[MOAB-dev] r1979 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Jul 3 13:46:43 CDT 2008
Author: kraftche
Date: 2008-07-03 13:46:43 -0500 (Thu, 03 Jul 2008)
New Revision: 1979
Modified:
   MOAB/trunk/MBBSPTree.cpp
   MOAB/trunk/MBBSPTree.hpp
Log:
store BSP tree root box as general hexahedron
Modified: MOAB/trunk/MBBSPTree.cpp
--- MOAB/trunk/MBBSPTree.cpp	2008-07-03 17:25:11 UTC (rev 1978)
+++ MOAB/trunk/MBBSPTree.cpp	2008-07-03 18:46:43 UTC (rev 1979)
@@ -36,6 +36,56 @@
 #define MB_BSP_TREE_DEFAULT_TAG_NAME "BSPTree"
+static void corners_from_box( const double box_min[3],
+                              const double box_max[3],
+                              double corners[8][3] )
+  const double* ranges[] = { box_min, box_max };
+  for (int z = 0; z < 2; ++z) {
+    corners[4*z  ][0] = box_min[0];
+    corners[4*z  ][1] = box_min[1];
+    corners[4*z  ][2] = ranges[z][2];
+    corners[4*z+1][0] = box_max[0];
+    corners[4*z+1][1] = box_min[1];
+    corners[4*z+1][2] = ranges[z][2];
+    corners[4*z+2][0] = box_max[0];
+    corners[4*z+2][1] = box_max[1];
+    corners[4*z+2][2] = ranges[z][2];
+    corners[4*z+3][0] = box_min[0];
+    corners[4*z+3][1] = box_max[1];
+    corners[4*z+3][2] = ranges[z][2];
+// assume box has planar sides
+// test if point is contained in box
+static bool point_in_box( const double corners[8][3],
+                          const double point[3] )
+  const unsigned side_verts[6][3] = { { 0, 3, 1 },
+                                      { 4, 5, 7 },
+                                      { 0, 1, 4 },
+                                      { 1, 2, 5 },
+                                      { 2, 3, 6 },
+                                      { 3, 0, 7 } };
+    // If we assume planar sides, then the box is the intersection
+    // of 6 half-spaces defined by the planes of the sides.
+  const MBCartVect pt(point);
+  for (unsigned s = 0; s < 6; ++s) {
+    MBCartVect v0( corners[side_verts[s][0]] );
+    MBCartVect v1( corners[side_verts[s][1]] );
+    MBCartVect v2( corners[side_verts[s][2]] );
+    MBCartVect N = (v1 - v0) * (v2 - v0);
+    if ((v0 - pt) % N < 0)
+      return false;
+  return true;
 MBBSPTree::MBBSPTree( MBInterface* mb,
                       const char* tagname,
                       unsigned set_flags )
@@ -53,7 +103,7 @@
   if (MB_SUCCESS != rval)
     planeTag = 0;
-  rval = mb->tag_create( rootname.c_str(), 6*sizeof(double), MB_TAG_SPARSE, MB_TYPE_DOUBLE, rootTag, 0, true );
+  rval = mb->tag_create( rootname.c_str(), 24*sizeof(double), MB_TAG_SPARSE, MB_TYPE_DOUBLE, rootTag, 0, true );
     rootTag = 0;
@@ -86,20 +136,21 @@
                                      const double box_max[3] )
-  const double box[6] = { box_min[0], box_min[1], box_min[2],
-                          box_max[0], box_max[1], box_max[2] };
-  return moab()->tag_set_data( rootTag, &root_handle, 1, box );
+  double corners[8][3];
+  corners_from_box( box_min, box_max, corners );
+  return set_tree_box( root_handle, corners );
+MBErrorCode MBBSPTree::set_tree_box( MBEntityHandle root_handle,
+                                     const double corners[8][3] )
+  return moab()->tag_set_data( rootTag, &root_handle, 1, corners );
 MBErrorCode MBBSPTree::get_tree_box( MBEntityHandle root_handle,
-                                     double box_min_out[3],
-                                     double box_max_out[3] )
-  double box[6];
-  MBErrorCode rval = moab()->tag_get_data( rootTag, &root_handle, 1, box );
-  box_min_out[0] = box[0]; box_min_out[1] = box[1]; box_min_out[2] = box[2];
-  box_max_out[0] = box[3]; box_max_out[1] = box[4]; box_max_out[2] = box[5];
-  return rval;
+  return moab()->tag_get_data( rootTag, &root_handle, 1, corners );
 MBErrorCode MBBSPTree::create_tree( MBEntityHandle& root_handle )
@@ -109,15 +160,14 @@
   return create_tree( min, max, root_handle );
-MBErrorCode MBBSPTree::create_tree( const double box_min[3],
-                                    const double box_max[3],
+MBErrorCode MBBSPTree::create_tree( const double corners[8][3],
   MBErrorCode rval = moab()->create_meshset( meshSetFlags, root_handle );
     return rval;
-  rval = set_tree_box( root_handle, box_min, box_max );
+  rval = set_tree_box( root_handle, corners );
   if (MB_SUCCESS != rval) {
     moab()->delete_entities( &root_handle, 1 );
     root_handle = 0;
@@ -126,7 +176,17 @@
   return MB_SUCCESS;
+MBErrorCode MBBSPTree::create_tree( const double box_min[3],
+                                    MBEntityHandle& root_handle )
+  return create_tree( corners, root_handle );
 MBErrorCode MBBSPTree::delete_tree( MBEntityHandle root_handle )
   MBErrorCode rval;
@@ -409,36 +469,13 @@
     return rval;
-  double box_min[3], box_max[3];
-  tool()->get_tree_box( root, box_min, box_max );
+  tool()->get_tree_box( root, leafCoords );
     return rval;
-  if (point) {
-    if (point[0] < box_min[0] || point[0] > box_max[0]
-     || point[1] < box_min[1] || point[1] > box_max[1]
-     || point[2] < box_min[2] || point[2] > box_max[2])
-      return MB_ENTITY_NOT_FOUND;
+  if (point && !point_in_box( leafCoords, point ))
+    return MB_ENTITY_NOT_FOUND;
-  const double* ranges[] = { box_min, box_max };
-  for (int z = 0; z < 2; ++z) {
-    leafCoords[4*z  ][0] = box_min[0];
-    leafCoords[4*z  ][1] = box_min[1];
-    leafCoords[4*z  ][2] = ranges[z][2];
-    leafCoords[4*z+1][0] = box_max[0];
-    leafCoords[4*z+1][1] = box_min[1];
-    leafCoords[4*z+1][2] = ranges[z][2];
-    leafCoords[4*z+2][0] = box_max[0];
-    leafCoords[4*z+2][1] = box_max[1];
-    leafCoords[4*z+2][2] = ranges[z][2];
-    leafCoords[4*z+3][0] = box_min[0];
-    leafCoords[4*z+3][1] = box_max[1];
-    leafCoords[4*z+3][2] = ranges[z][2];
   stackData.resize(1);
   return MB_SUCCESS;
Modified: MOAB/trunk/MBBSPTree.hpp
--- MOAB/trunk/MBBSPTree.hpp	2008-07-03 17:25:11 UTC (rev 1978)
+++ MOAB/trunk/MBBSPTree.hpp	2008-07-03 18:46:43 UTC (rev 1979)
@@ -96,18 +96,21 @@
   //! Get bounding box for entire tree
   MBErrorCode get_tree_box( MBEntityHandle root_node,
-                            double box_max_out[3] );
+                            double corner_coords[8][3] );
   //! Set bounding box for entire tree
   MBErrorCode set_tree_box( MBEntityHandle root_node,
                             const double box_max[3] );
+  MBErrorCode set_tree_box( MBEntityHandle root_node,
+                            const double corner_coords[8][3] );
   //! Create tree root node
   MBErrorCode create_tree( const double box_min[3],
                            MBEntityHandle& root_handle );
+  MBErrorCode create_tree( const double corner_coords[8][3],
+                           MBEntityHandle& root_handle );
   MBErrorCode create_tree( MBEntityHandle& root_handle );
