[MOAB-dev] r1938 - in MOAB/trunk: . tools/mbcoupler
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Jun 27 10:05:52 CDT 2008
Author: kraftche
Date: 2008-06-27 10:05:52 -0500 (Fri, 27 Jun 2008)
New Revision: 1938
Modified:
   MOAB/trunk/MBMatrix3.hpp
   MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp
Log:
o Terminate calculation of natural coordinates as soon as the Jacobian
  is negative (much faster that waiting for iteration limit when point
  in an invalid region outside of the element.)
o Check return value of nat_coords_trilinear_hex in point_in_trilinear_hex.
  NOTE: point_in_trilinear_hex will return false for inverted elements
        for points "inside" the element.
o Some minor cleanups to the two point_in_trilinear_hex functions.
Modified: MOAB/trunk/MBMatrix3.hpp
--- MOAB/trunk/MBMatrix3.hpp	2008-06-27 01:14:12 UTC (rev 1937)
+++ MOAB/trunk/MBMatrix3.hpp	2008-06-27 15:05:52 UTC (rev 1938)
@@ -146,9 +146,20 @@
   inline MBMatrix3 inverse() const;
+    // invert matrix without re-calculating the
+    // reciprocal of the determinant.
+  inline MBMatrix3 inverse( double inverse_det ) const;
+  inline bool positive_definite() const;
+  inline bool positive_definite( double& determinant_out ) const;
   inline MBMatrix3 transpose() const;
   inline bool invert();
+    // Calculate determinant of 2x2 submatrix composed of the
+    // elements not in the passed row or column.
+  inline double subdet( int r, int c ) const;
 inline MBMatrix3 operator+( const MBMatrix3& a, const MBMatrix3& b )
@@ -205,9 +216,23 @@
        - d[2] * d[4] * d[6];
-inline MBMatrix3 MBMatrix3::inverse() const
+inline bool MBMatrix3::positive_definite( double& det ) const
-  double i = 1.0 / determinant();
+  double subdet6 = d[1]*d[5]-d[2]*d[4];
+  double subdet7 = d[2]*d[3]-d[0]*d[5];
+  double subdet8 = d[0]*d[4]-d[1]*d[3];
+  det = d[6]*subdet6 + d[7]*subdet7 + d[8]*subdet8;
+  return d[0] > 0 && subdet8 > 0 && det > 0;
+inline bool MBMatrix3::positive_definite() const
+  double d;
+  return positive_definite(d);
+inline MBMatrix3 MBMatrix3::inverse( double i ) const
   return MBMatrix3( i * (d[4] * d[8] - d[5] * d[7]),
                     i * (d[2] * d[7] - d[8] * d[1]),
                     i * (d[1] * d[5] - d[4] * d[2]),
@@ -217,6 +242,11 @@
                     i * (d[3] * d[7] - d[6] * d[4]),
                     i * (d[1] * d[6] - d[7] * d[0]),
                     i * (d[0] * d[4] - d[3] * d[1]) );
+inline MBMatrix3 MBMatrix3::inverse() const
+  return inverse( 1.0 / determinant() );
 inline bool MBMatrix3::invert()
@@ -224,15 +254,7 @@
   if (!finite(i) || fabs(i) < std::numeric_limits<double>::epsilon())
     return false;
-  *this= MBMatrix3( i * (d[4] * d[8] - d[5] * d[7]),
-                    i * (d[2] * d[7] - d[8] * d[1]),
-                    i * (d[1] * d[5] - d[4] * d[2]),
-                    i * (d[5] * d[6] - d[8] * d[3]),
-                    i * (d[0] * d[8] - d[6] * d[2]),
-                    i * (d[2] * d[3] - d[5] * d[0]),
-                    i * (d[3] * d[7] - d[6] * d[4]),
-                    i * (d[1] * d[6] - d[7] * d[0]),
-                    i * (d[0] * d[4] - d[3] * d[1]) );
+  *this = inverse( i );
   return true;
@@ -243,6 +265,12 @@
                     d[2], d[5], d[8] );
+inline double MBMatrix3::subdet( int r, int c ) const
+  const int r1 = (r+1)%3, r2 = (r+2)%3;
+  const int c1 = (c+1)%3, c2 = (c+2)%3;
+  return d[3*r1+c1]*d[3*r2+c2] - d[3*r1+c2]*d[3*r2+c1];
 MBErrorCode EigenDecomp( const MBMatrix3& a,
                          double Eigenvalues[3],
Modified: MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp
--- MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp	2008-06-27 01:14:12 UTC (rev 1937)
+++ MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp	2008-06-27 15:05:52 UTC (rev 1938)
@@ -1,4 +1,5 @@
 #include <iostream>
+#include <limits>
 #include <assert.h>
 #include "MBElemUtil.hpp"
@@ -23,16 +24,16 @@
 bool VolMap::solve_inverse( const MBCartVect& x, MBCartVect& xi, double tol ) const
   const double error_tol_sqr = tol*tol;
-  const int max_iterations = 10000;
-  int iterations = 0;
+  double det;
   xi = center_xi();
   MBCartVect delta = evaluate(xi) - x;
   MBMatrix3 J;
-  while (delta.length_squared() > error_tol_sqr) {
+  while (delta % delta > error_tol_sqr) {
     J = jacobian(xi);
-    if (!J.invert() || ++iterations > max_iterations)
+    det = J.determinant();
+    if (det < std::numeric_limits<double>::epsilon())
       return false;
-    xi -= J * delta;
+    xi -= J.inverse(1.0/det) * delta;
     delta = evaluate( xi ) - x;
   return true;
@@ -153,18 +154,11 @@
                             const MBCartVect& xyz,
                             double etol)
-      const double one = 1.000001;
-      MBCartVect  nat(0.);
-      nat_coords_trilinear_hex(hex, xyz, nat, etol);
-      for (unsigned int i = 0; i < 3; i++) {
-            if ((nat[i] > one) || (nat[i] < -one)) return false;
-      return true;
+  MBCartVect xi;
+  return nat_coords_trilinear_hex( hex, xyz, xi, etol )
+      && fabs(xi[0])-1 < etol
+      && fabs(xi[1])-1 < etol
+      && fabs(xi[2])-1 < etol;
@@ -174,22 +168,14 @@
                             const MBCartVect& box_max,
                             double etol)
-      if ((xyz[0] < box_min[0]) || (xyz[0] > box_max[0])) return false;
-      if ((xyz[1] < box_min[1]) || (xyz[1] > box_max[1])) return false;
-      if ((xyz[2] < box_min[2]) || (xyz[2] > box_max[2])) return false;
-      return true;
+    // all values scaled by 2 (eliminates 3 flops)
+  const MBCartVect mid = box_max + box_min;
+  const MBCartVect dim = box_max - box_min;
+  const MBCartVect pt = 2*xyz - mid;
+  return fabs(pt[0]) - dim[0] < etol &&
+         fabs(pt[1]) - dim[1] < etol &&
+         fabs(pt[2]) - dim[2] < etol &&
+         point_in_trilinear_hex( hex, xyz, etol );
