[MOAB-dev] r1996 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Tue Jul 8 11:48:31 CDT 2008
Author: kraftche
Date: 2008-07-08 11:48:31 -0500 (Tue, 08 Jul 2008)
New Revision: 1996
Modified:
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
Log:
Fix MPI call after MPI_finalize error: need to release HDF5 property object that depends on MPI before MPI_finalize or the HDF5 lib will try to release it on exit, which is after the call to MPI_finalize.
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-07-08 16:41:22 UTC (rev 1995)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-07-08 16:48:31 UTC (rev 1996)
@@ -568,8 +568,8 @@
writeUtil->report_error( "%s\n", mhdf_message( &status ) );
return MB_FAILURE;
+ H5Pclose( hdf_opt );
return MB_SUCCESS;
