[MOAB-dev] r1573 - MOAB/trunk
kraftche at mcs.anl.gov
Thu Jan 31 16:40:17 CST 2008
Author: kraftche
Date: 2008-01-31 16:40:16 -0600 (Thu, 31 Jan 2008)
New Revision: 1573
Modified:
MOAB/trunk/WriteHDF5.cpp
Log:
Add proper testing for invalid (stale) handles in set contents. Rather
than relying on old dense tag behavior, where we get back the default value
for invalid handles, check the return code and explicitly mark invalid
handles as 'not to be written'.
This is more robust, and is better than wasting an entire day every time
I make changes to the tag code trying to figure out why the merge test
is failing.
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2008-01-31 20:39:48 UTC (rev 1572)
+++ MOAB/trunk/WriteHDF5.cpp 2008-01-31 22:40:16 UTC (rev 1573)
@@ -976,7 +976,15 @@
// Get file IDs from handles
output_id_list.resize( input_range.size() );
rval = iFace->tag_get_data( idTag, input_range, &output_id_list[0] );
- CHK_MB_ERR_0(rval);
+ if (MB_ENTITY_NOT_FOUND == rval) { // ignore stale handles
+ MBRange::const_iterator i;
+ std::vector<id_t>::iterator j = output_id_list.begin();
+ for (i = input_range.begin(); i != input_range.end(); ++i, ++j)
+ if (MB_SUCCESS != iFace->tag_get_data( idTag, &*i, 1, &*j ))
+ *j = 0;
+ else
+ CHK_MB_ERR_0(rval);
std::sort( output_id_list.begin(), output_id_list.end() );
// Count the number of ranges in the id list
@@ -1046,7 +1054,10 @@
handle = *i_iter;
rval = iFace->tag_get_data( idTag, &handle, 1, &id );
+ if (MB_ENTITY_NOT_FOUND == rval) // ignore stale handles
+ id = 0;
+ else
*o_iter = id;
++o_iter;
++i_iter;
