[MOAB-dev] r1881 - MOAB/trunk/refiner
dcthomp at mcs.anl.gov
Mon Jun 9 13:09:14 CDT 2008
Author: dcthomp
Date: 2008-06-09 13:09:14 -0500 (Mon, 09 Jun 2008)
New Revision: 1881
Modified:
MOAB/trunk/refiner/MBMeshRefiner.cpp
Log:
ENH: Trying to get a handle on tags used for distributed memory
meshes.
Modified: MOAB/trunk/refiner/MBMeshRefiner.cpp
--- MOAB/trunk/refiner/MBMeshRefiner.cpp 2008-06-09 18:08:26 UTC (rev 1880)
+++ MOAB/trunk/refiner/MBMeshRefiner.cpp 2008-06-09 18:09:14 UTC (rev 1881)
@@ -1,5 +1,6 @@
#include "MBMeshRefiner.hpp"
+#include "MBEdgeSizeEvaluator.hpp"
#include "MBEntityRefiner.hpp"
#include "MBInterface.hpp"
@@ -72,36 +73,78 @@
public:
/// Mesh to hold output (may/may not be same as input mesh)
MBInterface* mesh;
+ /// Edge size evaluator is required because it has a list of output tags
+ MBEdgeSizeEvaluator* edge_size_evaluator;
/// Hash table of newly-created vertices at edge midpoints
std::map<MBEdgeIndex, MBEntityHandle> edge_vertices;
/// Hash table of newly-created vertices interior to triangle faces
std::map<MBFaceIndex, MBEntityHandle> face_vertices;
/// Storage allocated for interprocess communication of vertex global IDs
std::map<int,MBRefinerPartition*> partitions;
+ /// Number of tags defined on vertices
+ int num_tags;
+ /// The accumulated vertices that are used to create a new element when complete.
+ std::vector<MBEntityHandle> vertex_accum;
+ /**\brief True if the output mesh (this->mesh) is also the input mesh.
+ * This indicates whether pre-existing vertices should be inserted into the new mesh or not.
+ bool output_is_input;
+ MBMeshRefinerOutputFunctor( MBInterface* m, bool oii, MBEdgeSizeEvaluator* es )
+ this->mesh = m;
+ this->output_is_input = oii;
+ this->edge_size_evaluator = es;
virtual ~MBMeshRefinerOutputFunctor() { }
- virtual void operator () ( const double* vcoords, const void* vtags )
+ virtual void operator () ( const double* vcoords, const void* vtags, MBEntityHandle* hash )
- // Assume that vtags contains the proper global ID for the vertex (assigned by the TagAssigner)
+ if ( ! hash[1] && this->output_is_input )
+ // Don't insert vertices that already exist in the output
+ this->vertex_accum.push_back( hash[0] );
+ return;
+ MBEntityHandle vertex_handle;
+ this->mesh->create_vertex( vcoords + 3, vertex_handle );
+ this->vertex_accum.push_back( vertex_handle );
+ MBTag tag_handle;
+ int tag_offset;
+ for ( int i = 0; i < num_tags; ++i )
+ this->edge_size_evaluator->get_vertex_tag( i, tag_handle, tag_offset );
+ this->mesh->tag_set_data( tag_handle, &vertex_handle, 1, (char*)vtags + tag_offset );
virtual void operator () ( MBEntityType etyp )
+ if ( ! this->vertex_accum.size() )
+ return; // Ignore creation of vertex-less entities
+ MBEntityHandle elem_handle;
+ this->mesh->create_element( etyp, &this->vertex_accum[0], this->vertex_accum.size(), elem_handle );
+ this->vertex_accum.clear();
-MBMeshRefiner::MBMeshRefiner( MBInterface* parentMesh )
+MBMeshRefiner::MBMeshRefiner( MBInterface* parent_mesh )
- this->mesh = parentMesh;
+ this->mesh = parent_mesh;
this->entity_refiner = 0;
MBMeshRefiner::~MBMeshRefiner()
+ if ( this->entity_refiner )
+ delete this->entity_refiner;
bool MBMeshRefiner::set_entity_refiner( MBEntityRefiner* er )
- if ( ! er ) return false;
+ if ( ! er || er == this->entity_refiner )
+ return false;
this->entity_refiner = er;
