[MOAB-dev] r1978 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Jul 3 12:25:12 CDT 2008
Author: kraftche
Date: 2008-07-03 12:25:11 -0500 (Thu, 03 Jul 2008)
New Revision: 1978
Modified:
   MOAB/trunk/MBAdaptiveKDTree.cpp
   MOAB/trunk/MBAdaptiveKDTree.hpp
   MOAB/trunk/MBRange.cpp
   MOAB/trunk/MBRange.hpp
Log:
Generalize kd-tree building code such that trees can also be constructed
from vertices, polyhedra, and entity sets; with the following limitations:
  o tree is built from bounding boxes of polyhedra
  o tree is built from bounding boxes in tags on sets (same tag as
    box for tree root node must be used)
  o only the subdivision algorithm will work for entity sets
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp	2008-07-03 16:52:09 UTC (rev 1977)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp	2008-07-03 17:25:11 UTC (rev 1978)
@@ -687,7 +687,8 @@
-static MBErrorCode intersect_children_with_elems( MBInterface* moab,
+static MBErrorCode intersect_children_with_elems(
+                                        MBAdaptiveKDTree* tool,
                                         const MBRange& elems,
                                         MBAdaptiveKDTree::Plane plane,
                                         double eps,
@@ -701,7 +702,8 @@
   left_tris.clear();
   right_tris.clear();
   both_tris.clear();
-  MBCartVect coords[8];
+  MBCartVect coords[16];
+  MBInterface *const moab = tool->moab();
     // get extents of boxes for left and right sides
   MBCartVect right_min( box_min ), left_max( box_max );
@@ -713,13 +715,44 @@
   const MBCartVect dim = box_max - box_min;
-    // test each triangle
+    // test each entity
   MBErrorCode rval;
-  int count;
-  const MBEntityHandle* conn;
-  for (MBRange::reverse_iterator i = elems.rbegin(); i != elems.rend(); ++i) {
+  int count, count2;
+  const MBEntityHandle* conn, *conn2;
+  const MBRange::const_iterator elem_begin = elems.lower_bound( MBEDGE );
+  const MBRange::const_iterator poly_begin = elems.lower_bound( MBPOLYHEDRON, elem_begin );
+  const MBRange::const_iterator set_begin = elems.lower_bound( MBENTITYSET, poly_begin );
+  MBRange::iterator left_ins = left_tris.begin();
+  MBRange::iterator right_ins = right_tris.begin();
+  MBRange::iterator both_ins = both_tris.begin();
+  MBRange::const_iterator i;
+    // vertices
+  for (i = elems.begin(); i != elem_begin; ++i) {
+    rval = moab->get_coords( &*i, 1, coords[0].array() );
+    if (MB_SUCCESS != rval)
+      return rval;
+    bool lo = false, ro = false;
+    if (coords[0][plane.norm] <= plane.coord)
+      lo = true;
+    if (coords[0][plane.norm] >= plane.coord)
+      ro = true;
+    if (lo && ro)
+      both_ins = both_tris.insert( both_ins, *i, *i );
+    else if (lo)
+      left_ins = left_tris.insert( left_ins, *i, *i );
+    else // if (ro)
+      right_ins = right_tris.insert( right_ins, *i, *i );
+    // non-polyhedron elements
+  for (i = elem_begin; i != poly_begin; ++i) {
     rval = moab->get_connectivity( *i, conn, count, true );
-    if (MB_SUCCESS != rval) return rval;
+      return rval;
     if (count > (int)(sizeof(coords)/sizeof(coords[0])))
       return MB_FAILURE;
     rval = moab->get_coords( &conn[0], count, coords[0].array() );
@@ -749,13 +782,67 @@
     if (lo && ro)
-      both_tris.insert( *i );
     else if (lo)
-      left_tris.insert( *i );
     else if (ro)
-      right_tris.insert( *i );
+    // polyhedra
+  for (i = poly_begin; i != set_begin; ++i) {
+    rval = moab->get_connectivity( *i, conn, count, true );
+      return rval;
+      // just check the bounding box of the polyhedron
+    for (int j = 0; j < count; ++j) {
+      rval = moab->get_connectivity( conn[j], conn2, count2, true );
+        return rval;
+      for (int k = 0; k < count2; ++k) {
+        rval = moab->get_coords( conn2 + k, 1, coords[0].array() );
+          return rval;
+          lo = true;
+          ro = true;
+    if (lo && ro)
+    else if (lo)
+    else if (ro)
+    // sets
+  MBCartVect tmin, tmax;
+  for (i = set_begin; i != elems.end(); ++i) {
+    rval = tool->get_tree_box( *i, tmin.array(), tmax.array() );
+      return rval;
+    if (tmin[plane.norm] <= plane.coord)
+      lo = true;
+    if (tmax[plane.norm] >= plane.coord)
+      ro = true;
+    if (lo && ro)
+    else if (lo)
+    else // if (ro)
   MBCartVect box_dim = box_max - box_min;
   double area_left = left_dim[0]*left_dim[1] + left_dim[1]*left_dim[2] + left_dim[2]*left_dim[0];
   double area_right = right_dim[0]*right_dim[1] + right_dim[1]*right_dim[2] + right_dim[2]*right_dim[0];
@@ -794,7 +881,7 @@
       MBAdaptiveKDTree::Plane plane = { box_min[axis] + (p/(1.0+plane_count)) * diff[axis], axis };
       MBRange left, right, both;
       double val;
-      r = intersect_children_with_elems( iter.tool()->moab(),
+      r = intersect_children_with_elems( iter.tool(),
                                          entities, plane, eps,
                                          box_min, box_max,
                                          left, right, both,
@@ -870,7 +957,7 @@
       MBAdaptiveKDTree::Plane plane = { closest_coord, axis };
       double val;
                                          box_min, box_max,
                                          left, right, both,
@@ -949,7 +1036,7 @@
       MBAdaptiveKDTree::Plane plane = { *citer, axis };
       double val;
                                          box_min, box_max,
                                          left, right, both,
@@ -1065,7 +1152,7 @@
       MBAdaptiveKDTree::Plane plane = { coords[indices[p]], axis };
       double val;
                                          box_min, box_max,
                                          left, right, both,
@@ -1102,42 +1189,76 @@
-static MBErrorCode bounding_box( MBInterface* moab,
-                                 const MBRange& elems,
-                                 MBCartVect& bmin,
-                                 MBCartVect& bmax )
+MBErrorCode MBAdaptiveKDTree::bounding_box( const MBRange& elems,
+                                            double box_min[3],
+                                            double box_max[3] )
   MBErrorCode rval;
-  bmin = MBCartVect(HUGE_VAL);
-  bmax = MBCartVect(-HUGE_VAL);
+  MBCartVect bmin(HUGE_VAL), bmax(-HUGE_VAL);
   MBCartVect coords;
   MBEntityHandle const *conn, *conn2;
   int len, len2;
-  for (MBRange::const_iterator i = elems.begin(); i != elems.end(); ++i) {
-    rval = moab->get_connectivity( *i, conn, len, true );
+    // vertices
+    rval = moab()->get_coords( &*i, 1, coords.array() );
       return rval;
-    if (TYPE_FROM_HANDLE(*i) != MBPOLYHEDRON) {
-      for (int j = 0; j < len; ++j) {
-        rval = moab->get_coords( conn+j, 1, coords.array() );
+    box_accum( coords, bmin, bmax );
+    // elements with vertex-handle connectivity list
+    rval = moab()->get_connectivity( *i, conn, len, true );
+      return rval;
+    for (int j = 0; j < len; ++j) {
+      rval = moab()->get_coords( conn+j, 1, coords.array() );
+        return rval;
+    // polyhedra
+      return rval;
+      rval = moab()->get_connectivity( conn[j], conn2, len2 );
+      for (int k = 0; k < len2; ++k) {
+        rval = moab()->get_coords( conn2+k, 1, coords.array() );
           return rval;
-    else {
-        rval = moab->get_connectivity( conn[j], conn2, len2 );
-        for (int k = 0; k < len2; ++k) {
-          rval = moab->get_coords( conn2+k, 1, coords.array() );
-            return rval;
-          box_accum( coords, bmin, bmax );
+    // sets
+    rval = get_tree_box( *i, tmin.array(), tmax.array() );
+      return rval;
+    for (int j = 0; j < 3; ++j) {
+      if (tmin[j] < bmin[j])
+        bmin[j] = tmin[j];
+      if (tmax[j] > bmax[j])
+        bmax[j] = tmax[j];
+  bmin.get( box_min );
+  bmax.get( box_max );
   return MB_SUCCESS;
@@ -1159,7 +1280,7 @@
     // calculate bounding box of elements
   MBCartVect bmin, bmax;
-  rval = bounding_box( moab(), elems, bmin, bmax );
+  rval = bounding_box( elems, bmin.array(), bmax.array() );
     return rval;
Modified: MOAB/trunk/MBAdaptiveKDTree.hpp
--- MOAB/trunk/MBAdaptiveKDTree.hpp	2008-07-03 16:52:09 UTC (rev 1977)
+++ MOAB/trunk/MBAdaptiveKDTree.hpp	2008-07-03 17:25:11 UTC (rev 1978)
@@ -220,6 +220,11 @@
                                       const double distance,
                                       std::vector<MBEntityHandle>& leaves_out );
+  //! Calculate bounding box for entities.
+  MBErrorCode bounding_box( const MBRange& entities,
+                            double box_min_out[3],
+                            double box_max_out[3] );
 private:
   /**\brief find a triangle near the input point */
Modified: MOAB/trunk/MBRange.cpp
--- MOAB/trunk/MBRange.cpp	2008-07-03 16:52:09 UTC (rev 1977)
+++ MOAB/trunk/MBRange.cpp	2008-07-03 17:25:11 UTC (rev 1978)
@@ -708,6 +708,13 @@
   MBEntityHandle handle = CREATE_HANDLE( type, 0, err );
   return err ? end() : lower_bound( begin(), end(), handle );
+MBRange::const_iterator MBRange::lower_bound( MBEntityType type,
+                                              const_iterator first ) const
+  int err;
+  MBEntityHandle handle = CREATE_HANDLE( type, 0, err );
+  return err ? end() : lower_bound( first, end(), handle );
 MBRange::const_iterator MBRange::upper_bound( MBEntityType type ) const
@@ -716,6 +723,14 @@
   MBEntityHandle handle = CREATE_HANDLE( type + 1, 0, err );
+MBRange::const_iterator MBRange::upper_bound( MBEntityType type,
+    // if (type+1) overflows, err will be true and we return end().
+  int err;
+  MBEntityHandle handle = CREATE_HANDLE( type + 1, 0, err );
 std::pair<MBRange::const_iterator, MBRange::const_iterator>
 MBRange::equal_range( MBEntityType type ) const
Modified: MOAB/trunk/MBRange.hpp
--- MOAB/trunk/MBRange.hpp	2008-07-03 16:52:09 UTC (rev 1977)
+++ MOAB/trunk/MBRange.hpp	2008-07-03 17:25:11 UTC (rev 1978)
@@ -280,6 +280,8 @@
   const_iterator lower_bound( MBEntityType type ) const;
   const_iterator upper_bound( MBEntityType type ) const;
   std::pair<const_iterator, const_iterator> equal_range( MBEntityType type ) const;
+  const_iterator lower_bound( MBEntityType type, const_iterator first ) const;
+  const_iterator upper_bound( MBEntityType type, const_iterator first ) const;
   //! True if all entities in range are of passed type
   //! (also true if range is empty)
