[MOAB-dev] MBElemUtil
David C Thompson dcthomp at sandia.gov
Fri Jun 27 13:00:04 CDT 2008
Jason,
	You've checked in some changes in the tools/mbcoupler directory that
break the build for me. Specifically, findpt_test.cpp tries to declare
variables of type MBElemUtil, but that is a namespace not a class. It
generates these errors:
/usr/local/src/ANL/MOAB/HEAD-anon/tools/mbcoupler/findpt_test.cpp: In function ‘void test_hex_findpt()’:
/usr/local/src/ANL/MOAB/HEAD-anon/tools/mbcoupler/findpt_test.cpp:19: error: expected primary-expression before ‘u’
/usr/local/src/ANL/MOAB/HEAD-anon/tools/mbcoupler/findpt_test.cpp:19: error: expected `;' before ‘u’
/usr/local/src/ANL/MOAB/HEAD-anon/tools/mbcoupler/findpt_test.cpp:44: error: ‘u’ was not declared in this scope
/usr/local/src/ANL/MOAB/HEAD-anon/tools/mbcoupler/findpt_test.cpp: In function ‘void test_nat_coords_trilinear_hex2()’:
/usr/local/src/ANL/MOAB/HEAD-anon/tools/mbcoupler/findpt_test.cpp:61: error: expected primary-expression before ‘u’
/usr/local/src/ANL/MOAB/HEAD-anon/tools/mbcoupler/findpt_test.cpp:61: error: expected `;' before ‘u’
/usr/local/src/ANL/MOAB/HEAD-anon/tools/mbcoupler/findpt_test.cpp:75: error: ‘u’ was not declared in this scope
I have fixed things by simpling using the namespace prefix where
appropriate but don't want to check it in if your real intention is to
turn MBElemUtil into a struct or class. Was that your intention or
should I check in my changes?
	David
