[MOAB-dev] r1987 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Mon Jul 7 16:12:48 CDT 2008
Author: kraftche
Date: 2008-07-07 16:12:48 -0500 (Mon, 07 Jul 2008)
New Revision: 1987
Modified:
MOAB/trunk/parallel/Makefile.am
Log:
revise previous commit: build mbparallelcomm_test for make check, but don't run it
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am 2008-07-07 21:10:43 UTC (rev 1986)
+++ MOAB/trunk/parallel/Makefile.am 2008-07-07 21:12:48 UTC (rev 1987)
@@ -19,6 +19,7 @@
MOAB_PARALLEL_SRCS =
MOAB_PARALLEL_HDRS =
MOAB_PARALLEL_TEST =
+MOAB_PARALLEL_CHECK =
if PARALLEL
MOAB_PARALLEL_SRCS += \
MBParallelComm.cpp \
@@ -43,7 +44,7 @@
MOAB_PARALLEL_HDRS += WriteHDF5Parallel.hpp
endif
- MOAB_PARALLEL_TEST += mbparallelcomm_test
+ MOAB_PARALLEL_CHECK += mbparallelcomm_test
mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
@@ -62,7 +63,7 @@
# Tests and such
-check_PROGRAMS = $(MOAB_PARALLEL_TEST)
+check_PROGRAMS = $(MOAB_PARALLEL_CHECK) $(MOAB_PARALLEL_TEST)
TESTS = $(MOAB_PARALLEL_TEST)
pcomm_unit_SOURCES = pcomm_unit.cpp
pcomm_unit_LDADD = $(top_builddir)/libMOAB.la
