[MOAB-dev] MOAB on MacOS X
Tim Tautges tautges at mcs.anl.gov
Tue Jun 10 11:17:49 CDT 2008
Sorry gang, my bad.  Jason, could you change your modification to
completely remove the commented out include?  Thanks.
- tim
Jason Kraftcheck wrote:
> Thompson, David C wrote:
>> Hi,
>>     I decided to try MOAB on my MacOS X machine and it
>> almost builds... except for the fact that errmem.h (both
>> copies of it -- in parallel and tools/mbcoupler) includes
>> malloc.h which isn't present on Darwin. What's the "MOAB
>> way" to detect header files and select which ones get
>> included?
> GNU autoconf (http://www.gnu.org/software/autoconf/)
>> It looks like errmem.h will be included by any
>> client that needs MBParallelComm.hpp, so it seems like
>> this should be something that's saved so client programs
>> using MOAB don't have to look for the header file and
>> define (or not) MOAB-specific stuff themselves.
> This problem has been fixed.  errmem.h did not require malloc.h and no
> longer includes it.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
