[MOAB-dev] r1880 - in MOAB/trunk: . tools/mbcoupler
dcthomp at mcs.anl.gov
Mon Jun 9 13:08:26 CDT 2008
Author: dcthomp
Date: 2008-06-09 13:08:26 -0500 (Mon, 09 Jun 2008)
New Revision: 1880
Added:
MOAB/trunk/tools/mbcoupler/CMakeLists.txt
Modified:
MOAB/trunk/CMakeLists.txt
Log:
ENH: Track new stuff in repository.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt 2008-06-06 19:45:15 UTC (rev 1879)
+++ MOAB/trunk/CMakeLists.txt 2008-06-09 18:08:26 UTC (rev 1880)
@@ -103,6 +103,7 @@
option ( MOAB_BUILD_MBSURFPLOT "Build the mbsurfplot application?" ON )
option ( MOAB_BUILD_MBZOLTAN "Build the mbzoltan partitioner?" OFF )
option ( MOAB_BUILD_DAGMC "Build the dagmc tool?" ON )
+ option ( MOAB_BUILD_MBCOUPLER "Build the mesh coupler tool?" ON )
# iMesh
option ( MOAB_BUILD_IMESH "Build the iMesh interface?" ON )
@@ -126,7 +127,6 @@
MBBSPTree.cpp
MBCN.cpp
MBCartVect.cpp
- MBElemUtil.cpp
MBHandleUtils.cpp
MBMatrix3.cpp
MBCore.cpp
@@ -274,6 +274,11 @@
add_subdirectory( tools/dagmc )
endif ( MOAB_BUILD_DAGMC )
+ # MBCoupler
+ if ( MOAB_BUILD_MBCOUPLER )
+ add_subdirectory( tools/mbcoupler )
+ endif ( MOAB_BUILD_MBCOUPLER )
# iMesh Babel
if ( MOAB_BUILD_IMESH )
option( MOAB_IMESH_FORTRAN "Should MOAB include iMesh FORTRAN bindings?" OFF )
Added: MOAB/trunk/tools/mbcoupler/CMakeLists.txt
--- MOAB/trunk/tools/mbcoupler/CMakeLists.txt (rev 0)
+++ MOAB/trunk/tools/mbcoupler/CMakeLists.txt 2008-06-09 18:08:26 UTC (rev 1880)
@@ -0,0 +1,22 @@
+include_directories(
+ ${CMAKE_CURRENT_SOURCE_DIRECTORY}
+set( MBCOUPLER_SRCS
+ MBElemUtil.cpp
+ tensor.c
+ poly.c
+ findpt.c
+ errmem.c
+add_library( mbcoupler
+ ${MBCOUPLER_SRCS}
+enable_testing()
+# A test for the coupler library
+add_executable( findpt_test findpt_test.cpp )
+target_link_libraries( findpt_test mbcoupler MOAB )
+add_test( TestMBCouplerFindPt ${EXECUTABLE_OUTPUT_PATH}/findpt_test )
