -0500 (Sat, 28 Jun 2008)
New Revision: 1950
Added:
MOAB/trunk/tools/mbcoupler/addfield.cpp
Log:
Putting the utility addfield here for now; adds an arbitrary
field to vertices (vertex_field) and 3d elements (element_field).
Added: MOAB/trunk/tools/mbcoupler/addfield.cpp
--- MOAB/trunk/tools/mbcoupler/addfield.cpp (rev 0)
+++ MOAB/trunk/tools/mbcoupler/addfield.cpp 2008-06-28 15:35:19 UTC (rev 1950)
@@ -0,0 +1,124 @@
+#include <iostream>
+#include "MBCore.hpp"
+using namespace std;
+//make a nice picture. tweak here
+//217: x,y -> [-8, 8] /// z -> [-65, 65]
+double physField(double x, double y, double z){
+ double out;
+ // 1/r^2 decay from {0,0,0}
+ out = x*x + y*y + z*z;
+ out += 1e-1; // clamp
+ out = 1/out;
+ return out;
+//get some sort of element center
+void getHexPos(MBInterface *mbi, MBEntityHandle *hex, double &x, double &y, double &z){
+ std::vector<MBEntityHandle> connect;
+ mbi->get_connectivity(hex, 1, connect);
+ double pos[3]={0,0,0};
+ int numVerts = connect.size();
+ for(int i=0; i<numVerts; i++){
+ double tempPos[3];
+ MBEntityHandle vert(connect[i]);
+ mbi->get_coords(&vert, 1, tempPos);
+ for(int j=0; j<3; j++){
+ pos[j] += tempPos[j]/numVerts;
+ x = pos[0];
+ y = pos[1];
+ z = pos[2];
+void putElementField(MBInterface *mbi, char *tagname){
+ MBRange hexes;
+ mbi->get_entities_by_type(0, MBHEX, hexes);
+ const double defVal = 0.;
+ MBTag fieldTag;
+ mbi->tag_create(tagname, sizeof(double), MB_TAG_DENSE, MB_TYPE_DOUBLE, fieldTag, &defVal);
+ int numHexes = hexes.size();
+ for(int i=0; i<numHexes; i++){
+ //cout << hexes[i] << endl;
+ MBEntityHandle hex = hexes[i];
+ double x,y,z;
+ getHexPos(mbi, &hex, x,y,z);
+ double fieldValue = physField(x,y,z);
+ mbi->tag_set_data(fieldTag, &hex, 1, &fieldValue);
+void putVertexField(MBInterface *mbi, char *tagname){
+ MBRange verts;
+ mbi->get_entities_by_type(0, MBVERTEX, verts);
+ MBTag fieldTag;
+ int numVerts = verts.size();
+ MBEntityHandle vert = verts[i]; //?
+ double vertPos[3];
+ mbi->get_coords(&vert, 1, vertPos);
+ double fieldValue = physField(vertPos[0], vertPos[1], vertPos[2]);
+ mbi->tag_set_data(fieldTag, &vert, 1, &fieldValue);
+//Using moab instead of imesh for dev speed
+int main(int argc, char **argv){
+ MBInterface *mbi = new MBCore();
+ if (argc != 3){
+ cout << "Usage: " << argv[0] << " <infile> <outfile> \n"
+ << "Writes both vertex and element fields.\n";
+ return 0;
+ mbi->load_mesh(argv[1]);
+ putVertexField(mbi, "vertex_field");
+ putElementField(mbi, "element_field");
+ MBErrorCode result = mbi->write_mesh(argv[2]);
+ if (MB_SUCCESS == result) cout << "wrote " << argv[2] << endl;
+ else cout << "Failed to write " << argv[2] << endl;
+ // vector<double> coords;
+ // mbi->get_vertex_coordinates(coords);
+ // double xavg = 0;
+ // for (int i = 0; i < coords.size()/3; i++) xavg += coords[i];
+ // cout << xavg << endl;
+ return 1;
