[MOAB-dev] r1995 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Tue Jul 8 11:41:22 CDT 2008
Author: kraftche
Date: 2008-07-08 11:41:22 -0500 (Tue, 08 Jul 2008)
New Revision: 1995
Modified:
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/parallel/WriteHDF5Parallel.hpp
Log:
Replace array of length num_proc with a std::map.
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-07-08 16:27:58 UTC (rev 1994)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-07-08 16:41:22 UTC (rev 1995)
@@ -259,7 +259,7 @@
// (and for elements, connectivity length). This function:
// o determines which entities are to be written by a remote processor
// o removes those entities from the ExportSet structs in WriteMesh
-// o puts them in the 'remoteMesh' array of MBRanges in this class
+// o puts them in the 'interfaceMesh' array of MBRanges in this class
// o sets their file Id to '1'
MBErrorCode WriteHDF5Parallel::gather_interface_meshes()
@@ -273,30 +273,30 @@
printrange(eiter->range);
printrange(setSet.range);
- // Allocate space for remote mesh data
- remoteMesh.resize( myPcomm->proc_config().proc_size() );
MBRange iface_sets = myPcomm->interface_sets();
// Populate lists of interface mesh entities
+ MBRange tmpset;
for (MBRange::iterator ifit = iface_sets.begin(); ifit != iface_sets.end(); ifit++) {
int owner;
result = myPcomm->get_owner(*ifit, owner);
if (MB_SUCCESS != result || -1 == owner) return result;
- result = iFace->get_entities_by_handle(*ifit, remoteMesh[owner], true);
+ tmpset.clear();
+ result = iFace->get_entities_by_handle(*ifit, tmpset, true);
if (MB_SUCCESS != result) return result;
+ interfaceMesh[owner].merge( tmpset );
- // remoteMesh currently contains interface entities for the
+ // interfaceMesh currently contains interface entities for the
// entire mesh. We now need to a) remove from the sets of entities
- // and handles that this proc doesn't own and b) remove from remoteMesh
+ // and handles that this proc doesn't own and b) remove from interfaceMesh
// any handles for entities that we aren't going to write (on any proc.)
// First move handles of non-owned entities from lists of entities
// that this processor will write to the 'nonowned' list.
- MBRange tmpset, nonowned;
+ MBRange nonowned;
tmpset.clear();
result = myPcomm->get_owned_entities( nodeSet.range, tmpset );
@@ -314,29 +314,29 @@
nonowned.merge( tmpset.subtract( eiter->range ) );
- // Now remove from remoteMesh any entities that are not
+ // Now remove from interfaceMesh any entities that are not
// in 'nonowned' because we aren't writing those entities
// (on any processor.)
- for (unsigned i = 0; i < myPcomm->proc_config().proc_size(); ++i)
- if (i != myPcomm->proc_config().proc_rank())
- remoteMesh[i] = nonowned.intersect( remoteMesh[i] );
+ for (proc_iter i = interfaceMesh.begin(); i != interfaceMesh.end(); ++i)
+ if (i->first != myPcomm->proc_config().proc_rank())
+ i->second = nonowned.intersect( i->second );
- // For the 'remoteMesh' list for this processor, just remove
+ // For the 'interfaceMesh' list for this processor, just remove
// entities we aren't writing.
tmpset.clear();
tmpset.merge( nodeSet.range );
for (std::list<ExportSet>::iterator eiter = exportList.begin();
eiter != exportList.end(); ++eiter )
tmpset.merge( eiter->range );
- MBRange& my_remote_mesh = remoteMesh[myPcomm->proc_config().proc_rank()];
+ MBRange& my_remote_mesh = interfaceMesh[myPcomm->proc_config().proc_rank()];
my_remote_mesh = my_remote_mesh.intersect( tmpset );
// print some debug output summarizing what we've accomplished
printdebug("Remote mesh:\n");
- for (unsigned int ii = 0; ii < myPcomm->proc_config().proc_size(); ++ii)
- printdebug(" proc %d : %d\n", ii, remoteMesh[ii].size());
- printrange( remoteMesh[ii] );
+ printdebug(" proc %u : %d\n", i->first, i->second.size());
+ printrange( i->second );
printdebug( "Post-interface mesh:\n");
@@ -1903,7 +1903,7 @@
// get file ids for my interface entities
MBRange::const_iterator i;
- const MBRange& imesh = remoteMesh[myPcomm->proc_config().proc_rank()];
+ const MBRange& imesh = interfaceMesh[myPcomm->proc_config().proc_rank()];
std::vector<MBEntityHandle> file_id_vect( imesh.size() );
std::vector<MBEntityHandle>::iterator j = file_id_vect.begin();
for (i = imesh.begin(); i != imesh.end(); ++i, ++j) {
@@ -1915,7 +1915,7 @@
printdebug( "Interface entities:\n" );
-printrange( remoteMesh[myPcomm->proc_config().proc_rank()] );
+printrange( interfaceMesh[myPcomm->proc_config().proc_rank()] );
// store file IDs in tag
rval = iFace->tag_set_data( file_id_tag, imesh, &file_id_vect[0] );
@@ -1932,19 +1932,19 @@
// store file IDs for remote entities
- for (unsigned p = 0; p < myPcomm->proc_config().proc_size(); ++p) {
- if (p == myPcomm->proc_config().proc_rank())
+ for (proc_iter p = interfaceMesh.begin(); p != interfaceMesh.end(); ++p) {
+ if (p->first == myPcomm->proc_config().proc_rank())
continue;
- file_id_vect.resize( remoteMesh[p].size() );
- rval = iFace->tag_get_data( file_id_tag, remoteMesh[p], &file_id_vect[0] );
+ file_id_vect.resize( p->second.size() );
+ rval = iFace->tag_get_data( file_id_tag, p->second, &file_id_vect[0] );
if (MB_SUCCESS != rval) {
iFace->tag_delete( file_id_tag );
return rval;
- for (i = remoteMesh[p].begin(); i != remoteMesh[p].end(); ++i, ++j) {
+ for (i = p->second.begin(); i != p->second.end(); ++i, ++j) {
if (*j == 0 || idMap.insert( *i, *j, 1 ) == idMap.end()) {
return MB_FAILURE;
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.hpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-07-08 16:27:58 UTC (rev 1994)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-07-08 16:41:22 UTC (rev 1995)
@@ -10,6 +10,7 @@
#include "WriteHDF5.hpp"
#include <mpi.h>
+#include <map>
struct RemoteSetData;
class MBParallelComm;
@@ -206,7 +207,8 @@
//! An array of interface mesh which is to be written by
//! remote processors. Indexed by MPI rank (processor number).
- std::vector<MBRange> remoteMesh;
+ std::map<unsigned,MBRange> interfaceMesh;
+ typedef std::map<unsigned,MBRange>::iterator proc_iter;
//! Tag names for identifying multi-processor meshsets
MultiProcSetTags multiProcSetTags;
