[MOAB-dev] r1948 - MOAB/trunk/refiner
dcthomp at mcs.anl.gov
Fri Jun 27 19:32:21 CDT 2008
Author: dcthomp
Date: 2008-06-27 19:32:21 -0500 (Fri, 27 Jun 2008)
New Revision: 1948
Modified:
MOAB/trunk/refiner/test_mesh_refiner.cpp
Log:
STYLE: Remove a debug printout
STYLE: Move some refinement code below the initialization.
Modified: MOAB/trunk/refiner/test_mesh_refiner.cpp
--- MOAB/trunk/refiner/test_mesh_refiner.cpp 2008-06-28 00:28:15 UTC (rev 1947)
+++ MOAB/trunk/refiner/test_mesh_refiner.cpp 2008-06-28 00:32:21 UTC (rev 1948)
@@ -34,23 +34,7 @@
MBInterface* imesh = new MBCore( rank, nprocs );
MBInterface* omesh = input_is_output ? imesh : new MBCore( rank, nprocs );
- // Print out the process ranks, one at a time.
#ifdef USE_MPI
- for ( int i = 0; i < nprocs; ++ i )
- MPI_Barrier( MPI_COMM_WORLD );
- if ( i == rank )
- std::cout << "Rank: " << ( rank + 1 ) << " of: " << nprocs << "\n";
-#endif // USE_MPI
- // The refiner will need an implicit function to be used as an indicator function for subdivision:
- MBEdgeSizeSimpleImplicit* eval = new MBEdgeSizeSimpleImplicit();
- eval->set_ratio( 2. );
-#ifdef USE_MPI
// Use an MBParallelComm object to help set up the input mesh
MBParallelComm* ipcomm = new MBParallelComm( imesh );
ReadParallel* readpar = new ReadParallel( imesh, ipcomm );
@@ -99,6 +83,9 @@
imesh->list_entities( 0, 1 );
#endif // USE_MPI
+ // The refiner will need an implicit function to be used as an indicator function for subdivision:
+ MBEdgeSizeSimpleImplicit* eval = new MBEdgeSizeSimpleImplicit();
+ eval->set_ratio( 2. );
// Refine the mesh
MBMeshRefiner* mref = new MBMeshRefiner( imesh, omesh );
MBSimplexTemplateRefiner* eref = new MBSimplexTemplateRefiner;
