[MOAB-dev] r1988 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Mon Jul 7 17:03:19 CDT 2008
Author: kraftche
Date: 2008-07-07 17:03:19 -0500 (Mon, 07 Jul 2008)
New Revision: 1988
Added:
MOAB/trunk/parallel/parallel_hdf5_test.cc
MOAB/trunk/parallel/ptest.cub
Modified:
MOAB/trunk/parallel/Makefile.am
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/parallel/WriteHDF5Parallel.hpp
Log:
o re-implement communication of file ids using MBParallelComm::exchange_tags
(not working yet)
o fix 64-bit bug (int vs long) in MPI communication call
o fix build errors in debug code
o add new test for parallel hdf5 writer
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am 2008-07-07 21:12:48 UTC (rev 1987)
+++ MOAB/trunk/parallel/Makefile.am 2008-07-07 22:03:19 UTC (rev 1988)
@@ -42,6 +42,8 @@
INCLUDES += -I$(top_srcdir)/mhdf/include
MOAB_PARALLEL_SRCS += WriteHDF5Parallel.cpp
MOAB_PARALLEL_HDRS += WriteHDF5Parallel.hpp
+ MOAB_PARALLEL_TEST += parallel_hdf5_test
endif
MOAB_PARALLEL_CHECK += mbparallelcomm_test
@@ -62,9 +64,11 @@
# Tests and such
check_PROGRAMS = $(MOAB_PARALLEL_CHECK) $(MOAB_PARALLEL_TEST)
TESTS = $(MOAB_PARALLEL_TEST)
pcomm_unit_SOURCES = pcomm_unit.cpp
pcomm_unit_LDADD = $(top_builddir)/libMOAB.la
+parallel_hdf5_test_SOURCES = parallel_hdf5_test.cc
+parallel_hdf5_test_LDADD = ../libMOAB.la
+parallel_hdf5_test_CPPFLAGS = -DSRCDIR=$(srcdir)
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-07-07 21:12:48 UTC (rev 1987)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-07-07 22:03:19 UTC (rev 1988)
@@ -41,7 +41,7 @@
#ifdef DEBUG
# define START_SERIAL \
- for (int _x = 0; _x < myPcomm->proc_config().proc_size(); ++_x) {\
+ for (unsigned _x = 0; _x < myPcomm->proc_config().proc_size(); ++_x) {\
MPI_Barrier( MPI_COMM_WORLD ); \
if (_x != myPcomm->proc_config().proc_rank()) continue
# define END_SERIAL \
@@ -122,20 +122,19 @@
#ifndef DEBUG
static void print_type_sets( MBInterface* , int , int , MBRange& ) {}
#else
-static void print_type_sets( MBInterface* iFace, int myPcomm->proc_config().proc_rank(), int myPcomm->proc_config().proc_size(), MBRange& sets )
+static void print_type_sets( MBInterface* iFace, int rank, int size, MBRange& sets )
- MBTag gid, did, bid, sid, nid, iid;
+ MBTag gid, did, bid, sid, nid;
iFace->tag_get_handle( GLOBAL_ID_TAG_NAME, gid );
iFace->tag_get_handle( GEOM_DIMENSION_TAG_NAME, did );
iFace->tag_get_handle( MATERIAL_SET_TAG_NAME, bid );
iFace->tag_get_handle( DIRICHLET_SET_TAG_NAME, nid );
iFace->tag_get_handle( NEUMANN_SET_TAG_NAME, sid );
- iFace->tag_get_handle( PARALLEL_PARTITION_TAG_NAME, iid );
MBRange typesets[10];
- const char* typenames[] = {"Block", "Sideset", "NodeSet", "Vertex", "Curve", "Surface", "Volume", "Body", "Partition", "Other"};
+ const char* typenames[] = {"Block", "Sideset", "NodeSet", "Vertex", "Curve", "Surface", "Volume", "Body", "Other"};
for (MBRange::iterator riter = sets.begin(); riter != sets.end(); ++riter)
- unsigned dim, id, proc[2], oldsize;
+ unsigned dim, id, oldsize;
if (MB_SUCCESS == iFace->tag_get_data(bid, &*riter, 1, &id))
dim = 0;
else if (MB_SUCCESS == iFace->tag_get_data(sid, &*riter, 1, &id))
@@ -147,11 +146,6 @@
iFace->tag_get_data(gid, &*riter, 1, &id);
dim += 3;
- else if (MB_SUCCESS == iFace->tag_get_data(iid, &*riter, 1, proc)) {
- assert(proc[0] == (unsigned)myPcomm->proc_config().proc_rank() || proc[1] == (unsigned)myPcomm->proc_config().proc_rank());
- id = proc[proc[0] == (unsigned)myPcomm->proc_config().proc_rank()];
- dim = 8;
else {
id = *riter;
dim = 9;
@@ -161,7 +155,7 @@
typesets[dim].insert( id );
assert( typesets[dim].size() - oldsize == 1 );
- for (int ii = 0; ii < 10; ++ii)
+ for (int ii = 0; ii < 9; ++ii)
char num[16];
std::string line(typenames[ii]);
@@ -415,8 +409,6 @@
rval = create_node_table( dimension );
if (MB_SUCCESS != rval) return rval;
- rval = communicate_remote_ids( MBVERTEX );
- if (MB_SUCCESS != rval) return rval;
/**************** Create element tables ***************/
@@ -424,14 +416,14 @@
rval = create_element_tables();
- for (std::list<ExportSet>::iterator ex_itor = exportList.begin();
- ex_itor != exportList.end(); ++ex_itor)
- rval = communicate_remote_ids( ex_itor->type );
- assert(MB_SUCCESS == rval);
+ /*************** Exchange file IDs *****************/
+ rval = exchange_file_ids();
+ if (MB_SUCCESS != rval) return rval;
/**************** Create adjacency tables *********************/
rval = create_adjacency_tables();
@@ -616,7 +608,7 @@
return MB_FAILURE;
mhdf_closeData( filePtr, handle, &status );
// send id offset to every proc
result = MPI_Bcast( &first_id, 1, MPI_LONG, 0, MPI_COMM_WORLD );
@@ -637,13 +629,13 @@
// send each proc it's offset in the node table
- int offset;
- result = MPI_Scatter( &node_counts[0], 1, MPI_INT,
- &offset, 1, MPI_INT,
+ long offset;
+ result = MPI_Scatter( &node_counts[0], 1, MPI_LONG,
+ &offset, 1, MPI_LONG,
assert(MPI_SUCCESS == result);
nodeSet.offset = offset;
return assign_ids( nodeSet.range, nodeSet.first_id + nodeSet.offset );
@@ -1903,129 +1895,72 @@
-MBErrorCode WriteHDF5Parallel::communicate_remote_ids( MBEntityType type )
+MBErrorCode WriteHDF5Parallel::exchange_file_ids()
- int result;
- MBErrorCode rval;
+ // create tag to store file IDs
+ MBEntityHandle default_val = 0;
+ MBTag file_id_tag = 0;
+ MBErrorCode rval = iFace->tag_create( "__hdf5_ll_fileid",
+ sizeof(MBEntityHandle),
+ MB_TAG_DENSE,
+ MB_TYPE_HANDLE,
+ file_id_tag,
+ &default_val );
+ return rval;
- // Get the export set for the specified type
- ExportSet* export_set = 0;
- if (type == MBVERTEX)
- export_set = &nodeSet;
- else if(type == MBENTITYSET)
- export_set = &setSet;
- else
- for (std::list<ExportSet>::iterator esiter = exportList.begin();
- esiter != exportList.end(); ++esiter)
- if (esiter->type == type)
- export_set = &*esiter;
- break;
+ // get file ids for my interface entities
+ MBRange::const_iterator i;
+ const MBRange& imesh = remoteMesh[myPcomm->proc_config().proc_rank()];
+ std::vector<MBEntityHandle> file_id_vect( imesh.size() );
+ std::vector<MBEntityHandle>::iterator j = file_id_vect.begin();
+ for (i = imesh.begin(); i != imesh.end(); ++i, ++j) {
+ *j = idMap.find( *i );
+ if (!*j) {
+ iFace->tag_delete( file_id_tag );
+ return MB_FAILURE;
- assert(export_set != NULL);
- // Get the ranges in the set
- std::vector<unsigned long> myranges;
- MBRange::const_pair_iterator p_iter = export_set->range.const_pair_begin();
- const MBRange::const_pair_iterator p_end = export_set->range.const_pair_end();
- for ( ; p_iter != p_end; ++p_iter)
- myranges.push_back( (*p_iter).first );
- myranges.push_back( (*p_iter).second );
+ // store file IDs in tag
+ rval = iFace->tag_set_data( file_id_tag, imesh, &file_id_vect[0] );
+ if (MB_SUCCESS != rval) {
+ return rval;
- START_SERIAL;
- printdebug("%s ranges to communicate:\n", MBCN::EntityTypeName(type));
- for (unsigned long xx = 0; xx != myranges.size(); xx+=2)
- printdebug(" %lu - %lu\n", myranges[xx], myranges[xx+1] );
- END_SERIAL;
- // Communicate the number of ranges and the start_id for
- // each processor.
- std::vector<int> counts(myPcomm->proc_config().proc_size()), offsets(myPcomm->proc_config().proc_size()), displs(myPcomm->proc_config().proc_size());
- int mycount = myranges.size();
- int mystart = export_set->first_id + export_set->offset;
- result = MPI_Allgather( &mycount, 1, MPI_INT, &counts[0], 1, MPI_INT, MPI_COMM_WORLD );
- assert(MPI_SUCCESS == result);
- result = MPI_Allgather( &mystart, 1, MPI_INT, &offsets[0], 1, MPI_INT, MPI_COMM_WORLD );
+ // do communication
+ rval = myPcomm->exchange_tags( file_id_tag );
+ return rval;
- // Communicate the ranges
- displs[0] = 0;
- for (unsigned int i = 1; i < myPcomm->proc_config().proc_size(); ++i)
- displs[i] = displs[i-1] + counts[i-1];
- std::vector<unsigned long> allranges( displs[myPcomm->proc_config().proc_size()-1] + counts[myPcomm->proc_config().proc_size()-1] );
- result = MPI_Allgatherv( &myranges[0], myranges.size(), MPI_UNSIGNED_LONG,
- &allranges[0], &counts[0], &displs[0],
- MPI_UNSIGNED_LONG, MPI_COMM_WORLD );
- MBTag global_id_tag;
- rval = iFace->tag_get_handle( PARALLEL_GID_TAG_NAME, global_id_tag );
- // Set file IDs for each communicated entity
- // For each processor
- for (unsigned int proc = 0; proc < myPcomm->proc_config().proc_size(); ++proc)
- if (proc == myPcomm->proc_config().proc_rank())
+ // store file IDs for remote entities
+ for (unsigned p = 0; p < myPcomm->proc_config().proc_size(); ++p) {
+ if (p == myPcomm->proc_config().proc_rank())
continue;
- // Get data for corresponding processor
- const int offset = offsets[proc];
- const int count = counts[proc];
- const unsigned long* const ranges = &allranges[displs[proc]];
+ file_id_vect.resize( remoteMesh[p].size() );
+ rval = iFace->tag_get_data( file_id_tag, remoteMesh[p], &file_id_vect[0] );
+ return rval;
- // For each geometry meshset in the interface
- MBRange::iterator r_iter = MBRange::lower_bound( remoteMesh[proc].begin(),
- remoteMesh[proc].end(),
- CREATE_HANDLE(type,0,result) );
- MBRange::iterator r_stop = MBRange::lower_bound( r_iter,
- CREATE_HANDLE(type+1,0,result) );
- for ( ; r_iter != r_stop; ++r_iter)
- MBEntityHandle entity = *r_iter;
- // Get handle on other processor
- MBEntityHandle global;
- rval = iFace->tag_get_data( global_id_tag, &entity, 1, &global );
- // Find corresponding fileid on other processor.
- // This could potentially be n**2, but we will assume that
- // the range list from each processor is short (typically 1).
- int j, steps = 0;
- unsigned long low, high;
- for (j = 0; j < count; j += 2)
- low = ranges[j];
- high = ranges[j+1];
- if (low <= global && high >= global)
- break;
- steps += (high - low) + 1;
+ j = file_id_vect.begin();
+ for (i = remoteMesh[p].begin(); i != remoteMesh[p].end(); ++i, ++j) {
+ if (*j == 0 || idMap.insert( *i, *j, 1 ) == idMap.end()) {
- if (j >= count) {
- printdebug("*** handle = %u, type = %d, id = %d, proc = %d\n",
- (unsigned)global, (int)(iFace->type_from_handle(global)), (int)(iFace->id_from_handle(global)), proc);
- for (int ii = 0; ii < count; ii+=2)
- printdebug("*** %u to %u\n", (unsigned)ranges[ii], (unsigned)ranges[ii+1] );
- MBRange junk; junk.insert( global );
- print_type_sets( iFace, myPcomm->proc_config().proc_rank(), myPcomm->proc_config().proc_size(), junk );
- assert(j < count);
- int fileid = offset + steps + (global - low);
- RangeMap<MBEntityHandle,id_t>::iterator ri = idMap.insert( entity, fileid, 1 );
- assert( ri != idMap.end() );
- } // for(r_iter->range)
- } // for(each processor)
- return MB_SUCCESS;
+ return iFace->tag_delete( file_id_tag );
MBErrorCode WriteHDF5Parallel::get_sharedset_tags()
// get all the sets
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.hpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-07-07 21:12:48 UTC (rev 1987)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-07-07 22:03:19 UTC (rev 1988)
@@ -112,10 +112,11 @@
MBErrorCode gather_interface_meshes();
//! For entities that will be written by another
+ //! processor but are referenced by entities on this
//! processor, get the file Ids that will be assigned
//! to those so they can be referenced by
//! entities to be written on this processor.
- MBErrorCode communicate_remote_ids(MBEntityType type);
+ MBErrorCode exchange_file_ids();
//! Sort the list of tag information in the parent
//! class by name so all procs have them in the same
Added: MOAB/trunk/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/parallel/parallel_hdf5_test.cc (rev 0)
+++ MOAB/trunk/parallel/parallel_hdf5_test.cc 2008-07-07 22:03:19 UTC (rev 1988)
@@ -0,0 +1,294 @@
+#include "TestUtil.hpp"
+#include "MBCore.hpp"
+#include "MBParallelComm.hpp"
+#include "MBTagConventions.hpp"
+#include "MBCN.hpp"
+#include <iostream>
+#include <mpi.h>
+#define STRINGIFY_(X) #X
+#define STRINGIFY(X) STRINGIFY_(X)
+#ifdef SRCDIR
+const char* InputFile = STRINGIFY(SRCDIR) "/ptest.cub";
+#else
+const char* InputFile = "ptest.cub";
+#endif
+void load_and_partition( MBInterface& moab, const char* filename );
+void save_and_load_on_root( MBInterface& moab, const char* tmp_filename );
+void check_identical_mesh( MBInterface& moab1, MBInterface& moab2 );
+void test_write_elements();
+void test_write_shared_sets();
+bool KeepTmpFiles = false;
+int main( int argc, char* argv[] )
+ int err = MPI_Init( &argc, &argv );
+ CHECK(!err);
+ if (argc == 2 && !strcmp(argv[1],"-k"))
+ KeepTmpFiles = true;
+ else if (argc != 1) {
+ std::cerr << "Usage: " << argv[0] << " [-k]" << std::endl;
+ return 1;
+ int result = 0;
+ result += RUN_TEST( test_write_elements );
+ result += RUN_TEST( test_write_shared_sets );
+ MPI_Finalize();
+ return result;
+ MBErrorCode rval;
+ MBEntityHandle set;
+ rval = moab.load_file( filename, set,
+ "PARALLEL=READ_DELETE;"
+ "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
+ "PARTITION_DISTRIBUTE;"
+ "PARALLEL_RESOLVE_SHARED_ENTS" );
+ CHECK_ERR(rval);
+ MBErrorCode rval;
+ int procnum;
+ MPI_Comm_rank( MPI_COMM_WORLD, &procnum );
+ rval = moab.write_file( tmp_filename, 0, "PARALLEL=FORMAT" );
+ std::cerr << "Parallel write filed on processor " << procnum << std::endl;
+ if (procnum == 0 && !KeepTmpFiles)
+ remove( tmp_filename );
+ CHECK_ERR(rval);
+ moab.delete_mesh();
+ if (procnum == 0) {
+ rval = moab.load_file( tmp_filename, set );
+ CHECK_ERR(rval);
+void count_owned_entities( MBInterface& moab, int counts[MBENTITYSET] )
+ MBErrorCode rval;
+ MBParallelComm* pcomm = MBParallelComm::get_pcomm( &moab, 0 );
+ CHECK(0 != pcomm);
+ std::fill( counts, counts+MBENTITYSET, 0u );
+ for (MBEntityType t = MBVERTEX; t < MBENTITYSET; ++t) {
+ MBRange range;
+ rval = moab.get_entities_by_type( 0, t, range );
+ CHECK_ERR(rval);
+ rval = pcomm->remove_nonowned_shared( range, -1, true, false );
+ CHECK_ERR(rval);
+ counts[t] = range.size();
+void check_identical_mesh( MBInterface& mb1, MBInterface& mb2 )
+ MBErrorCode rval;
+ std::map<MBEntityHandle,MBEntityHandle> entmap;
+ // match vertices by coordinate
+ MBRange r1, r2;
+ MBRange::iterator i1, i2;
+ rval = mb1.get_entities_by_type( 0, MBVERTEX, r1 );
+ CHECK_ERR(rval);
+ rval = mb2.get_entities_by_type( 0, MBVERTEX, r2 );
+ CHECK_ERR(rval);
+ CHECK_EQUAL( r1.size(), r2.size() );
+ for (i1 = r1.begin(); i1 != r1.end(); ++i1) {
+ double coords1[3];
+ rval = mb1.get_coords( &*i1, 1, coords1 );
+ CHECK_ERR(rval);
+ for (i2 = r2.begin(); i2 != r2.end(); ++i2) {
+ double coords2[3];
+ rval = mb2.get_coords( &*i2, 1, coords2 );
+ CHECK_ERR(rval);
+ coords2[0] -= coords1[0];
+ coords2[1] -= coords1[1];
+ coords2[2] -= coords1[2];
+ double lensqr = coords2[0]*coords2[0] + coords2[1]*coords2[1] + coords2[2]*coords2[2];
+ if (lensqr < 1e-12)
+ break;
+ CHECK( i2 != r2.end() );
+ entmap[*i2] = *i1;
+ r2.erase( i2 );
+ // match element connectivity
+ std::vector<MBEntityHandle> conn1, conn2;
+ for (MBEntityType t = MBEDGE; t < MBENTITYSET; ++t) {
+ r1.clear();
+ rval = mb1.get_entities_by_type( 0, t, r1 );
+ CHECK_ERR(rval);
+ r2.clear();
+ rval = mb2.get_entities_by_type( 0, t, r2 );
+ CHECK_ERR(rval);
+ conn1.clear();
+ rval = mb1.get_connectivity( &*i1, 1, conn1 );
+ CHECK_ERR(rval);
+ conn2.clear();
+ rval = mb2.get_connectivity( &*i2, 1, conn2 );
+ CHECK_ERR(rval);
+ if (conn1.size() != conn2.size())
+ continue;
+ for (std::vector<MBEntityHandle>::iterator j = conn2.begin(); j != conn2.end(); ++j)
+ *j = entmap[*j];
+ if (conn1 == conn2)
+ break;
+ r2.erase( i2 );
+ int proc_counts[MBENTITYSET], all_counts[MBENTITYSET], file_counts[MBENTITYSET];
+ int err, rank, size;
+ MBErrorCode rval;
+ err = MPI_Comm_rank( MPI_COMM_WORLD, &rank );
+ CHECK(!err);
+ err = MPI_Comm_size( MPI_COMM_WORLD, &size );
+ CHECK(!err);
+ MBCore moab_instance;
+ MBInterface& moab = moab_instance;
+ load_and_partition( moab, InputFile );
+ count_owned_entities( moab, proc_counts );
+ std::fill( all_counts, all_counts+MBENTITYSET, 0u );
+ err = MPI_Allreduce( proc_counts, all_counts, MBENTITYSET, MPI_INT, MPI_SUM, MPI_COMM_WORLD );
+ CHECK(!err);
+ save_and_load_on_root( moab, "test_write_elements.h5m" );
+ if (rank == 0) {
+ rval = moab.get_number_entities_by_type( 0, t, file_counts[t] );
+ CHECK_ERR(rval);
+ err = MPI_Bcast( file_counts, MBENTITYSET, MPI_INT, 0, MPI_COMM_WORLD );
+ CHECK(!err);
+ bool all_equal = true;
+ if (file_counts[t] != all_counts[t])
+ all_equal = false;
+ if (rank == 0 && !all_equal) {
+ std::cerr << "Type\tPartnd\tWritten" << std::endl;
+ std::cerr << MBCN::EntityTypeName(t) << '\t' << all_counts[t] << '\t' << file_counts[t] << std::endl;
+ CHECK(all_equal);
+ if (rank == 0) {
+ MBCore moab2;
+ rval = moab2.load_file( InputFile, set );
+ CHECK_ERR(rval);
+ check_identical_mesh( moab, moab2 );
+bool check_sets_sizes( MBInterface& mb1, MBEntityHandle set1,
+ MBInterface& mb2, MBEntityHandle set2 )
+ MBErrorCode rval;
+ bool result = true;
+ for (MBEntityType t = MBVERTEX; t < MBMAXTYPE; ++t) {
+ int count1, count2;
+ rval = mb1.get_number_entities_by_type( set1, t, count1 );
+ CHECK_ERR(rval);
+ rval = mb2.get_number_entities_by_type( set2, t, count2 );
+ CHECK_ERR(rval);
+ if (count1 != count2) {
+ std::cerr << "Sets differ in number of " << MBCN::EntityTypeName(t)
+ << " : " << count1 << " vs. " << count2 << std::endl;
+ result = false;
+ return result;
+ MBErrorCode rval;
+ CHECK(!err);
+ CHECK(!err);
+ save_and_load_on_root( moab, "test_write_shared_sets.h5m" );
+ if (rank != 0)
+ return;
+ MBCore moab2_instance;
+ MBInterface& moab2 = moab2_instance;
+ CHECK_ERR(rval);
+ MBTag mattag1, mattag2;
+ rval = moab.tag_get_handle( MATERIAL_SET_TAG_NAME, mattag1 );
+ CHECK_ERR(rval);
+ rval = moab2.tag_get_handle( MATERIAL_SET_TAG_NAME, mattag2 );
+ CHECK_ERR(rval);
+ MBRange matsets;
+ rval = moab2.get_entities_by_type_and_tag( 0, MBENTITYSET, &mattag2, 0, 1, matsets );
+ CHECK_ERR(rval);
+ for (MBRange::iterator i = matsets.begin(); i != matsets.end(); ++i) {
+ int block_id;
+ rval = moab2.tag_get_data( mattag2, &*i, 1, &block_id );
+ CHECK_ERR(rval);
+ MBRange tmpents;
+ void* tagdata[] = {&block_id};
+ rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &mattag1, tagdata, 1, tmpents );
+ if (tmpents.size() != 1)
+ std::cerr << tmpents.size() << " sets with material set id " << block_id << std::endl;
+ CHECK_EQUAL( (int)tmpents.size(), 1 );
+ CHECK( check_sets_sizes( moab2, *i, moab, tmpents.front() ) );
Added: MOAB/trunk/parallel/ptest.cub
(Binary files differ)
Property changes on: MOAB/trunk/parallel/ptest.cub
___________________________________________________________________
+ application/octet-stream
