[MOAB-dev] r1947 - MOAB/trunk/refiner
dcthomp at mcs.anl.gov dcthomp at mcs.anl.gov
Fri Jun 27 19:28:15 CDT 2008
Author: dcthomp
Date: 2008-06-27 19:28:15 -0500 (Fri, 27 Jun 2008)
New Revision: 1947
Modified:
   MOAB/trunk/refiner/MBMeshOutputFunctor.hpp
   MOAB/trunk/refiner/test_mesh_refiner.cpp
Log:
ENH: Checkpoint on progress. Load a file (hardwired right now)
     rather than create a mesh programmatically. Do not print
     out tags that are not present in the file.
Modified: MOAB/trunk/refiner/MBMeshOutputFunctor.hpp
--- MOAB/trunk/refiner/MBMeshOutputFunctor.hpp	2008-06-27 22:17:16 UTC (rev 1946)
+++ MOAB/trunk/refiner/MBMeshOutputFunctor.hpp	2008-06-28 00:28:15 UTC (rev 1947)
@@ -114,12 +114,14 @@
       std::cout << ", " << vcoords[i];
     std::cout << " ] ";
+#if 0
     double* x = (double*)vtags;
     int* m = (int*)( (char*)vtags + 2 * sizeof( double ) );
     std::cout << "< " << x[0]
               << ", " << x[1];
     for ( int i = 0; i < 4; ++i )
       std::cout << ", " << m[i];
+#endif // 0
     std::cout << " >\n";
Modified: MOAB/trunk/refiner/test_mesh_refiner.cpp
--- MOAB/trunk/refiner/test_mesh_refiner.cpp	2008-06-27 22:17:16 UTC (rev 1946)
+++ MOAB/trunk/refiner/test_mesh_refiner.cpp	2008-06-28 00:28:15 UTC (rev 1947)
@@ -7,10 +7,13 @@
 #ifdef USE_MPI
 #include "MBParallelComm.hpp"
+#include "ReadParallel.hpp"
+#include "FileOptions.hpp"
 #include "mpi.h"
 #endif // USE_MPI
 #include <iostream>
+#include <sstream>
 #include <map>
 int TestMeshRefiner( int argc, char* argv[] )
@@ -26,7 +29,8 @@
 #endif // USE_MPI
   // Create the input mesh and, if -new-mesh is specified, an output mesh
-  bool input_is_output = ( argc > 1 && ! strcmp( argv[1], "-new-mesh" ) ) ? false : true;
+  const char* ifname = argc > 1 ? argv[1] : "/home/dcthomp/fourVolsBare.cub";
+  bool input_is_output = ( argc > 2 && ! strcmp( argv[2], "-new-mesh" ) ) ? false : true;
   MBInterface* imesh = new MBCore( rank, nprocs );
   MBInterface* omesh = input_is_output ? imesh : new MBCore( rank, nprocs );
@@ -48,99 +52,13 @@
   eval->set_ratio( 2. );
 #ifdef USE_MPI
   // Use an MBParallelComm object to help set up the input mesh
-  MBParallelComm ipcomm( imesh );
+  MBParallelComm* ipcomm = new MBParallelComm( imesh );
+  ReadParallel* readpar = new ReadParallel( imesh, ipcomm );
 #endif // USE_MPI
-  // The arrays below specify the mesh we create.
-  // The mesh is distributed across processes.
-  // Vertex coordinates
-  double coords[][6] = {
-    {  0. ,  0.0,  0. ,  0. ,  0.0,  0.  }, // 0
-    {  0. ,  0. ,  1. ,  0. ,  0. ,  1.  }, // 1
-    { -1. ,  0.0,  0.5, -1. ,  0.0,  0.5 }, // 2
-    { -0.5, -1.0,  0.5, -0.5, -1.0,  0.5 }, // 3
-    {  0.5, -0.5,  0.5,  0.5, -0.5,  0.5 }, // 4
-    {  0.5,  0.5,  0.5,  0.5,  0.5,  0.5 }  // 5
-  // Floating-point tag values for testing
-  double default_floatular[2] = {
-     38.7,   104. };
-  double floatular_values[][2] = {
-    {  38.7,   104.,    }, // 0
-    {   3.141,   2.718, }, // 1
-    { 123.456, 789.012, }, // 2
-    {   0.,      1.,    }, // 3
-    {   1.,      0.,    }, // 4
-    {  -1.,      1.,    }  // 5
-  // Integer tag values for testing
-  int default_intular[4] = {
-     7, 11, 24,  7 };
-  int intular_values[][4] = {
-    {  7, 11, 24,  7, }, // 0
-    { 10,  4, 10, 20, }, // 1
-    {  1,  2,  3,  4, }, // 2
-    { 13, 17, 19, 23, }, // 3
-    {  3,  3,  0,  6, }, // 4
-    {  5,  4,  3,  2  }  // 5
-  // Global IDs of all entities
-  int default_gid[] = { -1 };
-  int gid_values[] = {
-    1, 2, 3, 4, 5, 6, // vertices
-    7, 8, 9, 10,      // tetrahedra
-    11, 12,
-    13, 14,
-    15, 16,
-    17, 18            // triangles
-  // List of vertices resident on each node, as an index into gid_values
-  int proc_nodes[4][4] = {
-    { 0, 1, 2, 3 },
-    { 0, 1, 3, 4 },
-    { 0, 1, 4, 5 },
-    { 0, 1, 5, 2 },
-  // List of nodes with a copy of each vertex (first entry is owner)
-  // Ignore this for now.
-  int node_procs[6][4] = {
-    { 0,  1,  2,  3 }, // 0
-    { 0,  1, -1, -1 }, // 1
-    { 0,  3, -1, -1 }, // 2
-    { 0,  1,  2,  3 }, // 3
-    { 1,  2, -1, -1 }, // 4
-    { 2,  3, -1, -1 }  // 5
-  // List of indices into local node_handles array of two triangles that interface with neighboring processes
-  int internal_bdy[4][6] = {
-    { 1, 0, 2, 0, 1, 3 },
-  MBEntityHandle node_handles[4];
-  MBEntityHandle tet_handle;
-  MBEntityHandle tri_handles[2];
-  MBEntityHandle tri_node_handles[6];
-  // Create some tags so we can test the refiner's ability to copy/interpolate them.
-  MBTag tag_floatular;
-  imesh->tag_create( "floatular", 2 * sizeof( double ), MB_TAG_DENSE, MB_TYPE_DOUBLE, tag_floatular, default_floatular );
-  MBTag tag_intular;
-  imesh->tag_create( "intular", 4 * sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_intular, default_intular );
   // Get the global ID tag so we can set things up for resolve_shared_ents
-  MBTag tag_gid;
-  imesh->tag_create( PARALLEL_GID_TAG_NAME, sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_gid, default_gid );
+  //MBTag tag_gid;
+  //imesh->tag_create( PARALLEL_GID_TAG_NAME, sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_gid, default_gid );
 #ifdef USE_MPI
   // Get tags for the various data-distributed mesh annotations
@@ -149,60 +67,21 @@
   MBTag tag_shand;
   MBTag tag_shands;
   MBTag tag_pstat;
-  ipcomm.get_shared_proc_tags( tag_sproc, tag_sprocs, tag_shand, tag_shands, tag_pstat );
-  MBTag tag_part = ipcomm.partition_tag();
+  ipcomm->get_shared_proc_tags( tag_sproc, tag_sprocs, tag_shand, tag_shands, tag_pstat );
+  MBTag tag_part = ipcomm->partition_tag();
 #endif // USE_MPI
-  // Create vertices for our local tet and prepare tag data for each
-  void const* iptrs[4];
-  void const* fptrs[4];
-  void const* gptrs[4];
-  void const* sptrs[4];
-  for ( int i = 0; i < 4; ++ i )
-    int pnode = proc_nodes[rank][i];
-    imesh->create_vertex( coords[pnode], node_handles[i] );
-    //std::cout << rank << ": global " << (pnode + 1) << " is handle " << node_handles[i] << "\n";
-    iptrs[i] = (void const*) intular_values[pnode];
-    fptrs[i] = (void const*) floatular_values[pnode];
-    gptrs[i] = (void const*) &gid_values[pnode];
-  // Set tag values on vertices
-  imesh->tag_set_data( tag_floatular, node_handles, 4, fptrs, 0 );
-  imesh->tag_set_data( tag_intular, node_handles, 4, iptrs, 0 );
-  imesh->tag_set_data( tag_gid, node_handles, 4, gptrs, 0 );
-  // Create a tetrahedron from the vertices
-  imesh->create_element( MBTET, node_handles, 4, tet_handle );
-  imesh->tag_set_data( tag_gid, &tet_handle, 1, gid_values + 6 + rank );
-  // Create two triangles on the interface of the tet with its 2 neighboring processes.
-  for ( int i = 0; i < 6; ++ i )
-    tri_node_handles[i] = node_handles[internal_bdy[rank][i]];
-  imesh->create_element( MBTRI, tri_node_handles, 3, tri_handles[0] );
-  imesh->create_element( MBTRI, tri_node_handles + 3, 3, tri_handles[1] );
-  imesh->tag_set_data( tag_gid, tri_handles, 2, gid_values + 10 + 2 * rank );
-  //imesh->tag_set_data( tag_sprocs, &tet_handle, 1, sptrs, 0 );
-  //MBRange proc_ents( node_handles[0], tet_handle );
-  // Create a mesh set containing the tet
   MBEntityHandle set_handle;
-  imesh->create_meshset( MESHSET_SET, set_handle );
-  imesh->add_entities( set_handle, &tet_handle, 1 );
+  std::ostringstream parallel_options;
+  parallel_options
+    << "PARALLEL=BCAST_DELETE" << ";"
+    << "PARTITION=MATERIAL_SET" << ";"
+    //<< "PARTITION_DISTRIBUTE" << ";"
+    << "PARTITION_VAL=" << ( rank + 1 ) << ";"
+    << "PARALLEL_RESOLVE_SHARED_ENTS" << ";"
+    << "CPUTIME";
 #ifdef USE_MPI
-  // Tag the mesh set as a parallel partition
-  imesh->tag_set_data( tag_part, &set_handle, 1, &rank );
-  // Resolve shared entities (we really only care about vertices but
-  // ipcomm.resolve_shared_ents( 0, 0 ) doesn't mark anything up.
-  ipcomm.resolve_shared_ents( 3, 0 );
-  //ipcomm.resolve_shared_ents( 0, 0 );
-  //ipcomm.resolve_shared_ents( 3, 3 );
+  readpar->load_file( ifname, set_handle, FileOptions( parallel_options.str().c_str() ), 0, 0 );
   // Print out what we have so far, one process at a time
   for ( int i = 0; i < nprocs; ++ i )
@@ -216,6 +95,7 @@
     MPI_Barrier( MPI_COMM_WORLD );
 #else // USE_MPI
+  imesh->load_file( ifname, set_handle, parallel_options.str().c_str() );
   imesh->list_entities( 0, 1 );
 #endif // USE_MPI
@@ -223,8 +103,8 @@
   MBMeshRefiner* mref = new MBMeshRefiner( imesh, omesh );
   MBSimplexTemplateRefiner* eref = new MBSimplexTemplateRefiner;
   mref->set_entity_refiner( eref );
-  mref->add_vertex_tag( tag_floatular );
-  mref->add_vertex_tag( tag_intular );
+  //mref->add_vertex_tag( tag_floatular );
+  //mref->add_vertex_tag( tag_intular );
   // (We don't add tag_gid to the refiner's tag manager because it is special)
   eref->set_edge_size_evaluator( eval );
   MBRange ents_to_refine;
