[MOAB-dev] r1939 - MOAB/trunk/tools/mbcoupler
kraftche at mcs.anl.gov
Fri Jun 27 11:05:03 CDT 2008
Author: kraftche
Date: 2008-06-27 11:05:03 -0500 (Fri, 27 Jun 2008)
New Revision: 1939
Modified:
MOAB/trunk/tools/mbcoupler/ElemUtilTest.cpp
Log:
Forgot to check this in earlier: unit tests for
MBElemUtil::nat_coords_trilinear_hex with input point outside
of element.
Modified: MOAB/trunk/tools/mbcoupler/ElemUtilTest.cpp
--- MOAB/trunk/tools/mbcoupler/ElemUtilTest.cpp 2008-06-27 15:05:52 UTC (rev 1938)
+++ MOAB/trunk/tools/mbcoupler/ElemUtilTest.cpp 2008-06-27 16:05:03 UTC (rev 1939)
@@ -45,7 +45,23 @@
return x *= 0.125;
+static void hex_bounding_box( const MBCartVect* corners, MBCartVect& min, MBCartVect& max )
+ min = max = corners[0];
+ for (unsigned i = 1; i < 8; ++i)
+ for (unsigned d = 0; d < 3; ++d)
+ if (corners[i][d] < min[d])
+ min[d] = corners[i][d];
+ else if (corners[i][d] > max[d])
+ max[d] = corners[i][d];
+static bool in_range( const MBCartVect& xi )
+ { return fabs(xi[0]) <= 1
+ && fabs(xi[1]) <= 1
+ && fabs(xi[2]) <= 1;
void test_hex_nat_coords()
MBCartVect xi, result_xi;
@@ -79,5 +95,41 @@
+ // test points outside of element
+ MBCartVect x, min, max;
+ hex_bounding_box( cube_corners, min, max );
+ for (x[0] = -1; x[0] <= 2; x[0] += 0.4) {
+ for (x[1] = -1; x[1] <= 2; x[1] += 0.4) {
+ for (x[2] = -1; x[2] <= 2; x[2] += 0.4) {
+ bool in_box = x[0] >= min[0] && x[0] <= max[0]
+ && x[1] >= min[1] && x[1] <= max[1]
+ && x[2] >= min[2] && x[2] <= max[2];
+ if (in_box)
+ continue;
+ valid = MBElemUtil::nat_coords_trilinear_hex( cube_corners, x, result_xi, EPS/10 );
+//std::cout << (valid ? 'y' : 'n');
+ CHECK(!valid || !in_range(result_xi));
+//std::cout << std::endl;
+ hex_bounding_box( hex_corners, min, max );
+ for (x[0] = -1; x[0] <= 3; x[0] += 0.5) {
+ for (x[1] = -2; x[1] <= 4; x[1] += 0.5) {
+ if (in_box)
+ continue;
+ valid = MBElemUtil::nat_coords_trilinear_hex( hex_corners, x, result_xi, EPS/10 );
